10-13-2017, 09:12 | #45496 (permalink) |
Freak Poster Join Date: Apr 2016 Location: South Africa /Pakistan Age: 29
Member: 2555393 Status: Offline Thanks Meter: 268 | Oneplus A3003 MSM8996 android version 7.1.1 reset frp and read firmware done with gre Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 820 [MSM8996] ID_BLOCK_S : 7132D88A ID_BLOCK_I : 009470E1 ID_BLOCK_E : 2A703DB9 ID_BLOCK_L : 131EBEF4573BCCC5EF9E8B5A8FF8C57C ID_BLOCK_L : 835461548F48D3FD9C76001A52EA67AB Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8996 , FLASH : UFS , mVER : 1 ExtInfo : 0x0001C000/0001C000/00001000/00001000/00001000 UFS Device : SAMSUNG KLUCG4J1CB-B0B1 0800 UFS SectSize : 0x1000 UFS LU0 Size : 0x00000007602F0000 : 29.50 GiB --------------UFS Device Info-------------- UFS Total Active LU: 0x6 UFS wManufacturerID: 0x1ce UFS Boot Partition Enabled: 0x1 UFS LU Write Protect: 0x0 UFS Boot LUN ID: = 0x0 UFS Memory Type: 0x0 UFS LU Total Blocks: 0x0 UFS Supported Memory Types: 0x800f UFS LUN Enable Bitmask: 0x3f UFS bConfigDescrLock: 0x0 Boot Ok! Remove FRP Reset Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:41 Read firmware log... Operation : Read Flash [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 820 [MSM8996] ID_BLOCK_S : 7132D88A ID_BLOCK_I : 009470E1 ID_BLOCK_E : 2A703DB9 ID_BLOCK_L : 131EBEF4573BCCC5EF9E8B5A8FF8C57C ID_BLOCK_L : 835461548F48D3FD9C76001A52EA67AB Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8996 , FLASH : UFS , mVER : 1 ExtInfo : 0x0001C000/0001C000/00001000/00001000/00001000 UFS Device : SAMSUNG KLUCG4J1CB-B0B1 0800 UFS SectSize : 0x1000 UFS LU0 Size : 0x00000007602F0000 : 29.50 GiB --------------UFS Device Info-------------- UFS Total Active LU: 0x6 UFS wManufacturerID: 0x1ce UFS Boot Partition Enabled: 0x1 UFS LU Write Protect: 0x0 UFS Boot LUN ID: = 0x0 UFS Memory Type: 0x0 UFS LU Total Blocks: 0x0 UFS Supported Memory Types: 0x800f UFS LUN Enable Bitmask: 0x3f UFS bConfigDescrLock: 0x0 Boot Ok! Brand : OnePlus Device : OnePlus3 AndroidVer: 7.1.1 SWVersion : OnePlus3Oxygen_16.A.56_GLO_056_1709231912 Manufact. : OnePlus QLMxCPU : MSM8996 DevInfo : MSM8996__OnePlus__OnePlus__ANDR_v7.1.1__OnePlus3__ OnePlus3Oxygen_16.A.56_GLO_056_1709231912 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : persist.img [Read Ok] : cache.img [Read Ok] : misc.img [Read Ok] : devcfg.mbn [Read Ok] : dnvbak.img [Read Ok] : pnvbak.img [Read Ok] : param.cfg [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin [Read Ok] : gpt_main1.bin [Read Ok] : xbl.elf [Read Ok] : gpt_backup1.bin [Read Ok] : gpt_main2.bin [Read Ok] : gpt_backup2.bin [Read Ok] : gpt_main3.bin [Read Ok] : ddr.bin [Read Ok] : gpt_backup3.bin [Read Ok] : gpt_main4.bin [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : hyp.mbn [Read Ok] : sec.dat [Read Ok] : pmic.bin [Read Ok] : NON-HLOS.bin [Read Ok] : adspso.bin [Read Ok] : mdtp.img [Read Ok] : emmc_appsboot.mbn [Read Ok] : lsplash.img [Read Ok] : boot.img [Read Ok] : boot_ag.img [Read Ok] : system.img [Read Ok] : recovery.img [Read Ok] : btfm.mbn [Read Ok] : keymaster.mbn [Read Ok] : cmnlib.mbn [Read Ok] : cmnlib64.mbn [Read Ok] : ap.mbn [Read Ok] : gpt_backup4.bin [Read Ok] : gpt_main5.bin [Read Ok] : md5.img [Read Ok] : gpt_backup5.bin Android Info saved! Read finished! Configuration : MSM8996 / UFS Firmware Size : 3334 MiB Done! Elapsed: 00:04:03 Sent from my D5803 using Tapatalk |
The Following User Says Thank You to sajjad akram For This Useful Post: |
10-13-2017, 09:29 | #45497 (permalink) |
No Life Poster Join Date: Mar 2014 Location: India
