Old 08-17-2017, 07:46   #44311 (permalink)
fahadboss's Avatar
Member: 2441366
Thanks Meter: 84
QMobile C10 SPD6531 Illegal Use remove done by CM2 (Just 10 sec
QMobile C10 spd6531 Illegal Use one click done.
Old 08-17-2017, 07:58   #44312 (permalink)
fahadboss's Avatar
Member: 2441366
Thanks Meter: 84
Cool QMobile C10 spd6531 Illegal Use one click done by CM2
Just format.
Only 10 sec.
Br,
Fahad Ahmad
The Following User Says Thank You to fahadboss For This Useful Post:
Old 08-17-2017, 08:14   #44313 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 3,973
Samsung J3 (Clone) Read factory firmware / Remove Virus Done :)
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 103 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A2058494E5948160066AA347163
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , HYNIX
[eMMC] : FLASH_CID : 90014A2058494E5948160066AA347163
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID    : 0x2BFA537D398677CB33E0D47D43CBD82F
INT RAM    : 0x00020000
EXT RAM    : 0x20000000 [512 MiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand     : Samsung
ProdName  : SM-J3109
ProdModel : SM-J3109
Device    : Galaxy J3
AndroidVer: 4.4.2
MTKxCPU   : MT6572
MTKxPRJ   : ALPS.KK1.MP7.V1
Done!
Elapsed: 00:00:13
Reconnect Power/Cable!
Operation : Read Flash [ v1.58 ]
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading Flash Content now ...
Brand     : Samsung
ProdName  : SM-J3109
Device    : Galaxy J3
AndroidVer: 4.4.2
MTKxCPU   : MT6572
[Read Ok] : preloader_keytak72_cwet_lca.bin
[Read Ok] : MBR
[Read Ok] : EBR1
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : secro.img
[Read Ok] : logo.bin
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : userdata.img
[ScatCFG] : MT6572 / V1.1.1 / keytak72_cwet_lca / EMMC
Android Info saved
MAUI Meta DB saved
HWConfig Info saved
FW Size : 952 MiB
Scatter saved to : F:\backup files\MT6572__Samsung__SM-J3109__Galaxy_J3__4.4.2__ALPS.KK1.MP7.V1\
All done!
Done!
Elapsed: 00:05:12
Operation : HW Test [ v1.58 ]
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[Processing] FlashMemory Read-Write test
[eMMC] : [HYNIX] , HYNIX , 0xE7000000 , 3696 MiB
[eMMC] : CID : 90014A2058494E5948160066AA347163
[eMMC] : MODE : SQ-WR
[PASSED] : eMMC RW Check #1 Ok!
[eMMC] : MODE : RA-WR
[PASSED] : eMMC RW Check #2 Ok!
[eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed!
All Done!
Done!
Elapsed: 00:00:34
Operation : Scan APPs [DDirect] [ v1.58 ]
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
DDirect : Init Ok!
Scanning FileSystem now , please wait
[User Select] : Remove Files and Garbage
[DDCleaner Info] : Files to remove : 1
[DDCleaner Info] : Additional garbage detected : 0
Removing files ...
[DDCleaner] : Removed 1
Special Op #1 : Clear Recovery Data Ok!
Special Op #2 : Clear UserData Ok!
Special Op #3 : PostFix Ok!
All Done!
Done!
Elapsed: 00:03:30
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:32
The Following User Says Thank You to syed tuqeer For This Useful Post:
Old 08-17-2017, 10:27   #44314 (permalink)
sachu2002's Avatar
Member: 2362867
Sonork: ththtuu
Thanks Meter: 642
Samsung B110E READ PHONE LOCK DONE CM2
Card found: S/N : AD4A22C5 , v0136
Chinese Miracle II [SPD module] v 1.24
Operation : Check/Read Info [ v1.24 ]
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
==== Wait for phone...
Phone found! [ 13 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6530 , FDLStat : 00C0
[0] Flash DIE : 00C8 0060 0017 0000
[0] Flash VEN : GigaDevice , GD25LQ64
[0] Flash CAP : 00800000
Elapsed: 00:00:18
Operation : Read User Code [ v1.24 ]
3. Insert battery
Phone found! [ 13 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Check data... Can take some time
User Code : 2323
Done!
