07-12-2017, 13:29 | #43501 (permalink) |
No Life Poster Join Date: Jul 2011 Location: malawi
Member: 1614640 Status: Offline Thanks Meter: 468 | Card found : S/N : xxxxxxxxx , v0135 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 40 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from IDB! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41X [eMMC] : FLASH_CID : 150100525831344D42079790D4E01431 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0xD2FF4FA435EB64C3A58B79F282077F89 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! [AP] : Initial info read Ok! Brand : OPPO ProdName : A59 ProdModel : OPPO A59s Device : A59 AndroidVer: 5.1 MTKxCPU : MT6755 MTKxPRJ : A59s_11_A.06_161227 EXTRA : LCD : Not info available LCD Res : M_HEIGHT=1280xM_WIDTH=720 TOUCH [0] : STOM_KERNEL_TOUCHPANEL=GT1XX CAM [0] : STOM_HAL_IMGSENSOR=s5k3l8_mipi_raw CAM [1] : imx258_mipi_raw CAM [2] : ov8865_mipi_raw CAM [3] : s5k3p3sp_mipi_raw MODEM : oppo6750_ca001_lwctg_c2k Done! Elapsed: 00:00:25 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 40 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from IDB! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM41X [eMMC] : FLASH_CID : 150100525831344D42079790D4E01431 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0xD2FF4FA435EB64C3A58B79F282077F89 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! Reading Flash Content now ... USBDL : Init HSUSB Ok! xGPT : Normalize settings Ok! Brand : OPPO ProdName : A59 ProdModel : OPPO A59s Device : A59 AndroidVer: 5.1 MTKxCPU : MT6755 MTKxPRJ : A59s_11_A.06_161227 [Read Ok] : preloader_oppo6750_15131.bin [Read Ok] : recovery.img [Read Ok] : md1img.img [Read Ok] : md1dsp.img [Read Ok] : md1arm7.img [Read Ok] : md3img.img [Read Ok] : lk.bin [Read Ok] : lk2.bin [Read Ok] : boot.img [Read Ok] : logo.bin [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6755 / V1.1.2 / oppo6750_15131 / EMMC Android Info saved HWConfig Info saved FW Size : 1933 MiB Scatter saved to : D:\chinese flash files\infinity box\mtk\Oppo\MT6755__OPPO__OPPO_A59s__A59__5.1__A5 9s_11_A.06_161227\ All done! Done! Elapsed: 00:09:06 Reconnect Power/Cable! |
The Following User Says Thank You to bright hlatini For This Useful Post: |
07-12-2017, 13:54 | #43502 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Mmx e455 fs frp read firmware done with cm2qlm:- READ INFO Code: Operation : Identify 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 415 [MSM8929] ID_BLOCK_S : 03B9FEA0 ID_BLOCK_I : 0091B0E1 ID_BLOCK_L : 25DFB541EC7A67625D32C2C30C57DFEF ID_BLOCK_L : 90E3ADFCF160CA5B7EB912CBD9D4C209 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8929 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Brand : Micromax ProdName : E455 ProdModel : Micromax E455 Device : E455 AndroidVer: 5.0.2 Manufact. : Micromax QLMxCPU : MSM8916 Done! Elapsed: 00:00:42 Reconnect Power/Cable! FORMAT FS Code: Operation : Reset Settings 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 415 [MSM8929] ID_BLOCK_S : 03B9FEA0 ID_BLOCK_I : 0091B0E1 ID_BLOCK_L : 25DFB541EC7A67625D32C2C30C57DFEF ID_BLOCK_L : 90E3ADFCF160CA5B7EB912CBD9D4C209 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8929 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP ( Google Reset Protection ) FRP removed! Done! Elapsed: 00:00:16 Reconnect Power/Cable! Code: Operation : Read Flash 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 415 [MSM8929] ID_BLOCK_S : 03B9FEA0 ID_BLOCK_I : 0091B0E1 ID_BLOCK_L : 25DFB541EC7A67625D32C2C30C57DFEF ID_BLOCK_L : 90E3ADFCF160CA5B7EB912CBD9D4C209 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8929 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000 Boot Ok! Brand : Micromax ProdName : E455 ProdModel : Micromax E455 Device : E455 AndroidVer: 5.0.2 Manufact. : Micromax QLMxCPU : MSM8916 DevInfo : MSM8916__Micromax__Micromax__ANDR_v5.0.2__Micromax_E455__E455__E455 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : sbl1.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : hyp.mbn [Read Ok] : misc.img [Read Ok] : splash.img [Read Ok] : ddr.bin [Read Ok] : NON-HLOS.bin [Read Ok] : fs_gc.img [Read Ok] : sec.dat [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : persist.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8929 / eMMC Firmware Size : 1801 MiB Done! Elapsed: 00:03:34 Reconnect Power/Cable! WBR sahil2000ind |
