Old 08-26-2017, 10:36   #44536 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,078
Qmobile X350 MT6582 Read Pattren Done With Infinity CM2
Operation : Read Pattern/DP Lock [ v1.58 ]
Wait for phone...
Phone found! [ 20 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 15010051375853414201B25CDEFE126B
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BASX7
[eMMC] : FLASH_CID : 15010051375853414201B25CDEFE126B
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xD9C8F395AB248765ECC0CF4912179D75
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Reading data ...
Get Locks ...
PatternLock Sequnce : 5428
Done!
Elapsed: 00:00:18
Reconnect Power/Cable!
The Following User Says Thank You to azhergoga007 For This Useful Post:
Old 08-26-2017, 10:40   #44537 (permalink)
rehmani's Avatar
Member: 333199
Sonork: may i help u just pm me
Thanks Meter: 2,390
nokia 1011 format done
Operation : Format FileSystem [ v1.56 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 137 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0000
BB_CPU_SN : D262C4718F1910A2FF0216A516362482
BROM Protocol Version : 05
BROM Status : 0000
Comm Status : 0000
EXBL Status : Alive [ USB Load Active ]
Switch to BL done
BL Version : 01
Setting...
Setting done , result code 0x8000
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_eMP_NkP.fg
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x8B
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW
[0] : FLASH_DIE : 00EF 0060 0018 0000
[0] : FLASH_LEN : 0x01000000
Executing FFS FORMAT now...
FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000
DA_RET   : DA_IN_PROGRESS
DA_RET   : FORMAT_DONE
Done!
Elapsed: 00:00:27
The Following User Says Thank You to rehmani For This Useful Post:
Old 08-26-2017, 10:41   #44538 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,390
micromaxx a106 flash done
Operation : Check / Read Info [ v1.56 ]
Wait for phone...
Phone found! [ 31 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A4838473264040503A1EBBF91AD
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d2G8
[eMMC] : FLASH_CID : 90014A4838473264040503A1EBBF91AD
DEV RID    : 0xC1F94A5C55B9C95B7BC348D11D6327BD
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand     : Micromax
ProdName  : A106
ProdModel : Micromax A106
Device    : A106
AndroidVer: 4.4.2
MTKxCPU   : MT6582
MTKxPRJ   : ALPS.KK1.MP1.V2.10
SECURITY :
IMEI_SW [1] : 91140115296----
IMEI_SW [2] : 91140115346----
BTMAC Addr  : D83C69618EF5
WiFi MAC    : D83C6960CB73
MODEM :
BaseBand  : MT6582_S00_MOLY_WR8_W1315_MD_WG_MP_V34_1_wg_n
Done!
Elapsed: 00:00:08
Operation : HW Test [ v1.56 ]
Wait for phone...
Phone found! [ 31 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[Processing] FlashMemory Read-Write test
[eMMC] : [HYNIX] , d2G8 , 0x1D2000000 , 7456 MiB
[eMMC] : CID : 90014A4838473264040503A1EBBF91AD
[eMMC] : MODE : SQ-WR
[PASSED] : eMMC RW Check #1 Ok!
[eMMC] : MODE : RA-WR
[PASSED] : eMMC RW Check #2 Ok!
[eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed!
All Done!
Done!
Elapsed: 00:00:48
Scatter Load Ok , BaseBand : MT6582 , Project : s4700 , Storage : EMMC
Files found : 12 , Set to Flash : 11
Ready to Flash!
Operation : Flash [ v1.56 ]
======= Flash
Wait for phone...
Phone found! [ 31 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : s4700 , Storage : EMMC
Setting : AFF verify :  Disabled
Setting : HW verify :  Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3654 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x000000007D280000
Flash Pre-Erase Done, time used : 00:00:03
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_s4700.bin
Preloader Sent , Init passed
PartCount : 0014
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EBR2
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:32
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:02:47
Old 08-26-2017, 10:43   #44539 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,390
ziox a19 format done
Chinese Miracle II  [SPD module] v 1.27
Set mode to : SPD6531
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
 ====  Wait for phone...
Phone found! [ 51 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00C8 0060 0016 0000
[0] Flash VEN : GigaDevice , GD25LQ32
[0] Flash CAP : 00400000
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:09
Operation : Read FullFlash [ v1.27 ]
3. Insert battery
Phone found! [ 51 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Read Flash Content
Read Ok , collect info
Set FileInfo :
Model Vendor : ziox
Model Name   : zx19
Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_GD25LQ32__ziox-zx19.bin
Done!
Elapsed: 00:01:08
Old 08-26-2017, 11:00   #44540 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,078
Qmobile I2 SPD65xx Logo Stuck Recover By Formte With Infinity CM2
Phone found! [ 30 ]
Port Opened
Sync...