Elapsed: 00:00:08
The Following User Says Thank You to sachu2002 For This Useful Post:
Old 08-17-2017, 10:31   #44315 (permalink)
sachu2002's Avatar
Member: 2362867
Sonork: ththtuu
Thanks Meter: 642
Sm-b110e read phone lock done cm2
3. Insert battery
Phone found! [ 13 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Elapsed: 00:00:18
3. Insert battery
Phone found! [ 13 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
User Code : 2323
Done!
Elapsed: 00:00:08
Old 08-17-2017, 12:46   #44316 (permalink)
RIZU007's Avatar
Member: 2559619
Sonork: 100.1672420
Thanks Meter: 195
Angry
COOLPAD NOTE 5 3600I MSM 8952 FRP REMOVE 1000% BY CM2 (RIZU007)
READ INFO
FRP REMOVE
AFTER FRP SS
RIZU007
The Following User Says Thank You to RIZU007 For This Useful Post:
Old 08-17-2017, 12:50   #44317 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,107
Jazz Js2 SPD77xx FRP Reset Done With King Infinity CM2
Phone found! [ 15 ]
Port Opened
Sync...
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:22
The Following User Says Thank You to azhergoga007 For This Useful Post:
Old 08-17-2017, 13:34   #44318 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,107
Qmobile I7i SPD77xx Logo Stuck Recover Done Only Formate With Infinity CM2
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
Phone found! [ 15 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v4 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Done!
Elapsed: 00:00:20
Old 08-17-2017, 13:43   #44319 (permalink)
mbiborna's Avatar
Member: 770503
Thanks Meter: 1,059
Samsung G355H Remove pattern
Phone found on COM44
Phone In Download mode...
Port open Ok!
LOKE received!
Prepare Ok!
Enter Setup...
Setup Done!
Try download PIT...
Download PIT Ok!
Start flashing!
Flashing cache.img
Flashing hidden.img
Flashing done
Reboot phone...
Read Info...
Read Info - ok
Connect ADB - Ok
Model - SM-G355H
Product - kanas3gxx
CPU - sc7735s
Phone version - G355HXXU0AOB2
Android version - 4.4.2
CSC country code - Afghanistan
CSC sales  code - AFG
Phone serial No - RV1G51QPY8F
Phone IMEI - 35xxxxxxxx75xxxx
Phone not Rooted
The Following User Says Thank You to mbiborna For This Useful Post:
Old 08-17-2017, 14:03   #44320 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,895
Oneplus a0001 frp/read flash/write flash done with cm2qlm:-
IDENTIFY
Operation : Identify [ v1.09 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 801 [MSM8974]
ID_BLOCK_S : 0DD8C08D
ID_BLOCK_I : 007B40E1
ID_BLOCK_L : 1AEA807ED945727D2A1FF1DE1960F0D8
ID_BLOCK_L : B3C24CDFD043EB789D583DEAF837212A
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8974 , FLASH : eMMC , mVER : 1
ExtInfo : 0x0000C000/00020000/00001000/00001000
Boot Ok!
Brand     : oneplus
ProdName  : bacon
ProdModel : A0001
Device    : A0001
AndroidVer: 6.0.1
Manufact. : OnePlus
QLMxCPU   : MSM8974
Done!
Elapsed: 00:00:12
RESET SETTING
Operation : Reset Settings [ v1.09 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Done!
Elapsed: 00:00:20
READ FLASH
Operation : Read Flash [ v1.09 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Brand     : oneplus
ProdName  : bacon
ProdModel : A0001
Device    : A0001
AndroidVer: 6.0.1
Manufact. : OnePlus
QLMxCPU   : MSM8974
DevInfo : MSM8974__OnePlus__oneplus__ANDR_v6.0.1__A0001__A0001__bacon
Reading Flash Content ...
[Read Ok] : gpt_main0.bin
[Read Ok] : NON-HLOS.bin
[Read Ok] : sbl1.mbn
[Read Ok] : dbi.mbn
[Read Ok] : ddr.bin
[Read Ok] : emmc_appsboot.mbn
[Read Ok] : rpm.mbn
[Read Ok] : tz.mbn
[Read Ok] : pnvbak.img
[Read Ok] : persist.img
[Read Ok] : misc.img
[Read Ok] : lsplash.img
[Read Ok] : driver.iso
[Read Ok] : gpt_backup0.bin
Android Info saved!
Read finished!