The Following User Says Thank You to sahil2000ind For This Useful Post: |
07-12-2017, 14:20 | #43503 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | Qmobile Noir X700i Privacy Lock Removed Operation : Reset Privacy Lock [ v1.58 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 233 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100523832314D4200D03ED0FE7245 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM128 [eMMC] : FLASH_CID : 150100523832314D4200D03ED0FE7245 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xB634BF4A12FCA06D5FF3B8E7660D569C INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Process block #1 Process block #2 Privacy Lock reset Ok! Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
The Following User Says Thank You to Nasir Mobiles For This Useful Post: |
07-12-2017, 14:35 | #43504 (permalink) |
Freak Poster Join Date: Jan 2016 Location: punjab pakistan Age: 34
Member: 2510895 Status: Offline Sonork: 100.1668345 Thanks Meter: 319 | Lenovo_A6010 MSM8916 FRP REMOVE DONE... mozair33 |
The Following 2 Users Say Thank You to mozair33 For This Useful Post: |
07-12-2017, 14:46 | #43505 (permalink) |
Member: 2510895 Status: Offline Sonork: 100.1668345 Thanks Meter: 319 | QMobile_J5_6.0 MT6737T FRP REMOVE DONE... mozair33 |
The Following User Says Thank You to mozair33 For This Useful Post: |
07-12-2017, 14:55 | #43506 (permalink) |
Freak Poster Join Date: Aug 2016 Location: out of world
Member: 2609423 Status: Offline Sonork: 1660954:2007 Thanks Meter: 360 | OnePlus3 firmware read done Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.13 Operation : Read Flash [ v1.13 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 821 [MSM8996 Pro] ID_BLOCK_S : AAA2CD57 ID_BLOCK_I : 0005F0E1 ID_BLOCK_E : 2A703DB9 ID_BLOCK_L : 6063F3872A48B996DCCBF417FAAB960F ID_BLOCK_L : 1324F1C4FFD8A38D0CE6706A227AF73B Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8996 , FLASH : UFS , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00001000 UFS Device : SAMSUNG KLUCG4J1CB-B0B1 0800 UFS SectSize : 0x1000 UFS LU0 Size : 0x00000007602F0000 : 29.50 GiB --------------UFS Device Info-------------- UFS Total Active LU: 0x6 UFS wManufacturerID: 0x1ce UFS Boot Partition Enabled: 0x1 UFS LU Write Protect: 0x0 UFS Boot LUN ID: = 0x0 UFS Memory Type: 0x0 UFS LU Total Blocks: 0x0 UFS Supported Memory Types: 0x800f UFS LUN Enable Bitmask: 0x3f UFS bConfigDescrLock: 0x0 Boot Ok! Brand : OnePlus Device : OnePlus3 AndroidVer: 7.1.1 SWVersion : OnePlus3TOxygen_28.A.54_GLO_054_1706101907 Manufact. : OnePlus QLMxCPU : MSM8996 DevInfo : MSM8996__OnePlus__OnePlus__ANDR_v7.1.1__OnePlus3__ OnePlus3TOxygen_28.A.54_GLO_054_1706101907 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : persist.img [Read Ok] : cache.img [Read Ok] : misc.img [Read Ok] : devcfg.mbn [Read Ok] : pnvbak.img [Read Ok] : param.cfg [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin [Read Ok] : gpt_main1.bin [Read Ok] : xbl.elf [Read Ok] : gpt_backup1.bin [Read Ok] : gpt_main2.bin [Read Ok] : gpt_backup2.bin [Read Ok] : gpt_main3.bin [Read Ok] : ddr.bin [Read Ok] : gpt_backup3.bin [Read Ok] : gpt_main4.bin [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : hyp.mbn [Read Ok] : sec.dat [Read Ok] : pmic.bin [Read Ok] : NON-HLOS.bin [Read Ok] : adspso.bin [Read Ok] : mdtp.img [Read Ok] : emmc_appsboot.mbn [Read Ok] : lsplash.img [Read Ok] : boot.img [Read Ok] : boot_ag.img [Read Ok] : system.img [Read Ok] : recovery.img [Read Ok] : btfm.mbn [Read Ok] : keymaster.mbn [Read Ok] : cmnlib.mbn [Read Ok] : cmnlib64.mbn [Read Ok] : ap.mbn [Read Ok] : gpt_backup4.bin [Read Ok] : gpt_main5.bin [Read Ok] : md5.img [Read Ok] : gpt_backup5.bin Android Info saved! Read finished! Configuration : MSM8996 / UFS Firmware Size : 3338 MiB Done! Elapsed: 00:02:53 Reconnect Power/Cable! |