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v4 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Done!
Elapsed: 00:00:23
Old 08-26-2017, 11:17   #44541 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,390
sansui s451720 4g read rom done
Wait for phone...
Phone found! [ 78 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x93
eMMC Flash : 504E01FE35394A318260124BFBE5961F
[eMMC] : FLASH_VEN : 0xFE , OEM : 014E
[eMMC] : FLASH_INF : [MICRON] , K59J1
[eMMC] : FLASH_CID : FE014E50314A39354B1260821F9643FB
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000001D3000000
[eMMC] : FLASH_UCP : 7472 MiB [eMMC 8 GiB]
DEV RID    : 0xC1F94A5C5A6FA0035E7CDBC887846AD0
SOC VERIFY : C1
Boot Ok!
Brand     : S451720
ProdName  : S451720
ProdModel : S451720
Device    : S451720
AndroidVer: 6.0
MTKxCPU   : MT6735
MTKxPRJ   : alps-mp-m0.mp1-V2.39.1_len6735m.65u.m_P26
SECURITY :
IMEI_SW [1] : 91151900103----
IMEI_SW [2] : 91151900103----
BTMAC Addr  : 000046033501
WiFi MAC    : 000000000000
MODEM :
BaseBand  : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V79_P9_1_lwg_n
EXTRA :
LCD : Not info available :(
LCD Res : 854x480
TOUCH [0] : ftxxx_m
CAM [0] : s5k5e2ya_mipi_raw
CAM [1] : s5k5e8yx_mipi_raw
CAM [2] : gc2355_mipi_raw
MODEM : ZH086V20_G4W18L13740
LOCALE : K_PRODUCT_LOCALES =en_US hi_IN te_IN ml_IN mr_IN pa_IN ta_IN ur_PK ar_EG
Done!
Elapsed: 00:00:40
Operation : Read Flash [ v1.56 ]
Wait for phone...
Phone found! [ 78 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading Flash Content now ...
xGPT : Normalize settings Ok!
Brand     : S451720
ProdName  : S451720
ProdModel : S451720
Device    : S451720
AndroidVer: 6.0
MTKxCPU   : MT6735
[Read Ok] : preloader_len6735m_65u_m.bin
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : logo.bin
[Read Ok] : secro.img
[Read Ok] : tz1.img
[Read Ok] : tz2.img
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : userdata.img
[ScatCFG] : MT6737M / V1.1.2 / len6735m_65u_m / EMMC
Android Info saved
MAUI Meta DB saved
HWConfig Info saved
FW Size : 2895 MiB
Scatter saved to : W:\china mobile\sansui\s451720 4g\MT6735__S451720__S451720__S451720__6.0__alps-mp-m0.mp1-V2.39.1_len6735m.65u.m_P26\
All done!
Done!
Elapsed: 00:09:55
Old 08-26-2017, 11:33   #44542 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,078
Samsung G30 MT6572 Pattren Disable Fix Done Only Formate With Infinity CM2
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 20 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 7001005331303030340855539FF0527D
[eMMC] : FLASH_VEN : 0x70 , OEM : 0100
[eMMC] : FLASH_INF : [KINGSTON] , 40001
[eMMC] : FLASH_CID : 7001005331303030340855539FF0527D
[eMMC] : FLASH_LEN : 0x00000000E4000000
[eMMC] : FLASH_UCP : 3648 MiB [eMMC 4 GiB]
DEV RID : 0xD9C8F39557ED5B7C5638821037037B95
EXT RAM : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:29
Old 08-26-2017, 12:18   #44543 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 3,971
QMobile T480 write factory firmware Done :)
Operation : Flash [ v1.25 ]
======= Flash
Files set for flashing :
[ MCU ] : QMobile_T480_W822_M03_S08_150831.pac
CRVersion  : BP_R1.0.0
PacCPUinfo : SC77xx
PacVersion : QMobile_T480_W822_M03_S08_150831
File : fdl1.bin
File : fdl2.bin
File : nvitem.bin
File : nvitem_wcn.bin
File : prodnv.img
File : u-boot-spl-16k.bin
File : SC7702_sc7731g_band128.bin
File : DSP_DM_G2.bin
File : SC8800G_x30g_wcn_dts_modem.bin
File : boot.img
File : recovery.img
File : system.img
File : userdata.img
File : logo.bmp
File : Logo1.bmp
File : cache.img
File : u-boot.bin
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
Phone found! [ 179 ]
Port Opened
Sync...
Sync...
Sending FDL
PickUp loaders from pac
FDL Ready!
Boot Ver : Spreadtrum Boot Block version 1.1
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x18 records
PMTManager : PMT Update Ok!
