Old 10-17-2017, 14:05   #45616 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,453
Motorola Xt1254 Frp Reset
Infinity-Box Android Service Tool [AST] v1.01
Operation : Reset FRP (ADB) [ v1.01 ]
Waiting for device in ADB mode ...
1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need!
2. Insert USB cable, accept AUTH on PhoneScreen, if software ask!
Connect Ok!
Device : quark_verizon
Model  : XT1254
FRP reset passed! Make FACTORY RESET from menu!
Done!
Elapsed: 00:00:14
The Following User Says Thank You to Tanha0321 For This Useful Post:
Old 10-17-2017, 14:06   #45617 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,453
Motorola Xt1526 Frp Reset
Connect Ok!
Device : surnia_boost
Model  : XT1526
Done!
Elapsed: 00:00:12
Old 10-17-2017, 14:08   #45618 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,453
Motorola Xt1548 Frp Reset
Connect Ok!
Device : osprey_retus
Model  : MotoG3
Done!
Elapsed: 00:00:13
Old 10-17-2017, 14:09   #45619 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 3,988
QMobile B500 read user code done :)
Operation : Read UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 32 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0000
BB_CPU_SN : 7D421C6FBB497C190A645503F1592354
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
InitRes : 00000000
DEV[0] : C800 6000 1800 0000
DEV[1] : 0000 0000 0000 0000
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x8B
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128
[0] : FLASH_DIE : 00C8 0060 0018 0000
[0] : FLASH_LEN : 0x01000000
INT_RAM : 0x0000D000
EXT_RAM : 0x00800000
Read ExtData
Sorting ExtData
Reading UserCode
Active : Yes , Code : 2536
PLock|MobTrack : Not active
Done!
Elapsed: 00:00:20
Reconnect Power/Cable!
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 32 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
SOC_VERIFY : 0xC1
File_Info   : R032_QMOBILE_PCB01_gprs_MT6260_S00.R032Q_B500_BT_FM_SC_12864_V008_20140811.bin
FileVersion : R032Q_B500_BT_FM_SC_12864_V008_20140811
Done!
Elapsed: 00:00:19
The Following User Says Thank You to syed tuqeer For This Useful Post:
Old 10-18-2017, 02:19   #45620 (permalink)
Member: 2718733
Thanks Meter: 2
This is a state of the art tool, I cant count how many time it has saved me, Kudos to the team that developed it.
Old 10-18-2017, 07:06   #45621 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,147
Qmobile E4 MT6261 Logo Stuck Recover Fix Only Formate Done With Infinity CM2
Card found : S/N : A19EC787 , v0136
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 16 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 3238DE303EE6742A90ED8D5D86F0AB8A
Setting...
BROM stage done
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV
[0] : FLASH_DIE : 00EF 0070 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
EXT_RAM : 0x00400000
Backup done
Executing FFS FORMAT now...
FAT_RANGE : 0x0039E000-0x003FDFFF , LEN : 0x00060000
DA_RET : DA_IN_PROGRESS
DA_RET : FORMAT_DONE
Done!
Elapsed: 00:00:09
The Following User Says Thank You to azhergoga007 For This Useful Post:
Old 10-18-2017, 07:46   #45622 (permalink)
Deepesh Sharma's Avatar
Member: 1301233
Sonork: 100.1614172
Thanks Meter: 9,216
Lyf wind7 remove frp
format
Operation : Reset Settings [ v1.15 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 210 [MSM8x09]
ID_BLOCK_S : 08182733
ID_BLOCK_I : 009600E1
ID_BLOCK_L : B0B02AD483EF1417F0A5AFB07FCA4A82
ID_BLOCK_L : F3820C9F9003AB38DD187DAAB877616A
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ]
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:19
The Following User Says Thank You to Deepesh Sharma For This Useful Post:
Old 10-18-2017, 08:32   #45623 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,147
Qmobile I7 MT6582 Hanging Probelam Fix Only Formate With Infinity CM2
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 1501004B3758564D42015513CE3851ED
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BMVX7
[eMMC] : FLASH_CID : 1501004B3758564D42015513CE3851ED
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xD9C8F39587550007CA5CFEBC9463FF16
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:34
Old 10-18-2017, 12:26   #45624 (permalink)
Member: 1429766
Thanks Meter: 62
Samsung J510FN FRP Reset done by Samsung Module 1.06:
SM S/N: ******** Version: 0100
Phone found on COM5
Phone In Download mode...
Reset FRP Procedure started...
Port open Ok!
LOKE received!
Prepare Ok!
Enter Setup...
Try download PIT...
Download PIT Ok!
Reset FRP done
Reboot phone...
Less than 10 seconds. Thank you Infinity Box Team!
The Following User Says Thank You to xukca For This Useful Post:
Old 10-18-2017, 12:27   #45625 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,147
Qmobile X700 Pro 2 MT6580 FRP Reset Done With King Infinity CM2
Wait for phone...
