Old 08-06-2017, 13:36   #44086 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 14,742
Smile Qmobile Noir X6 Format Done
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 13 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6571
BB_CPU_NME : [MediaTek] MT6571_S00
BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x8B
NAND Flash : 009800BC009000660076001600080000
eMMC Flash : NOT INSTALLED
Initialize Memory ...
DAgent sent , init HW now
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1
[NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008
[NAND] : FLASH_LEN : 0x20000000
[NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1
DEV RID : 0xE6C52A7D48FA218818F91329A2CF7482
INT RAM : 0x00020000
EXT RAM : 0x10000000 [256 MiB]
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:34
Reconnect Power/Cable!
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post:
Old 08-06-2017, 14:10   #44087 (permalink)
rehmani's Avatar
Member: 333199
Sonork: may i help u just pm me
Thanks Meter: 2,391
samsung b313e format done
Chinese Miracle II  [SPD module] v 1.27
Set mode to : SPD6530_SAMSUNG
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
 ====  Wait for phone...
Phone found! [ 21 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6530 , FDLStat : 0000
[0] Flash DIE : 00C8 0060 0019 0000
[0] Flash VEN : GigaDevice , GD25LQ256
[0] Flash CAP : 02000000
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:02:25
The Following User Says Thank You to rehmani For This Useful Post:
Old 08-06-2017, 14:11   #44088 (permalink)
Member: 1984599
Sonork: PM For Sonork Id ;P
Thanks Meter: 37
i want to tell you guys only One thing YOUR product is THe Best in the work
Old 08-06-2017, 15:06   #44089 (permalink)
komalraj's Avatar
Member: 1755126
Thanks Meter: 37
Oppo f1f(1601) Read pattern done by Belove Cm2 {success report}
Sent from my SM-J700F using Tapatalk
Old 08-06-2017, 16:55   #44090 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 3,984
QMobile S6 PLUS Read Factory Firmware DOne :)
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 214 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 150100514531334D4207B37CEE1993ED
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM31E
[eMMC] : FLASH_CID : 150100514531334D4207B37CEE1993ED
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID    : 0x2BFA537D3ED2013785776EFBF3172180
EXT RAM    : 0x80000000 [2 GiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand     : QMobile
ProdName  : QMobile_S6_PLUS
ProdModel : QMobile S6 PLUS
Device    : QMobile_S6_PLUS
AndroidVer: 6.0
MTKxCPU   : MT6580
MTKxPRJ   : alps-mp-m0.mp1-V2.34_rgk6580.we.m
SECURITY :
IMEI_SW [1] : 354413080430306
IMEI_SW [2] : 354413085430301
BTMAC Addr  : C0854C13816D
WiFi MAC    : C0854C932F06
MODEM :
BaseBand  : MT6580_S00_D6171_S2_QMOBILE_MP_V0_0_3_S160810_1_wg_n
EXTRA :
LCD : Not info available :(
LCD Res : 1280x720
TOUCH [0] : GT1XX
CAM [0] : gc2365_mipi_raw
CAM [1] :  sp2509_mipi_raw gc5005_mipi_raw  hi842_mipi_raw sub_gc5005_mipi_raw hi553_mipi_raw hi843b_mipi_raw
MODEM : d6171_s2_qmobile_hspa
LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES
Done!
Elapsed: 00:00:12
Operation : Read Flash [ v1.58 ]
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading Flash Content now ...
xGPT : Normalize settings Ok!
Brand     : QMobile
AndroidVer: 6.0
MTKxCPU   : MT6580
[Read Ok] : preloader_d6171_s2_qmobile.bin
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : logo.bin
[Read Ok] : secro.img
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : userdata.img
[ScatCFG] : MT6580 / V1.1.2 / d6171_s2_qmobile / EMMC
Android Info saved
MAUI Meta DB saved
HWConfig Info saved
FW Size : 2958 MiB
Scatter saved to : F:\backup files\MT6580__QMobile__QMobile_S6_PLUS__QMobile_S6_PLUS__6.0__alps-mp-m0.mp1-V2.34_rgk6580.we.m\
All done!
