Old 10-15-2016, 08:26   #36841 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 582
Qmobile Noir A290 Flashing Done
Scatter Load Ok , BaseBand : MT6572 , Project : s5201ap , Storage : EMMC
Files found : 11 , Set to Flash : 10
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand   : QMobile
Device Model   : QMobile A290
Device CPU     : MT6572
Device IntName : QMobile A290
Device Version : 4.4.2
Device Compile : 03-Jun-2015 8:35:50 AM
Device Project : ALPS.KK1.MP7.V1
Device ExtInfo : QMobile A290
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 19 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A483447316404050DA189887159
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A483447316404050DA189887159
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID    : 0xE6C52A7D081D35D54010E2424504702B
INT RAM    : 0x00020000
EXT RAM    : 0x20000000 [512 MiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : s5201ap , Storage : EMMC
Setting : AFF verify :  Disabled
Setting : HW verify :  Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 4093 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x00000000E5E00000
Flash Pre-Erase Done, time used : 00:00:03
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_s5201ap.bin
Preloader Sent , Init passed
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:28
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:02:57
Reconnect Power/Cable!
Old 10-15-2016, 09:05   #36842 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 582
Nokia 110 flashing done
Core : v2.23 , BB5XG FlashEngine : v10.1
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm827__03.51.mcusw
PPM : rm827__03.51.ppm_m2
CNT : rm827__03.51.image_m2_059N2R0
Flashing phone now...
[Gen] Rules accepted for : XGOLD Generation
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
-> If Windows say "Unrecognized device" / Operation not start
-> Or if Phone start charge - just reinsert battery
-> If flashing freeze - reinsert cable/battery and try again
--- Press phone's power button or insert usb cable! ---
Connection opened successfully
IF Boot Init : 0xF0
IF Resp Len  : 0x0A
IF xCPUID    : XGOLD 213 [XMM2130 QUANTUM]
IF Resp Data  :  1FB300020303010100FF
Sending EBL Loader ...
EBL Loader Ok, 01
EBL Loader ready, AA
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.49_M1S1
Speed accepted, use 6.500.000
FLASHID : EC001230
FLIC conf set, RST set
Boot done!
Check keys...
Check done. Image can be flashed
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 354646058855604
IMEI 2 : 354646058855612
PCcode : 059N2R0
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : C:\InfinityBox\BEST\Backup\Cert\354646058855604_2nd_XG213_CRT.rpl
Settings : EDM [0x8] , Block Mode , Fast CRC , Verify
   ===Flashing [MCU]===
File : rm827__03.51.mcusw
Image : rm827__03.51.mcusw_ebl_psi.fls
Sec-pack found, sending ...
Sec-pack sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:02
Write , Start : 0x40060000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 4/5
Erase , Start : 0x40280000 , Len : 0x01940000
Erasing, wait ...
Erase done, time : 00:00:50
Write , Start : 0x40280000 , Len : 0x018C0000
Flashing , wait ...
Region flash done, time : 00:00:36
Processing Region 5/5
Erase , Start : 0x43E20000 , Len : 0x00040000
Erasing, wait ...
No write data, skip
CRC check passed , 0xA3D6
   ===Flashing [PPM]===
File : rm827__03.51.ppm_m2
Image : package_m2.ppm_ebl_psi.fls
Sec-pack sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x41BC0000 , Len : 0x00600000
Erasing, wait ...
Erase done, time : 00:00:06
Write , Start : 0x41BC0000 , Len : 0x0030F748
Flashing , wait ...
Region flash done, time : 00:00:04
CRC check passed , 0x4605
   ===Flashing [CNT]===
File : rm827__03.51.image_m2_059N2R0
Image : package_m2_059N2R0.image.fls
Sec-pack sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x421C0000 , Len : 0x01C60000
Erasing, wait ...
Erase done, time : 00:01:16
Write , Start : 0x421C0000 , Len : 0x00F20000
Flashing , wait ...
Region flash done, time : 00:00:21
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
No write data, skip
CRC check passed , 0x2091
Flashing done!
Total flash time : 00:03:22
Reboot phone now...
Reading Phone Info....
Connected phone -   Nokia 110
Software Info:     V 03.51 06-08-13 RM-827 (c) Nokia
IMEI:  354646058855604
PPM version :   V 03.51 06-08-13 RM-827 (c) Nokia             M2
Product code:  059N2R0
Wait, when phone will be ready ...
