Old 08-20-2017, 00:32   #44356 (permalink)
Member: 280444
Sorry, I connect the cell phone
Originally Posted by rehmani View Post
mi 2015116 format done
Operation : Reset Settings [ v1.15 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 652 [MSM8976]
ID_BLOCK_S : 027DCE94
ID_BLOCK_I : 009B00E1
ID_BLOCK_L : 8AF75472FAC93F621365F3B22694646B
ID_BLOCK_L : 47B1CB6AAD8C8654039A3F2A55C16D50
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ]
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : BJNB4R
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:18
Reconnect Power/Cable!
Hi,
Sorry, I connect the cell phone, I do not read the phone
Card found : XXXXXX , v0136
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.15
Operation : Identify [ v1.15 ]
Wait for phone...
Device not found!
Check cable, connection and drivers!
Old 08-20-2017, 04:44   #44357 (permalink)
Taguro-GSMLover's Avatar
Member: 2669319
Thanks Meter: 401
zh&k C-1 PHONE LOCKED READ DONE
Card found: S/N : BCE8XXXX , v0136
Chinese Miracle II [RDA module] v 1.05
Operation : Read User Code
Waiting phone ...
Connect battery, press and hold '0' button
Connect USB cable and keep hold button, until phone will be detected
Init : D0046500
Settings registers ...
1st boot Ok
==== CPU
CPU_ID : 8809 , rev : 4009
CPU_CN : RDA Micro CT , RDA8851X
==== FLASH
FL_VEN : 60C8 , rev : 1600
FL_CNM : GigaDevice , GD25Q32
FL_CAP : 00400000
Initial : 81C0024C
==== Booting
Sending RamRun Loader ...
Set : 8809 , 00400000
Use : 8809_00400000_usb.fp
Sending HdrConf ...
Sending LdrData ...
Loader sent, starting...
Flush : 0400F000
Loader run
Boot Done!
Read UDA now , wait ...
Read done, sorting EXTData
Following items found :
Item : VDS0
Item : WAP_MM
Item : CSW
Item : VDS1
Item : NVRAM
Required data found, extracting code
UserCode : 1122
Elapsed: 00:00:16
Done
Old 08-20-2017, 06:43   #44358 (permalink)
sumatera's Avatar
Member: 756701
Sonork: 100.1592286
Thanks Meter: 91
Coolpad E570 Privacy Lock....Done
Start  at : [20/08/2017 / 12:24:58]
Operation : Reset Privacy Lock [ v1.58 ]
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 484A019065314738F4520705B1871D86
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A4838473165050752F4861D93B1
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID    : 0xC5E8D16AEF32C38ABF0B0D7CC8AC8640
INT RAM    : 0x00020000
EXT RAM    : 0x40000000 [1 GiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Checking data ...
Process block #1
Process block #2
Privacy Lock reset Ok!
Done!
Elapsed: 00:00:27
Finish at : [20/08/2017 / 12:25:26]
Coolpad E570 FRP lock ...Done
Start  at : [20/08/2017 / 12:28:40]
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:13
Finish at : [20/08/2017 / 12:28:53]
Old 08-20-2017, 07:34   #44359 (permalink)
akhtar.abbas's Avatar
Member: 1190193
Sonork: 1619687
Thanks Meter: 278
J-200h-flashing don-v-1,04
Phone found on COM161
Phone In Download mode...
Port open Ok!
LOKE received!
Prepare Ok!
Enter Setup...
Setup Done!
Try download PIT...
Download PIT Ok!
Start flashing!
Flashing spl.img
Flashing sboot.bin
Flashing sboot2.bin
Flashing boot.img
Flashing recovery.img
Flashing system.img
Flashing SPRDCP.img
Flashing SPRDDSP.img
Flashing cache.img
Flashing hidden.img
Flashing done
Reboot phone...