Phone found! [ 37 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
eMMC Flash : 90014A484147346132A42152A0BAA305
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , 2a4GA
[eMMC] : FLASH_CID : 90014A484147346132A42152A0BAA305
[eMMC] : FLASH_LEN : 0x00000003AB400000
[eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB]
DEV RID : 0xD9C8F395524C2CCB96DD02F3728CE333
EXT RAM : 0x80000000 [2 GiB]
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:17
Old 10-18-2017, 14:54   #45626 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,147
Qmobile X2 MT6571 Low Memory Fix Done With King Infinity CM2
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6571
BB_CPU_NME : [MediaTek] MT6571_S00
BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x8B
NAND Flash : 009800BC009000660076001600080000
eMMC Flash : NOT INSTALLED
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1
[NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008
[NAND] : FLASH_LEN : 0x20000000
[NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1
DEV RID : 0xD9C8F395FA9226AFC42AE3F08A713D70
EXT RAM : 0x10000000 [256 MiB]
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:13
Old 10-18-2017, 15:15   #45627 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,147
Qmobile J7 Pro MT6735 Log Hang Recover Fix Only Formate With Infinity CM2
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x93
eMMC Flash : 520001154D423158732207423F924BAA
[eMMC] : FLASH_INF : [SAMSUNG] , BMB1X
[eMMC] : FLASH_CID : 150100525831424D42072273AA4BB33F
[eMMC] : FLASH_LEN : 0x0000000747C00000
[eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB]
DEV RID : 0xD9C8F3954B38914869795938037A01F2
EXT RAM : 0xC0000000 [3 GiB]
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:40
Old 10-18-2017, 18:25   #45628 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,453
World's 1st Kibosun K31 SC6533G Pinlock Format
Identify
Operation : Identify [ v1.00 ]
----- > Powered On :
1. Power On device
2. Connect USB cable
3. When device show StorageMode : Press '0' button for a 5 second!
----- > Powered Off :
1. Insert USB cable
2. Wait when device show Charge icon
Wait for device ...
Device Connected!
BOOT_PWR0 : 0x00600000
BOOT_INIT : 0x81C0024C
BOOT_MODE : DOWNLOAD
BOOT_INTV : 6533G-FPTRUNK-W16.44.2
InternalVersion: g8bec5c4c
Setting BOOTROM mode
BOOT_MODE : BOOTROM
Boot_CPU  : 0x08090007 : [SPREADTRUM] : SC6533G
MEMD for flsh_spi32m Branch: none
Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ]
Performing MemoryInit
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot IV  : 0xFBA2A250
Boot done!
Identify : Code Integrity Check pass!
Device Info Details :
[0] : S069_HWD_A3_1_Kibosun_EL_F6_QQVGA
[1] : 8809
[2] : 8809e2
[3] : CT8851C
[4] : pasw_rda6625
[5] : flsh_spi32m
[6] : nv3021/gc9102/gc9105/st7735s/gc9106
[7] : bf3a01serial/gc6133
[8] : rdabt_8809
[9] : rdafm_8809e
[10] : release
[11] : 2017-07-11_13:40:42
[12] : S069_HWD_A3_1_Kibosun_EL_F6_V01_T01_20170711
Done!
Elapsed: 00:02:54
Reset Settings
Operation : Reset Settings [ v1.00 ]
1. Power On device
1. Insert USB cable
Wait for device ...
Device Connected!
BOOT_MODE : BOOTROM
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot done!
Preparing PMT
Verifying PMT
Erasing 1474560 bytes
FileSystem format done!
Done!
Elapsed: 00:00:45
Old 10-18-2017, 18:34   #45629 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,453
QMobile X30 Hang Logo Write File
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 90014A483447326111018D6A0D69628D
[eMMC] : FLASH_INF : [HYNIX] , a2G4
[eMMC] : FLASH_CID : 90014A483447326111018D6A0D69628D
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID    : 0xD5229C25ED836FF40E0F855AEAA54A26
EXT RAM    : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand     : TINNO
ProdName  : QMobile X30
ProdModel : QMobile X30
Device    : QMobile X30
AndroidVer: 4.4.2
MTKxCPU   : MT6572
MTKxPRJ   : ALPS.KK1.MP7.V1
Done!
Elapsed: 00:00:12
Scatter Load Ok , BaseBand : MT6572 , Project : s4050ap , Storage : EMMC
Files found : 11 , Set to Flash : 10
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC
Setting : AFF verify :  Disabled
Setting : HW verify :  Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3760 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x00000000E5E00000
Flash Pre-Erase Done, time used : 00:00:16
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_s4050ap.bin
Preloader Sent , Init passed
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:45
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:21
Old 10-18-2017, 18:35   #45630 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,453
Operation : Enable ADB (Moto) [ v1.01 ]
Waiting for NetInterface arrival ...
1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons
2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON'
3. Connect USB cable, when device boot complete!
Connect Ok!
Waiting ...
Trying link with  : 192.168.137.2
Connected to device!
Device : XT1254
VerInfo : QUARK_CUST
Version : Blur_Version.24.91.5.quark_verizon.verizon.en.US
Enabling ADB ...
1. Disconnect cable from device, press and hold 'VOLUME_DOWN' and 'POWER_ON'
2. Select 'FACTORY MODE' and press 'POWER ON'!
3. Wait for device boot completely!
Done!
Elapsed: 00:00:09
Connect Ok!
Model  : XT1254
Done!
Elapsed: 00:00:15
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.52352 seconds with 9 queries