Configuration : MSM8974 / eMMC
Firmware Size : 1589 MiB
Done!
Elapsed: 00:04:46
WRITE FLASH
Loading firmware ...
Created by Infinity-Box (c) Chinese Miracle II (c) 2017
Device Brand    : oneplus
Device Manufact.: OnePlus
Device Model    : A0001
Device CPU      : MSM8974
Device IntName  : bacon
Device Version  : 6.0.1
CU_SWVer        : OnePlus
Device Compile  : 8/12/2016 12:13:11 AM
Device ExtInfo  : A0001
Load Ok!
Operation : Flash [ v1.09 ]
ForceFlashing : Disabled
Verify FW package ...
Verification passed!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Pickup loader from firmware package
Boot Ok!
Files in Chain : 25
Flashing now
Flashing : gpt_main0.bin
Flashing : NON-HLOS.bin
Flashing : sbl1.mbn
Flashing : dbi.mbn
Flashing : emmc_appsboot.mbn
Flashing : rpm.mbn
Flashing : boot.img
Flashing : tz.mbn
Flashing : system.img
Flashing : persist.img
Flashing : cache.img
Flashing : recovery.img
Flashing : misc.img
Flashing : lsplash.img
Flashing : driver.iso
Flashing : userdata.img
Flashing : gpt_backup0.bin
Boot settings configured!
Flashing done!
Done!
Elapsed: 00:03:37
WBR
sahil2000ind
The Following User Says Thank You to sahil2000ind For This Useful Post:
Old 08-17-2017, 14:05   #44321 (permalink)
rehmani's Avatar
Member: 333199
Sonork: may i help u just pm me
Thanks Meter: 2,390
micromaxx a310 flash done
Operation : HW Test [ v1.56 ]
Wait for phone...
Phone found! [ 82 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BB_CPU_NME : [MediaTek] MT6592_S00
BromVer   : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Running DA ver.4.2 on BBID : 0x8A
eMMC Flash : 90014A48384732640405012865D941CF
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x40000000
[eMMC] : FLASH_INF : [HYNIX] , d2G8
[eMMC] : FLASH_CID : 90014A48384732640405012865D941CF
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID    : 0xC1F94A5CE5358CE96B533D4A9296FED5
EXT RAM    : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
[eMMC] : [HYNIX] , d2G8 , 0x1D2000000 , 7456 MiB
[eMMC] : CID : 90014A48384732640405012865D941CF
All Done!
Done!
Elapsed: 00:01:00
Operation : Check / Read Info [ v1.56 ]
Wait for phone...
Phone found! [ 82 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BromVer   : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Brand     : Micromax
ProdName  : A310
ProdModel : Micromax A310
Device    : A310
AndroidVer: 4.4.2
MTKxCPU   : MT6592
MTKxPRJ   : 4.4.030.P0.140806.A310
SECURITY :
IMEI_SW [1] : 91137570677----
IMEI_SW [2] : 91137570678----
BTMAC Addr  : 000046659201
WiFi MAC    : 18DC56F0885B
MODEM :
BaseBand  : MT6592_S00_MOLY_WR8_W1315_MD_WG_MP_V35_1_wg_n
Done!
Elapsed: 00:00:17
Scatter Load Ok , BaseBand : MT6592 , Project : yulong92_cwet_kk , Storage : EMMC
Files found : 12 , Set to Flash : 11
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand   : Micromax
Device Model   : A310
Device CPU     : MT6592
Device IntName : A310
Device Version : 4.4.2
Device Compile : 11/6/2014 1:18:08 PM
Device Project : 4.4.031.P0.140825.A310
Device ExtInfo : Micromax A310
Ready to Flash!
Operation : Flash [ v1.56 ]
======= Flash
Wait for phone...
