Old 07-07-2017, 06:52   #43381 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 976
Smile Motorola X Play Reset Frp Lock Done CM2
Reset Frp Lock
The Following User Says Thank You to A.G.Shahid For This Useful Post:
Old 07-07-2017, 07:06   #43382 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,164
Qmobile X30 MT6572 Dead Set Re Alive DOne By Flashing With Infinity CM2
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473261110115C66C1A6211
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , a2G4
[eMMC] : FLASH_CID : 90014A4834473261110115C66C1A6211
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xD9C8F3958698F31362A7CF8B1BD93A7D
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Skip checking by User request!
BL : BatteryLevel : 3513 mV
BL : [WARNING] : BatteryLevel LOW!!!
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x00000000E5E00000
Flash Pre-Erase Done, time used : 00:00:03
SecCfg Passed , 1799
BMT remark not need. Will skip
Preloader Download skipped by user request!
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:57
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:43
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:59
Reconnect Power/Cable!
The Following User Says Thank You to azhergoga007 For This Useful Post:
Old 07-07-2017, 08:08   #43383 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 14,875
Smile Qmobile Noir W15 Format Done
Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0]
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 6 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v3 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Done!
Elapsed: 00:00:27
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post:
Old 07-07-2017, 09:15   #43384 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 3,989
QMobile M95 Write Factory Firmware Done :)
Operation : FlashIC ReadOnly/BadBlock Test [ v1.25 ]
3. Insert cable
Phone found! [ 114 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Prepare test data ...
Test flow #0 ...
Test flow passed!
Test flow #1 ...
Test flow passed!
Test flow #2 ...
Test flow passed!
Test flow #3 ...
Test flow passed!
Test flow #4 ...
Test flow passed!
Test flow #5 ...
Test flow passed!
Finalize Ok!
Test passed successfully!
Elapsed: 00:00:31
Operation : Check/Read Info [ v1.25 ]
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name  : scx35_sp7731geaplus_dt
Model Brand : QMobile
Model Device: scx35_sp7731gea
AndrVersion : 4.4.3
BaseBand CPU: SP7731GEA
CompileDate : 7/31/2015 12:00:38 PM
Project Ver : KOT49H 14B_test-keys
Model Ext   : QMobile M95
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:30
Operation : Read NV [ v1.25 ]
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Read GSM NV
Read WCN NV
Read Ok , 0xA596
Saved to : F:\1+Flashing Software\1+Infinity Box\CM2SPD\phdata\backup\m95 CX77xx_SPDNV.spdnv
Elapsed: 00:00:38
Loading    : M95 v1 by Nasir Mobiles.pac
CRVersion  : BP_R1.0.0
PacCPUinfo : SC77xx
PacVersion : M95 v1 by Nasir Mobiles
FastCheck  : 0x00537684CD
Loading files ...
File : Infinity_fdl1.bin
File : Infinity_fdl2.bin
File : nvitem_w.bin
File : nvitem_wcn.bin
File : prodnv.img
File : u-boot-spl-16k.bin
File : sc7731g_CP0_modem.bin
File : DSP_DM_Gx.bin
File : sc8830g_modem_CP2_WCN_14D_W15.16_Release.bin
File : logo_540x960.bin
File : fblogo_540x960.bin
File : boot.img
File : system.img
File : cache.img
File : recovery.img
File : userdata.img
File : u-boot.bin
File : SC77xx.xml
Load Ok!
Operation : Flash [ v1.25 ]
======= Flash
Files set for flashing :
[ MCU ] : M95 v1 by Nasir Mobiles.pac
PacCPUinfo : SC77xx
File : nvitem_w.bin
File : prodnv.img
File : boot.img
File : system.img
File : cache.img
File : recovery.img
File : userdata.img
File : u-boot.bin
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
PickUp loaders from pac
FDL Ready!
Boot Ver : Spreadtrum Boot Block version 1.1
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
[FL] : Enabled NVM update. Will program all NVM images found in FW !
PMTManager : Load 0x17 records
PMTManager : PMT Update Ok!
Flashing now
[FlashProc] : NVM Update
Current ID   : NV_W
Current Part : wfixnv1
[FlashProc] : Ok!