The Following User Says Thank You to applebricks For This Useful Post: |
07-12-2017, 15:14 | #43507 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Qmobile 3G5 Format Done Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 129 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6276 BB_CPU_HW : CB00 BB_CPU_SW : 0101 BB_CPU_SB : 8A00 BB_CPU_NM : [MediaTek] MT6276_S0000 BROM Protocol Version : FF Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x80 SOC_VERIFY : 0xC1 BOOT_STYLE : NAND_FLASH_BOOT NAND Flash IC initialized FLASH_VEN : 0x0076 , [MXIC] MX63U1GD12EAXNI00 FLASH_DIE0 : 00C2 00B1 0080 0055 FLASH_DIE1 : 0002 0000 0000 0000 FLASH_LEN : 0x08000000 INT_RAM : 0x00015000 EXT_RAM : 0x04000000 Executing FFS FORMAT now... FAT_RANGE : 0x05000000-0x07EFFFFF , LEN : 0x02F00000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE NAND Status : 5A000000 / 5A000000 / 5A000000 / 5A000000 Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to Akhtar Ali Jatt For This Useful Post: |
07-12-2017, 15:33 | #43508 (permalink) |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | nokia 3 read ff and format done Code: Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 74 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 4400014531303446472C013697E082A3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , 6104F [eMMC] : FLASH_CID : 450100444634303136012C47A382C397 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0xC1F94A5C53248C30AE2DEE52B6349C9F INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Unknown ProdName : Unknown ProdModel : Heart Device : Unknown AndroidVer: 7.0 MTKxCPU : MT6737M MTKxPRJ : alps-mp-n0.mp1-V1.0.2_fih6737m.35.n_P96 SECURITY : IMEI_SW [1] : 35727708017---- IMEI_SW [2] : 35727708017---- BTMAC Addr : CC9F7A7E5404 WiFi MAC : CC9F7A7E5405 Done! Elapsed: 00:00:09 Reconnect Power/Cable! Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 74 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 4400014531303446472C013697E082A3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , 6104F [eMMC] : FLASH_CID : 450100444634303136012C47A382C397 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0xC1F94A5C53248C30AE2DEE52B6349C9F INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... [Error] : Bad Magic! Encrypted FS! [Info] : DP Lock not set! Done! Elapsed: 00:00:13 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 74 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 4400014531303446472C013697E082A3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , 6104F [eMMC] : FLASH_CID : 450100444634303136012C47A382C397 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0xC1F94A5C53248C30AE2DEE52B6349C9F INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:52 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 60 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 4400014531303446472C013697E082A3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , 6104F [eMMC] : FLASH_CID : 450100444634303136012C47A382C397 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0xC1F94A5C53248C30AE2DEE52B6349C9F INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : Unknown ProdName : Unknown ProdModel : Heart Device : Unknown AndroidVer: 7.0 MTKxCPU : MT6737M MTKxPRJ : alps-mp-n0.mp1-V1.0.2_fih6737m.35.n_P96 [Read Ok] : preloader_ne1.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : box.img [Read Ok] : sys_info.img [Read Ok] : cda.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6737M / V1.1.2 / ne1 / EMMC Android Info saved HWConfig Info saved FW Size : 4269 MiB Scatter saved to : W:\nokia\nokia 3\MT6737M__Unknown__Heart__Unknown__7.0__alps-mp-n0.mp1-V1.0.2_fih6737m.35.n_P96\ All done! Done! Elapsed: 00:12:06 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to rehmani For This Useful Post: |