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Processing After Flash Defaults...
FullFactorySet... Ok!
UserDataDefaultsSet...OK!
ServiceDefaultsSet... Ok!
LeaveDefaultsSet... Ok!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Check and Upload User Certificates ...
Total - 58 certs
Certificates found, skip upload ...
AfterFlash operations done ;D
Done!
Connect phone on selected interface...
Elapsed: 00:04:31
Phone found!
Series 40 Device detected!
read info...  - Ok
Old 10-15-2016, 09:07   #36843 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 582
Nokia 206 FlashingDone
MCU : rm872__04.52.mcusw
PPM : rm872__04.52.ppm_m2
CNT : rm872__04.52.image_m2_059Q4J7
Check files done...
IF Boot Init : 0xF0
IF Resp Len  : 0x0A
EBL Loader Ok, 01
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.53_M1S1
FLASHID : EC001230
Boot done!
Check keys...
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 358328051398645
IMEI 2 : 358328051398652
PCcode : 059S8K5
RPL saved : C:\InfinityBox\BEST\Backup\Cert\358328051398645_XG213_CRT.rpl
File : rm872__04.52.mcusw
Image : rm872__04.52.mcusw_ebl_psi.fls
Sec-pack sent
Found 5 region(s)
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erase , Start : 0x40280000 , Len : 0x01800000
Erasing, wait ...
Erase done, time : 00:00:48
Write , Start : 0x40280000 , Len : 0x01800000
Flashing , wait ...
Region flash done, time : 00:00:35
Erasing, wait ...
No write data, skip
CRC check passed , 0xFA4D
File : rm872__04.52.ppm_m2
Sec-pack sent
Found 1 region(s)
Erase , Start : 0x41A80000 , Len : 0x00680000
Erasing, wait ...
Erase done, time : 00:00:08
Write , Start : 0x41A80000 , Len : 0x003C68F0
Flashing , wait ...
CRC check passed , 0xC9E6
File : rm872__04.52.image_m2_059Q4J7
Image : package_m2_059Q4J7.image.fls
Sec-pack sent
Found 2 region(s)
Erase , Start : 0x42100000 , Len : 0x01D20000
Erasing, wait ...
Erase done, time : 00:01:22
Write , Start : 0x42100000 , Len : 0x01040000
Flashing , wait ...
Region flash done, time : 00:00:22
Erasing, wait ...
No write data, skip
CRC check passed , 0x5521
Flashing done!
Total flash time : 00:03:29
Reboot phone now...
Connected phone -   206
Software Info:     V 04.52 30-06-13 RM-872 (c) Nokia
IMEI:  358328051398645
PPM version :   V 04.52 30-06-13 RM-872 (c) Nokia             M2
Product code:  059S8K5
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 58 certs
Done!
Elapsed: 00:04:35
Phone found!
read info...  - Ok
Old 10-15-2016, 09:35   #36844 (permalink)
Kwesi_Roy_GH's Avatar
Member: 2575234
Thanks Meter: 1,105
Blu dash m d030u/01 read flash & frp reset done successfully
Card found : S/N : xxxxxxxx , v0134
Chinese Miracle II [MTK module] v 1.56
Operation : Read Flash [ v1.56 ]
Wait for phone...
Phone found! [ 9 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
eMMC Flash : 150100464A32374D4202FBF6DC059283
[eMMC] : FLASH_INF : [SAMSUNG] , BM72J
[eMMC] : FLASH_CID : 150100464A32374D4202FBF6DC059283
DEV RID : 0x821AAA712C1F5C6B3F5EB0C1887893E6
EXT RAM : 0x30000000 [768 MiB]
SOC VERIFY : C1
Boot Ok!
Reading Flash Content now ...
xGPT : Normalize settings Ok!
Brand : BLU
ProdName : BLU_DASH_M
ProdModel : BLU DASH M
Device : BLU_DASH_M
AndroidVer: 5.1
MTKxCPU : MT6580
MTKxPRJ : ALPS.L1.MP6.V2_TINNO6580.WE.L
[Read Ok] : preloader_s5030.bin
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : logo.bin
[Read Ok] : secro.img
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : userdata.img
[ScatCFG] : MT6580 / V1.1.2 / s5030 / EMMC
Android Info saved
FW Size : 961 MiB
Scatter saved to : C:\Users\Roy\Desktop\MT6580__BLU__BLU_DASH_M__BLU_ DASH_M__5.1__ALPS.L1.MP6.V2_TINNO6580.WE.L\
All done!
