Old 07-16-2017, 15:48   #43576 (permalink)
rehmani's Avatar
Member: 333199
Sonork: may i help u just pm me
Thanks Meter: 2,390
mi2016100 format done
Operation : Reset Settings [ v1.14 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 625 [MSM8953]
ID_BLOCK_S : C44E1E1A
ID_BLOCK_I : 000460E1
ID_BLOCK_L : 347DEECC7077B9FC95EF792CA012EAED
ID_BLOCK_L : 16E69C3BFADDF525D2B56E5926905C01
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ]
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RX1BMB
Boot Ok!
MIAccount reset passed!
Normal reset :
> Select "FORCED FIX" or "REPAIR"  in FMT settings, press "Format FS / Reset Settings"
> PowerOn device and use. IF Device stuck on black screen with cable - use another FMT
> Not all devices supported yet! (tested on Hydrogen,Land,Redmi2)
Done!
Elapsed: 00:00:36
Reconnect Power/Cable!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:16
The Following User Says Thank You to rehmani For This Useful Post:
Old 07-16-2017, 15:49   #43577 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,390
lyf ls5009 format done
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.14
Operation : Identify [ v1.14 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 210 [MSM8x09]
ID_BLOCK_S : 04211BAA
ID_BLOCK_I : 009600E1
ID_BLOCK_L : 3FC9A35BFA606D98473CD439065DD5F5
ID_BLOCK_L : F88B35949908B233D6216AA3A14C5A61
Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ]
Boot Ok!
Brand     : LYF
ProdName  : LS-5009
ProdModel : LS-5009
Device    : msm8909
AndroidVer: 5.1.1
Manufact. : LYF
SysPatch  : LMY47V
QLMxCPU   : MSM8909
QLMxPRJ   : LYF_LS-5009_00_224_170217
Done!
Elapsed: 00:00:11
Wait for phone...
Device not found!
Check cable, connection and drivers!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:22
Old 07-16-2017, 15:57   #43578 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,390
lenovo a319 flash done
Chinese Miracle II  [MTK module] v 1.56
Operation : HW Test [ v1.56 ]
Wait for phone...
Phone found! [ 73 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A48344732611101BBE0926A727F
Initialize Memory ...
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x20000000
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , a2G4
[eMMC] : FLASH_CID : 90014A48344732611101BBE0926A727F
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID    : 0xC1F94A5C7535A807151003A87A2F2919
INT RAM    : 0x00020000
EXT RAM    : 0x20000000 [512 MiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[Processing] FlashMemory Read-Write test
[eMMC] : [HYNIX] , a2G4 , 0xE9000000 , 3728 MiB
[eMMC] : CID : 90014A48344732611101BBE0926A727F
[eMMC] : MODE : SQ-WR
[PASSED] : eMMC RW Check #1 Ok!
[eMMC] : MODE : RA-WR
[PASSED] : eMMC RW Check #2 Ok!
[eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed!
All Done!
Done!
Elapsed: 00:00:38
Scatter Load Ok , BaseBand : MT6572 , Project : huaqin72_cwet_1a_kk , Storage : EMMC
Files found : 11 , Set to Flash : 10
Ready to Flash!
Operation : Flash [ v1.56 ]
======= Flash
Wait for phone...
Phone found! [ 73 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer   : 0x0005
BLVersion : 0x00FE
Processing DA stage
DRAM configured from ScatFW!
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : huaqin72_cwet_1a_kk , Storage : EMMC
Setting : AFF verify :  Disabled
Setting : HW verify :  Enabled
Switching to HSUSB
HSUSB Init Ok
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3834 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x0000000094840000
Flash Pre-Erase Done, time used : 00:00:02
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_huaqin72_cwet_1a_kk.bin
Preloader Sent , Init passed
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:04:17
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:04:39
Old 07-16-2017, 16:00   #43579 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,390
videocon z q star flash done
Chinese Miracle II  [SPD module] v 1.27
Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0]
Infinity SC Firmware Detected
FW Size : 562 MiB
Load Ok!
