Old 10-19-2017, 05:57   #45631 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,131
Qmobile Eco2 SPD6531 Logo Stuck Fix Only Formate With Infinity CM2
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
==== Wait for phone...
Phone found! [ 9 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00C8 0060 0016 0000
[0] Flash VEN : GigaDevice , GD25LQ32
[0] Flash CAP : 00400000
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:09
Reconnect Power/Cable!
The Following User Says Thank You to azhergoga007 For This Useful Post:
Old 10-19-2017, 06:06   #45632 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,131
Huawei Y560-U02 SPD77xx Logo Hang Fix Only Formate With Infinity CM2
Set mode to : [AltLDR] SP [SC773x] eMMC [Android 5.x]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
Phone found! [ 23 ]
Port Opened
Sync...
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v4 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Done!
Elapsed: 00:00:24
Old 10-19-2017, 06:44   #45633 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,131
Qmobile S1 MT6580 Pin Lock Reset Done With King Infinity CM2
Card found : S/N : A19EC787 , v0136
Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.58 ]
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A483847316505072A523192135F
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A483847316505072A523192135F
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xD9C8F395A78D96B10AF47D299C442323
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
LSSDB Ok!
LSSWL Ok!
LSSSH Ok!
LSSGS Ok!
LSSKY Ok!
Security Settings : Clear Ok!
[Info] : That feature NOT RESET "PRIVACY PASSWORD LOCK"! Use separate button!
[Info] : That feature NOT RESET "FRP/GoogleLOCK"! Use separate "FRP" reset!
[Info] : If phone stuck on "Logo" :
1. Wait 2-3 minutes. Power Off phone by long press "Power" button
2. Power On phone again
3. Or wait up to 3-7 minutes, until phone start by itself
4. Also recommended reboot phone twice before start use it
Done!
Elapsed: 00:00:21
Old 10-19-2017, 07:17   #45634 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,131
Qmobile B67 MT6261 Read Code Done With King Infinity CM2
Operation : Read UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 16 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 5E937B89713C1EB7B56EEAF91C8753B3
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09
[0] : FLASH_DIE : 00C2 0020 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Read ExtData
Sorting ExtData
Reading UserCode
Active : Yes , Code : 7171
PLock|MobTrack : Not active
Done!
Elapsed: 00:00:21
Old 10-19-2017, 08:59   #45635 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,131
Voice V780 SPD6531 Logo Stuck Fix Only Formate With Infinity CM2
Card found: S/N : A19EC787 , v0136
Chinese Miracle II [SPD module] v 1.27
Set mode to : SPD6531
3. Insert battery
Phone found! [ 9 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
[0] Flash DIE : 00EF 0040 0016 0000
[0] Flash VEN : Winbond , W25Q32
Format Block Done!
Done!
Elapsed: 00:00:10
Old 10-19-2017, 09:31   #45636 (permalink)
monusah25's Avatar
Member: 2650572
Sonork: 100.107126
Thanks Meter: 149
Diamond R2 Read Firmware Done With GREAT Cm2 Tool
Set mode to : SP [SC773x] eMMC [Android 6.x]
Operation : Read FullFlash [ v1.27 ]
3. Insert cable
Phone found! [ 39 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
[FW_READER] : Prepare Ok!
- > Wait phone connected ...
Phone found! [ 39 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Phone found! [ 39 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Name  : sp7731c_c7356_wvga_oversea
Model Brand : Diamond
Model Device: R2
AndrVersion : 6.0
BaseBand CPU: SP7731CEB
Project Ver : C7357_BP_BP241_Diamond_360X640_324_B1V01.01B05
Model Ext   : BP241
[Read Mode] : HSUSB : 0x3000
[FW_READER] : Reading Firmware Now ...
[Read Ok] : u-boot-spl-16k.bin
[Read Ok] : u-boot.bin
[Read Ok] : prodnv.img
[Read Ok] : sc7731C_CP0_modem.bin
[Read Ok] : DSP_DM_Gx.bin
[Read Ok] : nvitem_w.bin
[Read Ok] : sc8830g_modem_CP2_WCN_Trunk_W17.21.3_Release.bin
[Read Ok] : nvitem_wcn.bin
[Read Ok] : logo_360x640.bin
[Read Ok] : fblogo_360x640.bin
[Read Ok] : boot.img
[Read Ok] : system.img
[Build Ok] : cache.img
[Read Ok] : recovery.img
[Read Ok] : sysinfo.img
[Build Ok] : userdata.img
AndroidInfo created
Firmware Size : 1888 MiB
Saved to : C:\InfinityBox\CM2SPD\Read_out\SP7731CEB_R2_6.0_C7357_BP_BP241_Diamond_360X640_324_B1V01.01B05_BP241\
Done!