Done!
Elapsed: 00:06:05
Operation : Format FileSystem [ v1.56 ]
Wait for phone...
Phone found! [ 9 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:20
Old 10-15-2016, 10:20   #36845 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 582
Qmobile K135 flash And Imei Repair Done
Operation : Flash [ v1.22 ]
======= Flash
Files set for flashing :
[ MCU ] : SPD6531_00400000_GD25LQ32_English-Urdu__Qmobile-K135.bin
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
 ====  Wait for phone...
Phone found! [ 119 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00EF 0040 0016 0000
[0] Flash VEN : Winbond , W25Q32
[0] Flash CAP : 00400000
======= Flashing MCU
Mapping file ...
Mapping done
Processing file : SPD6531_00400000_GD25LQ32_English-Urdu__Qmobile-K135.bin
Init ok, send data
Flashing Done!
Info : In some cases after flash required make "Format Fs / Reset Phone"
Done!
Elapsed: 00:01:39
Operation : Repair Security [ v1.22 ]
3. Insert battery
Phone found! [ 132 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
[0] Flash DIE : 00C8 0060 0016 0000
[0] Flash VEN : GigaDevice , GD25LQ32
Process can take some time, please, wait
Init ok, send data
Write done!
Elapsed: 00:00:19
Old 10-15-2016, 10:47   #36846 (permalink)
Member: 56090
Thanks Meter: 135
Originally Posted by ibrahimtr View Post
logicom L-EMENT401 successfully read pac firmware .
Phone found! [ 52 ]
Port Opened
Sync...
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7730/7731 eMMC Loader v1.1 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Detected eMMC Flash , Structure detect Ok!
[FW_READER] : Step #1 Passed!
[FW_READER] : Step #2 Passed!
[FW_READER] : Step #3 Passed!
Phone found! [ 52 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Name : L-EMENT401
Model Brand : LOGICOM
Model Device: L-EMENT401
AndrVersion : 4.4.2
BaseBand CPU: L-EMENT401
Project Ver : L-EMENT401_V20_04-06-2015
Model Ext : L-EMENT401
[Read Mode] : HSUSB : 0x3000
[FW_READER] : Reading Firmware Now ...
[Read Ok] : u-boot-spl-16k.bin
[Read Ok] : u-boot.bin
[Read Ok] : prodnv.img
[Read Ok] : sc7731g_CP0_modem.bin
[Read Ok] : DSP_DM_Gx.bin
[Read Ok] : nvitem_w.bin
[Read Ok] : sc8830g_modem_CP2_WCN_14D_W15.22.3_Release.bin
[Read Ok] : nvitem_wcn.bin
[Read Ok] : logo_480x800.bin
[Read Ok] : fblogo_480x800.bin
AndroidInfo created
Firmware Size : 1040 MiB
Saved to : C:\Users\hello\Desktop\L-EMENT401_L-EMENT401_4.4.2_L-EMENT401_V20_04-06-2015_L-EMENT401\
Done!
Elapsed: 00:09:21
Infinity SC Firmware Detected
FW Size : 1040 MiB
Load Ok!
File Info
Device Brand : LOGICOM
Device Model : L-EMENT401
Device CPU : L-EMENT401
Device IntName : L-EMENT401
Device Compile : 05/06/2015 04:10:33
Device Project : L-EMENT401_V20_04-06-2015
Device ExtInfo : L-EMENT401
Need urgently this firmware provide us a link to download thank you
Salam
Old 10-15-2016, 12:26   #36847 (permalink)
onz
onz's Avatar
Member: 2012334
Sonork: 100.1658100
Thanks Meter: 673
Post mobicel retro flashing done
Scatter Load Ok , BaseBand : MT6572 , Project : mtk_android , Storage : EMMC
Files found : 17 , Set to Flash : 16
Ready to Flash!
======= Flash
Wait for phone...
Device boot not done
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:29
======= Flash
Wait for phone...