File Info
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand   : Videocon
Device Model   : scx35_sp7731gea
Device CPU     : sp7731gea
Device IntName : scx35_sp7731gea_dt_MM5029A04_Videocon
Device Version : 4.4.2
Device Compile : 12/31/2014 1:56:49 AM
Device Project : Videocon_Z40QStar_V1.1.2_31-12-2014
Device ExtInfo : Z40QStar
Operation : Check/Read Info [ v1.27 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
 -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
 ====  Wait for phone...
Device boot not done
Check Drivers
Try again
3. Insert cable
Phone found! [ 31 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC773x Android 5.x eMMC v1.0 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name  : scx35_sp7731gea_dt_MM5029A04_Videocon
Model Brand : Videocon
Model Device: scx35_sp7731gea
AndrVersion : 4.4.2
BaseBand CPU: SP7731GEA
CompileDate : 12/31/2014 1:56:49 AM
Project Ver : Videocon_Z40QStar_V1.1.2_31-12-2014
Model Ext   : Z40QStar
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:26
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : SC77xx Infinity Package
3. Insert cable
Phone found! [ 31 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x18 records
PMTManager : PMT Update Ok!
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write FSImage : prodnv.img
Write Data ...
Write Data Ok!
Write CodeData : sc7731g_CP0_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Write CodeData : sc7731g_modem_CP2_WCN_14E_W14.50_Release.bin
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Write CodeData : logo_480x800.bin
Write Data ...
Write Data Ok!
Write CodeData : fblogo_480x800.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system.img
Write Data ...
Write Data Ok!
Write FSImage : cache.img
Write Data ...
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Erase Block : MISC
Erase block ...
Block erase Ok!
Write FSImage : userdata.img
Write Data ...
Write Data Ok!
Erase Block : INTERNALSD
Erase block ...
Block erase Ok!
Elapsed: 00:07:42
Old 07-16-2017, 16:09   #43580 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,390
lenovo a3500 hv av done
Operation : Check / Read Info [ v1.56 ]
Wait for phone...
Phone found! [ 74 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x87
eMMC Flash : 1501004B3858564D420176C3C81371F3
[eMMC] : FLASH_INF : [SAMSUNG] , BMVX8
[eMMC] : FLASH_CID : 1501004B3858564D420176C3C81371F3
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID    : 0xC1F94A5C29674B3CD948841B44ECC568
EXT RAM    : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand     : Lenovo
ProdName  : A3500-HV
ProdModel : Lenovo A3500-HV
Device    : A3500HV
AndroidVer: 4.4.2
MTKxCPU   : MT6582
MTKxPRJ   : ALPS.KK1.MP1.V2.10
SECURITY :
IMEI_SW [1] : 86538102383----
BTMAC Addr  : 70720D719D6F
WiFi MAC    : 70720D889D6F
MODEM :
BaseBand  : MT6582_S00_MOLY_WR8_W1315_MD_WG_MP_V34_P6_1_wg_n
Done!
Elapsed: 00:00:12
Operation : Read Flash [ v1.56 ]
Wait for phone...
Phone found! [ 74 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading Flash Content now ...
Brand     : Lenovo
ProdName  : A3500-HV
Device    : A3500HV
AndroidVer: 4.4.2
MTKxCPU   : MT6582
[Read Ok] : preloader_lcsh82_tb_3gfull_kk.bin
[Read Ok] : MBR
[Read Ok] : EBR1
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : secro.img
[Read Ok] : logo.bin
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : userdata.img
[ScatCFG] : MT6582 / V1.1.1 / lcsh82_tb_3gfull_kk / EMMC
Android Info saved
MAUI Meta DB saved
HWConfig Info saved
FW Size : 1249 MiB
Scatter saved to : P:\tablet\lenovo\a3500 hv\MT6582__Lenovo__Lenovo_A3500-HV__A3500HV__4.4.2__ALPS.KK1.MP1.V2.10\
All done!
Done!
Elapsed: 00:06:17
Operation : Remove Viruses [SmartAV] [ v1.56 ]
SmartAV Conf : 100/80/2000
Wait for phone...
Phone found! [ 74 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
SmartAV Init Ok!
Scanning FileSystem now , please wait
Scan Done, infected files found : 2
Removing infected files and scripts ...
SmartAV Report : Removed 2 infected files!
Making additional operations ...
Special Op #1 : Clear Recovery Data Ok!
Special Op #3 : PostFix Ok!
