Old 03-20-2017, 14:54   #40966 (permalink)
Member: 1982255
Sonork: mnb_noor
Thanks Meter: 14
OPPO Mirror 3&3006 Flase Done By CM2
OPPO Mirror 3&3006 Flase Done By CM2 Greate Work By CM2QLM Tool
The Following User Says Thank You to sgamim For This Useful Post:
Old 03-20-2017, 15:27   #40967 (permalink)
bright hlatini's Avatar
Member: 1614640
Thanks Meter: 462
VODAFONE VFD 1100 FRP UNLOCK DONE
Card found : S/N : xxxxxxx, v0134
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 14 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 15010038575044335200BEC5E8F93365
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , R3DPW
[eMMC] : FLASH_CID : 15010038575044335200BEC5E8F93365
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xD2FF4FA4E343B5AC258E3FBC863FDF4F
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
SECURITY :
IMEI_OTP [1] : 35xxxxxxxxxxx
EXTRA :
LCD : Not info available
LCD Res : 1024x600
TOUCH [0] : GT9XXTB_hotknot
CAM [0] : sp2508_mipi_raw
CAM [1] : gc23552nd_mipi_raw
CAM [2] : gc2355_mipi_raw
MODEM : tcl8321_tb_m_hspa
LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES
Done!
Elapsed: 00:00:14
Reconnect Power/Cable!
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 14 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:14
The Following 2 Users Say Thank You to bright hlatini For This Useful Post:
Old 03-21-2017, 07:15   #40968 (permalink)
Nasir Mobiles's Avatar
Member: 355782
Thanks Meter: 1,246
Qmobile L7 Read Security Lock.
Operation : Read User Code [ v1.24 ]
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
 ====  Wait for phone...
Phone found! [ 207 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00EF 0040 0016 0000
[0] Flash VEN : Winbond , W25Q32
[0] Flash CAP : 00400000
Check data... Can take some time
User Code : 5050
Done!
Elapsed: 00:00:04
The Following User Says Thank You to Nasir Mobiles For This Useful Post:
Old 03-21-2017, 07:22   #40969 (permalink)
Member: 1763380
Thanks Meter: 83
Redmi 3 hard bricked done
Operation : Identify [ v1.11 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 610 [MSM8936]
ID_BLOCK_S : 0867CA5E
ID_BLOCK_I : 0090B0E1
ID_BLOCK_L : F0B92A08B4B365385913BDE87CEE2E21
ID_BLOCK_L : 31CFA51CD3FAEC423D8C45403FAF7B2E
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8936 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000
Boot Ok!
Brand : Xiaomi
ProdName : ido
ProdModel : Redmi 3
Device : ido
AndroidVer: 5.1.1
Manufact. : Xiaomi
QLMxCPU : MSM8916
Done!
Elapsed: 00:00:05
Loading firmware ...
Load Ok!
Operation : Flash [ v1.11 ]
ForceFlashing : Disabled
Verify FW package ...
Verification passed!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Pickup loader from firmware package
Boot Ok!
Files in Chain : 33
Flashing now
Flashing : NON-HLOS.bin
Flashing : sbl1.mbn
Flashing : sbl1.mbn
Flashing : emmc_appsboot.mbn
Flashing : rpm.mbn
Flashing : rpm.mbn
Flashing : tz.mbn
Flashing : tz.mbn
Flashing : hyp.mbn
Flashing : hyp.mbn
Flashing : boot.img
Flashing : system.img
Flashing : persist.img
Flashing : cache.img
Flashing : recovery.img
Flashing : cust.img
Flashing : userdata.img
Flashing : gpt_main0.bin
Flashing : gpt_backup0.bin
Flash sequence completed!
Records in Chain : 26
Processing records now
Records sequence completed!
Boot settings configured!
Flashing done!
Done!