Flashing now
[FlashProc] : CODE
Current ID : PRODNV
Current File : prodnv.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : ERASEUBOOT
Current Part : uboot
[FlashProc] : Ok!
[FlashProc] : BOOTCODE
Current ID   : SPLLOADER
Current File : u-boot-spl-16k.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_W
Current File : SC7702_sc7731g_band128.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : DSP_W
Current File : DSP_DM_G2.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_WCN
Current File : SC8800G_x30g_wcn_dts_modem.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOT
Current File : boot.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : RECOVERY
Current File : recovery.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : SYSTEM
Current File : system.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : USERDATA
Current File : userdata.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOTLOGO
Current File : logo.bmp
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : FASTBOOT_LOGO
Current File : Logo1.bmp
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : FLASH
Current Part : wruntimenv1
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : FLASH_WCN
Current Part : wcnruntimenv1
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : CACHE
Current File : cache.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : ERASEMISC
Current Part : misc
[FlashProc] : Ok!
Current ID   : UBOOTLOADER
Current File : u-boot.bin
Flashing now ...
[FlashProc] : Ok!
Elapsed: 00:09:49
The Following User Says Thank You to syed tuqeer For This Useful Post:
Old 08-26-2017, 12:25   #44544 (permalink)
.::Mustafa::.'s Avatar
Member: 1857951
Sonork: 100.1638512
Thanks Meter: 200
huawei Y520-u22 dead Recover done with cm2 by .::Mustafa::.
Scatter Load Ok , BaseBand : MT6572 , Project : ckt72_we_72_kk , Storage : EMMC
Files found : 11 , Set to Flash : 10
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 227 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A483447326111020456C0ECB2AF
[eMMC] : FLASH_INF : [HYNIX] , a2G4
[eMMC] : FLASH_CID : 90014A483447326111020456C0ECB2AF
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xC355518824998AE2514A43C774D2D553
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : ckt72_we_72_kk , Storage : EMMC
Setting : AFF verify : Enabled
BL : BatteryLevel : 3666 mV
Erase : 0x0000000002900000-0x0000000090040000
Flash Pre-Erase Done, time used : 00:00:00
Use : preloader_ckt72_we_72_kk.bin
PartCount : 0013
Repartition Done!
Use FLN Mode
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:03:58
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:17
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:04:35
The Following User Says Thank You to .::Mustafa::. For This Useful Post:
Old 08-26-2017, 13:20   #44545 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,390
micromaxx a069 flash done
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A4834473164040501A2B707A175
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040501A2B707A175
DEV RID    : 0xC1F94A5C8D42A9D5A906310090575503
SOC VERIFY : C1
Boot Ok!
Brand     : Micromax
ProdName  : A069
ProdModel : Micromax A069
Device    : A069
AndroidVer: 4.4.2
MTKxCPU   : MT6572
MTKxPRJ   : ALPS.KK1.MP7.V1
SECURITY :
IMEI_SW [1] : 9114000001-----
IMEI_SW [2] : 9114000006-----
BTMAC Addr  : D83C69E56705
WiFi MAC    : D83C69E4A383
MODEM :
BaseBand  : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V36_1_2g_n
EXTRA :
LCD [0] : ili9806e_fwvga_dsi_vdo_txd
LCD [1] : hx8379c_fwvga_dsi_vdo_tcl
LCD [2] : ili9806e_fwvga_dsi_vdo_dj
LCD [3] : ili9806e_fwvga_dsi_vdo_glass
LCD Res : 854x480
TOUCH [0] : GT9XX
CAM [0] : ov5646_mipi_yuv
CAM [1] : gc0329_yuv
CAM [2] : sp0a19_yuv
MODEM : mt6572_s5200ap_gprs_gemini
LOCALE : en_US hi_IN de_DE fr_FR es_ES in_ID it_IT ms_MY pt_BR vi_VN tr_TR ar_EG zh_CN ru_RU hdpi
Done!
Elapsed: 00:00:52
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[eMMC] : [HYNIX] , d1G4 , 0xE9000000 , 3728 MiB
[eMMC] : CID : 90014A4834473164040501A2B707A175
All Done!
Done!
Elapsed: 00:00:45
Scatter Load Ok , BaseBand : MT6572 , Project : s5200ap , Storage : EMMC
Ready to Flash!
======= Flash
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : s5200ap , Storage : EMMC
BL : BatteryLevel : Unknown (not supported or without battery)
Erase : 0x0000000002900000-0x0000000083B40000
Flash Pre-Erase Done, time used : 00:00:06
Use : preloader_s5200ap.bin
PartCount : 0013
Repartition Done!
Use FLN Mode
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:55
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:44
Old 08-26-2017, 13:23   #44546 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,078
Read Code Done BY Great infinity CM2
Wait for phone...