Phone found! [ 110 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A48344732611101189519CF9209
[eMMC] : FLASH_INF : [HYNIX] , a2G4
[eMMC] : FLASH_CID : 90014A48344732611101189519CF9209
DEV RID : 0xC65197530F479D6D013CEC7C40DA6491
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : mtk_android , Storage : EMMC
Setting : AFF verify : Enabled
BL : BatteryLevel : 3615 mV
Erase : 0x0000000001000000-0x00000000E7700000
Flash Pre-Erase Done, time used : 00:00:06
Use : preloader.bin
PartCount : 0013
Repartition Done!
Use FLN Mode
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : NVRAM
Image Flash Ok
Flash now : PROTECT_F
Image Flash Ok
Flash now : PROTECT_S
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : MISC
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EXPDB
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash now : FAT
Image Flash Ok
Flash Write Done, time used : 00:03:42
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : NVRAM
Verify Passed : PROTECT_F
Verify Passed : PROTECT_S
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : MISC
Verify Passed : LOGO
Verify Passed : EXPDB
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Verify Passed : FAT
Data Verify Done, time used : 00:01:09
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:05:30
The Following User Says Thank You to onz For This Useful Post:
Old 10-15-2016, 13:35   #36848 (permalink)
onz
onz's Avatar
Member: 2012334
Sonork: 100.1658100
Thanks Meter: 673
Ag mobile zone read flash done
Operation : Read Flash [ v1.58 ]
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 110100303034474530014C8EEA444331
[DA_ERROR] : DA Init failed!
Something wrong with battery or connection!
Boot Error!
Operation Failed
Elapsed: 00:00:43
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
[eMMC] : FLASH_VEN : 0x11 , OEM : 0100
[eMMC] : FLASH_INF : [TOSHIBA] , 0EG40
[eMMC] : FLASH_CID : 110100303034474530014C8EEA444331
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000
[eMMC] : FLASH_LEN : 0x00000000EC000000
[eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB]
DEV RID : 0xC6519753A9EE5EC55A834FC629155786
SOC VERIFY : C1
Boot Ok!
Brand : AG
ProdName : Zone
ProdModel : Zone
Device : Zone
AndroidVer: 5.1
MTKxCPU : MT6572
MTKxPRJ : ALPS.L1.MP6.V2.8_ZECHIN6572.WE.L_P11
[Read Ok] : preloader_zechin6572_we_l.bin
[Read Ok] : MBR
[Read Ok] : EBR1
[Read Ok] : lk.bin
[ScatCFG] : MT6572 / V1.1.1 / zechin6572_we_l / EMMC
Android Info saved
MAUI Meta DB saved
HWConfig Info saved
FW Size : 1261 MiB
Scatter saved to : D:\500GB\MTK FLASH FILE\MT6572__AG__Zone__Zone__5.1__ALPS.L1.MP6.V2.8 _ZECHIN6572.WE.L_P11\
All done!
Done!
Elapsed: 00:10:21
Old 10-15-2016, 17:02   #36849 (permalink)
luzer's Avatar
Member: 44659
Thanks Meter: 348
Sky 4.0LM direct unlock
Operation : SP Unlock [ v1.58 ]
Mode : Direct Unlock
Wait for phone...
Phone found! [ 178 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
Running DA ver.4.2 on BBID : 0x93
eMMC Flash : 4400014530303153A1B90138DBC51447
[eMMC] : FLASH_VEN : 0x45 , OEM : 0100
[eMMC] : FLASH_INF : [SANDISK] , 8001S
[eMMC] : FLASH_CID : 45010044533130303801B9A1471413DB
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0x4F0A13541FD8F58C687CE993C719543B
EXT RAM : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
SIM Lock Status : Locked!
Unlocking now ...
Unlock done!
Done!
Old 10-16-2016, 05:34   #36850 (permalink)
rehmani's Avatar
Member: 333199
Sonork: may i help u just pm me
Thanks Meter: 2,390
panasonic eluga i flash done
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x87
eMMC Flash : 700100563130303038060BFF5A073265
[eMMC] : FLASH_VEN : 0x70 , OEM : 0100
[eMMC] : FLASH_INF : [KINGSTON] , 80001
[eMMC] : FLASH_CID : 700100563130303038060BFF5A073265
[eMMC] : FLASH_LEN : 0x00000001C3000000
[eMMC] : FLASH_UCP : 7216 MiB [eMMC 8 GiB]
DEV RID    : 0xC1F94A5CE2EB802D96E4F375C39BE7ED
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
SECURITY :
IMEI_SW [1] : 3559410618-----
IMEI_SW [2] : 3559410619-----
BTMAC Addr  : DE5546658248
WiFi MAC    : 700BC0800FDE
Done!
