06-16-2017, 05:48 | #42916 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile A120 MT6572 Resterting Probelam Solve Only Formate With Infinity CM2 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 28 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164048601A38D5F418F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A38D5F418F [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F3957880583D8E2BB67B3023D48C INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
The Following User Says Thank You to azhergoga007 For This Useful Post: |
06-16-2017, 06:44 | #42918 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile Metal 1 MT6580 FRP Reset Done With World Famous Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 41 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48384731650507047400374399 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A48384731650507047400374399 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F395B7AAC8749DB7B142CCEB570B INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:38 Reconnect Power/Cable! |
06-16-2017, 08:02 | #42919 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile I5 MT6580 Restert probelam solve Only Formate With Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 28 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040503A2A91C2259 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040503A2A91C2259 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F39557D74029F3E7B9DEDE1D01C5 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:26 Reconnect Power/Cable! 1 More Flash Done Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 28 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040503A2A91C2259 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040503A2A91C2259 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F39557D74029F3E7B9DEDE1D01C5 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : s4700 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3657 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:04 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:03:04 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:51 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:04:12 Reconnect Power/Cable! Last edited by azhergoga007; 06-16-2017 at 08:12. |
06-16-2017, 09:39 | #42920 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile S250 MT6261 Read Coad Done With Phardo Infinity CM2 Operation : Read UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 40 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 98D378FFD44C017C10D3B95C711829D5 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 8000 PLock|MobTrack : Not active Done! Elapsed: 00:00:04 Reconnect Power/Cable! |
06-16-2017, 10:29 | #42921 (permalink) |
No Life Poster Join Date: Jul 2015 Location: India
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 | Moto xt 1068 (Moto G 2nd Gen. 3G) Restart Problem Solved By AST Module Restart Problem Solved By AST Module Only 2 Click, No Need Full Flash Read Info........................ Code: Operation : Identify [ v1.0 ] Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Main Info ============ CPU : MSM8226 CS CID : 0x0007 IMEI : 35332XXXXXXXXX UID : 0F217E070F000000000000000000 Model Info ============ DevModel : XT1068 IntName : titanZX1D63PBCQ SW Info ============ DevSWVer : Blur_Version.21.11.23.titan_retaildsds.retaildsdsall.en.03 DevQCVer : AU_LINUX_ANDROID_LNX.LA.3.5.1_RB1.04.04.02.048.045 BootLDRv : 4807(*) HW Info ============ eMMCInfo : 16GB ID=15 REV=07 PRV=0B TYPE=57 DRAMInfo : 1024MB Hynix S4 SDRAM DIE=4Gb Lock Info ============ BLUnlock : no WarrantyVoid : no Done! Elapsed: 00:00:21 Code: Operation : Reset Settings [ v1.0 ] Mode : Format FS Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Block [1] ERASE OK! Block [2] ERASE OK! Done! Elapsed: 00:00:18 |
The Following 7 Users Say Thank You to 4G Telecom For This Useful Post: |
06-16-2017, 12:26 | #42922 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Samsung Clone Grand Prime Format Done Samsung Clone Grand Prime Format Done Code: Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8B00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 150100534A5330304D003BA52BBF7FF1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , M00SJ [eMMC] : FLASH_CID : 150100534A5330304D003BA52BBF7FF1 [eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xE6C52A7D8B83E20173F01F615B7EA5DE INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:35 Reconnect Power/Cable! |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
06-16-2017, 12:41 | #42923 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Lyf Ls5017 FullFlash Done Code: Scatter Load Ok , BaseBand : MT6735 , Project : hct6735_35gu_m0 , Storage : EMMC Files found : 11 , Set to Flash : 10 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : Hipstreet-LYF Device Model : LS-5017 Device CPU : MT6735 Device IntName : LS-5017 Device Version : 6.0 Device Compile : 11/3/2016 11:47:35 AM Device Project : LYF-LS-5017-R13 Device ExtInfo : LS-5017 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 520001154D42314541F707421F924AD6 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB1E [eMMC] : FLASH_CID : 150100524531424D4207F741D64A631F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xC1F94A5CE9A9CA02AA0EFFE461404D69 INT RAM : 0x00020000 EXT RAM : 0xC0000000 [3 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6735 , Project : hct6735_35gu_m0 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 4165 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001C80000-0x0000000004D80000 Erase : 0x0000000006B00000-0x000000039C280000 Flash Pre-Erase Done, time used : 00:00:01 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_hct6735_35gu_m0.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0016 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : TEE1 Image Flash Ok Flash now : TEE2 Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:04:11 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : SECRO Verify Passed : TEE1 Verify Passed : TEE2 Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:01:18 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:05:46 Reconnect Power/Cable! |