Current ID   : NV_WCN
Current Part : wcnfixnv1
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : PRODNV
Current File : prodnv.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : BOOTCODE
Current ID   : SPLLOADER
Current File : u-boot-spl-16k.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_W
Current File : sc7731g_CP0_modem.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : DSP_W
Current File : DSP_DM_Gx.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_WCN
Current File : sc8830g_modem_CP2_WCN_14D_W15.16_Release.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOTLOGO
Current File : logo_540x960.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : FASTBOOT_LOGO
Current File : fblogo_540x960.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOT
Current File : boot.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : SYSTEM
Current File : system.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : CACHE
Current File : cache.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : RECOVERY
Current File : recovery.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : USERDATA
Current File : userdata.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : ERASEUBOOT
Current Part : uboot
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : FLASH
Current Part : wruntimenv1
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : FLASH_WCN
Current Part : wcnruntimenv1
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : ERASEMISC
Current Part : misc
[FlashProc] : Ok!
Current ID   : UBOOTLOADER
Current File : u-boot.bin
Flashing now ...
[FlashProc] : Ok!
Elapsed: 00:04:46
Operation : Write NV [ v1.25 ]
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Write NVM Part #1 Ok!
Write NVM Part #2 Ok!
Clean DYNV
Elapsed: 00:00:22
Old 07-07-2017, 09:22   #43385 (permalink)
Member: 654997
Thanks Meter: 3,989
AGMobile AG Go Tab Access 2 read factory firmware / Reset FRP lock Done :)
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 93 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
eMMC Flash : 8801034E43617264202965260124533F
[eMMC] : FLASH_VEN : 0x88 , OEM : 0103
[eMMC] : FLASH_INF : [FORESEE] , draC
[eMMC] : FLASH_CID : 8801034E43617264202965260124533F
[eMMC] : FLASH_LEN : 0x00000001CE100000
[eMMC] : FLASH_UCP : 7393 MiB [eMMC 8 GiB]
DEV RID    : 0x2BFA537D0169E3D4AB2CAC4C774AEFB3
EXT RAM    : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand     : AG
ProdName  : AG_Go_Tab_Access_2
ProdModel : AG_Go_Tab_Access_2
Device    : AG_Go_Tab_Access_2
AndroidVer: 5.1
MTKxCPU   : MT6580
MTKxPRJ   : ALPS.L1.MP6.V2.48.1_JOYASZ8321.FEMMC_P7
Done!
Elapsed: 00:00:07
Operation : Read Flash [ v1.58 ]
Wait for phone...
Phone found! [ 93 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading Flash Content now ...
xGPT : Normalize settings Ok!
Brand     : AG
AndroidVer: 5.1
MTKxCPU   : MT6580
[Read Ok] : preloader_joyasz8321_femmc.bin
[Read Ok] : items.img
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : logo.bin
[Read Ok] : secro.img
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : userdata.img
[ScatCFG] : MT6580 / V1.1.2 / joyasz8321_femmc / EMMC
Android Info saved
MAUI Meta DB saved
HWConfig Info saved
FW Size : 1848 MiB
Scatter saved to : F:\backup files\MT6580__AG__AG_Go_Tab_Access_2__AG_Go_Tab_Access_2__5.1__ALPS.L1.MP6.V2.48.1_JOYASZ8321.FEMMC_P7\
All done!
Done!
Elapsed: 00:10:30
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 93 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:41
Old 07-07-2017, 09:33   #43386 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,164
Wiko Leany Black MT6572 logo Hang Recover Done By Great Infinity CM2
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A483447326111013EE7CDB2A275
[eMMC] : FLASH_CID : 90014A483447326111013EE7CDB2A275
DEV RID : 0xD9C8F3955CC696380D7E03C4619CD306
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:47
Old 07-07-2017, 10:59   #43387 (permalink)
Member: 654997
Thanks Meter: 3,989
QTab Q150 Write Factory Firmware Done :)
Wait for phone...
Phone found! [ 91 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x87
eMMC Flash : 8801034E436172642023D757335632CF
[eMMC] : FLASH_CID : 8801034E436172642023D757335632CF
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000
[eMMC] : FLASH_LEN : 0x00000000E7400000
[eMMC] : FLASH_UCP : 3700 MiB [eMMC 4 GiB]
DEV RID    : 0x2BFA537DDE8254C5EF47E52F37FF3885
SOC VERIFY : C1
Boot Ok!
Brand     : QTab
ProdName  : QTab_Q150
ProdModel : QTab Q150
Device    : QTab_Q150
AndroidVer: 4.4.2
MTKxCPU   : MT6582
MTKxPRJ   : ALPS.KK1.MP1.V2.11
Done!
