Old 08-27-2017, 08:27   #44566 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 14,519
Smile VGO Tel i251 read user code done
Operation : Read UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 27 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 50A1126D73CCB7009EA1D346D9E80590
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09
[0] : FLASH_DIE : 00C2 0020 0016 0000
[0] : FLASH_LEN : 0x00300000
SDS_INFO : 0x002FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Read ExtData
Sorting ExtData
Reading UserCode
Active : Yes , Code : 922325
PLock|MobTrack : Not active
Done!
Elapsed: 00:00:26
Reconnect Power/Cable!
The Following 2 Users Say Thank You to Akhtar Ali Jatt For This Useful Post:
Old 08-27-2017, 08:28   #44567 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Qmobile i7i Flashing Done
Set mode to : SP [SC773x] eMMC [Android 5.x]
Infinity SC Firmware Detected
FW Size : 1239 MiB
Load Ok!
File Info
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand   : Qmobile
Device Model   : QMobile_i7i
Device CPU     : QMobile_i7i
Device IntName : QMobile_i7i
Device Version : 5.1
Device Compile : 4/6/2016 9:24:37 AM
Device Project : QMobile_i7i_MP_06_04
Device ExtInfo : QMobile i7i
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : SC77xx Infinity Package
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
 -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
 ====  Wait for phone...
Phone found! [ 20 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v4 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x17 records
PMTManager : PMT Update Ok!
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write FSImage : prodnv.img
Write Data ...
Write Data Ok!
Write CodeData : sc7731g_CP0_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Write CodeData : sc8830g_modem_CP2_WCN_14D_W15.43.3_Release.bin
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Write CodeData : logo_480x854.bin
Write Data ...
Write Data Ok!
Write CodeData : fblogo_480x854.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system.img
Write Data ...
Write Data Ok!
Write FSImage : cache.img
Write Data ...
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Erase Block : MISC
Erase block ...
Block erase Ok!
Write FSImage : userdata.img
Write Data ...
Write Data Ok!
Elapsed: 00:02:16
Old 08-27-2017, 08:38   #44568 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Qmobile X6i 3G Format Done
Set mode to : SP [SC7715] NAND [Generic]
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
3. Insert cable
Phone found! [ 29 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC7715 Loader NAND v1.1 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected NAND Flash , Structure detect Ok!
Formatting NAND Flash
Format UserData
Format Ok!
Format Cache
Format Ok!
Done!
Elapsed: 00:00:18
Old 08-27-2017, 08:38   #44569 (permalink)
rehmani's Avatar
Member: 333199
Sonork: may i help u just pm me
Thanks Meter: 2,390
samsung b313e format done
Chinese Miracle II  [SPD module] v 1.27
Set mode to : SPD6530_SAMSUNG
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
Phone found! [ 14 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6530 , FDLStat : 0000
[0] Flash DIE : 00C8 0060 0019 0000
[0] Flash VEN : GigaDevice , GD25LQ256
[0] Flash CAP : 02000000
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:02:27
The Following User Says Thank You to rehmani For This Useful Post:
Old 08-27-2017, 08:39   #44570 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 3,973
QMobile I2 POWER Remove FRP Lock Done :)
Operation : Check/Read Info [ v1.25 ]
3. Insert cable
Phone found! [ 179 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name  : i2_POWER
Model Brand : QMobile
Model Device: i2_POWER
AndrVersion : 6.0
BaseBand CPU: SP7731CEA
CompileDate : 11/28/2016 8:41:14 AM
Project Ver : QMobile_i2_POWER_MP_08_11
Model Ext   : QMobile i2 POWER
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:24
Operation : Format File System / Reset Settings [ v1.25 ]
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:29
The Following User Says Thank You to syed tuqeer For This Useful Post:
Old 08-27-2017, 08:49   #44571 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,107
Callme C881 SPD6531 Logo Stuck Recover Done Only Formate With Infinity CM2
Card found: S/N : A19EC787 , v0136
Set mode to : SPD6531
3. Insert battery
Phone found! [ 11 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00EF 0040 0016 0000
[0] Flash VEN : Winbond , W25Q32
[0] Flash CAP : 00400000
Format Block Done!
Done!