07-12-2017, 16:07 | #43509 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | Infinity-Box Chinese Miracle-2 MTK/Mediatek v1.58 Successfully REPAIR FIX DL MODE (LENOVO P1MA40)USB 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 34 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 520001154D31323877AD00420B8C30C6 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM128 [eMMC] : FLASH_CID : 150100523832314D4200AD77C630C20B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xFD096D45DEBF122E763AB1A2DAA0B4B8 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! DA DLFix Passed! Done! Elapsed: 00:00:07 Reconnect Power/Cable! THANKS INFINITY-BOX TEAM |
The Following User Says Thank You to gracy_elec For This Useful Post: |
07-12-2017, 17:24 | #43510 (permalink) |
Member: 1614640 Status: Offline Thanks Meter: 468 | MOBICEL RETRO READ PATTERN DONE Card found : S/N : xxxxxxxx , v0135 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 38 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040502A11F2981B7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040502A11F2981B7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD2FF4FA43C980A8BED6E0AECE6379B32 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Mobicel ProdName : Retro ProdModel : Retro Device : Retro AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP6.V1 SECURITY : IMEI_SW [1] : 355xxxxxxxxx BTMAC Addr : D83C698AC905 WiFi MAC : D83C698A514B MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V36_1_wg_n EXTRA : LCD [0] : hx8357d LCD [1] : ili9488 LCD Res : 480x320 TOUCH [0] : ektf2k CAM [0] : hi257_yuv CAM [1] : sp0a19_yuv CAM [2] : sp0a18_yuv CAM [3] : gc0329_yuv CAM [4] : sp2519_yuv MODEM : mt6572_s3511a_hspa_gemini LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB ur_PK fa_IR Done! Elapsed: 00:00:13 Reconnect Power/Cable! Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 38 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040502A11F2981B7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040502A11F2981B7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD2FF4FA43C980A8BED6E0AECE6379B32 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... Get Locks ... PatternLock Sequnce : 15746 Done! Elapsed: 00:00:39 Reconnect Power/Cable! |
07-13-2017, 07:03 | #43511 (permalink) |
No Life Poster Join Date: Aug 2009 Location: madhya pradesh
Member: 1091455 Status: Offline Sonork: qq 2250871952 Thanks Meter: 769 | Oppo f1s 1601 patan read job done Oppo f1s 1601 patan read job done cm2 Wasim mansuri Gsm expert engineers tem... Sent from my Redmi 3S using Tapatalk |
The Following 2 Users Say Thank You to wasim786mansure For This Useful Post: |
07-13-2017, 07:58 | #43512 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile E4 MT625A Read Coad done with great infinity cm2 Operation : Read UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 20 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0000 BB_CPU_SN : 1BF02ABCBA027CD6553C87ADFC40243B BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 INT_RAM : 0x0000D400 EXT_RAM : 0x00400000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 2580 PLock|MobTrack : Not active Done! Elapsed: 00:00:08 Reconnect Power/Cable! |
The Following User Says Thank You to azhergoga007 For This Useful Post: |
07-13-2017, 08:08 | #43513 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile Gold One SPD6531 Logo Stuck Recover By FOrmate With Infinity CM2 Set mode to : SPD6531 Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:10 Reconnect Power/Cable! |