Phone found! [ 82 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BromVer   : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6592 , Project : yulong92_cwet_kk , Storage : EMMC
Setting : AFF verify :  Enabled
Setting : HW verify :  Enabled
Switching to HSUSB
HSUSB Init Ok
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : Undefined structure, determined as forced
BL : BatteryLevel : 3901 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000000000-0x0000000000100000
Erase : 0x0000000001D00000-0x00000001CEE00000
Flash Pre-Erase Done, time used : 00:00:14
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_yulong92_cwet_kk.bin
Preloader Sent , Init passed
PartCount : 0016
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EBR2
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:03:43
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : EBR2
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:09
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:04:27
The Following User Says Thank You to rehmani For This Useful Post:
Old 08-17-2017, 14:06   #44322 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,390
nokia 108 format done
Chinese Miracle II  [MTK module] v 1.56
Operation : Format FileSystem [ v1.56 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 70 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6250_S0000
BB_CPU_SN : 5E68C264ABCEA18E6EE0F6C960B7D76D
BROM Protocol Version : 05
BROM Status : 1012
Comm Status : 0000
EXBL Status : Alive [ USB Load Active ]
Switch to BL done
BL Version : 01
Setting...
Setting done , result code 0x8000
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_eMP_NkB.fg
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x88
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E
[0] : FLASH_DIE : 00C2 0025 0036 0000
[0] : FLASH_LEN : 0x00400000
Executing FFS FORMAT now...
FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000
DA_RET   : DA_IN_PROGRESS
DA_RET   : FORMAT_DONE
Done!
Elapsed: 00:00:14
Old 08-17-2017, 14:44   #44323 (permalink)
fahadboss's Avatar
Member: 2441366
Thanks Meter: 84
Cool One click done
QMobile T250 SPD7731 Black screen after logo done!
Tool used: Infinity CM2 SPD
Operation used: Format FS/Reset phone
Info:
Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0]
Operation : Check/Read Info [ v1.27 ]
3. Insert cable
Phone found! [ 20 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v3 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name  : QMobile T250
Model Brand : QMobile
Model Device: scx35_sp7731gea
AndrVersion : 4.4.2
BaseBand CPU: SP7731GEA
CompileDate : 7/2/2015 11:59:16 AM
Project Ver : QMobile_T250_MP_30_06
Model Ext   : QMobile T250
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:59
3. Insert cable
Phone found! [ 20 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Done!
Elapsed: 00:00:54
Br,
Fahad Ahmad
The Following 2 Users Say Thank You to fahadboss For This Useful Post:
Old 08-17-2017, 16:09   #44324 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,107
Rivo Pz4 MT6735 FRP Reset Done With Infnity CM2
Card found : S/N : A19EC787 , v0136
Wait for phone...
Phone found! [ 12 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x93
eMMC Flash : 460001154D323237B7E80042572185A8
[eMMC] : FLASH_INF : [SAMSUNG] , BM227
[eMMC] : FLASH_CID : 150100463732324D4200E8B7A8853357
DEV RID : 0xD9C8F395042A081B58231B83719F5004
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:44
Old 08-17-2017, 17:11   #44325 (permalink)
Member: 2712020
Thanks Meter: 16
upload flash file pleas.....
Wait for phone...
Phone found! [ 3 ]
Sync...
Boot Info :
BB_CPU_ID : 6735
BB_CPU_HW : CA00
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6735_S00
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v5.1540.01.01
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 510001154D3332383EEB004223BBEFDE
DA Stat : v4.2 on BBID : 0x93
DA Sent. Configure setting now ...
DA started successuflly
[eMMC] : FLASH_VEN : 0015 , OEM : 0100
[eMMC] : FLASH_INF : [SAMSUNG] , BM328
[eMMC] : FLASH_CID : 150100513832334D4200EB3EDEEFA223
[eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB
EXT RAM    : 0x80000000
SOC VERIFY : C1
Boot Ok!
Reading Flash Conent now ...
Brand     : Lenovo
ProdName  : P1ma40
ProdModel : Lenovo P1ma40
Device    : P1ma40
AndroidVer: 5.1
MTKxCPU   : MT6735
MTKxPRJ   : P1ma40_USR_S025_1509241530_MP3V2_16G_ROW_US
MediaTek MT67xx [x64] : Normalize settings Ok
[Read Ok] : preloader_wt98735_a1.bin
[Read Ok] : lk.bin
[Read Ok] : tz1.img
[Read Ok] : tz2.img
[ScatCFG] : MT6735M / V1.1.2 / wt98735_a1 / EMMC
FW Size : 2485 MiB
Scatter saved to : C:\Documents and Settings\hamza\Desktop\MT6735__Lenovo__Lenovo_P1ma40__P1ma40__5.1__P1ma40_USR_S025_1509241530_MP3V2_16G_ROW_US\
All done!
Done!
GSM BOSS
upload flash file please
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.87362 seconds with 9 queries