Elapsed: 00:00:11
The Following 2 Users Say Thank You to azhergoga007 For This Useful Post:
Old 08-27-2017, 09:04   #44572 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,895
Mmx q450 flashing done with cm2qlm:-
Operation : Identify [ v1.09 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 0D2C25ED
ID_BLOCK_I : 007050E1
ID_BLOCK_L : FA0A609E39A5D2DD8AFF117EB9801038
ID_BLOCK_L : E79E208B8C1747CCC12C615E545B5576
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000
Boot Ok!
Brand     : Micromax
ProdName  : Q450
ProdModel : Micromax Q450
Device    : Q450
AndroidVer: 5.1.1
Manufact. : Micromax
QLMxCPU   : MSM8916
Done!
Elapsed: 00:00:19
FLASH FW
Loading firmware ...
Load Ok!
Operation : Flash [ v1.09 ]
ForceFlashing : Disabled
Verify FW package ...
Verification passed!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Pickup loader from firmware package
Boot Ok!
Files in Chain : 172
Flashing now
Flashing : NON-HLOS.bin
Flashing : sbl1.mbn
Flashing : sbl1.mbn
Flashing : emmc_appsboot.mbn
Flashing : rpm.mbn
Flashing : rpm.mbn
Flashing : tz.mbn
Flashing : tz.mbn
Flashing : hyp.mbn
Flashing : hyp.mbn
Flashing : misc.img
Flashing : splash.img
Flashing : sec.dat
Flashing : boot.img
Flashing : system_1.img
Flashing : system_2.img
Flashing : system_3.img
Flashing : system_4.img
Flashing : system_5.img
Flashing : system_6.img
Flashing : system_7.img
Flashing : system_8.img
Flashing : system_9.img
Flashing : system_10.img
Flashing : system_11.img
Flashing : system_12.img
Flashing : system_13.img
Flashing : system_14.img
Flashing : system_15.img
Flashing : system_16.img
Flashing : system_17.img
Flashing : system_18.img
Flashing : system_19.img
Flashing : system_20.img
Flashing : system_21.img
Flashing : system_22.img
Flashing : system_23.img
Flashing : system_24.img
Flashing : system_25.img
Flashing : system_26.img
Flashing : system_27.img
Flashing : system_28.img
Flashing : system_29.img
Flashing : system_30.img
Flashing : system_31.img
Flashing : system_32.img
Flashing : system_33.img
Flashing : persist_1.img
Flashing : cache_1.img
Flashing : cache_2.img
Flashing : cache_3.img
Flashing : cache_4.img
Flashing : cache_5.img
Flashing : recovery.img
Flashing : config.img
Flashing : userdata_1.img
Flashing : userdata_2.img
Flashing : userdata_3.img
Flashing : userdata_4.img
Flashing : userdata_5.img
Flashing : userdata_6.img
Flashing : userdata_7.img
Flashing : userdata_8.img
Flashing : userdata_9.img
Flashing : userdata_10.img
Flashing : userdata_11.img
Flashing : userdata_12.img
Flashing : userdata_13.img
Flashing : userdata_14.img
Flashing : userdata_15.img
Flashing : userdata_16.img
Flashing : userdata_17.img
Flashing : userdata_18.img
Flashing : userdata_19.img
Flashing : userdata_20.img
Flashing : userdata_21.img
Flashing : userdata_22.img
Flashing : userdata_23.img
Flashing : userdata_24.img
Flashing : userdata_25.img
Flashing : userdata_26.img
Flashing : userdata_27.img
Flashing : userdata_28.img
Flashing : userdata_29.img
Flashing : userdata_30.img
Flashing : userdata_31.img
Flashing : userdata_32.img
Flashing : userdata_33.img
Flashing : userdata_34.img
Flashing : userdata_35.img
Flashing : userdata_36.img
Flashing : userdata_37.img
Flashing : userdata_38.img
Flashing : userdata_39.img
Flashing : userdata_40.img
Flashing : userdata_41.img
Flashing : userdata_42.img
Flashing : userdata_43.img
Flashing : userdata_44.img
Flashing : userdata_45.img
Flashing : userdata_46.img
Flashing : userdata_47.img
Flashing : userdata_48.img
Flashing : userdata_49.img
Flashing : userdata_50.img
Flashing : userdata_51.img
Flashing : userdata_52.img
Flashing : userdata_53.img
Flashing : userdata_54.img
Flashing : userdata_55.img
Flashing : userdata_56.img
Flashing : userdata_57.img
Flashing : userdata_58.img
Flashing : userdata_59.img
Flashing : userdata_60.img
Flashing : userdata_61.img
Flashing : userdata_62.img
Flashing : userdata_63.img
Flashing : userdata_64.img
Flashing : userdata_65.img
Flashing : userdata_66.img
Flashing : userdata_67.img
Flashing : userdata_68.img
Flashing : userdata_69.img