Done!
Elapsed: 00:12:39
The Following User Says Thank You to syed tuqeer For This Useful Post:
Old 08-06-2017, 22:50   #44091 (permalink)
nessyb's Avatar
Member: 1866877
Sonork: 100.1681933
Thanks Meter: 673
world first 6.0 Hurricane Swirl firware read by cm2spd
Model Name : Swirl
Model Brand : Hurricane
Model Device: Swirl
AndrVersion : 6.0
BaseBand CPU: SP7731CEA
Project Ver : Hurricane_Swirl_IND_Ver1.0_161227_1200
Model Ext : Swirl
[Read Mode] : HSUSB : 0x3000
[FW_READER] : Reading Firmware Now ...
[Read Ok] : u-boot-spl-16k.bin
[Read Ok] : u-boot.bin
[Read Ok] : prodnv.img
[Read Ok] : sc7731C_CP0_modem.bin
[Read Ok] : DSP_DM_Gx.bin
[Read Ok] : nvitem_w.bin
[Read Ok] : sc8830g_modem_CP2_WCN_Trunk_W16.32.2_Release.bin
[Read Ok] : nvitem_wcn.bin
[Read Ok] : logo_480x854.bin
[Read Ok] : fblogo_480x854.bin
[Build Ok] : cache.img
[Read Ok] : sysinfo.img
[Build Ok] : userdata.img
AndroidInfo created
Firmware Size : 2180 MiB
Saved to : H:\flash firmware\infinity\SP7731CEA_Swirl_6.0_Hurricane_Sw irl_IND_Ver1.0_161227_1200_Swirl\
Done!
The Following User Says Thank You to nessyb For This Useful Post:
Old 08-07-2017, 05:55   #44092 (permalink)
Member: 1444454
Sonork: art
Hello Friend i need the Flash file
please Any body can send me flash file Download link >> "G-tab p906i spd 7731" SP7731GEA_K03_TYHT_9INC_BASE_64_4_scx35_sp7731gea_ k03_tyht_9inc_base_64_4_4.4.2_KOT49H_14B_test-keys_P906i
The Following User Says Thank You to infosaju For This Useful Post:
Old 08-07-2017, 08:03   #44093 (permalink)
dyo
dyo's Avatar
Member: 768985
Sonork: 100.1676685
Thanks Meter: 586
oppo R1001 read flash done
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 90014A483447316404050CA142FA8139
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x20000000
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A483447316404050CA142FA8139
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xD05B159F08EB387F2ED1B56C2CAC32D6
EXT RAM : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
USBDL : Init HSUSB Ok!
Brand : OPPO
ProdName : OPPO72_13076
ProdModel : R1001
Device : OPPO72_13076
AndroidVer: 4.2.2
MTKxCPU : MT6572
MTKxPRJ : R1001_11_A.18_160323
[Read Ok] : preloader_oppo72_13076.bin
[Read Ok] : MBR
[Read Ok] : EBR1
[Read Ok] : lk.bin
[Read Ok] : EBR2
[ScatCFG] : MT6572 / V1.1.1 / oppo72_13076 / EMMC
Android Info saved
HWConfig Info saved
FW Size : 908 MiB
Scatter saved to : G:\OPPO\MT6572__OPPO__R1001__OPPO72_13076__4.2.2__ R1001_11_A.18_160323\
All done!
Done!
Elapsed: 00:04:16
Old 08-07-2017, 08:09   #44094 (permalink)
Deepesh Sharma's Avatar
Member: 1301233
Sonork: 100.1614172
Thanks Meter: 9,202
lyf water10 remove frp
format
Wait for phone...
Phone found! [ 84 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x93
eMMC Flash : 484A019065324741D5180705531A6BF4
[eMMC] : FLASH_INF : [HYNIX] , e2GA
[eMMC] : FLASH_CID : 90014A4841473265050718D5F46B5353
[eMMC] : FLASH_LEN : 0x00000003AB800000
[eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB]
DEV RID    : 0x4AD5A99BFA8A93E2FFC6C56646956170
EXT RAM    : 0xC0000000 [3 GiB]
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:17
Old 08-07-2017, 08:26   #44095 (permalink)
Member: 654997
Thanks Meter: 3,984
QMobile S6 PLUS Remove FRP Lock Done :)
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Brand     : QMobile
AndroidVer: 6.0
MTKxCPU   : MT6580
Done!