The Following User Says Thank You to monusah25 For This Useful Post:
Old 10-19-2017, 10:35   #45637 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 14,770
Smile Nokia 105 DS flashing done
Core : v2.29 , MTKx FlashEngine : v14.0
Verify files ...
MAUI : RM-1190_DUBAI_ROM_eMP_11.00.11
VIVA : RM-1190_DUBAI_VIVA_eMP_11.00.11
LANG : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_11.00.11
CUST : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_11.00.11
JMPT : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_11.00.11
 - > MODE : FullFlash
Dead Mode is Selected
Waiting for USB device...
1. Phone should be Off!
2. Battery must be charged and inserted! ( if not used external power )
 - > If phone can't switch to BL - use battery or flash from Local mode!
--- Insert USB cable now! ---
Wait for phone...
Phone found! [ 77 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0001
BB_CPU_SN : A6776B8C966020C64412198E1B9A8226
BROM Status : 0000
Comm Status : 0000
EXBL Status : Alive [ USB Load Active ]
Switch to BL done
BL Version : 01
Setting...
Setting done , result code 0x8000
Project ID : DUBAI61D.11.00.11.p1
BROM/BL stage done
DA_eMP_Dubai.fg
DA_VERIFY : 00
DA_JUMP   : 00100000
DA_AUTH   : Passed!
DA_CSTAT  : 0x5A
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x0113 ,
[0] : FLASH_DIE : 00EF 0070 0016 0000
FAT_RANGE : 0x003A0000-0x003F7FFF , LEN : 0x00058000
SecureDecrypt : RM-1190_DUBAI_ROM_eMP_11.00.11
SecureDecrypt : RM-1190_DUBAI_VIVA_eMP_11.00.11
SecureDecrypt : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_11.00.11
SecureDecrypt : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_11.00.11
SecureDecrypt : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_11.00.11
Executing FFS FORMAT now...
DA_RET   : DA_IN_PROGRESS
DA_RET   : FORMAT_DONE
OVRLP : 000069B900000001
PHPID : DUBAI61D.11.00.11.p1
OVRLP : 00004DF900000001
DA : FORMAT_BIN
Processing Flash Pre-format
FILES : 5
SAFE_BLOCK : 04
FORMAT_BIN : Ok
WRITE_STYLE : DEF : 0x01 (SEQ)
Write : RM-1190_DUBAI_ROM_eMP_11.00.11
Write : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_11.00.11
Write : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_11.00.11
Write : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_11.00.11
Write : RM-1190_DUBAI_VIVA_eMP_11.00.11
CODE_DNLOAD : Ok
[VERIFY] DONE : RM-1190_DUBAI_ROM_eMP_11.00.11
[VERIFY] DONE : RM-1190_DUBAI_LANG_PACK_ROM_IJ_eMP_11.00.11
[VERIFY] DONE : RM-1190_DUBAI_CUSTPACK_ROM_IJ_eMP_11.00.11
[VERIFY] DONE : RM-1190_DUBAI_JUMP_TABLE_IJ_eMP_11.00.11
[VERIFY] DONE : RM-1190_DUBAI_VIVA_eMP_11.00.11
CODE_VERIFY : Ok
Flashing done!
Total flash time : 00:00:58
Reboot phone Ok
The Following 2 Users Say Thank You to Akhtar Ali Jatt For This Useful Post:
Old 10-19-2017, 10:55   #45638 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,131
Qmobile I4 SPD77xx Dead Set Re Alive Done By Flashing With Infinity CM2
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : QMobilei4_MP_20150721.pac
CRVersion : BP_R1.0.0
PacCPUinfo : SC7731_UMS
PacVersion : QMobilei4_MP_20150721
File : fdl1.bin
File : fdl2.bin
File : nvitem.bin
File : nvitem_wcn.bin
File : u-boot-spl-16k.bin
File : SC7702_sc7731g_band128.bin
File : DSP_DM_G2.bin
File : SC8800G_x30g_wcn_dts_modem.bin
File : boot.img
File : recovery.img
File : system.img
File : userdata.img
File : LOGO.bmp
File : charge.bmp
File : prodnv.img
File : cache.img
File : u-boot.bin
3. Insert cable
Phone found! [ 23 ]
Port Opened
Sync...
Sync...
Sending FDL
PickUp loaders from pac
FDL Ready!
Boot Ver : Spreadtrum Boot Block version 1.1
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x18 records
PMTManager : PMT Update Ok!
Flashing now
[FlashProc] : ERASE
Current ID : ERASEUBOOT
Current Part : uboot
[FlashProc] : Ok!