Phone Disconnected
Old 08-20-2017, 08:24   #44360 (permalink)
Salman725626's Avatar
Member: 2488001
Sonork: 100.1669288
Thanks Meter: 263
Q Mobile A8 Hang On logo Recoverd Done
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
BB_CPU_NME : [MediaTek] MT6575|MT6577_S00
BB_CPU_EXT : 0xCB00 , 0x8B00 , 0xE201
i2c Init : 0300771F
SpeedSet : 0000
VChrgSet : 0x28 , BatStat : 0x02
WD Disable stat : 0x0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.3.2 on BBID : 0x84
[eMMC] : FLASH_INF : [SAMSUNG] , M00SJ
[eMMC] : FLASH_CID : 1501004E4A5330304D00AD9623E7CF2D
[eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00020000
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xDD423B820596DD8BDD2F4E5AAD3E9DE5
EXT RAM : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : QMobile
ProdName : QMobile
ProdModel : A8
Device : QMobile
AndroidVer: 4.1.1
MTKxCPU : MT6577
MTKxPRJ : ALPS.JB.MP.V1
MODEM :
BaseBand : MT6577_S00_MAUI_11AMD_W12_22_SP_V15
Done!
Elapsed: 00:00:28
Scatter Load Ok , BaseBand : MT6577 , Project : MTK6577 , Storage : eMMC
Files found : 12 , Set to Flash : 11
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
i2c Init : 0300771F
SpeedSet : 0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6577 , Project : MTK6577 , Storage : eMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : Old Dedvice , skip BatteryLevel check
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000600000-0x0000000000008000
Erase : 0x0000000000F28000-0x00000000E60D8000
Flash Pre-Erase Done, time used : 00:00:00
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_gionee77_cu_ics2.bin
Preloader Sent , Init passed
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash now : FAT
Image Flash Ok
Flash Write Done, time used : 00:01:22
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Verify Passed : FAT
Data Verify Done, time used : 00:00:39
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:02:15
Old 08-20-2017, 08:59   #44361 (permalink)
rehmani's Avatar
Member: 333199
Sonork: may i help u just pm me
Thanks Meter: 2,390
gionee s6s done
Chinese Miracle II  [MTK module] v 1.56
Operation : Check / Read Info [ v1.56 ]
Wait for phone...
Phone found! [ 31 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 520001154D4231589AAB07426139E4AC
[eMMC] : FLASH_INF : [SAMSUNG] , BMB1X
[eMMC] : FLASH_CID : 150100525831424D4207AB9AACE47361
[eMMC] : FLASH_LEN : 0x0000000747C00000
[eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB]
DEV RID    : 0xC1F94A5C9E7F03EDFA92778B5070BA6E
EXT RAM    : 0xC0000000 [3 GiB]
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:06
Operation : Format FileSystem [ v1.56 ]
Wait for phone...
Phone found! [ 31 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:01:59
Old 08-20-2017, 09:06   #44362 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,390
micromaxx q333 write nv and format done
Chinese Miracle II  [SPD module] v 1.27
Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0]
Operation : Check/Read Info [ v1.27 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
 -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
 ====  Wait for phone...
Phone found! [ 25 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v3 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name  : Q333
Model Brand : Micromax
Model Device: Q333
AndrVersion : 4.4.3
BaseBand CPU: SP7731GEA
CompileDate : 8/15/2015 3:46:37 AM
Project Ver : MMX_Q333_SW_1.0.2_HW_4.0.0_20150624
Model Ext   : Micromax Q333
ExtraInfo : HWInfo exists!!! This phone have DYNAMIC HW settings!!!
Elapsed: 00:00:25
NVM File looks Ok
Operation : Write NV [ v1.27 ]
3. Insert cable
Phone found! [ 25 ]
Open Port Failed!
NVM File looks Ok
3. Insert cable
Phone found! [ 25 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Detected eMMC Flash , Structure detect Ok!
Write NVM Part #1 Ok!
Write NVM Part #2 Ok!
Clean DYNV
Elapsed: 00:00:30
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
3. Insert cable
Phone found! [ 25 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount :
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Done!
Elapsed: 00:00:26
Old 08-20-2017, 09:24   #44363 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,895
Micromax q386 frp done with cm2mtk:-
READ INFO
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
eMMC Flash : 150100463832324D42006C21C46A2319
[eMMC] : FLASH_INF : [SAMSUNG] , BM228
[eMMC] : FLASH_CID : 150100463832324D42006C21C46A2319
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID    : 0x58001544DB022473D06DF9CA65F2BD3A
SOC VERIFY : C1
Boot Ok!