Elapsed: 00:25:50
The Following 2 Users Say Thank You to den fatih For This Useful Post:
Old 03-21-2017, 07:29   #40970 (permalink)
..::BobbyMobiles::..'s Avatar
Member: 900602
Thanks Meter: 99
Mi Note 4 Pattern lock Done CM2QLM
Use Boot Cabel
The Following User Says Thank You to ..::BobbyMobiles::.. For This Useful Post:
Old 03-21-2017, 08:32   #40971 (permalink)
shahid41's Avatar
Member: 623703
Sonork: 100.1614330
Thanks Meter: 431
motorola xt1700 unlock Done
Card found : S/N : 2585E1C8 , v0135
Operation : SP Unlock [ v1.58 ]
Mode : Direct Unlock
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
SecCfgVal : 0x01000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
Running DA ver.4.2 on BBID : 0x93
eMMC Flash : 484A019061344738B10DA292693CF200
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0x2003
EMICFG_NOT_FOUND
TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT!
Boot Error!
Operation Failed
Elapsed: 00:00:15
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , a4G8
[eMMC] : FLASH_CID : 90014A483847346192A20DB100F2B369
DEV RID : 0x5DD3D5DAF35FD90528BEFFC506E20B65
SOC VERIFY : C1
Boot Ok!
SIM Lock Status : Locked!
Unlocking now ...
Unlock done!
Done!
Elapsed: 00:00:38
The Following 2 Users Say Thank You to shahid41 For This Useful Post:
Old 03-21-2017, 08:46   #40972 (permalink)
wutangclan33's Avatar
Member: 1616754
Thanks Meter: 223
LG X Power K220dsZ Remove google,read nvm,read FW
Infinity-Box LG Service Tool [ LGS ] v1.01
Operation : Reset Settings/Format FS [ v1.01 ]
2. PRESS and HOLD VOLUME UP KEY!
3. Insert USB cable, wait until Download mode screen will appear
Wait for phone...
Connection opened successfully!
Waiting for loader ...
Handshake passed!
Collect info...
Prepare passed, mode 0x01
Boot done!
Format UserData
Format Cache
Format done
Erase FRP0 block Ok!
Erase FRP1 block Ok!
Done!
Elapsed: 00:00:20
Operation : Read Security [ v1.01 ]
Wait for phone...
Handshake passed!
Collect info...
Boot done!
Reading NVM0
Reading NVM1
File saved to : G:\Firmware LG\LG X Power K220DSZ\MT6735_LG-K220dsZ_K22010a.lgnv
Done!
Elapsed: 00:01:11
Operation : Read Firmware [ v1.01 ]
Wait for phone...
Handshake passed!
Collect info...
Boot done!
DevInfo : MT6735__LG-K220dsZ__K22010a__V10a__AOSv6.0.1__LGK220dsZAT-00-V10a-OPT2-SI-JUL-22-2016+0
Reading Flash Content ...
[Read Ok] : gpt_main.bin
[Read Ok] : lgmsnv.bin
[Read Ok] : ftm.img
[Read Ok] : nvitems.bin
[Read Ok] : lk.img
[Read Ok] : laf.img
[Read Ok] : para.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : lsplash.img
[Read Ok] : secro.img
[Read Ok] : tz.bin
[Read Ok] : persist_lg.img
[Read Ok] : cust.img
[Read Ok] : fact.img
[Read Ok] : persist.img
[Read Ok] : swfuse.bin
[Read Ok] : system.img
[Read Ok] : opt.img
[Read Ok] : gpt_backup.bin
Android Info saved!
Read finished!
Configuration : MT6735 / 6.0.1 / V10a
Firmware Size : 3276 MiB
Done!
Elapsed: 00:04:58
The Following 2 Users Say Thank You to wutangclan33 For This Useful Post:
Old 03-21-2017, 09:51   #40973 (permalink)
Member: 1763380
Thanks Meter: 83
asiafone AF_V11 ilegal use done
Operation : Check/Read Info [ v1.24 ]
3. Insert battery
Phone found! [ 14 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
[0] Flash DIE : 00C8 0060 0018 0000
[0] Flash VEN : GigaDevice , GD25LQ128
[0] Flash CAP : 01000000
Elapsed: 00:00:08
Operation : Read FullFlash [ v1.24 ]
3. Insert battery
Phone found! [ 14 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Read Flash Content
Read Ok , collect info
ExtInfo : ALF_X2811_HY_Y29_AF_V11
Project : SC6531_BAR
HWInfo : SC6531_BAR
Compile : 06-11-2014 18:04:39
Set FileInfo :
Model Vendor : asiafone
Model Name : af11
ExtInfo Data : dx
Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_01000000_AL F_X2811_HY_Y29_AF_V11_06112014180439_dx__asiafone-af11.bin
Done!