Flashing : userdata_70.img
Flashing : userdata_71.img
Flashing : userdata_72.img
Flashing : userdata_73.img
Flashing : userdata_74.img
Flashing : userdata_75.img
Flashing : userdata_76.img
Flashing : userdata_77.img
Flashing : userdata_78.img
Flashing : userdata_79.img
Flashing : userdata_80.img
Flashing : userdata_81.img
Flashing : userdata_82.img
Flashing : userdata_83.img
Flashing : userdata_84.img
Flashing : userdata_85.img
Flashing : userdata_86.img
Flashing : userdata_87.img
Flashing : userdata_88.img
Flashing : userdata_89.img
Flashing : userdata_90.img
Flashing : userdata_91.img
Flashing : userdata_92.img
Flashing : userdata_93.img
Flashing : userdata_94.img
Flashing : userdata_95.img
Flashing : userdata_96.img
Flashing : userdata_97.img
Flashing : userdata_98.img
Flashing : userdata_99.img
Flashing : userdata_100.img
Flashing : userdata_101.img
Flashing : userdata_102.img
Flashing : userdata_103.img
Flashing : userdata_104.img
Flashing : gpt_main0.bin
Flashing : gpt_backup0.bin
Flash sequence completed!
Records in Chain : 26
Processing records now
Records sequence completed!
Boot settings configured!
Flashing done!
Done!
Elapsed: 00:06:37
WBR
sahil2000ind
The Following User Says Thank You to sahil2000ind For This Useful Post:
Old 08-27-2017, 10:01   #44573 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,107
Qmobile X25 MT6572 Logo Reset Fix By Flashing With Infinity CM2
Card found : S/N : A19EC787 , v0136
Scatter Load Ok , BaseBand : MT6572 , Project : s4011 , Storage : EMMC
Files found : 11 , Set to Flash : 10
Device Brand : QMobile
Device Model : X25
Device CPU : MT6572
Device IntName : X25
Device Version : 4.4.2
Device Compile : 7/18/2014 4:51:01 PM
Device Project : ALPS.KK1.MP6.V1
Device ExtInfo : QMobile X25
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 20 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164040509A137505175
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040509A137505175
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xD9C8F39582EC8AB84EF3ED7D03EA70C9
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : s4011 , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3860 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x00000000E5E00000
Flash Pre-Erase Done, time used : 00:00:03
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_s4011.bin
Preloader Sent , Init passed
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:22
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:03
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:02:44
Old 08-27-2017, 10:04   #44574 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,107
Micromax S1 MT6582 Logo Hang Fix Only Formate With Infinity CM2
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 20 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x87
eMMC Flash : 90014A483847316505079092247F62CD
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A483847316505079092247F62CD
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xD9C8F395EFB6CA79D15D93AAC3FFA496
EXT RAM : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:37
Old 08-27-2017, 11:09   #44575 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,336
Moto x1021 reset by cm2-ast
Infinity-Box Android Service Tool [AST] v1.01
Operation : Reset Settings [ v1.01 ]
Mode : Format FS
Waiting for device in fastboot mode ...
1. Power off device. Press and hold 'VOL DOWN' button
2. Insert USB cable, hold button until device will be found!
Device not found! Check cable, drivers and conection!
Operation : Identify [ v1.01 ]
Connect Ok!
Main Info  ============
CPU      : MSM8210 CS
CID      : 0x0007
IMEI     : 359300050735910
UID      : B11AD10112000000000000000000
Model Info ============
DevModel : XT1021
IntName  : condor
SW Info ============
DevSWVer : Blur_Version.23.201.3.condor_retgb.retgb.en.GB
DevQCVer : AU_LINUX_ANDROID_LNX.LA.3.5.1_RB1.04.04.02.048.045
BootLDRv : 500E
HW Info ============
eMMCInfo : 4GB Micron REV=06 PRV=12 TYPE=17
DRAMInfo : 1024MB Elpida S4 SDRAM DIE=4Gb
Lock Info ============
BLUnlock : no
WarrantyVoid : no
Done!
