Old 08-15-2017, 12:17   #44281 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,129
Qmobile T5 SPD7715 NAND Pattren Reset Done With Great Infinity CM2
Card found: S/N : A19EC787 , v0136
Chinese Miracle II [SPD module] v 1.27
Set mode to : SP [SC7715] NAND [Generic]
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 15 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7715 Loader NAND v1.1 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected NAND Flash , Structure detect Ok!
Formatting NAND Flash
Format UserData
Format Ok!
Format Cache
Format Ok!
Done!
Elapsed: 00:00:20
Reconnect Power/Cable!
The Following User Says Thank You to azhergoga007 For This Useful Post:
Old 08-15-2017, 12:18   #44282 (permalink)
diesel6's Avatar
Member: 315867
Sonork: 100.1654770
Thanks Meter: 698
7562 write flash done
Phone found on COM15
Phone In Download mode...
Port open Ok!
LOKE received!
Prepare Ok!
Enter Setup...
Setup Done!
Try download PIT...
Download PIT Ok!
Start flashing!
Flashing oemsbl
Flashing appsbl
Flashing qcsbl.mbn
Flashing qcsblhd_cfgdata.mbn
Flashing appsbl
Flashing boot.img
Flashing oemsbl
Flashing persist.img.ext4
Flashing qcsbl.mbn
Flashing recovery.img
Flashing system.img.ext4
Flashing userdata.img.ext4
Flashing fat.bin
Flashing cache.img.ext4
Flashing hidden.img.ext4
Flashing done
Reboot phone...
Phone Disconnected
The Following User Says Thank You to diesel6 For This Useful Post:
Old 08-15-2017, 13:28   #44283 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,129
Qmobiile Z12 MT6735 FRP Reset Done With Great Infinity CM2
Card found : S/N : A19EC787 , v0136
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 46 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
DAgent configured successfully
Connection agent : PRELOADER
Link with DAgent established
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM41X
[eMMC] : FLASH_CID : 150100525831344D420717E4C26C93FF
[eMMC] : FLASH_LEN : 0x0000000747C00000
[eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB]
DEV RID : 0xD9C8F395AFCE41559A7E645A192E3D4B
INT RAM : 0x00000000
EXT RAM : 0x80000000 [2 GiB]
[NAND] : FLASH : NOT INSTALLED
[UFSM] : FLASH : NOT INSTALLED
[HSUSB] : MODE : HIGH-SPEED
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear PVL ( PrivacyLock )
Clear Ok!
Done!
Elapsed: 00:00:06
The Following 2 Users Say Thank You to azhergoga007 For This Useful Post:
Old 08-15-2017, 14:15   #44284 (permalink)
Salman725626's Avatar
Member: 2488001
Sonork: 100.1669288
Thanks Meter: 269
Leovo K53 Read Flash Done By Great Cm2 Tool
Operation : Read Flash [ v1.15 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 430 [MSM8937]
ID_BLOCK_S : B72B94BC
ID_BLOCK_I : 0004F0E1
ID_BLOCK_E : 00007A2A
ID_BLOCK_L : 9CC2C33B3D4924CD1051BB71FA4D8E37
ID_BLOCK_L : 1F6250BFBCD3F881A82C91A7D3AD339D
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ]
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RX1BMB
Boot Ok!
Brand : Lenovo
ProdName : karatep
ProdModel : Lenovo K53
Device : K53
AndroidVer: 6.0.1
Manufact. : LENOVO
QLMxCPU : MSM8937
QLMxPRJ : K53_USR_S116_1611150903_Q00380_ROW
DevInfo : MSM8937__LENOVO__Lenovo__ANDR_v6.0.1__Lenovo_K53__ K53__karatep__K53_USR_S116_1611150903_Q00380_ROW
Reading Flash Content ...