Elapsed: 00:01:49
Operation : Format File System / Reset Settings [ v1.24 ]
Settings : SmartFormat is On
3. Insert battery
Phone found! [ 14 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:11
The Following User Says Thank You to den fatih For This Useful Post:
Old 03-21-2017, 09:55   #40974 (permalink)
Member: 2489651
Thanks Meter: 17
Privacy Lock reset Ok stylus
Card found : S/N : D7B2B9CB , v0135
Operation : Reset Privacy Lock [ v1.58 ]
Wait for phone...
Phone found! [ 11 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BB_CPU_NME : [MediaTek] MT6592_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x8A
eMMC Flash : 150100523858314D4201AB6E60FB318D
[eMMC] : FLASH_INF : [SAMSUNG] , BM1X8
[eMMC] : FLASH_CID : 150100523858314D4201AB6E60FB318D
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0xAFE48DD9160BCE585D933672BC6D9C2C
EXT RAM : 0x80000000 [2 GiB]
SOC VERIFY : C1
Boot Ok!
Checking data ...
Process block #1
Process block #2
Privacy Lock reset Ok!
Done!
The Following 2 Users Say Thank You to sakib6190 For This Useful Post:
Old 03-21-2017, 09:56   #40975 (permalink)
Member: 835111
Sonork: celltech
Thanks Meter: 15
YU 4711 FLASHING SUCCESS
Card found : AF55BDE0 , v0135
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.10
Load Ok!
Operation : Flash [ v1.10 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 18915209
ID_BLOCK_I : 007050E1
ID_BLOCK_L : 9E661CFA55C1CEF9A69B755AA5FC7454
ID_BLOCK_L : 483B852429B822A32691FA3331FCEAD1
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ]
Boot Ok!
Files in Chain : 109
Flashing now
Flashing : sbl1.mbn
Flashing : sbl1.mbn
Flashing : rpm.mbn
Flashing : rpm.mbn
Flashing : tz.mbn
Flashing : tz.mbn
Flashing : hyp.mbn
Flashing : hyp.mbn
Flashing : splash.img
Flashing : persist_1.unsparse
Flashing : boot.img
Flashing : devinfo_unlock_mmi.img
Flashing : system_1.unsparse
Flashing : system_2.unsparse
Flashing : system_3.unsparse
Flashing : system_4.unsparse
Flashing : system_5.unsparse
Flashing : system_6.unsparse
Flashing : system_7.unsparse
Flashing : system_8.unsparse
Flashing : system_9.unsparse
Flashing : system_10.unsparse
Flashing : system_11.unsparse
Flashing : system_12.unsparse
Flashing : system_13.unsparse
Flashing : system_14.unsparse
Flashing : system_15.unsparse
Flashing : system_16.unsparse
Flashing : system_17.unsparse
Flashing : system_18.unsparse
Flashing : system_19.unsparse
Flashing : system_20.unsparse
Flashing : system_21.unsparse
Flashing : system_22.unsparse
Flashing : system_23.unsparse
Flashing : system_24.unsparse
Flashing : system_25.unsparse
Flashing : system_26.unsparse
Flashing : system_27.unsparse
Flashing : system_28.unsparse
Flashing : system_29.unsparse
Flashing : system_30.unsparse
Flashing : system_31.unsparse
Flashing : cache_1.unsparse
Flashing : cache_2.unsparse
Flashing : cache_3.unsparse
Flashing : config.img
Flashing : userdata_1.unsparse
Flashing : userdata_2.unsparse
Flashing : userdata_3.unsparse
Flashing : userdata_4.unsparse
Flashing : userdata_5.unsparse
Flashing : userdata_6.unsparse
Flashing : userdata_7.unsparse
Flashing : userdata_8.unsparse
Flashing : userdata_9.unsparse
Flashing : userdata_10.unsparse
Flashing : userdata_11.unsparse
Flashing : userdata_12.unsparse
Flashing : userdata_13.unsparse
Flashing : userdata_14.unsparse
Flashing : userdata_15.unsparse
Flashing : userdata_16.unsparse
Flashing : userdata_17.unsparse
Flashing : userdata_18.unsparse
Flashing : userdata_19.unsparse
Flashing : userdata_20.unsparse
Flashing : userdata_21.unsparse
Flashing : userdata_22.unsparse
Flashing : userdata_23.unsparse
Flashing : userdata_24.unsparse
Flashing : userdata_25.unsparse
Flashing : userdata_26.unsparse
Flashing : userdata_27.unsparse
Flashing : userdata_28.unsparse
Flashing : userdata_29.unsparse
Flashing : userdata_30.unsparse
Flashing : userdata_31.unsparse
Flashing : userdata_32.unsparse
Flashing : userdata_33.unsparse
Flashing : userdata_34.unsparse
Flashing : userdata_35.unsparse
Flashing : userdata_36.unsparse
Flashing : userdata_37.unsparse
Flashing : userdata_38.unsparse
Flashing : userdata_39.unsparse
Flashing : userdata_40.unsparse
Flashing : userdata_41.unsparse
Flashing : userdata_42.unsparse
Flashing : userdata_43.unsparse
Flashing : userdata_44.unsparse
Flashing done!