Elapsed: 00:00:20
Mode : Format FS
Connect Ok!
Block [1] ERASE OK!
Block [2] ERASE OK!
Done!
Elapsed: 00:00:11
The Following User Says Thank You to Kirumira For This Useful Post:
Old 08-27-2017, 12:46   #44576 (permalink)
Member: 953334
Sonork: 100.1614005
Smile LG LS755 Reset Settings/Format FS Done
Operation : Identify [ v1.03 ]
2. PRESS and HOLD VOLUME UP KEY!
3. Insert USB cable, wait until Download mode screen will appear
Wait for phone...
Connection opened successfully!
Waiting for loader ...
Handshake passed!
Collect info...
Running : MiniOS 3.0 , ver.1.1 , with proto ver.01000004
HWInfo  : BaseBand : MT6755
HWInfo  : ChargeLv : 50%
HWInfo  : MEM_INFO : QE13MB , MEM_LEN : 0x01D1F000 [eMMC 16 GiB]
DevInfo : Model : LGLS755 , Type : LS755ZV8
DevInfo : ANDROID 6.0.1
DevInfo :   PSN : CT01S160825000332 , PID : LGLS755PRYHB6OVR
DevInfo : IMEI  : 356956286717866
DevInfo : SecMode : S , Build : U , RCT : 000F4240
SWInfo  : SWver : ZV8 , SW : LS755ZV8_05
SWInfo  : FacSW : LS755ZV8_05
RegInfo : Region : US , Provider : SPR
Prepare passed, mode 0x01
Boot done!
Brand     : lge
ProdName  : mk6p55_spr_us
ProdModel : LGLS755
Device    : mk6p55
AndroidVer: 6.0.1
SWVersion : LGLS755AT-00-ZV8-SPR-US-JUN-01-2017+05
Manufact. : LGE
LGMxCPU   : MT6755
Done!
Elapsed: 00:00:18
Operation : Reset Settings/Format FS [ v1.03 ]
Wait for phone...
Handshake passed!
Collect info...
Boot done!
Format UserData
Format Cache
Format done
Erase FRP#0 block Ok!
Done!
Elapsed: 00:01:11
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post:
Old 08-27-2017, 12:49   #44577 (permalink)
Member: 953334
Sonork: 100.1614005
Smile LG LS990 Flashing Done
Infinity-Box LG Service Tool [ LGS ] v1.03
FType   : TOT file
BB_Gen  : QLM
Model   : LGLS990
Version : LS990ZV4
SWInfo  : user
File [0] : PrimaryGPT
File [1] : modem
File [2] : sbl1
File [3] : dbi
File [4] : aboot
File [5] : rpm
File [6] : tz
File [7] : boot
File [8] : persist
File [9] : recovery
File [10] : rct
File [11] : misc
File [12] : laf
File [13] : factory
File [14] : system
File [15] : system
File [16] : system
File [17] : system
File [18] : system
File [19] : system
File [20] : system
File [21] : system
File [22] : system
File [23] : system
File [24] : system
File [25] : system
File [26] : system
File [27] : system
File [28] : system
File [29] : system
File [30] : system
File [31] : system
File [32] : system
File [33] : system
File [34] : system
File [35] : system
File [36] : system
File [37] : system
File [38] : system
File [39] : system
File [40] : system
File [41] : cache
File [42] : cache
File [43] : cache
File [44] : cache
File [45] : cache
File [46] : cache
File [47] : cache
File [48] : userdata
File [49] : userdata
File [50] : userdata
File [51] : userdata
File [52] : userdata
File [53] : userdata
File [54] : userdata
File [55] : userdata
File [56] : userdata
File [57] : userdata
File [58] : userdata
File [59] : userdata
File [60] : userdata
File [61] : userdata
File [62] : userdata
File [63] : userdata
File [64] : userdata
File [65] : userdata
File [66] : userdata
File [67] : userdata
File [68] : userdata
File [69] : userdata
File [70] : userdata
File [71] : userdata
File [72] : userdata
File [73] : userdata
File [74] : userdata
File [75] : userdata
File [76] : userdata
File [77] : userdata
File [78] : userdata
File [79] : userdata
File [80] : userdata
File [81] : userdata
File [82] : userdata
File [83] : userdata
File [84] : userdata
File [85] : userdata
File [86] : userdata
File [87] : userdata
File [88] : userdata
File [89] : userdata
File [90] : userdata
File [91] : userdata
File [92] : userdata
File [93] : userdata
File [94] : userdata