Member: 2156086 Status: Offline Sonork: 4562 Thanks Meter: 210 | Micromax d321 flashing done Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48344732611101C1820A7162F3 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x20000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A48344732611101C1820A7162F3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xC45652883BE6DDA8A1EB12DCF1676318 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s5201ap , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3764 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x000000009DE40000 Flash Pre-Erase Done, time used : 00:00:00 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s5201ap.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:03:51 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:04 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:04:23 Reconnect Power/Cable! |
The Following User Says Thank You to jjamshad5 For This Useful Post: |
10-13-2017, 11:03 | #45498 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | HTC D526G PLUS PATTERN LOCK REMOVE Done SUCCESSFULLY REMOVE PATTERN LOCK(HTC D526G PLUS)USB Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 31 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 150100513858534142067C2ADEDB4239 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BASX8 [eMMC] : FLASH_CID : 150100513858534142067C2ADEDB4239 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xFD096D451780A9C74F26C8B3990BC14B INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : htc ProdName : v02_htc_asia_wwe ProdModel : HTC 0PL4100 Device : htc_v02_dug AndroidVer: 4.4.2 MTKxCPU : MT6592 MTKxPRJ : 1.05.720.1 SECURITY : IMEI_SW [1] : XXXXXXXXXXXXXX IMEI_SW [2] : XXXXXXXXXXXXXX BTMAC Addr : XXXXXXXXX WiFi MAC : XXXXXXXXXX MODEM : BaseBand : MT6592_S00_MOLY_WR8_W1315_MD_WG_MP_V62_1_wg_n EXTRA : LCD [0] : ili9807_qhd_dsi_vdo LCD [1] : hx8389c_qhd_dsi_vdo_tcl LCD [2] : hx8389b_qhd_dsi_vdo_tm LCD [3] : ili9807_qhd_dsi_vdo_bld LCD [4] : dummy_lcm LCD Res : 960x540 TOUCH [0] : GT9XXS TOUCH [1] : ft6436l TOUCH [2] : msg2142 CAM [0] : s5k4h5yx_mipi_raw CAM [1] : ov8858_mipi_raw CAM [2] : gc2355_mipi_raw CAM [3] : ov2680_mipi_raw MODEM : mt6592kk_hspa_18_2014_12_17 LOCALE : en_IN en_US af_ZA in_ID ms_MY ca_ES cs_CZ da_DK de_DE de_AT de_CH de_LI en_GB en_AU en_CA en_IE en_NZ en_SG en_ZA es_ES es_US tl_PH fr_FR fr_BE fr_CA fr_CH hr_HR zu_ZA it_IT it_CH sw_TZ lv_LV lt_LT hu_HU nl_NL nl_BE nb_NO pl_PL pt_BR pt_PT ro_RO rm_CH sk_SK sl_SI fi_FI sv_SE vi_VN tr_TR el_GR bg_BG ru_RU sr_RS uk_UA iw_IL ar_EG ar_IL fa_IR am_ET hi_IN th_TH my_MM km_KH ko_KR zh_CN zh_TW ja_JP en_ID en_MY en_PH en_PK en_TH en_VN zh_HK Done! Elapsed: 00:00:15 Reconnect Power/Cable! ---------------------------------------------------------------------------------------------------------------------------------------------------- Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 31 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 150100513858534142067C2ADEDB4239 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BASX8 [eMMC] : FLASH_CID : 150100513858534142067C2ADEDB4239 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xFD096D451780A9C74F26C8B3990BC14B INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear RDP Clear Ok! Done! Elapsed: 00:00:17 Reconnect Power/Cable! THANKS INFINITY-BOX TEAM |
The Following 2 Users Say Thank You to gracy_elec For This Useful Post: |