Done!
Elapsed: 00:02:44
The Following User Says Thank You to celltech7610 For This Useful Post:
Old 03-21-2017, 11:11   #40976 (permalink)
Member: 1614640
Thanks Meter: 462
SAMSUNG SM-G5308W CHINESE HANG ON LOGO DONE WITH FORMAT
Card found : S/N : XXXXXXX , v0134
Wait for phone...
Phone found! [ 14 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 7001004D4D43303447550C4019D59025
[eMMC] : FLASH_VEN : 0x70 , OEM : 0100
[eMMC] : FLASH_INF : [KINGSTON] , G40CM
[eMMC] : FLASH_CID : 7001004D4D43303447550C4019D59025
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000
[eMMC] : FLASH_LEN : 0x00000000E6800000
[eMMC] : FLASH_UCP : 3688 MiB [eMMC 4 GiB]
DEV RID : 0xD2FF4FA4B75477D1443201E3BCE3FD7E
EXT RAM : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
Brand : samsung
ProdName : SM-G5308W
ProdModel : SM-G5308W
Device : SM-G5308W
AndroidVer: 4.4.4
MTKxCPU : MT6572
MTKxPRJ : ALPS.JB3.MP.V1
SECURITY :
IMEI_SW [1] : 355XXXXXXXXXXX
IMEI_SW [2] : 355XXXXXXXXXXX
BTMAC Addr : 000046657201
WiFi MAC : CC3A615EB3C7
EXTRA :
LCD [0] : hx8389b_qhd_dsi_vdo_cpt
LCD [1] : s6d78a0_qhd_dsi_vdo
LCD [2] : rm68191_qhd_dsi_vdo#hx8379c_dsi_vdo
LCD [3] : rm68172_dsi_vdo
LCD [4] : hx8369b_dsi_vdo
LCD [5] : nt35510_dsi_cmd_6572_fwvga
LCD [6] : otm8009a_fwvga_dsi_cmd
LCD [7] : #nt35510_dsi
LCD [8] : hx8369b_dsi_vdo
LCD Res : 960x540
TOUCH [0] : ft5206
TOUCH [1] : GT9XX
CAM [0] : s5k4ecgx_mipi_yuv
CAM [1] : gc2145mipi_yuv
CAM [2] : gc0328_yuv
MODEM : mbk72_wet_jb3_hspa_839
LOCALE : en_US es_ES ru_RU zh_CN pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG fa_IR th_TH pt_PT nl_NL el_GR hu_HU tl_PH ur_PK ro_RO cs_CZ iw_IL pl_PL my_MM km_KH hdpi -sw600dp -sw720dp
Done!
Elapsed: 00:00:17
Wait for phone...
Phone found! [ 14 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:34
The Following User Says Thank You to bright hlatini For This Useful Post:
Old 03-21-2017, 11:29   #40977 (permalink)
Member: 1614640
Thanks Meter: 462
VODAFONE SMART mini7 VFD 300 frp unlock done
Card found : S/N : xxxxxxxx , v0134
Wait for phone...