Brand     : Micromax
ProdName  : Q386
ProdModel : Micromax Q386
Device    : Q386
AndroidVer: 6.0
MTKxCPU   : MT6580
MTKxPRJ   : ALPS.W10.24.p0
SECURITY :
IMEI_SW [1] : 911507xxxxxxxxx
IMEI_SW [2] : 911507xxxxxxxxx
BTMAC Addr  : C0C9xxxxxxxx
WiFi MAC    : C0C9xxxxxxxx
MODEM :
BaseBand  : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V57_1_wg_n
EXTRA :
LCD : Not info available :(
LCD Res : 1280x720
TOUCH [0] : s2333_v3750
TOUCH [1] : ft5346i_v3750
CAM [0] : s5k4h8_mipi_raw
CAM [1] : hi842_mipi_raw
CAM [2] : ov5670_mipi_raw_sunwin
CAM [3] : ov5670_mipi_raw_cmk
CAM [4] : s5k5e2ya_mipi_raw
MODEM : STOM_MODEM =mt6580_v3750_hspa_modemB18_mmx
LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES hi_IN ta_IN te_IN bn_IN mr_IN gu_IN pa_IN ml_IN kn_IN or_IN
Done!
Elapsed: 00:00:20
RESET FRP
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:18
FEEL THE POWER OF CM2
WBR
sahil2000ind
Old 08-20-2017, 09:40   #44364 (permalink)
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,895
Samsung z1 z130h flashing done with cm2sm 1.04:-
SM S/N: xxxxxxxx Version: 0100
Phone found on COM6
Port open Ok!
LOKE received!
Prepare Ok!
Enter Setup...
Setup Done!
Try download PIT...
Download PIT Ok!
Start flashing!
Flashing dzImage
Flashing sboot.bin
Flashing spl.img
Flashing dzImage-recovery
Flashing rootfs.img
Flashing ramdisk-recovery.img
Flashing csc.img
Flashing SPRDCP.img
Flashing nvitem.bin
Flashing done
Reboot phone...
Phone Disconnected
WBR
sahil2000ind
The Following User Says Thank You to sahil2000ind For This Useful Post:
Old 08-20-2017, 09:46   #44365 (permalink)
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,895
Redmi note3 done with cm2qlm:-
IDENTIFY
Operation : Identify [ v1.09 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_S : 007501E4
ID_BLOCK_L : 7A27A4822A39EFB2C3952362F66494BB
ID_BLOCK_L : 3FB9B312A5F49E4C0B9237324DB96558
ExtInfo : 0x0000C000/00100000/00001000/00001000
Storage : MFR : 0x11 , VENDOR : TOSHIBA , NAME : 032G34
Boot Ok!
Brand     : Xiaomi
ProdName  : kenzo
ProdModel : Redmi Note 3
Device    : kenzo
AndroidVer: 6.0.1
Manufact. : Xiaomi
QLMxCPU   : MSM8952
Done!
Elapsed: 00:00:16
READ PATTERN
Operation : Read PatternLock [ v1.09 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Error : FS verification fail! Encrypted or damaged!
RESET SETTING
Operation : Reset Settings [ v1.09 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP ( Google Reset Protection )
FRP removed!
Done!
Elapsed: 00:00:18
WBR
sahil2000ind
Old 08-20-2017, 10:22   #44366 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,390
samsung b313e format done
Set mode to : SPD6530_SAMSUNG
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
Phone found! [ 21 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6530 , FDLStat : 0000
[0] Flash DIE : 00C8 0060 0019 0000
[0] Flash VEN : GigaDevice , GD25LQ256
[0] Flash CAP : 02000000
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:02:55
Old 08-20-2017, 10:31   #44367 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,390
intex aqua y2 1gb flash done
Loading    : W230IN2_RAM1GB_user_19607_150629.141549.pac
CRVersion  : BP_R1.0.0
PacCPUinfo : SC77xx
PacVersion : W230IN2_RAM1GB_user_19607_150629.141549
FastCheck  : 0x002D09B3EC
Loading files ...