10-13-2017, 11:13 | #45499 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | LENOVO S860 REPAIR TOOL DL IMAGE FAIL! Done SUCCESSFULLY REPAIR TOOL DL IMAGE FAIL!(LENOVO S860)USB Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 15010049385530304104FD7888036143 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , A00U8 [eMMC] : FLASH_CID : 15010049385530304104FD7888036143 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xFD096D4567341E89C14FBBDC42EB6100 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Lenovo ProdName : phaetondvt3_row ProdModel : Lenovo S860 Device : S860 AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : S860_ROW_S405_150126 Done! Elapsed: 00:00:08 Reconnect Power/Cable! ---------------------------------------------------------------------------------------------------------------------------------------------------- Operation : Fix DL Errors [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 15010049385530304104FD7888036143 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , A00U8 [eMMC] : FLASH_CID : 15010049385530304104FD7888036143 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xFD096D4567341E89C14FBBDC42EB6100 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! DA DLFix Passed! Done! Elapsed: 00:00:07 Reconnect Power/Cable! THANKS INFINITY-BOX TEAM |
10-13-2017, 11:32 | #45500 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | SWIPE MTV SLASH2 MC706 HANG ON LOGO Done SUCCESSFULLY RECOVER HANG ON LOGO(SWIPE MTV SLASH2 MC706)USB Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004D3447314641036E19523DCFA1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , AF1G4 [eMMC] : FLASH_CID : 1501004D3447314641036E19523DCFA1 [eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000EE800000 [eMMC] : FLASH_UCP : 3816 MiB [eMMC 4 GiB] DEV RID : 0xFD096D4594C8760273708758D5C70D67 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : SWIPE ProdName : mc706 ProdModel : MTV SLASH2 Device : mc706 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.TABLET.MP.V1 SECURITY : IMEI_SW [1] : XXXXXXXXXXXXXX IMEI_SW [2] : XXXXXXXXXXXXXX BTMAC Addr : XXXXXXXXXXX WiFi MAC : XXXXXXXXX MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V26_1_2g_n EXTRA : LCD [0] : ek9716ba_rgb_6572_high LCD Res : 600x1024 TOUCH [0] : gslX688 CAM [0] : gc2035_yuv CAM [1] : gc0328_yuv CAM [2] : gc0308_yuv CAM [3] : gc0329_yuv CAM [4] : gc0311_yuv CAM [5] : sp0718_yuv CAM [6] : sp2518_yuv CAM [7] : bf3a03_yuv CAM [8] : bf3920_yuv CAM [9] : gc2155_yuv MODEM : mc706_wet_jb3_gprs LOCALE : en_US af_ZA am_ET ar_EG ar_IL bg_BG bn_IN ca_ES cs_CZ da_DK de_AT de_CH de_DE de_LI el_GR en_AU en_CA en_GB en_IE en_IN en_NZ en_SG en_ZA es_ES fa_IR fi_FI fr_BE fr_CA fr_CH fr_FR hi_IN hr_HR hu_HU in_ID it_CH it_IT iw_IL ja_JP km_KH ko_KR lt_LT lv_LV ms_MY my_MM nb_NO nl_BE nl_NL pl_PL pt_BR pt_PT rm_CH ro_RO ru_RU sk_SK sl_SI sr_RS sv_SE sw_TZ th_TH tl_PH tr_TR uk_UA ur_PK vi_VN zh_CN zh_TW zu_ZA hdpi mdpi Done! Elapsed: 00:00:10 Reconnect Power/Cable! ---------------------------------------------------------------------------------------------------------------------------------------------------- Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004D3447314641036E19523DCFA1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , AF1G4 [eMMC] : FLASH_CID : 1501004D3447314641036E19523DCFA1 [eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000EE800000 [eMMC] : FLASH_UCP : 3816 MiB [eMMC 4 GiB] DEV RID : 0xFD096D4594C8760273708758D5C70D67 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:18 Reconnect Power/Cable! THANKS INFINITY-BOX TEAM |