Phone found! [ 14 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 11010030303447453000A9CB74F573A1
[eMMC] : FLASH_VEN : 0x11 , OEM : 0100
[eMMC] : FLASH_INF : [TOSHIBA] , 0EG40
[eMMC] : FLASH_CID : 11010030303447453000A9CB74F573A1
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000
[eMMC] : FLASH_LEN : 0x00000000EC000000
[eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB]
DEV RID : 0xD2FF4FA4E269B7713BA35CCD8E6EB168
SOC VERIFY : C1
Boot Ok!
Brand : Vodafone
ProdName : Smart_mini7
ProdModel : VFD 300
Device : VFD300
AndroidVer: 6.0
MTKxCPU : MT6580
MTKxPRJ : alps-mp-m0.mp1-V2.34_jhz6580.weg.vf.m_P68
SECURITY :
IMEI_OTP [1] : 35xxxxxxxxxxxxx
EXTRA :
LCD Res : 800x480
TOUCH [0] : GT1XX
CAM [0] : ov5670_mipi_raw
CAM [1] : s5k5e8yx_mipi_raw
CAM [2] : ov2680_mipi_raw
CAM [3] : gc2355_mipi_raw_rear
CAM [4] : gc2355_mipi_raw_front
CAM [5] : sp2508_mipi_raw
CAM [6] : gc0310_mipi_yuv
MODEM : jhz6580_we_vf_m_hspa jhz6580_we_vf_m_gprs
Done!
Elapsed: 00:00:24
Wait for phone...
Phone found! [ 14 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:18
Old 03-21-2017, 13:05   #40978 (permalink)
rehmani's Avatar
Member: 333199
Sonork: may i help u just pm me
Thanks Meter: 2,391
panasonic p55 flash done
Chinese Miracle II  [MTK module] v 1.56
Operation : Check / Read Info [ v1.56 ]
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 150100513732534D42008DC69A3782D7
[eMMC] : FLASH_INF : [SAMSUNG] , BMS27
[eMMC] : FLASH_CID : 150100513732534D42008DC69A3782D7
DEV RID    : 0xC1F94A5C84357142D5FEA335BC05B6B0
SOC VERIFY : C1
Boot Ok!
Brand     : Panasonic
ProdName  : P55_Novo
ProdModel : Panasonic P55 Novo
Device    : P55_Novo
AndroidVer: 4.4.2
MTKxCPU   : MT6592
MTKxPRJ   : S3569_DS35691_KARBONN_L118
SECURITY :
IMEI_SW [1] : 35211207591----
IMEI_SW [2] : 35211207595----
BTMAC Addr  : FEBF4665925E
WiFi MAC    : 700BC095E7B6
MODEM :
BaseBand  : MT6592_S00_MOLY_WR8_W1315_MD_WG_MP_V62_P20_1_wg_n
EXTRA :
LCD [0] : hx8394d_hd720_dsi_vdo_s35
LCD [1] : otm1287_hd720_dsi_vdo_boyi_s35
LCD Res : 1280x720
TOUCH [0] : GT915M_S35
CAM [0] : ov13850_mipi_raw_s35_sunwin
CAM [1] : ov5670_mipi_raw_s35
CAM [2] : gc2355_mipi_raw_s35
MODEM : s3598_modem
LOCALE : en_US en_GB hi_IN ja_JP fr_FR de_DE it_IT ru_RU zh_CN ar_IL bn_IN th_TH af_ZA ar_IL zh_TW en_IN tl_PH in_ID fa_IR pt_PT es_ES sw_TZ ur_PK vi_VN zu_ZA nl_BE nl_NL pl_PL tr_TR uk_UA gu_IN mr_IN pa_IN
Done!
Elapsed: 00:00:09
Operation : HW Test [ v1.56 ]
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[Processing] FlashMemory Read-Write test
[eMMC] : [SAMSUNG] , BMS27 , 0x1D2000000 , 7456 MiB
[eMMC] : CID : 150100513732534D42008DC69A3782D7
[eMMC] : MODE : SQ-WR
[PASSED] : eMMC RW Check #1 Ok!
[eMMC] : MODE : RA-WR
[PASSED] : eMMC RW Check #2 Ok!
[eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed!
All Done!
Done!
Elapsed: 00:00:54
Scatter Load Ok , BaseBand : MT6592 , Project : s3569 , Storage : EMMC
Files found : 13 , Set to Flash : 12
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand   : Panasonic
Device Model   : P55_Novo
Device CPU     : MT6592
Device IntName : P55_Novo
Device Version : 4.4.2
Device Compile : 8/19/2015 9:49:14 AM
Device Project : S3569_DS35691_KARBONN_L118
Device ExtInfo : Panasonic P55 Novo
Ready to Flash!