Done!
Done!
Elapsed: 00:02:44
Operation : Format FileSystem [ v1.56 ]
Wait for phone...
Phone found! [ 74 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:01:52
Old 07-16-2017, 16:10   #43581 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,390
mi2014811 format done
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 08E02654
ID_BLOCK_I : 007050E1
ID_BLOCK_L : 5193C935A00E3B3611468E97502BABA3
ID_BLOCK_L : BBCA74D7D84BF370956035E2E00F1922
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Brand     : Xiaomi
ProdName  : 2014811
ProdModel : 2014811
Device    : HM2014811
AndroidVer: 4.4.4
Manufact. : Xiaomi
SysPatch  : KTU84P
QLMxCPU   : MSM8916
Done!
Elapsed: 00:00:11
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Normal reset :
Done!
Elapsed: 00:00:16
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:13
Old 07-16-2017, 16:25   #43582 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 3,975
Haier-JS-500 Jazz Write Factory Firmware Done :)
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 91 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A483447326111017B6A343AA231
[eMMC] : FLASH_CID : 90014A483447326111017B6A343AA231
DEV RID    : 0x2BFA537D0CFC225C4E4EE2A304337E13
SOC VERIFY : C1
Boot Ok!
Brand     : Haier-JS-500
ProdName  : hct72_cwet_kk
ProdModel : JS 500
Device    : hct72_cwet_kk
AndroidVer: 4.4.2
MTKxCPU   : MT6572
MTKxPRJ   : HM-JS-500-H01-S007-PK
Done!
Elapsed: 00:00:13
Scatter Load Ok , BaseBand : MT6572 , Project : hct72_cwet_kk , Storage : EMMC
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 91 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : hct72_cwet_kk , Storage : EMMC
Setting : AFF verify :  Enabled
BL : BatteryLevel : 3656 mV
Erase : 0x0000000001400000-0x0000000000100000
Erase : 0x0000000003100000-0x0000000094840000
Flash Pre-Erase Done, time used : 00:00:07
Use : preloader_hct72_cwet_kk.bin
PartCount : 0013
Repartition Done!
Use FLN Mode
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:32
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:15
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:14
The Following User Says Thank You to syed tuqeer For This Useful Post:
Old 07-16-2017, 17:25   #43583 (permalink)
sky73's Avatar
Member: 1876736
Thanks Meter: 360
lg g4 reset frp done
Operation : Reset Settings/Format FS [ v1.03 ]
2. PRESS and HOLD VOLUME UP KEY!
3. Insert USB cable, wait until Download mode screen will appear
Wait for phone...
Connection opened successfully!
Waiting for loader ...
Handshake passed!
Collect info...
Prepare passed, mode 0x00
Boot done!
Format UserData
Format Cache
Format done
Erase FRP#1 block Ok!
Done!
Elapsed: 00:00:37
The Following User Says Thank You to sky73 For This Useful Post:
Old 07-16-2017, 17:44   #43584 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,112
Qmobile X2 MT6571 Low Memory Recover Done Only Formate With Infinity CM2
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 26 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6571
BB_CPU_NME : [MediaTek] MT6571_S00
BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x8B
NAND Flash : 009800BC009000660076001600080000
eMMC Flash : NOT INSTALLED
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1
[NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008
[NAND] : FLASH_LEN : 0x20000000
[NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1
DEV RID : 0xD9C8F3952846265A8067E905B90A65BE
EXT RAM : 0x10000000 [256 MiB]
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:14
The Following User Says Thank You to azhergoga007 For This Useful Post:
Old 07-16-2017, 17:54   #43585 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,112
Qmobile A910 MT6582 Dead Set Re Alive DOne By Flashing With Infinity CM2
======= Flash
Wait for phone...
Phone found! [ 41 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A4834473164048601A3295041DB
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164048601A3295041DB
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : 0xD9C8F39570F4B53576E8FE280268F636
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : s8513a , Storage : EMMC
BL : BatteryLevel : 3753 mV
Erase : 0x0000000003100000-0x00000000E3000000
Flash Pre-Erase Done, time used : 00:00:00
Use : preloader_s8513a.bin
PartCount : 0014
Repartition Done!