Elapsed: 00:00:08
Chinese Miracle II  [MTK module] v 1.58
Scatter Load Ok , BaseBand : MT6582 , Project : qmobile82_7121 , Storage : EMMC
Files found : 13 , Set to Flash : 12
Ready to Flash!
======= Flash
Wait for phone...
Phone found! [ 91 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : qmobile82_7121 , Storage : EMMC
BL : Check eMMC compatibility
BL : Only one records found, and determined as universal
BL : BatteryLevel : 3653 mV
BL : BatteryLevel Ok
Erase : 0x0000000001400000-0x0000000000100000
Erase : 0x0000000003100000-0x00000000E3220000
Flash Pre-Erase Done, time used : 00:00:02
Sending Preloader ...
Use : preloader_qmobile82_7121.bin
Preloader Sent , Init passed
PartCount : 0014
Repartition Done!
Use FLN Mode
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EBR2
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash now : FAT
Image Flash Ok
Flash Write Done, time used : 00:01:51
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR2
Verify Passed : FAT
Data Verify Done, time used : 00:01:42
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:51
Old 07-07-2017, 11:03   #43388 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Chilli B38 Read Flash File Done
Operation : Read FullFlash [ v1.27 ]
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
Phone found! [ 26 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00C8 0060 0016 0000
[0] Flash VEN : GigaDevice , GD25LQ32
[0] Flash CAP : 00400000
Read Flash Content
Read Ok , collect info
Set FileInfo :
Model Vendor : CHILLI
Model Name : B38
ExtInfo Data : English
Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_GD 25LQ32_English__CHILLI-B38.bin
Done!
Elapsed: 00:00:40
Old 07-07-2017, 11:06   #43389 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Qmobile L9 Format And Read Flash File Done
Chinese Miracle II  [SPD module] v 1.27
Set mode to : SPD6531
Start  at : [06-Jul-17 / 7:08:45 PM]
3. Insert battery
Phone found! [ 26 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ver : Spreadtrum Boot Block version 1.2 Yť(Boot Ok
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:07
3. Insert battery
Phone found! [ 26 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ver : Spreadtrum Boot Block version 1.2     Boot Ok
Read Flash Content
Set FileInfo :
Model Vendor : Qmobile
Model Name   : L9
Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_GD25LQ32_English__Qmobile-L9.bin
Done!
Elapsed: 00:00:49
Old 07-07-2017, 11:08   #43390 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Qmobile Noir i4 .Pac FIle flashing Done
Operation : Flash [ v1.27 ]
======= Flash
[ MCU ] : QMobilei4_MP_20150721.pac
PacCPUinfo : SC7731_UMS
PacVersion : QMobilei4_MP_20150721
File : fdl1.bin
File : fdl2.bin
File : nvitem.bin
File : SC7702_sc7731g_band128.bin
File : DSP_DM_G2.bin
File : SC8800G_x30g_wcn_dts_modem.bin
File : boot.img
File : recovery.img
File : system.img
File : userdata.img
File : LOGO.bmp
File : charge.bmp
File : prodnv.img
File : cache.img
File : u-boot.bin
3. Insert cable
Phone found! [ 51 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x18 records
Flashing now
[FlashProc] : ERASE
[FlashProc] : Ok!
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current File : SC7702_sc7731g_band128.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : DSP_W
Current File : DSP_DM_G2.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current File : SC8800G_x30g_wcn_dts_modem.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOT
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : SYSTEM
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current File : LOGO.bmp
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current File : charge.bmp
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : FLASH
[FlashProc] : Ok!
[FlashProc] : ERASE
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : PRODNV
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : CACHE
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current Part : misc
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : ERASESD
Current Part : internalsd
[FlashProc] : Ok!
Flashing now ...
[FlashProc] : Ok!
Elapsed: 00:06:38
Old 07-07-2017, 11:11   #43391 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Samsung Clone G530 Format Done
Wait for phone...
Phone found! [ 19 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A2058494E594814020611001011
[eMMC] : FLASH_INF : [HYNIX] , HYNIX
[eMMC] : FLASH_CID : 90014A2058494E594814020611001011
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x000000008F800000
[eMMC] : FLASH_UCP : 2296 MiB [eMMC 4 GiB]
DEV RID : 0xE6C52A7D0B15942F6F63CEEE755E3E22
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:30
Old 07-07-2017, 12:44   #43392 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,389
Infinity-Box LG Service Module LGS v1.03
Successfully RECOVER HANG ON LOGO AND RESTART(LG-D380)USB
2. PRESS and HOLD VOLUME UP KEY!
3. Insert USB cable, wait until Download mode screen will appear
Wait for phone...