Elapsed: 00:00:12
Scatter Load Ok , BaseBand : MT6582 , Project : g3478 , Storage : EMMC
Files found : 12 , Set to Flash : 11
Ready to Flash!
Operation : Flash [ v1.56 ]
======= Flash
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : g3478 , Storage : EMMC
BL : BatteryLevel : 3650 mV
Erase : 0x0000000002900000-0x000000009B880000
Flash Pre-Erase Done, time used : 00:00:00
Use : preloader_g3478.bin
PartCount : 0014
Repartition Done!
Use FLN Mode
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EBR2
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:06:11
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:06:24
The Following User Says Thank You to rehmani For This Useful Post:
Old 10-16-2016, 07:39   #36851 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,390
lava a88 format done
Operation : Check/Read Info [ v1.22 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
Phone found! [ 14 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC9830 eMMC Generic Loader v2 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name  : A88
Model Brand : Lava
Model Device: A88
AndrVersion : 5.1
BaseBand CPU: A88
CompileDate : 2/6/2016 1:42:27 PM
Project Ver : Lava_A88_S109_20160206
Model Ext   : A88
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:17
Operation : Format File System / Reset Settings [ v1.22 ]
Settings : SmartFormat is On
3. Insert cable
Phone found! [ 14 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:18
Old 10-16-2016, 08:35   #36852 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 582
Samsung Core II Format Done
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 19 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
NAND Flash : 002C00BC009000550056000000000000
eMMC Flash : NOT INSTALLED
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0091 , [Micron] NAND_MT29C4G48MAAHBAAKS_5WT
[NAND] : FLASH_DIE : 002C 00BC 0090 0055 0056 0000 0000
[NAND] : FLASH_LEN : 0x20000000
[NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2
DEV RID    : 0xE6C52A7D1790D28DCC24FD7449D5A73D
EXT RAM    : 0x10000000 [256 MiB]
BOOT TYPE  : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:12
Old 10-16-2016, 11:59   #36853 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 582
Oppo R831K Flashing Done
======= Flash
Wait for phone...
Phone found! [ 106 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer   : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
eMMC Flash : 90014A483447316404050BA1174771BF
DRAM configured from ScatFW!
DRAM initialize passed!
DRAM size : 0x40000000
[eMMC] : FLASH_CID : 90014A483447316404050BA1174771BF
DEV RID    : 0xE6C52A7D19035C0070D9A8C32FF8D0C2
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : OPPO72_14079 , Storage : EMMC
Switching to HSUSB
HSUSB Init Ok
BL : BatteryLevel : 3903 mV
Total blocks to Erase : 4
Erase : 0x0000000002900000-0x0000000001A80000
Erase : 0x0000000004480000-0x0000000002000000
Erase : 0x0000000007480000-0x0000000080900000
Flash Pre-Erase Done, time used : 00:00:01
Use : preloader_OPPO72_14079.bin
PartCount : 0017
Repartition Done!
Use FLN Mode
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EBR2
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash now : FAT
Image Flash Ok
Flash Write Done, time used : 00:03:35
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:59
Old 10-16-2016, 12:10   #36854 (permalink)
Deepesh Sharma's Avatar
Member: 1301233
Sonork: 100.1614172
Thanks Meter: 9,178
gionee p3s remove frp protection
format
Wait for phone...
Phone found! [ 139 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer   : 0x0005
BLVersion : 0x00FE
Processing DA stage
eMMC Flash : 15010051385853414206C486C26D8267
DRAM configured from IDB!
[eMMC] : FLASH_INF : [SAMSUNG] , BASX8
[eMMC] : FLASH_CID : 15010051385853414206C486C26D8267
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID    : 0x4AD5A99B7FE72366ED3D12D30B6E1BAC
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:36
Old 10-16-2016, 12:26   #36855 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 582
Nokia Asha 500 Flashing Done
MCU : rm934_14.0.6.mcusw.fls
PPM : rm934_14.0.6_059S9V4_m1.rofs.fls
CNT : rm934_14.0.6_059S9V4_m1.image.fls
Check files done...