Use FLN Mode
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EBR2
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash now : FAT
Image Flash Ok
Flash Write Done, time used : 00:04:47
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR2
Verify Passed : FAT
Data Verify Done, time used : 00:00:52
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:05:55
Old 07-17-2017, 07:13   #43586 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,112
Qmobile X25 Logo Stuck Recover By Formte WIth King Infinity CM2
Wait for phone...
Phone found! [ 26 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A4834473164040502A10A159175
[eMMC] : FLASH_CID : 90014A4834473164040502A10A159175
DEV RID : 0xD9C8F395FF87ACC122075EE361E242D7
SOC VERIFY : C1
Boot Ok!
Brand : QMobile
ProdName : X25
ProdModel : QMobile X25
Device : X25
AndroidVer: 4.4.2
MTKxCPU : MT6572
MTKxPRJ : ALPS.KK1.MP6.V1
SECURITY :
IMEI_SW [1] : 355794060661831
IMEI_SW [2] : 355794065661836
BTMAC Addr : D83C6963314F
WiFi MAC : D83C69638131
MODEM :
BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V36_1_wg_n
EXTRA :
LCD [0] : ili9806e_wvga_dsi_vdo_txd
LCD [1] : ili9806e_wvga_dsi_vdo_tkc
LCD Res : 800x480
TOUCH [0] : ektf2k_6041
CAM [0] : sp0a18_yuv
CAM [1] : sp2519_yuv
CAM [2] : sp0a19_yuv
CAM [3] : hi257_yuv
MODEM : mt6572_s4011_hspa_gemini_gms4_b1b8
LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB ur_PK fa_IR hdpi
Done!
Elapsed: 00:00:09
Wait for phone...
Phone found! [ 26 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:28
Old 07-17-2017, 07:15   #43587 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,112
Qmobile X11 low Memory Done Only Formate With King Infinity CM2
Wait for phone...
Phone found! [ 26 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A483447316404050CA23A7FC1D7
[eMMC] : FLASH_CID : 90014A483447316404050CA23A7FC1D7
DEV RID : 0xD9C8F395368DFC3857081AD4041F714B
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:29
Old 07-17-2017, 07:34   #43588 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,112
Qmobile E4 Classic Logo Resetert Promelam Solve Only Formate With Infinity CM2
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 20 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : B7892B76D608505746DB60FD999FD599
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32
[0] : FLASH_DIE : 00C8 0060 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Backup done
Executing FFS FORMAT now...
FAT_RANGE : 0x003C3000-0x003FDFFF , LEN : 0x0003B000
DA_RET : DA_IN_PROGRESS
DA_RET : FORMAT_DONE
Done!
Elapsed: 00:00:12
Old 07-17-2017, 07:40   #43589 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,112
Gfive G6 Plus Pattren Read Done With King Infinity CM2
Operation : Read Pattern/DP Lock [ v1.58 ]
Wait for phone...
Phone found! [ 26 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A4838473264040500A2CEC42265
[eMMC] : FLASH_INF : [HYNIX] , d2G8
[eMMC] : FLASH_CID : 90014A4838473264040500A2CEC42265
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xD9C8F395E11EA6A5A41FE9F0920567EE
SOC VERIFY : C1
Boot Ok!
Reading data ...
Get Locks ...
PatternLock Sequnce : 3568
Done!
Elapsed: 00:00:16
Old 07-17-2017, 08:45   #43590 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,112
Qmobile X30 MT6572 Dead Set Recover Done By Flashing With Infinity CM2
======= Flash
Wait for phone...
Phone found! [ 41 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A48344732611101C48822C32267
[eMMC] : FLASH_CID : 90014A48344732611101C48822C32267
DEV RID : 0xD9C8F3954B2DFC83F0B18FA9D5AAAB5A
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC
BL : Skip checking by User request!
BL : BatteryLevel : 4043 mV
Erase : 0x0000000002900000-0x00000000E5E00000
Flash Pre-Erase Done, time used : 00:00:11
Preloader Download skipped by user request!
PartCount : 0012
Repartition Done!
Use FLN Mode
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:03:07
Processing : Verify
Verify Passed : MBR
Data Verify Done, time used : 00:00:47
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:04:21
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-29-2010 21:17
Page generated in 0.56998 seconds with 9 queries