[FlashProc] : BOOTCODE
Current ID : SPLLOADER
Current File : u-boot-spl-16k.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_W
Current File : SC7702_sc7731g_band128.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : DSP_W
Current File : DSP_DM_G2.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_WCN
Current File : SC8800G_x30g_wcn_dts_modem.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOT
Current File : boot.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : RECOVERY
Current File : recovery.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : SYSTEM
Current File : system.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : USERDATA
Current File : userdata.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOTLOGO
Current File : LOGO.bmp
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : FASTBOOT_LOGO
Current File : charge.bmp
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : FLASH
Current Part : wruntimenv1
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : FLASH_WCN
Current Part : wcnruntimenv1
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : PRODNV
Current File : prodnv.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : CACHE
Current File : cache.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : ERASEMISC
Current Part : misc
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : ERASESD
Current Part : internalsd
[FlashProc] : Ok!
Current ID : UBOOTLOADER
Current File : u-boot.bin
Flashing now ...
[FlashProc] : Ok!
Elapsed: 00:09:09
The Following 2 Users Say Thank You to azhergoga007 For This Useful Post:
Old 10-19-2017, 11:01   #45639 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,131
Qmobile L2 Classic SPD6531 Call Logs Not Show Recover Done By Flashing With Infinity
3. Insert battery
Phone found! [ 9 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Format Block Done!
Done!
Elapsed: 00:00:06
Old 10-19-2017, 11:37   #45640 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Smile Qmobile i6 metal one reset frp lock done with king infinity cm2
QMOBILE I6 METAL ONE RESET FRP LOCK DONE WITH KING INFINITY CM2
Operation : Check/Read Info [ v1.27 ]
3. Insert cable
Phone found! [ 4 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name : i6_Metal_ONE
Model Brand : QMobile
Model Device: i6_Metal_ONE_new
AndrVersion : 6.0
BaseBand CPU: I6_METAL_ONE
CompileDate : 2/28/2017 10:16:31 AM
Project Ver : MRA58K release-keys
Model Ext : QMobile i6 Metal ONE
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:20
3. Insert cable
Phone found! [ 4 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:29
If You Like My Post Press Thanks
ShahiD
The Following 2 Users Say Thank You to A.G.Shahid For This Useful Post:
Old 10-19-2017, 11:40   #45641 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Smile Qmobile i8i hang on logo done with king infinity cm2
QMOBILE I8I HANG ON LOGO DONE WITH KING INFINITY CM2
3. Insert cable
Phone found! [ 4 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Name : I8i
Model Device: I8i
AndrVersion : 6.0
BaseBand CPU: SP7731CEA
CompileDate : 7/21/2017 11:50:35 AM
Project Ver : QMobile I8i_MP_21_07
Model Ext : QMobile I8i
Elapsed: 00:00:22
3. Insert cable
Phone found! [ 4 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Reset Ok!
Done!
Elapsed: 00:00:25
ShahiD
The Following 3 Users Say Thank You to A.G.Shahid For This Useful Post:
Old 10-19-2017, 11:44   #45642 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Smile Qmobile m95 hang on logo done with king infinity cm2
QMOBILE M95 HANG ON LOGO DONE WITH KING INFINITY CM2
Set mode to : SP [SC773x] eMMC [Android 5.x]
3. Insert cable
Phone found! [ 4 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC773x Android 5.x eMMC v1.0 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Name : scx35_sp7731geaplus_dt
Model Device: scx35_sp7731gea
AndrVersion : 4.4.3
BaseBand CPU: SP7731GEA
CompileDate : 7/31/2015 12:00:38 PM
Project Ver : KOT49H 14B_test-keys
Model Ext : QMobile M95
Elapsed: 00:00:21
Infinity SC Firmware Detected
FW Size : 1239 MiB
Load Ok!
======= Flash
[ MCU ] : SC77xx Infinity Package
3. Insert cable
Phone found! [ 4 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x17 records
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write FSImage : prodnv.img
Write Data ...
Write Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Erase block ...
Block erase Ok!
Erase block ...
Block erase Ok!
Erase block ...
Block erase Ok!
Write CodeData : sc7731g_CP0_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Write CodeData : sc8830g_modem_CP2_WCN_14D_W15.16_Release.bin
Write Data ...
Write Data Ok!
Write CodeData : logo_540x960.bin
Write Data ...
Write Data Ok!
Write CodeData : fblogo_540x960.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system.img
Write Data ...
Write Data Ok!
Write FSImage : cache.img
Write Data ...
FSImage : Make and Flush SPImage
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Process : Flush
Flush Ok!
