Old 10-12-2017, 09:09   #45481 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,311
YUNIQE YU4711 FRP REMOVE Done
SUCCESSFULLY REMOVE FRP(YUNIQUE YU4711)USB
Operation : Identify [ v1.15 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 0CCB977F
ID_BLOCK_I : 007050E1
ID_BLOCK_L : 04FC9660CF5B40433C11E3EC2B76FECE
ID_BLOCK_L : 86FD43EAEF76D86D604F00F9CB3A3417
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Brand : YU
ProdName : YU4711
ProdModel : YU4711
Device : YU4711
AndroidVer: 5.1
Manufact. : YU
SysPatch : LMY47V
QLMxCPU : MSM8916
QLMxPRJ : 2016080111
Done!
Elapsed: 00:00:09
Reconnect Power/Cable!
Operation : Reset Settings [ v1.15 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:17
THANKS INFINITY-BOX TEAM
The Following 2 Users Say Thank You to gracy_elec For This Useful Post:
Old 10-12-2017, 09:39   #45482 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,147
Oppo A33F FRP Reset Done With King Infinity CM2
Card found : A19EC787 , v0136
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.14
Operation : Reset Settings [ v1.14 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_S : 20B9D868
ID_BLOCK_L : 7D87FD19B4222F5A057A9AFB441F97B7
ID_BLOCK_L : 90E3ADFCF160CA5B7EB912CBD9D4C209
MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ]
Boot Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:11
The Following 2 Users Say Thank You to azhergoga007 For This Useful Post:
Old 10-12-2017, 09:47   #45483 (permalink)
ibrajinja's Avatar
Member: 562975
Sonork: better tomorow
Thanks Meter: 216
Wink Reset FRP Lock
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 453 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:31
The Following User Says Thank You to ibrajinja For This Useful Post:
Old 10-12-2017, 10:21   #45484 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,147
Qmobile X30 MT6572 Dead Set Recover Done With Great Infinity CM2
Card foundaMTK module] v 1.58
Scatter Load Ok , BaseBand : MT6572 , Project : s4050ap , Storage : EMMC
Files found : 11 , Set to Flash : 10
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 37 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A48344732611101159B80686233
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , a2G4
[eMMC] : FLASH_CID : 90014A48344732611101159B80686233
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xD9C8F3950EC371ED77CF47B19CCCCEE3
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Skip checking by User request!
BL : BatteryLevel : 3744 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x00000000E5E00000
Flash Pre-Erase Done, time used : 00:00:06
SecCfg Passed , 1799
BMT remark not need. Will skip
Preloader Download skipped by user request!
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:55
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:40
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:58
Old 10-12-2017, 12:38   #45485 (permalink)
amn32's Avatar
Member: 569925
Sonork: 100.1624057
Thanks Meter: 6,280
The Great Cm2 King Of The King Micromaxx D304 Successfully Converted Into Qmobile X30
The Following 12 Users Say Thank You to amn32 For This Useful Post:
Old 10-12-2017, 12:57   #45486 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Smile Samsung sm-j500h reset frp lock done by cm2
SAMSUNG SM-J500H RESET FRP LOCK DONE BY CM2
Phone In Download mode...
Reset FRP Procedure started...
Port open Ok!
LOKE received!
Prepare Ok!
Enter Setup...
Try download PIT...
Download PIT Ok!
Reset FRP done
Reboot phone...
Phone Disconnected
If You Like My Post Press Thanks
ShahiD
The Following 3 Users Say Thank You to A.G.Shahid For This Useful Post:
Old 10-12-2017, 13:02   #45487 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Smile Samsung clone gt- i9082 hang on logo done by cm2
SAMSUNG CLONE GT- I9082 HANG ON LOGO DONE BY CM2
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 20 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 45010053454D3034472853E0C8327155
[eMMC] : FLASH_VEN : 0x45 , OEM : 0100
[eMMC] : FLASH_INF : [SANDISK] , G40ME
[eMMC] : FLASH_CID : 45010053454D3034472853E0C8327155
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000EC000000
[eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB]
DEV RID : 0x0B9C44DE13D6CDE1702D89A7A8F44185
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : samsung
ProdName : lenovo72_we_jb3
ProdModel : GT-I9082
Device : lenovo72_we_jb3
AndroidVer: 4.2.2
MTKxCPU : MT6572
MTKxPRJ : ALPS.JB3.MP.V1
EXTRA :
LCD [0] : hx8369b_dsi_ylt
LCD Res : 800x480
TOUCH [0] : cy8ctma463
TOUCH [1] : ft6x06
CAM [0] : ov5645_mipi_yuv
CAM [1] : hi257_yuv
MODEM : lenovo72_we_jb2_hspa
LOCALE : zh_CN en_US hdpi
Done!
Elapsed: 00:00:25
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 20 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:28
ShahiD
Old 10-12-2017, 13:43   #45488 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,453
Infinix X557 Pattern Format
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
eMMC Flash : 150100514531334D420DB6D3DCDF44E7
[eMMC] : FLASH_INF : [SAMSUNG] , BM31E
[eMMC] : FLASH_CID : 150100514531334D420DB6D3DCDF44E7
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID    : 0xD5229C25EE0B5319BA7D7D14D3EEE09D
EXT RAM    : 0x80000000 [2 GiB]
SOC VERIFY : C1
Boot Ok!