10-13-2017, 11:57 | #45501 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | MICROMAX Q386 FRP REMOVE Done SUCCESSFULLY REMOVE FRP (MICROMAX Q386)USB Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100463832324D4200949EE0A23341 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM228 [eMMC] : FLASH_CID : 150100463832324D4200949EE0A23341 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xFD096D456AF3EF981DEA47F3F493C3D3 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Micromax ProdName : Q386 ProdModel : Micromax Q386 Device : Q386 AndroidVer: 6.0 MTKxCPU : MT6580 MTKxPRJ : ALPS.W10.24.p0 SECURITY : IMEI_SW [1] : XXXXXXXXXXXXX IMEI_SW [2] : XXXXXXXXXXXXX BTMAC Addr : XXXXXXXX WiFi MAC : XXXXXXX MODEM : BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V57_1_wg_n EXTRA : LCD : Not info available LCD Res : 1280x720 TOUCH [0] : s2333_v3750 TOUCH [1] : ft5346i_v3750 CAM [0] : s5k4h8_mipi_raw CAM [1] : hi842_mipi_raw CAM [2] : ov5670_mipi_raw_sunwin CAM [3] : ov5670_mipi_raw_cmk CAM [4] : s5k5e2ya_mipi_raw MODEM : STOM_MODEM =mt6580_v3750_hspa_modemB18_mmx LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES hi_IN ta_IN te_IN bn_IN mr_IN gu_IN pa_IN ml_IN kn_IN or_IN Done! Elapsed: 00:00:15 Reconnect Power/Cable! ---------------------------------------------------------------------------------------------------------------------------------------------------- Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100463832324D4200949EE0A23341 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM228 [eMMC] : FLASH_CID : 150100463832324D4200949EE0A23341 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xFD096D456AF3EF981DEA47F3F493C3D3 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:16 Reconnect Power/Cable! THANKS INFINITY-BOX TEAM |
10-13-2017, 12:07 | #45502 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | MICROMAX Q332 HANG ON LOGO Done SUCCESSFULLY RECOVER HANG ON LOGO(MICROMAX Q332)USB Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 31 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483447326111017095ECC94223 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x20000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A483447326111017095ECC94223 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xFD096D454187026E651AE00DDCD47203 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Micromax ProdName : Q332 ProdModel : Micromax Q332 Device : Q332 AndroidVer: 5.1 MTKxCPU : MT6580 MTKxPRJ : ALPS.L1.MP6.V2_LCSH6580.WE.L_P59 SECURITY : IMEI_SW [1] : XXXXXXXXXXXXXX IMEI_SW [2] : XXXXXXXXXXXXXX BTMAC Addr : XXXXXXXXXX WiFi MAC : XXXXXXXX MODEM : BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V6_P5_1_wg_n EXTRA : LCD : Not info available LCD Res : 854x480 TOUCH [0] : mstar2xxx#### TOUCH [1] : mstar2238 CAM [0] : ov2680_mipi_raw CAM [1] : ov5670_mipi_raw CAM [2] : hi542_mipi_raw CAM [3] : hi542sub_mipi_raw MODEM : lcsh_6580_we_l_hspa_3gb1b8_mcx_v4 LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:14 Reconnect Power/Cable! ---------------------------------------------------------------------------------------------------------------------------------------------------- Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 31 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483447326111017095ECC94223 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x20000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A483447326111017095ECC94223 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xFD096D454187026E651AE00DDCD47203 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:39 Reconnect Power/Cable! THANKS INFINITY-BOX TEAM |
10-13-2017, 12:16 | #45503 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | MICROMAX A109 REMOVE PATTERN LOCK Done SUCCESSFULLY REMOVE PATTERN LOCK(MICROMAX A109)USB Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 484A019064314734A30186049341030B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A30B034193 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0xFD096D45C5EEC8F3B1EF47F7BB9307A0 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Micromax ProdName : A109 ProdModel : Micromax A109 Device : A109 AndroidVer: 4.4.2 MTKxCPU : MT6589 MTKxPRJ : ALPS.KK1.MP5.V1.5 SECURITY : IMEI_SW [1] : XXXXXXXXXXXXXX