File [95] : userdata
File [96] : userdata
File [97] : userdata
File [98] : userdata
File [99] : userdata
File [100] : userdata
File [101] : userdata
File [102] : userdata
File [103] : userdata
File [104] : userdata
File [105] : userdata
File [106] : userdata
File [107] : userdata
File [108] : userdata
File [109] : userdata
File [110] : userdata
File [111] : userdata
File [112] : userdata
File [113] : userdata
File [114] : userdata
File [115] : userdata
File [116] : userdata
File [117] : userdata
File [118] : userdata
File [119] : userdata
File [120] : userdata
File [121] : userdata
File [122] : userdata
File [123] : userdata
File [124] : userdata
File [125] : userdata
File [126] : userdata
File [127] : userdata
File [128] : userdata
File [129] : userdata
File [130] : userdata
File [131] : userdata
File [132] : userdata
File [133] : userdata
File [134] : userdata
File [135] : userdata
File [136] : userdata
File [137] : userdata
File [138] : userdata
File [139] : userdata
File [140] : userdata
File [141] : userdata
File [142] : userdata
File [143] : userdata
File [144] : userdata
File [145] : BackupGPT
Load Ok!
Operation : Flash [ v1.03 ]
Forced Flash    : Disabled
Factory Reset  : Enabled
Wait for phone...
Handshake passed!
Collect info...
Prepare passed, mode 0x00
Boot done!
[INFO] : Low Battery level ignored by user request!
Loading firmware
Load ok!
Checking compatibility
Checking passed!
Prepare device
Prepare Passed!
Secure prepare skipped!
Start flashing device
Flash : PrimaryGPT
Flash : modem
Flash : sbl1
Flash : dbi
Flash : aboot
Flash : rpm
Flash : tz
Flash : boot
Flash : persist
Flash : recovery
Flash : rct
Flash : misc
Flash : laf
Flash : factory
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : cache
Flash : cache
Flash : cache
Flash : cache
Flash : cache
Flash : cache
Flash : cache
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : BackupGPT
Processing Post-Flashing tune
Flash done!
Done!
Elapsed: 00:02:49
Old 08-27-2017, 12:52   #44578 (permalink)
Member: 953334
Sonork: 100.1614005
Smile VGO TEL i255 Reset User Code Done
Operation : Reset UserCode [ v1.58 ]
Wait for phone...
Phone found! [ 27 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_SN : 77277D9E3D31DC87531100F6237F0398
Setting...
BROM stage done
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV
[0] : FLASH_DIE : 00EF 0070 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
Backup done
Read ExtData
Sorting ExtData
Sort Ok, Rebuild Ok
Restore ExtData
All done
UserCode request removed
UserCode set to default ( 0000 or 1122 )
Done!
Elapsed: 00:00:14
Old 08-27-2017, 12:54   #44579 (permalink)
Member: 953334
Sonork: 100.1614005
Smile HAIER I70 Format Done
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BB_CPU_NME : [MediaTek] MT6592_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x8A
eMMC Flash : 15010051385853414206BC68D80F3217
[eMMC] : FLASH_INF : [SAMSUNG] , BASX8
[eMMC] : FLASH_CID : 15010051385853414206BC68D80F3217
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0xE6C52A7D2C22FCC24BD603C094E21B99
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:44
Old 08-27-2017, 12:55   #44580 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Qmobile i6i Format Done
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
eMMC Flash : 150100464A32374D42021A05D6C0925F
[eMMC] : FLASH_INF : [SAMSUNG] , BM72J
[eMMC] : FLASH_CID : 150100464A32374D42021A05D6C0925F
DEV RID : 0xE6C52A7D0B7B14E6AA6C11CED17FA304
EXT RAM : 0x30000000 [768 MiB]
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:29
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.53565 seconds with 9 queries