Operation : Flash [ v1.56 ]
======= Flash
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6592 , Project : s3569 , Storage : EMMC
Setting : AFF verify :  Disabled
Setting : HW verify :  Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3852 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 3
Erase : 0x0000000000000000-0x0000000000100000
Erase : 0x0000000001D00000-0x0000000002DA0000
Erase : 0x0000000004BA0000-0x00000001CBF60000
Flash Pre-Erase Done, time used : 00:00:04
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_s3569.bin
Preloader Sent , Init passed
PartCount : 0015
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EBR2
Image Flash Ok
Flash now : TEST
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:04:20
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:04:38
The Following User Says Thank You to rehmani For This Useful Post:
Old 03-21-2017, 13:08   #40979 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,391
lava iris x8 flash done
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A48414732650507CC1BCCA93295
[eMMC] : FLASH_INF : [HYNIX] , e2GA
[eMMC] : FLASH_CID : 90014A48414732650507CC1BCCA93295
[eMMC] : FLASH_LEN : 0x00000003AB800000
[eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB]
DEV RID    : 0xC1F94A5C5329724AEBEFFE10FBCEAAB2
SOC VERIFY : C1
Boot Ok!
Brand     : iris
ProdName  : X8
ProdModel : irisX8
Device    : irisX8
AndroidVer: 4.4.2
MTKxCPU   : MT6592
MTKxPRJ   : Lava_irisx8_S016_20150313
SECURITY :
IMEI_SW [1] : 91143380599----
IMEI_SW [2] : 91143380605----
BTMAC Addr  : 3E0B33659239
WiFi MAC    : 90218146ED8F
EXTRA :
LCD [0] : ili9881_dsi_hd720_txd_aw809
LCD [1] : otm1283_hd720_trust_aw809
LCD [2] : nt35521_hd720_dijin_aw809
LCD Res : 1280x720
TOUCH [0] : ft6436l_aw809
TOUCH [1] : msg2238a_aw809
TOUCH [2] : GT9XX_ZAW809#S7020
TOUCH [3] : #GT9XX
CAM [0] : ov8865_mipi_raw_aw809
CAM [1] : s5k4h5yx_mipi_raw_aw809
CAM [2] : ov8858_mipi_raw_aw809
CAM [3] : ov2680_mipi_raw_aw809
CAM [4] : gc2355_mipi_raw_aw809
MODEM : aw809_zaw809aa_md1_hspa_gemini_g4w1_w2100 #change modem for sim reverse
LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR hi_IN xhdpi
Done!
Elapsed: 00:00:11
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[eMMC] : [HYNIX] , e2GA , 0x3AB800000 , 15032 MiB
[eMMC] : CID : 90014A48414732650507CC1BCCA93295
All Done!
Done!
Elapsed: 00:00:58
Scatter Load Ok , BaseBand : MT6592 , Project : full_zaw809p_lava , Storage : EMMC
Files found : 11 , Set to Flash : 10
Ready to Flash!
======= Flash
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6592 , Project : full_zaw809p_lava , Storage : EMMC
BL : BatteryLevel : 3668 mV
Total blocks to Erase : 2
Erase : 0x0000000001D00000-0x0000000131B00000
Flash Pre-Erase Done, time used : 00:00:03
Use : preloader_zaw809p_platform.bin
PartCount : 0012
Repartition Done!
Use FLN Mode
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:03:40
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:57
Old 03-21-2017, 13:09   #40980 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,391
micromaxx a310 format done
Operation : Format FileSystem [ v1.56 ]
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BromVer   : 0x0005
BLVersion : 0x00FE
Processing DA stage
eMMC Flash : 90014A48384732640403020C98C9212D
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x40000000
[eMMC] : FLASH_INF : [HYNIX] , d2G8
[eMMC] : FLASH_CID : 90014A48384732640403020C98C9212D
DEV RID    : 0xC1F94A5C57D1757C49006455F8A5EE7F
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:02:52
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-29-2010 21:17
Page generated in 0.81374 seconds with 9 queries