Elapsed: 00:00:08
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:32
Old 08-07-2017, 08:42   #44096 (permalink)
Member: 654997
Thanks Meter: 3,984
QMobile D10 Read User Code / factory firmware Done :)
Operation : Read UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 229 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : B6E59068C94B3078CA544A15DED47003
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV
[0] : FLASH_DIE : 00EF 0070 0016 0000
[0] : FLASH_LEN : 0x00400000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Read ExtData
Sorting ExtData
Reading UserCode
Active : Yes , Code : 1122
PLock|MobTrack : Not active
Done!
Elapsed: 00:00:11
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
SOC_VERIFY : 0xC1
Read Flash now
Read Ok , 4194304 bytes read
Check and collect compile info
File_Info   : RDR61D_F126_PCB01_gprs_MT6261_S00.A606_QMOBILE_D10_V06_20161210.bin
FileVersion : A606_QMOBILE_D10_V06_20161210
[ScatCFG] : MT6261 / A606_QMOBILE_D10_V06_20161210 / NOR , SF
Firmware saved to : F:\1+Flashing Software\1+Infinity Box\CM2MTK\Read_out\RDR61D_F126_PCB01_gprs_MT6261_S00\
Done!
Elapsed: 00:00:16
Old 08-07-2017, 09:26   #44097 (permalink)
Member: 233142
Sonork: 100.1595099
Thanks Meter: 446
le-Tide READ CODE DONE
Card found: S/N : 334FA6A3 , v0136
Set mode to : SPD6531
Operation : Check/Read Info [ v1.27 ]
3. Insert battery
Phone found! [ 18 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00EF 0040 0016 0000
[0] Flash VEN : Winbond , W25Q32
[0] Flash CAP : 00400000
Elapsed: 00:00:24
Operation : Read User Code [ v1.27 ]
3. Insert battery
Phone found! [ 18 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Check data... Can take some time
User Code : 0246
Done!
Elapsed: 00:00:14
Old 08-07-2017, 09:28   #44098 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Qmobile i6 Metal One Format Done
Wait for phone...
Phone found! [ 9 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A483847316505072A526CF113CD
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A483847316505072A526CF113CD
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xE6C52A7DA41106F3C6892894C321A91C
EXT RAM : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:43
Old 08-07-2017, 10:15   #44099 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 924
Smile Qmobile i10 hang on logo done by infinity cm2
QMOBILE I10 HANG ON LOGO DONE BY INFINITY CM2
Read Info
Write Flash
Shahid
Old 08-07-2017, 10:20   #44100 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 924
Smile Samsung sm-j110h hang on logo done by infinity cm2
SAMSUNG SM-J110H HANG ON LOGO DONE BY INFINITY CM2
Read Info
Full Factory Reset (All)
Wait for phone...
Phone found! [ 64 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x87
eMMC Flash : 90014A4834473164048600A22170A0BD
[eMMC] : FLASH_CID : 90014A4834473164048600A22170A0BD
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : 0xB9E2EB77C304D74C2BCEAC0A34363228
SOC VERIFY : C1
Boot Ok!
Brand : Samsung
ProdName : SM-J110H
ProdModel : SM-J110H
Device : Galaxy J1 ace
AndroidVer: 4.2.2
MTKxCPU : MT6582
MTKxPRJ : J8215_2G_4.2_V1.3
MODEM :
BaseBand : MT6582_S00_MOLY_WR8_W1315_MD_WG_MP_V23_1_2g_n
Done!
Elapsed: 00:00:06
Wait for phone...
Phone found! [ 64 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:50
Shahid
The Following User Says Thank You to A.G.Shahid For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-29-2010 21:17
Page generated in 0.82384 seconds with 9 queries