[Read Ok] : gpt_main0.bin
[Read Ok] : NON-HLOS.bin
[Read Ok] : sec.dat
[Read Ok] : cmnlib.mbn
[Read Ok] : cmnlib64.mbn
[Read Ok] : keymaster.mbn
[Read Ok] : emmc_appsboot.mbn
[Read Ok] : sbl1.mbn
[Read Ok] : rpm.mbn
[Read Ok] : tz.mbn
[Read Ok] : devcfg.mbn
[Read Ok] : adspso.bin
[Read Ok] : ddr.bin
[Read Ok] : fs_gc.img
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : ap.mbn
[Read Ok] : msap.mbn
[Read Ok] : splash.img
[Read Ok] : misc.img
[Read Ok] : mdtp.img
[Read Ok] : persist.img
[Read Ok] : cache.img
[Read Ok] : system.img
[Read Ok] : preload.img
[Read Ok] : userdata.img
[Read Ok] : gpt_backup0.bin
Android Info saved!
Read finished!
Configuration : MSM8937 / eMMC
Firmware Size : 3950 MiB
Done!
Elapsed: 00:09:08
The Following User Says Thank You to Salman725626 For This Useful Post:
Old 08-15-2017, 14:26   #44285 (permalink)
4G Telecom's Avatar
Member: 2421242
Sonork: 100.1614558
Thanks Meter: 673
Moto G3 Frp Remove Done
Adb Enable
Operation : Enable ADB (Moto) [ v1.01 ]
Waiting for NetInterface arrival ...
1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons
2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON'
3. Connect USB cable, when device boot complete!
Connect Ok!
Waiting ...
Trying link with : 192.168.137.2
Connected to device!
Device : XT1550
VerInfo : OSPREY_APAC_CUST
Version : Blur_Version.24.226.17.osprey_retasia_ds_2gb.retas ia.en.03
Enabling ADB ...
Frp Remove
Operation : Reset FRP (ADB) [ v1.01 ]
Waiting for device in ADB mode ...
1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need!
2. Insert USB cable, accept AUTH on PhoneScreen, if software ask!
Connect Ok!
Device : osprey_retasia_ds_2gb
Model : MotoG3
FRP reset passed! Make FACTORY RESET from menu!
The Following User Says Thank You to 4G Telecom For This Useful Post:
Old 08-15-2017, 14:32   #44286 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,424
Samsung I8262 Pinlock Format
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
NAND Flash : 002C00BC009000550056000000000000
eMMC Flash : NOT INSTALLED
Initialize Memory ...
DAgent sent , init HW now
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0091 , [Micron] NAND_MT29C4G48MAAHBAAKS_5WT
[NAND] : FLASH_DIE : 002C 00BC 0090 0055 0056 0000 0000
[NAND] : FLASH_LEN : 0x20000000
[NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2
DEV RID    : 0xD5229C25EA66E4985ED488FB6C817BB7
INT RAM    : 0x00020000
EXT RAM    : 0x10000000 [256 MiB]
BOOT TYPE  : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand     : alps
ProdName  : zr72_wet_lca
ProdModel : zr72_wet_lca
Device    : zr72_wet_lca
AndroidVer: 4.2.2
MTKxCPU   : MT6572
MTKxPRJ   : ALPS.JB3.MP.V1.8
Done!
Elapsed: 00:00:13
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:16
The Following User Says Thank You to Tanha0321 For This Useful Post:
Old 08-15-2017, 15:13   #44287 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,129
Qmobile Z14 MT6755 Dead Set ReAlive Only Done Preloder With Infinity CM2
Wait for phone...
Phone found! [ 78 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Ok!
Supported HW by Preloader :
FlashID [0] CID : 150100523331424142 , Name : R31BAB , Vendor : 15 , [SAMSUNG]
FlashID [1] CID : 150100525831344D42 , Name : RX14MB , Vendor : 15 , [SAMSUNG]
FlashID [2] CID : 150100524331344D42 , Name : RC14MB , Vendor : 15 , [SAMSUNG]
BL : Storage supported by BootLoader!
Sending BootLoader ...
Init BL #1 : 0001
Init BL #2 : 0001
PartTable Init Ok , Count : 1D
All Done
Done!
Elapsed: 00:00:13
Old 08-15-2017, 15:25   #44288 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,424
Motorola Xt1254 Frp Reset
Connect Ok!
Waiting ...
Device : XT1254
VerInfo : QUARK_CUST
Version : Blur_Version.24.91.5.quark_verizon.verizon.en.US
Enabling ADB ...
