07-05-2017, 09:01 | #43336 (permalink) |
Major Poster Join Date: Jan 2017 Location: Dhaka.BD
Member: 2667438 Status: Offline Sonork: 100.1676500 Thanks Meter: 34 | Symphony H300 plus firmware read successfully by CM2QLM 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 100726DB ID_BLOCK_I : 007050E1 ID_BLOCK_L : E818728C2BB7BCAF98CD0708D792222A ID_BLOCK_L : C2B11FAEA3329C29AC0B4C858F66705B Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Brand : qcom ProdName : l5261 ProdModel : l5261 Device : l5261 AndroidVer: 5.1.1 Manufact. : Tinno QLMxCPU : MSM8916 DevInfo : MSM8916__Tinno__qcom__ANDR_v5.1.1__l5261__l5261__l 5261 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : hyp.mbn [Read Ok] : splash.img [Read Ok] : fs_gc.img [Read Ok] : sec.dat [Read Ok] : emmc_appsboot.mbn [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : persist.img [Read Ok] : misc.img [Read Ok] : oem.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8916 / eMMC Firmware Size : 2070 MiB Done! Elapsed: 00:04:32 |
07-05-2017, 10:19 | #43337 (permalink) |
Freak Poster Join Date: Oct 2013
Member: 2043843 Status: Offline Thanks Meter: 39 | SAmsung g7202 Restart problem solve with INinity SM v0.9. ( Z3x failed ) Card found! Main Infinity-Box/Dongle S/N: 009185DB79 Phone found on COM8 Port open Ok! LOKE received! Prepare Ok! Enter Setup... Setup Done! Try download PIT... Download PIT Ok! Start flashing! Flashing aboot.mbn Flashing sbl1.mbn Flashing rpm.mbn Flashing tz.mbn Flashing hyp.mbn Flashing NON-HLOS.bin Flashing sec.dat Flashing boot.img Flashing recovery.img Flashing system.img.ext4 Flashing modem.bin Flashing cache.img.ext4 Flashing done Reboot phone... Phone Disconnected Phone found on COM9 |
The Following User Says Thank You to vishal110094 For This Useful Post: |
07-05-2017, 10:43 | #43338 (permalink) |
Member: 2043843 Status: Offline Thanks Meter: 39 | G7202 restart problem solver with infinity SM test version ( z3x failed) Card found! Main Infinity-Box/Dongle S/N: 009185DB79 Phone found on COM8 Port open Ok! LOKE received! Prepare Ok! Enter Setup... Setup Done! Try download PIT... Download PIT Ok! Start flashing! Flashing aboot.mbn Flashing sbl1.mbn Flashing rpm.mbn Flashing tz.mbn Flashing hyp.mbn Flashing NON-HLOS.bin Flashing sec.dat Flashing boot.img Flashing recovery.img Flashing system.img.ext4 Flashing modem.bin Flashing cache.img.ext4 Flashing done Reboot phone... Phone Disconnected Phone found on COM9 |
07-05-2017, 10:45 | #43339 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Samsung Clone G360H MT6572 Logo Stuck Recover By Flashing Done With Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 110100303034474530016ED74BBA52DB Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 110100303034474530016ED74BBA52DB [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F3955FAECBDA5B9DB29D36853A00 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:28 Reconnect Power/Cable! |
07-05-2017, 10:53 | #43340 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | ElePhone S7 MT6797 Reset/FRP Reset Done With Phardo Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6797 BB_CPU_NME : [MediaTek] Helio[X20]|MT6797_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , 4604F [eMMC] : FLASH_CID : 45010044463430363401145E933AA353 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000E8F800000 [eMMC] : FLASH_UCP : 59640 MiB [eMMC 128 GiB] DEV RID : 0xD9C8F3957FD9C1D2C6ACD92329C316F1 INT RAM : 0x00000000 EXT RAM : 0xC0000000 [3 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
07-05-2017, 11:21 | #43341 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Samsung Clone J910FN MT6572 Logo Stuck Recover Done By Flashing With Infinity CM2 Brand : Samsung ProdName : SM-J900FN ProdModel : SM-J900FN Device : j7209 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : J7209_J9_6.0.1_V1.7 20161222-1652 Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E35575A4D42014618D0F1B021 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D42014618D0F1B021 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F395400AD40B0ECDB76B6613EAE9 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : j7209 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3846 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001400000-0x0000000000100000 Erase : 0x0000000003100000-0x00000000E2620000 Flash Pre-Erase Done, time used : 00:00:00 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:08 |
07-05-2017, 11:46 | #43342 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile B65 MT6261 Read Coad Done with Great Infinity CM2 Operation : Read UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 8 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 5147D091A33917B1E0D4A33019FEB0FC BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 4580 PLock|MobTrack : Not active Done! Elapsed: 00:00:08 Reconnect Power/Cable! |