06-16-2017, 12:42 | #42924 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Spice Mi524 FullFlash Done Code: Scatter Load Ok , BaseBand : MT6582 , Project : techain82_wet_kk , Storage : EMMC Files found : 11 , Set to Flash : 10 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : Spice Device Model : Mi-524 Device CPU : MT6582 Device IntName : Mi-524 Device Version : 4.4.2 Device Compile : 9/2/2014 6:30:14 AM Device Project : ALPS.KK1.MP1.V2.11 Device ExtInfo : Spice Mi-524 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 1501004B3758564D42019716C8EC817D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D42019716C8EC817D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xC1F94A5C5B035BDAD5EA94BB4BC483EE INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : techain82_wet_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Disabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3932 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000900000-0x0000000000080000 Erase : 0x0000000002580000-0x000000010D880000 Flash Pre-Erase Done, time used : 00:00:02 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_techain82_wet_kk.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0011 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:04:09 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:04:10 |
06-16-2017, 12:43 | #42925 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Qmobile Noir X6 Storage Problem Solved Code: Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : 009800BC009000660076001600080000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 DEV RID : 0xE6C52A7DDDCB83999F7A28C6C0252CBC INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
06-16-2017, 12:45 | #42926 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Qmobile Noir Z8 Qlcm FullFlash Done Code: Loading firmware ... Load Ok! Operation : Flash [ v1.12 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 044711C6 ID_BLOCK_I : 007050E1 ID_BLOCK_L : C3255FA7169C898463D83825E2B93911 ID_BLOCK_L : 0271DF6E63F25CE9ECCB8C454FA6B09B Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Files in Chain : 164 Flashing now Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : hyp.mbn Flashing : hyp.mbn Flashing : splash.img Flashing : sec.dat Flashing : boot.img Flashing : system_1.img Flashing : system_2.img Flashing : system_3.img Flashing : system_4.img Flashing : system_5.img Flashing : system_6.img Flashing : system_7.img Flashing : system_8.img Flashing : system_9.img Flashing : system_10.img Flashing : system_11.img Flashing : system_12.img Flashing : system_13.img Flashing : system_14.img Flashing : system_15.img Flashing : system_16.img Flashing : system_17.img Flashing : system_18.img Flashing : system_19.img Flashing : system_20.img Flashing : system_21.img Flashing : system_22.img Flashing : system_23.img Flashing : system_24.img Flashing : system_25.img Flashing : persist_1.img Flashing : cache_1.img Flashing : cache_2.img Flashing : cache_3.img Flashing : cache_4.img Flashing : recovery.img Flashing : userdata_1.img Flashing : userdata_2.img Flashing : userdata_3.img Flashing : userdata_4.img Flashing : userdata_5.img Flashing : userdata_6.img Flashing : userdata_7.img Flashing : userdata_8.img Flashing : userdata_9.img Flashing : userdata_10.img Flashing : userdata_11.img Flashing : userdata_12.img Flashing : userdata_13.img Flashing : userdata_14.img Flashing : userdata_15.img Flashing : userdata_16.img Flashing : userdata_17.img Flashing : userdata_18.img Flashing : userdata_19.img Flashing : userdata_20.img Flashing : userdata_21.img Flashing : userdata_22.img Flashing : userdata_23.img Flashing : userdata_24.img Flashing : userdata_25.img Flashing : userdata_26.img Flashing : userdata_27.img Flashing : userdata_28.img Flashing : userdata_29.img Flashing : userdata_30.img Flashing : userdata_31.img Flashing : userdata_32.img Flashing : userdata_33.img Flashing : userdata_34.img Flashing : userdata_35.img Flashing : userdata_36.img Flashing : userdata_37.img Flashing : userdata_38.img Flashing : userdata_39.img Flashing : userdata_40.img Flashing : userdata_41.img Flashing : userdata_42.img Flashing : userdata_43.img Flashing : userdata_44.img Flashing : userdata_45.img Flashing : userdata_46.img Flashing : userdata_47.img Flashing : userdata_48.img Flashing : userdata_49.img Flashing : userdata_50.img Flashing : userdata_51.img Flashing : userdata_52.img Flashing : userdata_53.img Flashing : userdata_54.img Flashing : userdata_55.img Flashing : userdata_56.img Flashing : userdata_57.img Flashing : userdata_58.img Flashing : userdata_59.img Flashing : userdata_60.img Flashing : userdata_61.img Flashing : userdata_62.img Flashing : userdata_63.img Flashing : userdata_64.img Flashing : userdata_65.img Flashing : userdata_66.img Flashing : userdata_67.img Flashing : userdata_68.img Flashing : userdata_69.img Flashing : userdata_70.img Flashing : userdata_71.img Flashing : userdata_72.img Flashing : userdata_73.img Flashing : userdata_74.img Flashing : userdata_75.img Flashing : userdata_76.img Flashing : userdata_77.img Flashing : userdata_78.img