Phone found! [ 37 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 451302E93665DE1750A27B35506DC143
Setting...
Setting done , result code 0x000E
BROM stage done
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09
[0] : FLASH_DIE : 00C2 0020 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Backup done
FAT_RANGE : 0x003BF000-0x003FDFFF , LEN : 0x0003F000
Done!
Elapsed: 00:00:11
Old 08-26-2017, 13:26   #44547 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,078
Qmobile X700 Pro Lite MT6580 FRP Done With Great Infinity CM2
Wait for phone...
Phone found! [ 20 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
eMMC Flash : 90014A483847316505074EB7652663B3
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A483847316505074EB7652663B3
DEV RID : 0xD9C8F3959F99E01676E218F494969D87
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:17
Old 08-26-2017, 13:32   #44548 (permalink)
Member: 654997
Thanks Meter: 3,971
QMobile X33 remove frp Lock Done :)
Operation : Check/Read Info [ v1.25 ]
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name  : QMobile_X33
Model Brand : QMobile
Model Device: QMobile_X33
AndrVersion : 6.0
BaseBand CPU: QMOBILE_X33
CompileDate : 2/9/2017 9:24:43 AM
Project Ver : MRA58K release-keys
Model Ext   : QMobile X33
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:26
Operation : Format File System / Reset Settings [ v1.25 ]
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:28
Old 08-26-2017, 14:00   #44549 (permalink)
Member: 654997
Thanks Meter: 3,971
QMobile X33 Read factory firmware Done :)
Set mode to : SP [SC773x] eMMC [Android 6.x]
Operation : Read FullFlash [ v1.25 ]
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
[FW_READER] : Prepare Ok!
- > Wait phone connected ...
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
AndrVersion : 6.0
[Read Mode] : HSUSB : 0x3000
[FW_READER] : Reading Firmware Now ...
[Read Ok] : u-boot-spl-16k.bin
[Read Ok] : u-boot.bin
[Read Ok] : prodnv.img
[Read Ok] : sc7731C_CP0_modem.bin
[Read Ok] : DSP_DM_Gx.bin
[Read Ok] : nvitem_w.bin
[Read Ok] : sc8830g_modem_CP2_WCN_Trunk_W16.28.5_Release.bin
[Read Ok] : nvitem_wcn.bin
[Read Ok] : logo_480x800.bin
[Read Ok] : fblogo_480x800.bin
[Read Ok] : sysinfo.img
[Build Ok] : cache.img
[Build Ok] : userdata.img
AndroidInfo created
Firmware Size : 2625 MiB
Saved to : F:\1+Flashing Software\1+Infinity Box\CM2SPD\phdata\backup\QMOBILE_X33_QMobile_X33_6.0_MRA58K_release-keys_QMobile_X33\
Done!
Elapsed: 00:12:53
Old 08-26-2017, 14:21   #44550 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,078
Qmobile M95 SPD77xx Logo Hang Recover Done By Flash With Infinity CM2
Card found: S/N : A19EC787 , v0136
Set mode to : SP [SC773x] eMMC [Android 5.x]
Set mode to : [AltLDR] SP [SC773x] eMMC [Android 5.x]
Loading : last.pac
PacCPUinfo : SC7730_UMS
PacVersion : m95
FastCheck : 0x005360DB6E
Loading files ...
File : fdl1.bin
File : fdl2.bin
File : nvitem.bin
File : prodnv.img
File : SC7702_sc7731g_band128_SC2662H.bin
File : boot.img
File : recovery.img
File : system
File : userdata.img
File : hong1.bmp
File : hd720_kpoc_charge.bmp
File : cache.img
File : u-boot.bin
File : SC7730_UMS.xml
Load Ok!
Operation : Flash [ v1.27 ]
======= Flash
[ MCU ] : last.pac
PacVersion : m95
File : fdl1.bin
File : fdl2.bin
File : nvitem.bin
File : prodnv.img
File : boot.img
File : recovery.img
File : system
File : userdata.img
File : hong1.bmp
File : cache.img
File : u-boot.bin
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
Phone found! [ 30 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x17 records
Flashing now
[FlashProc] : CODE
Current ID : PRODNV
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
[FlashProc] : Ok!
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current File : SC7702_sc7731g_band128_SC2662H.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : DSP_W
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOT
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : SYSTEM
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current File : hong1.bmp
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current File : hd720_kpoc_charge.bmp
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : FLASH
[FlashProc] : Ok!
[FlashProc] : ERASE
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : CACHE
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current Part : misc
[FlashProc] : Ok!
Flashing now ...
[FlashProc] : Ok!
Elapsed: 00:07:14
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.85666 seconds with 9 queries