File : fdl1.bin
File : fdl2.bin
File : wnvitem.bin
File : wcnnvitem.bin
File : u-boot-spl-16k.bin
File : wmodem.bin
File : wdsp.bin
File : wcnmodem.bin
File : boot.img
File : recovery.img
File : system.img
File : userdata.img
File : boot_logo.bmp
File : prodnv.img
File : cache.img
File : u-boot.bin
File : SC7731_UMS_IN8G.xml
Load Ok!
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : W230IN2_RAM1GB_user_19607_150629.141549.pac
PacCPUinfo : SC77xx
File : fdl1.bin
File : fdl2.bin
File : wnvitem.bin
File : wmodem.bin
File : wdsp.bin
File : wcnmodem.bin
File : boot.img
File : recovery.img
File : system.img
File : userdata.img
File : prodnv.img
File : cache.img
File : u-boot.bin
3. Insert cable
Phone found! [ 25 ]
Port Opened
Sync...
Sync...
Sending FDL
PickUp loaders from pac
FDL Ready!
Boot Ver : Spreadtrum Boot Block version 1.1
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x18 records
PMTManager : PMT Update Ok!
Flashing now
[FlashProc] : ERASE
Current ID   : ERASEUBOOT
Current Part : uboot
[FlashProc] : Ok!
[FlashProc] : BOOTCODE
Current ID   : SPLLOADER
Current File : u-boot-spl-16k.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_W
Current File : wmodem.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : DSP_W
Current File : wdsp.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_WCN
Current File : wcnmodem.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOT
Current File : boot.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : RECOVERY
Current File : recovery.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : SYSTEM
Current File : system.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : USERDATA
Current File : userdata.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOTLOGO
Current File : boot_logo.bmp
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : FASTBOOT_LOGO
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : FLASH
Current Part : wruntimenv1
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : FLASH_WCN
Current Part : wcnruntimenv1
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : PRODNV
Current File : prodnv.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : CACHE
Current File : cache.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : ERASEMISC
Current Part : misc
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : ERASESD
Current Part : internalsd
[FlashProc] : Ok!
Current ID   : UBOOTLOADER
Current File : u-boot.bin
Flashing now ...
[FlashProc] : Ok!
Elapsed: 00:03:00
3. Insert cable
Phone found! [ 25 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Name  : W230IN2
Model Brand : Intex
Model Device: W230IN2
AndrVersion : 4.4.2
CompileDate : 6/29/2015 6:20:53 AM
Project Ver : S-0-1 14B_dev-keys
Model Ext   : Aqua Y2 1GB
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:23
Old 08-20-2017, 10:33   #44368 (permalink)
Member: 2691025
Thanks Meter: 234
LAVA Iris S8Q Backup read done by grate Cm2
LAVA Iris S8Q
Reading Flash Content now ...
Brand     : LAVA
ProdName  : iris X8q
ProdModel : iris X8q
Device    : iris X8q
AndroidVer: 4.4.2
MTKxCPU   : MT6582
MTKxPRJ   : ALPS.KK1.MP1.V2.12
[Read Ok] : preloader_lava82_sp19w.bin
[Read Ok] : MBR
[Read Ok] : EBR1
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : secro.img
[Read Ok] : logo.bin
[Read Ok] : EBR2
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : userdata.img
[ScatCFG] : MT6582 / V1.1.1 / lava82_sp19w / EMMC
Android Info saved
FW Size : 947 MiB
Scatter saved to : C:\Users\M4 MIRZA\Desktop\MT6582__LAVA__iris_X8q__iris_X8q__4.4.2__ALPS.KK1.MP1.V2.12\
All done!
Done!
Elapsed: 00:05:17
MIRZA ASIM
Old 08-20-2017, 11:09   #44369 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,390
nokia 206 flash done
Connect phone on selected interface...
Core : v2.27 , BB5XG FlashEngine : v10.3
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
CNT : rm872__04.52.image_mh2_059Q318
Flashing phone now...
[Gen] Rules accepted for : XGOLD Generation
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
-> If Windows say "Unrecognized device" / Operation not start
-> Or if Phone start charge - just reinsert battery
-> If flashing freeze - reinsert cable/battery and try again
--- Press phone's power button or insert usb cable! ---
Connection opened successfully
IF Boot Init : 0xF0
IF Resp Len  : 0x0A
IF xCPUID    : XGOLD 213 [XMM2130 QUANTUM]
IF Resp Data  :  1FB300020303010100FF
Sending EBL Loader ...