1. Disconnect cable from device, press and hold 'VOLUME_DOWN' and 'POWER_ON'
2. Select 'FACTORY MODE' and press 'POWER ON'!
3. Wait for device boot completely!
Done!
Elapsed: 00:00:09
Connect Ok!
Device : quark_verizon
Model  : XT1254
Done!
Elapsed: 00:00:12
Old 08-15-2017, 16:49   #44289 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,129
Oppo A37f QLM Pattren Read Done By King Infinity CM2
Operation : Read PatternLock [ v1.14 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 23E4D0D6
ID_BLOCK_I : 007050E1
ID_BLOCK_L : D3154FB7268CB9B493C80815D2A92921
ID_BLOCK_L : BFD678D3C44FFF74896429E6EC031D3E
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Read Ok! Trying decrypt ...
PatternLock sequence : 26598
Done!
Elapsed: 00:00:22
Old 08-15-2017, 17:48   #44290 (permalink)
mak1983's Avatar
Member: 1704666
Sonork: 100.1652565
Thanks Meter: 155
Arrow cs2 best redmi note 4 2016100 read file and MIAccount remove
Operation : Identify [ v1.15 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 625 [MSM8953]
ID_BLOCK_S : AA5A6FDD
ID_BLOCK_I : 000460E1
ID_BLOCK_L : 713EAD893332E6B9D8AC3C6BFF6FAFA0
ID_BLOCK_L : 22D2A80FCEE9F9312EB95A4D2A9C483D
Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ]
Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RC14MB
Boot Ok!
Brand : xiaomi
ProdName : mido
ProdModel : Redmi Note 4
Device : mido
AndroidVer: 6.0.1
Manufact. : Xiaomi
SysPatch : MMB29M
DevComTime: 02/06/2017 1:53:58 PM
QLMxCPU : MSM8953
USERData : ENCRYPTED
GCSec : NORMAL
Done!
Elapsed: 00:00:23
Wait for phone...
Device not found!
Check cable, connection and drivers!
Wait for phone...
Device not found!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Brand : xiaomi
ProdName : mido
Device : mido
AndroidVer: 6.0.1
Manufact. : Xiaomi
QLMxCPU : MSM8953
DevInfo : MSM8953__Xiaomi__xiaomi__ANDR_v6.0.1__Redmi_Note_4 __mido__mido
[Read Ok] : rpm.mbn
[Read Ok] : tz.mbn
[Read Ok] : ddr.bin
[Read Ok] : sec.dat
[Read Ok] : lksecapp.mbn
[Read Ok] : cust.img
Android Info saved!
Read finished!
Configuration : MSM8953 / eMMC
Firmware Size : 3684 MiB
Done!
Elapsed: 00:04:33
Operation : Reset Settings [ v1.15 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
MIAccount reset passed!
Complete reset :
> If device lock after WiFi - use RESET MI APP
> PowerOn device, NOT power WiFi, SIM and etc. Make device setup
> Reset MI APP. Device will not have MIServices anymore
Done!
Elapsed: 00:00:23
The Following User Says Thank You to mak1983 For This Useful Post:
Old 08-15-2017, 18:20   #44291 (permalink)
Member: 2606598
Thanks Meter: 17
Infinix x -554 read flash done
MT6580__INFINIX__Infinix_HOT_3__W90918A2_Infinix_H OT_3__5.1__ALPS.L1.MP6.V2.19_WT6580.WE.XIAN.L_P16
Operation : Read Flash [ v1.58 ]
Wait for phone...
Phone found! [ 35 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 7001005631303031365011D77385C239
[eMMC] : FLASH_VEN : 0x70 , OEM : 0100
[eMMC] : FLASH_INF : [KINGSTON] , 61001
[eMMC] : FLASH_CID : 7001005631303031365011D77385C239
[eMMC] : FLASH_LEN : 0x0000000386000000
[eMMC] : FLASH_UCP : 14432 MiB [eMMC 16 GiB]
DEV RID : 0xEE6AE9A2C192457A6F47E5EA9A6930C6
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Reading Flash Content now ...
xGPT : Normalize settings Ok!