07-05-2017, 13:31 | #43343 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | nokia 1035 flash done Code: Connect phone on selected interface... Core : v2.27 , MTKx FlashEngine : v11.5 Verify files ... MAUI : RM-1035_ROM_eMP_10.01.11 VIVA : RM-1035_VIVA_eMP_10.01.11 LANG : RM-1035_LANG_PACK_ROM_MH_eMP_10.01.11_001 CUST : RM-1035_CUSTPACK_ROM_MH_INDIA_IN_eMP_10.01.11_001 JMPT : RM-1035_JUMP_TABLE_MH_INDIA_IN_eMP_10.01.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 68 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 9E1460BE37753159970B9F8EB210430B BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.02.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_10.01.11 SecureDecrypt : RM-1035_VIVA_eMP_10.01.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_MH_eMP_10.01.11_001 SecureDecrypt : RM-1035_CUSTPACK_ROM_MH_INDIA_IN_eMP_10.01.11_001 SecureDecrypt : RM-1035_JUMP_TABLE_MH_INDIA_IN_eMP_10.01.11_001 OVRLP : 000069B900000001 PHPID : CRYSTAL.10.02.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_10.01.11 Write : RM-1035_LANG_PACK_ROM_MH_eMP_10.01.11_001 Write : RM-1035_CUSTPACK_ROM_MH_INDIA_IN_eMP_10.01.11_001 Write : RM-1035_JUMP_TABLE_MH_INDIA_IN_eMP_10.01.11_001 Write : RM-1035_VIVA_eMP_10.01.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_10.01.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_MH_eMP_10.01.11_001 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_MH_INDIA_IN_eMP_10.01.11_001 [VERIFY] DONE : RM-1035_JUMP_TABLE_MH_INDIA_IN_eMP_10.01.11_001 [VERIFY] DONE : RM-1035_VIVA_eMP_10.01.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:07 Reboot phone Ok Connect phone on selected interface... |
07-05-2017, 13:53 | #43344 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile E40 MT625A Blue screen Recover By Flashing With InfinityCM2 Operation : Flash [ v1.58 ] ======= Flash Files set for flashing : [ MCU ] : QMOBILE E40 625A 3MB CODE 2255-3333.bin 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 36 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : E8ACF3E399511374F427E1F8435570C9 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 INT_RAM : 0x0000D400 EXT_RAM : 0x00400000 File_Info : TINNO50M_3232_11B_PCB01_gsm_MT6250_S00.B2050B_MP_F 3F8_PK_F5_06_V7.bin FileVersion : B2050B_MP_F3F8_PK_F5_06_V7 Flash now Erase region , wait ... Write data , wait ... Write : QMOBILE E40 625A 3MB CODE 2255-3333.bin Done! Elapsed: 00:00:40 Reconnect Power/Cable! |
07-05-2017, 14:18 | #43345 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | alcatel pop3 format done Code: Operation : Identify [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 01E971C9 ID_BLOCK_I : 009600E1 ID_BLOCK_L : DE265CBA15818EB966DB351AE5BC3414 ID_BLOCK_L : A0D37DCCC150FA0B8E69229BE9041239 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Brand : TCL ProdName : 5054T ProdModel : 5054T Device : Pop355 AndroidVer: 5.1.1 Manufact. : TCL SysPatch : LMY47V QLMxCPU : MSM8909 Done! Elapsed: 00:00:21 Reconnect Power/Cable! Operation : Reset Settings [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 01E971C9 ID_BLOCK_I : 009600E1 ID_BLOCK_L : DE265CBA15818EB966DB351AE5BC3414 ID_BLOCK_L : A0D37DCCC150FA0B8E69229BE9041239 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
07-05-2017, 14:27 | #43346 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile T2 SPD77xx NAND Pattren Reset Done With Great Infinity CM2 Card found: S/N : A19EC787 , v0136 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC7715] NAND [Generic] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 6 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader NAND v1.1 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! Formatting NAND Flash Format UserData Format Ok! Format Cache Format Ok! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
07-05-2017, 14:30 | #43347 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile I5 MT6582 Hanging Probel Recover Done Only Formate With Infinity CM2 Brand : QMobile ProdName : QMobile i5 ProdModel : QMobile i5 Device : QMobile i5 AndroidVer: 4.2.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.JB5.MP.V1.6 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483447316404050CA1C93851AD Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A483447316404050CA1C93851AD [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F395F95BD606B81582166A7AACE4 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:30 Reconnect Power/Cable! |