Write FSImage : userdata.img
Write Data ...
Write Data Ok!
Elapsed: 00:03:16
ShahiD
Old 10-19-2017, 11:49   #45643 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Smile Haier g30 hang on logo done with king infinity cm2
HAIER G30 HANG ON LOGO DONE WITH KING INFINITY CM2
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 45010053454D3034473AF00339455291
[eMMC] : FLASH_VEN : 0x45 , OEM : 0100
[eMMC] : FLASH_INF : [SANDISK] , G40ME
[eMMC] : FLASH_CID : 45010053454D3034473AF00339455291
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000EC000000
[eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB]
DEV RID : 0x0B9C44DE75DA1DF100BBD7A27F826AF6
EXT RAM : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : Haier
ProdName : G30
ProdModel : G30
Device : G30
AndroidVer: 4.4.2
MTKxCPU : MT6572
MTKxPRJ : G30-H01-S023-PK
MODEM :
BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V62_P6_1_wg_n
EXTRA :
LCD [0] : ili9806e_fwvga_dsi_vdo_zgd
LCD [1] : ili9806e_fwvga_dsi_vdo_huashi
LCD Res : 854x480
TOUCH [0] : ft6306_yuye
TOUCH [1] : GT9XX_hotknot
CAM [0] : gc2145_mipi_yuv_m11
CAM [1] : hi541_mipi_yuv_m11
CAM [2] : ov5645_mipi_yuv_m11 sp2529_mipi_yuv_m11
CAM [3] : s5k4ecgx_mipi_yuv
CAM [4] : #s5k8aayx_yuv
MODEM : huiyue72_w_kk_hspa_m11_b1b8_pk
LOCALE : en_US ur_PK fa_IR
Done!
Elapsed: 00:00:16
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:30
ShahiD
Old 10-19-2017, 12:08   #45644 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 3,987
QMobile I5.5 read firmware / reset frp Done :)
Operation : Check/Read Info [ v1.25 ]
3. Insert cable
Phone found! [ 43 ]
Open Port Failed!
3. Insert cable
Phone found! [ 43 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Elapsed: 00:00:22
Operation : Read FullFlash [ v1.25 ]
3. Insert cable
Phone found! [ 43 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Phone found! [ 43 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Phone found! [ 43 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
[Read Ok] : sc7731g_CP0_modem.bin
[Read Ok] : sc8830g_modem_CP2_WCN_14D_W16.29.3_Release.bin
[Read Ok] : logo_720x1280.bin
[Read Ok] : fblogo_720x1280.bin
AndroidInfo created
Firmware Size : 2629 MiB
Saved to : F:\backup files\SC77xx_ANDROID_\
Done!
Elapsed: 00:10:23
Operation : Read NV [ v1.25 ]
3. Insert cable
Phone found! [ 43 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Read GSM NV
Read WCN NV
Read Ok , 0xA5F7
Saved to : F:\1+Flashing Software\1+Infinity Box\CM2SPD\phdata\backup\qmobile i5.5 CX77xx_SPDNV.spdnv
Elapsed: 00:00:42
Operation : Format File System / Reset Settings [ v1.25 ]
3. Insert cable
Phone found! [ 43 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Reset Ok!
Done!
Elapsed: 00:00:25
The Following User Says Thank You to syed tuqeer For This Useful Post:
Old 10-19-2017, 13:41   #45645 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,434
QMobile I5 Hang Logo Write File
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A4834473164040502A11955418F
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040502A11955418F
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID    : 0xD5229C251D7B676E21EB58D73E3DA4F8
SOC VERIFY : C1
Boot Ok!
Brand     : QMobile
ProdName  : QMobile i5
ProdModel : QMobile i5
Device    : QMobile i5
AndroidVer: 4.2.2
MTKxCPU   : MT6582
MTKxPRJ   : ALPS.JB5.MP.V1.6
Done!
Elapsed: 00:00:17
Scatter Load Ok , BaseBand : MT6582 , Project : s4700 , Storage : EMMC
Files found : 13 , Set to Flash : 12
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : s4700 , Storage : EMMC
Setting : AFF verify :  Disabled
Setting : HW verify :  Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 4120 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000001400000-0x0000000000100000
Erase : 0x0000000003100000-0x00000000E5600000
Flash Pre-Erase Done, time used : 00:00:09
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_s4700.bin
Preloader Sent , Init passed
PartCount : 0014
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EBR2
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash now : FAT
Image Flash Ok
Flash Write Done, time used : 00:03:04
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:30
The Following User Says Thank You to Tanha0321 For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-29-2010 21:17
Page generated in 0.61121 seconds with 9 queries