Connection opened successfully!
Waiting for loader ...
Handshake passed!
Collect info...
Prepare passed, mode 0x00
Boot done!
[INFO] : Low Battery level ignored by user request!
Loading firmware
Load ok!
Checking compatibility
Checking passed!
Prepare device
Prepare Passed!
Secure prepare skipped!
Start flashing device
Flash : PrimaryGPT_0.bin
Flash : modem_8192.bin
Flash : sbl1_139264.bin
Flash : rpm_141312.bin
Flash : tz_142336.bin
Flash : sdi_143360.bin
Flash : aboot_144384.bin
Flash : rpmb_148480.bin
Flash : tzb_149504.bin
Flash : abootb_150528.bin
Flash : persist_204800.bin
Flash : laf_270336.bin
Flash : boot_319488.bin
Flash : recovery_364544.bin
Flash : factory_475136.bin
Flash : sbl1b_581632.bin
Flash : cust_655360.bin
Flash : system_770048.bin
Flash : system_1036984.bin
Flash : system_1298352.bin
Flash : system_1561272.bin
Flash : system_1822640.bin
Flash : system_2085560.bin
Flash : system_2346928.bin
Flash : system_2609848.bin
Flash : system_2871216.bin
Flash : system_3134136.bin
Flash : system_3395504.bin
Flash : system_3653632.bin
Flash : system_3657648.bin
Flash : BackupGPT_7633920.bin
Processing Post-Flashing tune
Flash done!
Done!
Elapsed: 00:03:48
THANKS INFINITY-BOX TEAM
The Following User Says Thank You to gracy_elec For This Useful Post:
Old 07-07-2017, 12:44   #43393 (permalink)
Member: 1770631
Sonork: id
Thanks Meter: 85
WOW Vodafone Smart first 7(VFD 200) SPD ESILY UNLOCKED WITH CM2SPD...thanks team
Card found: S/N : 94473379 , v0136
Chinese Miracle II [SPD module] v 1.25
Set mode to : SP [SC8830] eMMC [Generic]
Operation : SP Unlock [ v1.25 ]
Mode : DirectUnlock
3. Insert cable
Phone found! [ 41 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
DS : Loader start failed! Wrong Model selection!
Boot failed!
Set mode to : SP [SC773x] eMMC [Android 5.x]
Mode : DirectUnlock
3. Insert cable
Phone found! [ 41 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC773x Android 5.x eMMC v1.0 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
SimLock state : Locked!
Unlocking ...
Unlock Done!
Elapsed: 00:00:36
The Following User Says Thank You to kumenger For This Useful Post:
Old 07-07-2017, 14:33   #43394 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,389
Infinity-Box Chinese Miracle-2 MTK/Mediatek v1.58
Successfully REPAIR POPUP ADDS PROBLEM(SPICE XLIFE 5PLUS)USB
Wait for phone...
Phone found! [ 14 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : A80111303546534D4110000004371399
[WARNING] : MEMORY_eMMC_VALIDATE_FAILED
[eMMC] : FLASH_VEN : 0xA8 , OEM : 0111
[eMMC] : FLASH_INF : [NOT_IN_BASE] , AMSF5
[eMMC] : FLASH_CID : A80111303546534D4110000004371399
[eMMC] : FLASH_LEN : 0x00000001BB400000
[eMMC] : FLASH_UCP : 7092 MiB [eMMC 8 GiB]
DEV RID : 0xFD096D45FC8D563D1508D1D4F38717A7
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:29
Wait for phone...
Phone found! [ 14 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
SmartAV Init Ok!
Scanning FileSystem now , please wait
Scan Done, infected files found : 1
Removing infected files and scripts ...
SmartAV Report : Removed 1 infected files!
Making additional operations ...
Special Op #1 : Clear Recovery Data Ok!
Special Op #2 : Clear UserData Ok!
Special Op #3 : PostFix Ok!
Done!
Done!
Elapsed: 00:00:38
Old 07-07-2017, 18:56   #43395 (permalink)
Member: 941008
Frp SOLONE COSY S4002
Modulo spd
Cpu s773x EMMC Android 6.0
3. Insert cable
Phone found! [ 79 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:32
Finish at : [05/07/2017 / 07:28:00 p.m.]
The Following User Says Thank You to CESETEMTI For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.89781 seconds with 9 queries