07-05-2017, 14:56 | #43348 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | micromaxx a121 format and read rom done Code: Operation : Read Flash [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 033F2941 ID_BLOCK_I : 008140E1 ID_BLOCK_L : 46BED4228D190601FE53BDA26D34BC8C ID_BLOCK_L : 1A69D7767BEA54D1F4C3944D47AEB883 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Brand : Micromax ProdName : A121 ProdModel : Micromax A121 AndroidVer: 4.3 Manufact. : Micromax QLMxCPU : MSM8610 DevInfo : MSM8610__Micromax__Micromax__ANDR_v4.3__Micromax_A121__A121 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : deploy.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : boot.img [Read Ok] : tz.mbn [Read Ok] : system.img [Read Ok] : persist.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : misc.img [Read Ok] : fs_gc.img [Read Ok] : splash.img [Read Ok] : usbdisk.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8x10 / eMMC Firmware Size : 1906 MiB Done! Elapsed: 00:05:13 Reconnect Power/Cable! Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.14 Operation : Identify [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 033F2941 ID_BLOCK_I : 008140E1 ID_BLOCK_L : 46BED4228D190601FE53BDA26D34BC8C ID_BLOCK_L : 1A69D7767BEA54D1F4C3944D47AEB883 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Brand : Micromax ProdName : A121 ProdModel : Micromax A121 AndroidVer: 4.3 Manufact. : Micromax SysPatch : JLS36C QLMxCPU : MSM8610 Done! Elapsed: 00:00:35 Reconnect Power/Cable! Operation : Reset Settings [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 033F2941 ID_BLOCK_I : 008140E1 ID_BLOCK_L : 46BED4228D190601FE53BDA26D34BC8C ID_BLOCK_L : 1A69D7767BEA54D1F4C3944D47AEB883 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Format USER ... Format CACHE ... Format Ok! Done! Elapsed: 00:00:14 Reconnect Power/Cable! |
07-05-2017, 16:19 | #43349 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile X32 SPD7731 FRP/Reset Done With Great Infinity CM2 Card found: S/N : A19EC787 , v0136 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Android 6.x] Set mode to : [AltLDR] SP [SC773x] eMMC [Android 6.x] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 6 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000011B1F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
07-05-2017, 16:31 | #43350 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | Infinity-Box Android Service Tool / AST v1.00 Successfully REPAIR HANG ON AP FASTBOOT MODE(MOTO XT1068)USB Selected NormalFlash mode definition! Pre-Flash verification passed! Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Processing Flashing ... READ INFO : MAX-SPARSE-SIZE Result : 268435456 Executing OEM operation OEM operation OK! FLASH : PARTITION Unpack file, please wait ... FileInfo : gpt.bin , Checksum : 1d2b1622c27346de5e3bbf236304c67e Sending data ... FLASH operation OK! FLASH : MOTOBOOT Unpack file, please wait ... FileInfo : motoboot.img , Checksum : 690ee3c621aebeb5654016b2d8fa8cc1 Sending data ... flashing tz ... flashing rpm ... flashing sdi ... flashing aboot ... flashing sbl1 ... FLASH operation OK! FLASH : LOGO Unpack file, please wait ... FileInfo : logo.bin , Checksum : a2611dae73c28551cfdaa9a009355fdd Sending data ... FLASH operation OK! FLASH : BOOT Unpack file, please wait ... FileInfo : boot.img , Checksum : 381983aec808a844de74edae10b9e660 Sending data ... FLASH operation OK! FLASH : RECOVERY Unpack file, please wait ... FileInfo : recovery.img , Checksum : 000a72974c4fba4e3d50fa81c6420aed Sending data ... FLASH operation OK! FLASH : SYSTEM Unpack file, please wait ... FileInfo : system.img_sparsechunk.0 , Checksum : 27837689e1b2940c44d409bd6cf88c15 Sending data ... FLASH operation OK! FLASH : SYSTEM Unpack file, please wait ... FileInfo : system.img_sparsechunk.1 , Checksum : 012e75ee5bf95dddee37dbbc6e96dc4a Sending data ... FLASH operation OK! FLASH : SYSTEM Unpack file, please wait ... FileInfo : system.img_sparsechunk.2 , Checksum : 94253002b008892a5f0fd9980da2a0ef Sending data ... FLASH operation OK! FLASH : SYSTEM Unpack file, please wait ... FileInfo : system.img_sparsechunk.3 , Checksum : 74a707e94527f140cf28094cb35dcff4 Sending data ... FLASH operation OK! FLASH : MODEM Unpack file, please wait ... FileInfo : NON-HLOS.bin , Checksum : f21b9ec2848fe9a1ac975f6ce4c38881 Sending data ... FLASH operation OK! ERASE : MODEMST1 ERASE operation OK! ERASE : MODEMST2 ERASE operation OK! FLASH : FSG Unpack file, please wait ... FileInfo : fsg.mbn , Checksum : e6f3f8068e3b5780b54e72c2739bd4e4 Sending data ... FLASH operation OK! ERASE : CACHE ERASE operation OK! ERASE : USERDATA ERASE operation OK! Executing OEM operation OEM operation OK! Flashing finished! Done! Elapsed: 00:05:11 THANKS INFINITY-BOX TEAM |
The Following User Says Thank You to gracy_elec For This Useful Post: |