IF Boot Init : 0xF0
IF Resp Len  : 0x16
IF xCPUID    : XGOLD 221 [XMM2210 QIMING]
IF uCHIPID    :  19421A09928C4562
IF Resp Data  :  194200021C030101
Wait for user action : Insert battery
EBL Loader Ok
EBL Loader ready
Sending EBL ...
EBL sent Ok
EBL : 1_1345.300_MKEYSKEY
QIMING EEP config Ok
FLASHID : 52F00000 , [ NOR ]
Boot conf set, Target Ready
Boot done!
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 358355058517307
IMEI 2 : 358355058517315
Phone Product Code : 059S9V4
RPL saved : C:\InfinityBox\BEST\Backup\Cert\358355058517307_XG221_CRT.rpl
Processing file : rm934_14.0.6.mcusw.fls
Region count : 2
00 : [ PSI ]   : rm934_14.0.6.mcusw.fls.fls
01 : [ Code ]  : rm934_14.0.6.mcusw.fls.fls
Parse done , flashing now
Flash : 00 : rm934_14.0.6.mcusw.fls.fls
Sending Sec-Pack
SecInfo Area : 0x0000 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x40000000 , Len : 0x00020000
Erase now...
Erase done
Region Start : 0x40000000 , Data Len : 0x00020000
Region Load done
Wait for phone write all data ...
Write done
rm934_14.0.6.mcusw.fls.fls image flash done
Flash : 01 : rm934_14.0.6.mcusw.fls.fls
Sending Sec-Pack
SecInfo Area : 0x0001 , SecInfo Len : 0x0800
Erase area 0x00 , Start 0x40040000 , Len : 0x00020000
Erase now...
Erase done
Erase area 0x01 , Start 0x40060000 , Len : 0x00160000
Erase now...
Erase done
Erase area 0x02 , Start 0x40340000 , Len : 0x02540000
Erase now...
Erase done
Erase area 0x03 , Start 0x47E00000 , Len : 0x00040000
Erase now...
Erase done
Region Start : 0x40040000 , Data Len : 0x00020000
Region Load done
Write done
Region Start : 0x40060000 , Data Len : 0x00160000
Region Load done
Write done
Region Start : 0x40340000 , Data Len : 0x02076498
Region Load done
Write done
Processing file : rm934_14.0.6_059S9V4_m1.rofs.fls
Region count : 1
00 : [ Cust ]  : rofs_ebl_psi.fls
Flash : 00 : rofs_ebl_psi.fls
Sending Sec-Pack
Erase area 0x00 , Start 0x42880000 , Len : 0x00F80000
Erase now...
Erase done
Region Start : 0x42880000 , Data Len : 0x005EF1C4
Region Load done
Write done
rofs_ebl_psi.fls image flash done
Processing file : rm934_14.0.6_059S9V4_m1.image.fls
Region count : 1
00 : [ Cust ]  : rm934_14.0.6_059S9V4_m1.image.fls.image.fls
Flash : 00 : rm934_14.0.6_059S9V4_m1.image.fls.image.fls
Sending Sec-Pack
Erase area 0x00 , Start 0x43800000 , Len : 0x04600000
Erase now...
Erase done
Erase area 0x01 , Start 0x47E40000 , Len : 0x000E0000
Erase now...
Erase done
Region Start : 0x43800000 , Data Len : 0x02800000
Region Load done
Write done
rm934_14.0.6_059S9V4_m1.image.fls.image.fls image flash done
Flashing done!
Total flash time : 00:02:07
Reboot phone now...
Connected phone -   500
Software Info:     V 14.0.6 10-07-14 RM-934 (c) Nokia
IMEI:  358355058517307
PPM version :   9697f5b3610880d6eb201c62b87c342c53fc98fe
Product code:  059S9V4
Checking...
Read Info Done!
SwUpgradeSet...OK!
Total - 59 certs
Battery voltage is enough for start
Done!
Elapsed: 00:02:42
Phone found!
read info...  - Ok
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.87501 seconds with 9 queries