IMEI_SW [2] : XXXXXXXXXXXXXX BTMAC Addr : XXXXXXXXXX WiFi MAC : XXXXXXXXX MODEM : BaseBand : MT6589_S00_MOLY_WR8_W1248_MD_WG_MP_V47_1_3g_n EXTRA : LCD [0] : otm9605a_dsi_7296yt LCD [1] : hx8389b_dsi_7296tm LCD [2] : otm9605a_dsi_7296by LCD [3] : hx8389b_dsi_vdo_7296yashi LCD Res : 960 #800x540 #480 TOUCH [0] : s3202 CAM [0] : ov5647_mipi_raw CAM [1] : a5142_mipi_raw CAM [2] : hi704_yuv MODEM : yulong89_wet_kk_md1_hspa LOCALE : en_US en_IN hi_IN in_ID ms_MY de_DE es_ES fr_FR it_IT pt_PT vi_VN tr_TR ar_AE zh_CN hdpi mdpi Done! Elapsed: 00:00:15 Reconnect Power/Cable! ---------------------------------------------------------------------------------------------------------------------------------------------------- Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 484A019064314734A30186049341030B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A30B034193 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0xFD096D45C5EEC8F3B1EF47F7BB9307A0 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:18 Reconnect Power/Cable! THANKS INFINITY-BOX TEAM |
10-13-2017, 13:06 | #45504 (permalink) |
Member: 2555393 Status: Offline Thanks Meter: 268 | Mobiwire Kohana frp reset done with great infinity cm2 but DA file from inferno... :) Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100463732324D42006657D44FA3DB Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D42006657D44FA3DB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x020C5EFE1F9A7DC6145CEE527DD8F12C INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:40 Reconnect Power/Cable! Sent from my D5803 using Tapatalk |
10-13-2017, 17:11 | #45505 (permalink) |
Freak Poster Join Date: Jul 2008 Location: Belize
Member: 809261 Status: Offline Sonork: 100.61830 Thanks Meter: 100 | successful flash and reset ls675 lgs module Card found : 147xxxxx , v0136 Infinity-Box LG Service Tool [ LGS ] v1.03 Loading firmware ... FType : DZ file BB_Gen : QLM Model : LGLS675 Version : LS675ZV5 SWInfo : user File [0] : PrimaryGPT_0.bin File [1] : modem_16384.bin File [2] : sbl1_147456.bin File [3] : tz_148480.bin File [4] : rpm_150528.bin File [5] : aboot_151552.bin File [6] : sbl1bak_155648.bin File [7] : tzbak_156672.bin File [8] : rpmbak_158720.bin File [9] : abootbak_159744.bin File [10] : sec_176128.bin File [11] : rct_208896.bin File [12] : raw_resources_212992.bin File [13] : raw_resourcesbak_215040.bin File [14] : persist_344064.bin File [15] : laf_360448.bin File [16] : boot_393216.bin File [17] : recovery_425984.bin File [18] : factory_458752.bin File [19] : system_524288.bin File [20] : system_787848.bin File [21] : system_791872.bin File [22] : system_1052600.bin File [23] : system_1312136.bin File [24] : system_1316160.bin File [25] : system_1576888.bin File [26] : system_1836424.bin File [27] : system_1840448.bin File [28] : system_2101176.bin File [29] : system_2360712.bin File [30] : system_2364736.bin File [31] : system_2625464.bin File [32] : system_2885000.bin File [33] : system_2889024.bin File [34] : system_3149752.bin File [35] : system_3411896.bin File [36] : system_3674040.bin File [37] : system_3936184.bin File [38] : system_4198328.bin File [39] : system_4460472.bin File [40] : system_4722616.bin File [41] : system_4984760.bin File [42] : system_5246904.bin File [43] : system_5505024.bin File [44] : system_5767168.bin File [45] : system_6029312.bin File [46] : system_6032376.bin File [47] : BackupGPT_15268864.bin File [48] : misc_241664.bin File [49] : cache_6160384.bin File [50] : cache_6422528.bin File [51] : cache_6425880.bin File [52] : userdata_6569984.bin File [53] : userdata_6832128.bin File [54] : userdata_6834312.bin File [55] : userdata_7094272.bin File [56] : userdata_7356416.bin File [57] : userdata_7358600.bin File [58] : userdata_7618560.bin File [59] : userdata_7880704.bin File [60] : userdata_7882888.bin File [61] : userdata_8142848.bin File [62] : userdata_8404992.bin File [63] : userdata_8407176.bin File [64] : userdata_8667136.bin File [65] : userdata_8929280.bin File [66] : userdata_8931464.bin File [67] : userdata_9191424.bin File [68] : userdata_9453568.bin File [69] : userdata_9715712.bin File [70] : userdata_9977856.bin File [71] : userdata_10240000.bin File [72] : userdata_10502144.bin File [73] : userdata_10764288.bin File [74] : userdata_11026432.bin File [75] : userdata_11288576.bin File [76] : userdata_11550720.bin File [77] : userdata_11812864.bin File [78] : userdata_12075008.bin File [79] : userdata_12337152.bin File [80] : userdata_12599296.bin File [81] : userdata_12861440.bin File [82] : userdata_13123584.bin File [83] : userdata_13125768.bin File [84] : userdata_13385728.bin File [85] : userdata_13647872.bin File [86] : userdata_13650056.bin File [87] : userdata_13910016.bin File [88] : userdata_14172160.bin File [89] : userdata_14434304.bin File [90] : userdata_14696448.bin File [91] : userdata_14958592.bin File [92] : userdata_15220736.bin File [93] : userdata_15224744.bin Load Ok! Operation : Flash [ v1.03 ] Forced Flash : Disabled Factory Reset : Enabled 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x01 Boot done! Loading firmware Load ok! Checking compatibility Checking passed! Prepare device Prepare Passed! Secure prepare passed! Start flashing device Flash : PrimaryGPT_0.bin Flash : modem_16384.bin Flash : sbl1_147456.bin Flash : tz_148480.bin Flash : rpm_150528.bin Flash : aboot_151552.bin Flash : sbl1bak_155648.bin Flash : tzbak_156672.bin Flash : rpmbak_158720.bin Flash : abootbak_159744.bin Flash : sec_176128.bin Flash : rct_208896.bin Flash : raw_resources_212992.bin Flash : raw_resourcesbak_215040.bin Flash : persist_344064.bin Flash : laf_360448.bin Flash : boot_393216.bin Flash : recovery_425984.bin Flash : factory_458752.bin Flash : system_524288.bin Flash : system_787848.bin Flash : system_791872.bin Flash : system_1052600.bin Flash : system_1312136.bin Flash : system_1316160.bin Flash : system_1576888.bin Flash : system_1836424.bin Flash : system_1840448.bin Flash : system_2101176.bin Flash : system_2360712.bin Flash : system_2364736.bin Flash : system_2625464.bin Flash : system_2885000.bin Flash : system_2889024.bin Flash : system_3149752.bin Flash : system_3411896.bin Flash : system_3674040.bin Flash : system_3936184.bin Flash : system_4198328.bin Flash : system_4460472.bin Flash : system_4722616.bin Flash : system_4984760.bin Flash : system_5246904.bin Flash : system_5505024.bin Flash : system_5767168.bin Flash : system_6029312.bin Flash : system_6032376.bin Flash : BackupGPT_15268864.bin Flash : misc_241664.bin Flash : cache_6160384.bin Flash : cache_6422528.bin Flash : cache_6425880.bin Flash : userdata_6569984.bin Flash : userdata_6832128.bin Flash : userdata_6834312.bin Flash : userdata_7094272.bin Flash : userdata_7356416.bin Flash : userdata_7358600.bin Flash : userdata_7618560.bin Flash : userdata_7880704.bin Flash : userdata_7882888.bin Flash : userdata_8142848.bin Flash : userdata_8404992.bin Flash : userdata_8407176.bin Flash : userdata_8667136.bin Flash : userdata_8929280.bin Flash : userdata_8931464.bin Flash : userdata_9191424.bin Flash : userdata_9453568.bin Flash : userdata_9715712.bin Flash : userdata_9977856.bin Flash : userdata_10240000.bin Flash : userdata_10502144.bin Flash : userdata_10764288.bin Flash : userdata_11026432.bin Flash : userdata_11288576.bin Flash : userdata_11550720.bin Flash : userdata_11812864.bin Flash : userdata_12075008.bin Flash : userdata_12337152.bin Flash : userdata_12599296.bin Flash : userdata_12861440.bin Flash : userdata_13123584.bin Flash : userdata_13125768.bin Flash : userdata_13385728.bin Flash : userdata_13647872.bin Flash : userdata_13650056.bin Flash : userdata_13910016.bin Flash : userdata_14172160.bin Flash : userdata_14434304.bin Flash : userdata_14696448.bin Flash : userdata_14958592.bin Flash : userdata_15220736.bin Flash : userdata_15224744.bin Processing Post-Flashing tune Flash done! Reconnect Power/Cable! Done! Elapsed: 00:07:14 Card found : 147xxxx , v0136 Infinity-Box LG Service Tool [ LGS ] v1.03 Operation : Reset Settings/Format FS [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x01 Boot done! Format UserData Format Cache Format done Erase sFRP#3 Ok! Reconnect Power/Cable! Done! Elapsed: 00:01:20 |
The Following 2 Users Say Thank You to elnmx For This Useful Post: |
10-13-2017, 17:20 | #45506 (permalink) |
Member: 809261 Status: Offline Sonork: 100.61830 Thanks Meter: 100 | Fix sm-g900t stuck @ boot logo by flash modem SM S/N: 147xxxxx Version: 0100 Phone found on COM204 Phone In Download mode... Port open Ok! LOKE received! Prepare Ok! Enter Setup... Setup Done! Try download PIT... Download PIT Ok! Start flashing! Flashing aboot.mbn Flashing sbl1.mbn Flashing rpm.mbn Flashing tz.mbn Flashing sdi.mbn Flashing NON-HLOS.bin Flashing boot.img Flashing recovery.img Flashing system.img.ext4 Flashing cache.img.ext4 Flashing modem.bin Error flashing SM S/N: 147xxxxx Version: 0100 Phone found on COM204 Phone In Download mode... Port open Ok! LOKE received! Prepare Ok! Enter Setup... Setup Done! Try download PIT... Download PIT Ok! Start flashing! Flashing modem.bin Flashing done Reboot phone... Phone Disconnected Phone found on COM255 |
The Following User Says Thank You to elnmx For This Useful Post: |
10-13-2017, 17:54 | #45507 (permalink) |
Freak Poster Join Date: May 2016 Location: INDIA(EGRA,PURBA MEDINIPURE)
Member: 2567557 Status: Offline Sonork: 100.1664271:SUBHENDU Thanks Meter: 54 | Oppo a57 pattern lock done with cm2 qualcomm.............. OPPO A57 PATTERN LOCK DONE WITH CM2 QUALCOMM 1.11.............. |
The Following 4 Users Say Thank You to suvendurath1 For This Useful Post: |
10-14-2017, 05:09 | #45508 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile S3 MT56580 FRP Reset Done With King infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48414732650507747B9592A21D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A48414732650507747B9592A21D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0xD9C8F395F13B44C4C3175B266D4E030A INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:45 Reconnect Power/Cable! |
The Following User Says Thank You to azhergoga007 For This Useful Post: |
10-14-2017, 05:11 | #45509 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile K150 SPD6531 Logo Stuck Fix Only Formate With Infinity CM2 Card found: S/N : A19EC787 , v0136 Chinese Miracle II [SPD module] v 1.27 Set mode to : SPD6531 Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0040 0016 0000 [0] Flash VEN : Winbond , W25Q32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:09 Reconnect Power/Cable! |
10-14-2017, 05:17 | #45510 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile X4 MT6261 Read Code Done With King Infinity CM2 Card found : S/N : A19EC787 , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Read UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 10 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 2A56DC40A6E8D127D803D543886AEAF4 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Read ExtData Sorting ExtData Reading UserCode Active : No , Code : 86856 Privacy Lock :0 Done! Elapsed: 00:00:05 Reconnect Power/Cable! |