07-13-2017, 08:09 | #43514 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile A55 MT6572 Virus Error Remove By Flashing With Great Infinity CM2 Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 62 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E35575A4D4201DAF141F2B045 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x20000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D4201DAF141F2B045 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F3959B8EB608794C1D290DE2FB2C INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : gionee72_wet_jb3 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3778 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000600000-0x0000000000100000 Erase : 0x0000000002300000-0x00000000E5C80000 Flash Pre-Erase Done, time used : 00:00:02 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0015 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : SPDATA Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash now : FAT Image Flash Ok Flash Write Done, time used : 00:03:56 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : SPDATA Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Verify Passed : FAT Data Verify Done, time used : 00:00:39 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:04:58 Reconnect Power/Cable! |
07-13-2017, 08:10 | #43515 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Samsung Clone G530H MT6572 Blue Screen Only Recover Done By Flashing With Infinity CM 1- First Rite Only Prloder Phone found! [ 62 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E355530304D0831C2C228A0F7 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x20000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , M00U5 [eMMC] : FLASH_CID : 1501004E355530304D0831C2C228A0F7 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F39502CD1E6163A3C7E9EF1ED9E5 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SecCfg Passed , 1799 BL : BBID supported by BootLoader! Supported HW by Preloader : FlashID [0] CID : 1501004E355530304D , Name : N5U00M , Vendor : 15 , [SAMSUNG] FlashID [1] CID : 90014A2058494E5948 , Name : XINYH , Vendor : 90 , [HYNIX] FlashID [2] CID : 1501004E4A5330304D , Name : NJS00M , Vendor : 15 , [SAMSUNG] FlashID [3] CID : 110100303034473930 , Name : 004G90 , Vendor : 11 , [TOSHIBA] FlashID [4] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX] FlashID [5] CID : 7001004D4D43303447 , Name : MMC04G , Vendor : 70 , [KINGSTON] FlashID [6] CID : 7001004D4D43303447 , Name : MMC04G , Vendor : 70 , [KINGSTON] FlashID [7] CID : 1501004E35575A4D42 , Name : N5WZMB , Vendor : 15 , [SAMSUNG] FlashID [8] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX] FlashID [9] CID : 45010053454D303447 , Name : SEM04G , Vendor : 45 , [SANDISK] FlashID [10] CID : 1501004B355530304D , Name : K5U00M , Vendor : 15 , [SAMSUNG] FlashID [11] CID : 1501004B4A5330304D , Name : KJS00M , Vendor : 15 , [SAMSUNG] BL : Storage supported by BootLoader! Sending BootLoader ... Preloader Sent , Init passed SecCfg Passed , 1799 PartTable Init Ok , Count : 14 All Done Done! Elapsed: 00:00:14 Reconnect Power/Cable! 2- Flash Done Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E355530304D0831C2C228A0F7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , M00U5 [eMMC] : FLASH_CID : 1501004E355530304D0831C2C228A0F7 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F39502CD1E6163A3C7E9EF1ED9E5 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : keytak72_cwet_lca , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3934 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001400000-0x0000000000100000 Erase : 0x0000000003100000-0x00000000E4E20000 Flash Pre-Erase Done, time used : 00:00:00 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_keytak72_cwet_lca.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:01:50 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:03 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:02:08 Reconnect Power/Cable! |