Brand     : Infinix
ProdName  : X557A1
ProdModel : Infinix HOT 4
Device    : X557
AndroidVer: 6.0
MTKxCPU   : MT6580
MTKxPRJ   : X557-H807AD-M-170524V251
Done!
Elapsed: 00:00:15
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:48
The Following 2 Users Say Thank You to Tanha0321 For This Useful Post:
Old 10-12-2017, 13:50   #45489 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Smile Motorola xt1254 reset frp lock done by cm2
MOTOROLA XT1254 RESET FRP LOCK DONE BY CM2
Operation : Reset Settings [ v1.0 ]
Mode : Format FS
Waiting for device in fastboot mode ...
1. Power off device. Press and hold 'VOL DOWN' button
2. Insert USB cable, hold button until device will be found!
Connect Ok!
Block [1] ERASE OK!
Block [2] ERASE OK!
Done!
Elapsed: 00:00:22
Waiting for NetInterface arrival ...
1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons
2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON'
3. Connect USB cable, when device boot complete!
Connect Ok!
Waiting ...
Trying link with : 192.168.137.2
Connected to device!
Device : XT1254
VerInfo : QUARK_CUST
Version : Blur_Version.24.91.5.quark_verizon.verizon.en.US
Enabling ADB ...
1. Disconnect cable from device, press and hold 'VOLUME_DOWN' and 'POWER_ON'
2. Select 'FACTORY MODE' and press 'POWER ON'!
3. Wait for device boot completely!
Done!
Elapsed: 00:00:09
Operation : Reset FRP (ADB) [ v1.0 ]
Waiting for device in ADB mode ...
1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need!
2. Insert USB cable, accept AUTH on PhoneScreen, if software ask!
Connect Ok!
Device : quark_verizon
Model : XT1254
FRP reset passed! Make FACTORY RESET from menu!
Done!
Elapsed: 00:00:12
ShahiD
The Following 2 Users Say Thank You to A.G.Shahid For This Useful Post:
Old 10-12-2017, 14:12   #45490 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,147
Qmobile I9 MT6582 Logo Stuck Recover Done By Formate With Infinity CM2
Card found : S/N : A19EC787 , v0136
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x87
eMMC Flash : 90014A4834473164048601A35A4131D3
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164048601A35A4131D3
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : 0xD9C8F3953DECD05699D4721F187F8874
EXT RAM : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:28
Old 10-12-2017, 14:32   #45491 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Smile Haier g30 hang on logo done by cm2
HAIER G30 HANG ON LOGO DONE BY CM2
Wait for phone...
Phone found! [ 58 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 45010053454D3034473AF00339455291
[eMMC] : FLASH_CID : 45010053454D3034473AF00339455291
DEV RID : 0x0B9C44DE75DA1DF100BBD7A27F826AF6
SOC VERIFY : C1
Boot Ok!
Brand : Haier
ProdName : G30
ProdModel : G30
Device : G30
AndroidVer: 4.4.2
MTKxCPU : MT6572
MTKxPRJ : G30-H01-S023-PK
MODEM :
BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V62_P6_1_wg_n
EXTRA :
LCD [0] : ili9806e_fwvga_dsi_vdo_zgd
LCD [1] : ili9806e_fwvga_dsi_vdo_huashi
LCD Res : 854x480
TOUCH [0] : ft6306_yuye
TOUCH [1] : GT9XX_hotknot
CAM [0] : gc2145_mipi_yuv_m11
CAM [1] : hi541_mipi_yuv_m11
CAM [2] : ov5645_mipi_yuv_m11 sp2529_mipi_yuv_m11
CAM [3] : s5k4ecgx_mipi_yuv
CAM [4] : #s5k8aayx_yuv
MODEM : huiyue72_w_kk_hspa_m11_b1b8_pk
LOCALE : en_US ur_PK fa_IR
Done!
Elapsed: 00:00:16
Wait for phone...
Phone found! [ 58 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:30
ShahiD
Old 10-12-2017, 15:10   #45492 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,147
Hot Wav Cosmos V6 SPD Pattren Reset Dioone With King Infinity CM2
Phone found! [ 16 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v4 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Done!
Elapsed: 00:00:26
Old 10-12-2017, 15:44   #45493 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,147
Qmobile S3 MT6580 FRP Reset Done With Great King Infinity CM2
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A48414732650507747B9592A21D
[eMMC] : FLASH_INF : [HYNIX] , e2GA
[eMMC] : FLASH_CID : 90014A48414732650507747B9592A21D
[eMMC] : FLASH_LEN : 0x00000003AB800000
[eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB]
DEV RID : 0xD9C8F395F13B44C4C3175B266D4E030A
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:21
Old 10-13-2017, 09:12   #45494 (permalink)
sajjad akram's Avatar
Member: 2555393
Thanks Meter: 232
Oneplus A3003 MSM8996 android version 7.1.1 reset frp and read firmware done with gre
Frp log.....