Flashing : userdata_79.img Flashing : userdata_80.img Flashing : userdata_81.img Flashing : userdata_82.img Flashing : userdata_83.img Flashing : userdata_84.img Flashing : userdata_85.img Flashing : userdata_86.img Flashing : userdata_87.img Flashing : userdata_88.img Flashing : userdata_89.img Flashing : userdata_90.img Flashing : userdata_91.img Flashing : userdata_92.img Flashing : userdata_93.img Flashing : userdata_94.img Flashing : userdata_95.img Flashing : userdata_96.img Flashing : userdata_97.img Flashing : userdata_98.img Flashing : userdata_99.img Flashing : userdata_100.img Flashing : userdata_101.img Flashing : userdata_102.img Flashing : userdata_103.img Flashing : userdata_104.img Flashing : userdata_105.img Flashing : userdata_106.img Flashing : gpt_main0.bin Flashing : gpt_backup0.bin Flash sequence completed! Records in Chain : 26 Processing records now Records sequence completed! Boot settings configured! Flashing done! Done! Elapsed: 00:04:10 Reconnect Power/Cable! |
06-16-2017, 12:46 | #42927 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Sony Clone V3 Stuck @ Logo Done Code: Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E3958524D4200B0EEB25812AF Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMRX9 [eMMC] : FLASH_CID : 1501004E3958524D4200B0EEB25812AF [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x0000000070000000 [eMMC] : FLASH_UCP : 1792 MiB [eMMC 2 GiB] DEV RID : 0xC0BB5E81AB6FBD39C647977AA9537A68 INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
06-16-2017, 12:48 | #42928 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | HTC Desire 616 Flashing Done Code: Scatter Load Ok , BaseBand : MT6592 , Project : wt98518 , Storage : EMMC Files found : 12 , Set to Flash : 11 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 121 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164048603A47FC1910B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048603A47FC1910B [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0xC1F94A5C57DA1E23BCF0605AD889E7F0 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6592 , Project : wt98518 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Disabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3744 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000000000-0x0000000000100000 Erase : 0x0000000001D00000-0x00000000A9F00000 Flash Pre-Erase Done, time used : 00:00:04 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_wt98518.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0015 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:07:20 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:07:22 Reconnect Power/Cable! |
06-16-2017, 12:56 | #42929 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Qmobile W50 Spd FullFlash Done Code: Set mode to : SP [SC773x] eMMC [Generic] Loading : QMobileW50_MP_10_30.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : QMobileW50_MP_10_30 FastCheck : 0x007E90CBAF Loading files ... File : fdl1.bin File : fdl2.bin File : nvitem.bin File : wcnnvitem.bin File : prodnv.img File : u-boot-spl-16k.bin File : wmodem.bin File : wdsp.bin File : wcnmodem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : logo.bmp File : fastboot_logo.bmp File : cache.img File : u-boot.bin File : SC77xx.xml Load Ok! Operation : Flash [ v1.25 ] ======= Flash Files set for flashing : [ MCU ] : QMobileW50_MP_10_30.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : QMobileW50_MP_10_30 File : fdl1.bin File : fdl2.bin File : nvitem.bin File : wcnnvitem.bin File : prodnv.img File : u-boot-spl-16k.bin File : wmodem.bin File : wdsp.bin File : wcnmodem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : logo.bmp File : fastboot_logo.bmp File : cache.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 138 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! [FL] : Enabled NVM update. Will program all NVM images found in FW ! PMTManager : Load 0x17 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : NVM Update Current ID : NV_W Current Part : wfixnv1 [FlashProc] : Ok! [FlashProc] : NVM Update Current ID : NV_WCN Current Part : wcnfixnv1 [FlashProc] : Ok! [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W Current File : wmodem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_W Current File : wdsp.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WCN Current File : wcnmodem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : USERDATA Current File : userdata.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOTLOGO Current File : logo.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : FASTBOOT_LOGO Current File : fastboot_logo.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH Current Part : wruntimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH_WCN Current Part : wcnruntimenv1 [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : CACHE Current File : cache.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEMISC Current Part : misc [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : UBOOTLOADER Current File : u-boot.bin Flashing now ... [FlashProc] : Ok! Elapsed: 00:05:35 Reconnect Power/Cable! |
06-16-2017, 12:57 | #42930 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Lenovo A7020 Frp Remove Done Code: Operation : Format FileSystem [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 56 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41X [eMMC] : FLASH_CID : 150100525831344D42078143D0605353 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0xC1F94A5CD0800A5CA1B354D34EA3BAE4 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear PVL ( PrivacyLock ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