Brand : INFINIX
ProdName : Infinix HOT 3
ProdModel : Infinix HOT 3
Device : W90918A2 Infinix HOT 3
AndroidVer: 5.1
MTKxCPU : MT6580
MTKxPRJ : ALPS.L1.MP6.V2.19_WT6580.WE.XIAN.L_P16
[Read Ok] : preloader_t90918a2.bin
[Read Ok] : lk.bin
[Read Ok] : logo.bin
[Read Ok] : secro.img
[ScatCFG] : MT6580 / V1.1.2 / t90918a2 / EMMC
Android Info saved
MAUI Meta DB saved
HWConfig Info saved
FW Size : 2859 MiB
Scatter saved to : C:\Users\my pc\Desktop\faulty phones backup\MT6580__INFINIX__Infinix_HOT_3__W90918A2_In finix_HOT_3__5.1__ALPS.L1.MP6.V2.19_WT6580.WE.XIAN .L_P16\
All done!
The Following User Says Thank You to rose_petel For This Useful Post:
Old 08-15-2017, 18:22   #44292 (permalink)
sachu2002's Avatar
Member: 2362867
Sonork: ththtuu
Thanks Meter: 643
Oppo a37 read pattern done just one click with cm2
Operation : Read PatternLock [ v1.15 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_S : 216D5564
ID_BLOCK_L : 6183F905B03E2B2601769E87401B9BB3
ID_BLOCK_L : 245FE1484DD4068F02EDA61F159896B5
Boot Ok!
PatternLock sequence : 7584
Done!
Elapsed: 00:00:34
The Following User Says Thank You to sachu2002 For This Useful Post:
Old 08-16-2017, 08:36   #44293 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 3,984
TICHIPS T230 Read factory firmware Done :)
World First ! (bla bla......)
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 229 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 16FAED1E977888DE7775E32E52EE38DD
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV
[0] : FLASH_DIE : 00EF 0070 0016 0000
[0] : FLASH_LEN : 0x00400000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
File_Info   : HEXIN23_KK_PCB01_gprs_MT6261_S01.M61D_TICHIPS_EFABPWHE_GC0310_BT_T230_V1.bin
FileVersion : M61D_TICHIPS_EFABPWHE_GC0310_BT_T230_V1
Done!
Elapsed: 00:00:07
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
SOC_VERIFY : 0xC1
Read Flash now
Read Ok , 4194304 bytes read
Check and collect compile info
[ScatCFG] : MT6261 / M61D_TICHIPS_EFABPWHE_GC0310_BT_T230_V1 / NOR , SF
Firmware saved to : F:\1+Flashing Software\1+Infinity Box\CM2MTK\Read_out\HEXIN23_KK_PCB01_gprs_MT6261_S01\
Done!
Elapsed: 00:00:18
The Following User Says Thank You to syed tuqeer For This Useful Post:
Old 08-16-2017, 08:57   #44294 (permalink)
rehmani's Avatar
Member: 333199
Sonork: may i help u just pm me
Thanks Meter: 2,391
ao5510 format done
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 610 [MSM8936]
ID_BLOCK_S : 007849D0
ID_BLOCK_I : 0090B0E1
ID_BLOCK_L : 5221F4C59BF28131D55B9DA61D154B00
ID_BLOCK_L : 395950BAED1EC32E7A0CE6C4EC39332B
Running FireHose on BBID : MSM8936 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ]
Boot Ok!
Brand     : YU
ProdName  : YUREKA
ProdModel : AO5510
Device    : YUREKA
AndroidVer: 5.0.2
Manufact. : YU
SysPatch  : LRX22G
DevComTime: 5/1/2015 12:10:06 AM
QLMxCPU   : MSM8916
USERData : NORMAL
GCSec    : NORMAL
Done!
Elapsed: 00:00:14
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Done!
Elapsed: 00:00:18
The Following User Says Thank You to rehmani For This Useful Post:
Old 08-16-2017, 08:58   #44295 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,391
mi 2015116 format done
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 652 [MSM8976]
ID_BLOCK_S : 027DCE94
ID_BLOCK_I : 009B00E1
ID_BLOCK_L : 8AF75472FAC93F621365F3B22694646B
ID_BLOCK_L : 47B1CB6AAD8C8654039A3F2A55C16D50
Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1
Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : BJNB4R
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:18
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-29-2010 21:17
Page generated in 0.84491 seconds with 9 queries