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 820 [MSM8996]
ID_BLOCK_S : 7132D88A
ID_BLOCK_I : 009470E1
ID_BLOCK_E : 2A703DB9
ID_BLOCK_L : 131EBEF4573BCCC5EF9E8B5A8FF8C57C
ID_BLOCK_L : 835461548F48D3FD9C76001A52EA67AB
Running FireHose on BBID : MSM8996 , FLASH : UFS , mVER : 1
ExtInfo : 0x0001C000/0001C000/00001000/00001000/00001000
UFS Device : SAMSUNG KLUCG4J1CB-B0B1 0800
UFS SectSize : 0x1000
UFS LU0 Size : 0x00000007602F0000 : 29.50 GiB
--------------UFS Device Info--------------
UFS Total Active LU: 0x6
UFS wManufacturerID: 0x1ce
UFS Boot Partition Enabled: 0x1
UFS LU Write Protect: 0x0
UFS Boot LUN ID: = 0x0
UFS Memory Type: 0x0
UFS LU Total Blocks: 0x0
UFS Supported Memory Types: 0x800f
UFS LUN Enable Bitmask: 0x3f
UFS bConfigDescrLock: 0x0
Boot Ok!
Remove FRP
Reset Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:41
Read firmware log...
Operation : Read Flash [ v1.15 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Brand : OnePlus
Device : OnePlus3
AndroidVer: 7.1.1
SWVersion : OnePlus3Oxygen_16.A.56_GLO_056_1709231912
Manufact. : OnePlus
QLMxCPU : MSM8996
DevInfo : MSM8996__OnePlus__OnePlus__ANDR_v7.1.1__OnePlus3__ OnePlus3Oxygen_16.A.56_GLO_056_1709231912
Reading Flash Content ...
[Read Ok] : gpt_main0.bin
[Read Ok] : persist.img
[Read Ok] : cache.img
[Read Ok] : misc.img
[Read Ok] : devcfg.mbn
[Read Ok] : dnvbak.img
[Read Ok] : pnvbak.img
[Read Ok] : param.cfg
[Read Ok] : userdata.img
[Read Ok] : gpt_backup0.bin
[Read Ok] : gpt_main1.bin
[Read Ok] : xbl.elf
[Read Ok] : gpt_backup1.bin
[Read Ok] : gpt_main2.bin
[Read Ok] : gpt_backup2.bin
[Read Ok] : gpt_main3.bin
[Read Ok] : ddr.bin
[Read Ok] : gpt_backup3.bin
[Read Ok] : gpt_main4.bin
[Read Ok] : rpm.mbn
[Read Ok] : tz.mbn
[Read Ok] : hyp.mbn
[Read Ok] : sec.dat
[Read Ok] : pmic.bin
[Read Ok] : NON-HLOS.bin
[Read Ok] : adspso.bin
[Read Ok] : mdtp.img
[Read Ok] : emmc_appsboot.mbn
[Read Ok] : lsplash.img
[Read Ok] : boot.img
[Read Ok] : boot_ag.img
[Read Ok] : system.img
[Read Ok] : recovery.img
[Read Ok] : btfm.mbn
[Read Ok] : keymaster.mbn
[Read Ok] : cmnlib.mbn
[Read Ok] : cmnlib64.mbn
[Read Ok] : ap.mbn
[Read Ok] : gpt_backup4.bin
[Read Ok] : gpt_main5.bin
[Read Ok] : md5.img
[Read Ok] : gpt_backup5.bin
Android Info saved!
Read finished!
Configuration : MSM8996 / UFS
Firmware Size : 3334 MiB
Done!
Elapsed: 00:04:03
Sent from my D5803 using Tapatalk
The Following User Says Thank You to sajjad akram For This Useful Post:
Old 10-13-2017, 09:29   #45495 (permalink)
jjamshad5's Avatar
Member: 2156086
Sonork: 4562
Thanks Meter: 206
Micromax d321 flashing done
======= Flash
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
eMMC Flash : 90014A48344732611101C1820A7162F3
DRAM configured from ScatFW!
DRAM initialize passed!
DRAM size : 0x20000000
[eMMC] : FLASH_CID : 90014A48344732611101C1820A7162F3
DEV RID : 0xC45652883BE6DDA8A1EB12DCF1676318
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : s5201ap , Storage : EMMC
Switching to HSUSB
HSUSB Init Ok
BL : Check eMMC compatibility
BL : BatteryLevel : 3764 mV
Erase : 0x0000000002900000-0x000000009DE40000
Flash Pre-Erase Done, time used : 00:00:00
Sending Preloader ...
Use : preloader_s5201ap.bin
Preloader Sent , Init passed
PartCount : 0013
Repartition Done!
Use FLN Mode
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:03:51
Processing : Verify
Verify Passed : MBR
Data Verify Done, time used : 00:00:04
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:04:23
The Following User Says Thank You to jjamshad5 For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.63361 seconds with 9 queries