EBL Loader Ok, 01
EBL Loader ready, AA
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.53_M1S1
Speed accepted, use 6.500.000
FLASHID : EC001230
FLIC conf set, RST set
Boot done!
Check keys...
Check done. Image can be flashed
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 3583710563-----
IMEI 2 : 3583710563-----
PCcode : 059R9X1
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : C:\InfinityBox\BEST\Backup\Cert\3583710563-----_XG213_CRT.rpl
Settings : EDM [0x8] , Block Mode , Fast CRC , Verify
   ===Flashing [CNT]===
File : rm872__04.52.image_mh2_059Q318
Image : package_mh2_059Q318.image.fls
Sec-pack found, sending ...
Sec-pack sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x42100000 , Len : 0x01D20000
Erasing, wait ...
Erase done, time : 00:01:12
Write , Start : 0x42100000 , Len : 0x01160000
Flashing , wait ...
Region flash done, time : 00:00:25
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
Erase done, time : 00:00:02
No write data, skip
CRC check passed , 0x152B
Flashing done!
Total flash time : 00:01:40
Reboot phone now...
Reading Phone Info....
Connected phone -   206
Software Info:     V 04.52 30-06-13 RM-872 (c) Nokia
IMEI:  35837105631----
PPM version :   V 04.52 30-06-13 RM-872 (c) Nokia             MH2
Product code:  059R9X1
Wait, when phone will be ready ...
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Processing After Flash Defaults...
FullFactorySet... Ok!
UserDataDefaultsSet...OK!
ServiceDefaultsSet... Ok!
LeaveDefaultsSet... Ok!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Check and Upload User Certificates ...
Total - 58 certs
Certificates found, skip upload ...
AfterFlash operations done ;D
Done!
Elapsed: 00:02:41
Phone found!
Series 40 Device detected!
read info...  - Ok
Phone disconected!
Old 08-20-2017, 11:12   #44370 (permalink)
rmstk's Avatar
Member: 2484144
Sonork: QQ_3272429273
Thanks Meter: 309
Symphony V46 Flashing Success
Scatter Load Ok , BaseBand : MT6580 , Project : rs618 , Storage : EMMC
Files found : 11 , Set to Flash : 10
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : Symphony
Device Model : V46
Device CPU : MT6580
Device IntName : V46
Device Version : 5.1
Device Compile : 6/6/2016 7:24:46 AM
Device Project : RS618S_V46_V9.0_20160606
Device ExtInfo : V46
Ready to Flash!
Start at : [8/20/2017 / 2:16:40 PM]
======= Flash
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 70010045453445413401032D87439381
[eMMC] : FLASH_VEN : 0x70 , OEM : 0100
[eMMC] : FLASH_INF : [KINGSTON] , 4AE4E
[eMMC] : FLASH_CID : 70010045453445413401032D87439381
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000
[eMMC] : FLASH_LEN : 0x00000000E2000000
[eMMC] : FLASH_UCP : 3616 MiB [eMMC 4 GiB]
DEV RID : 0xAF60FF252C0D934EC441EA5CA2AE5F46
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6580 , Project : rs618 , Storage : EMMC
BL : BatteryLevel : 3815 mV
BL : BatteryLevel Ok
Erase : 0x0000000001C80000-0x0000000003320000
Erase : 0x00000000050A0000-0x00000000DBEE0000
Use : preloader_rs618.bin
PartCount : 0016
Repartition Done!
Use FLN Mode
Flash now : LK
Image Flash Ok
Flash now : BOOT
Image Flash Ok
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : TEE1
Image Flash Ok
Flash now : TEE2
Image Flash Ok
Flash now : SECRO
Image Flash Ok
Flash now : SYSTEM
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USERDATA
Image Flash Ok
Flash Write Done, time used : 00:03:46
Processing : Verify
Verify Passed : LK
Verify Passed : TEE1
Verify Passed : TEE2
Verify Passed : SECRO
Verify Passed : SYSTEM
Verify Passed : USERDATA
Data Verify Done, time used : 00:00:06
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:04:09
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.79870 seconds with 9 queries
