Old 10-26-2017, 09:25   #45766 (permalink)
meerl329's Avatar
Member: 2752651
Thanks Meter: 176
Acer Liquid Zest T06 FRP, Read And Write Firmware By CM2
The Following User Says Thank You to meerl329 For This Useful Post:
Old 10-26-2017, 09:26   #45767 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,125
Qmobile L1 Classic SPD6531 Logo Stuck Recover Don By Formate With Infinity CM2
Card found: S/N : A19EC787 , v0136
Chinese Miracle II [SPD module] v 1.27
Set mode to : SPD6531
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
==== Wait for phone...
Phone found! [ 9 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00C8 0060 0016 0000
[0] Flash VEN : GigaDevice , GD25LQ32
[0] Flash CAP : 00400000
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:11
Reconnect Power/Cable!
The Following User Says Thank You to azhergoga007 For This Useful Post:
Old 10-26-2017, 11:36   #45768 (permalink)
Member: 2653242
Thanks Meter: 2
thanks a lot zte blade L6 AND archos 55 helium done with success
Old 10-26-2017, 12:11   #45769 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,125
Qmobile E9 MT625A Logo Stuck Fix Only Formate With Infinity CM2
Operation : Format FileSystem [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 16 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6250_S0000
BB_CPU_SN : 60536087C65CCE84BA69AF0436508120
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
InitRes : 00000000
DEV[0] : C800 6000 1800 0000
DEV[1] : 0000 0000 0000 0000
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128
[0] : FLASH_DIE : 00C8 0060 0018 0000
[0] : FLASH_LEN : 0x01000000
INT_RAM : 0x0000D400
EXT_RAM : 0x00800000
Backup done
Executing FFS FORMAT now...
FAT_RANGE : 0x00D70000-0x00FFFFFF , LEN : 0x00290000
DA_RET : DA_IN_PROGRESS
DA_RET : FORMAT_DONE
Done!
Elapsed: 00:00:47
Old 10-26-2017, 12:42   #45770 (permalink)
NadeemSandhu1's Avatar
Member: 2077858
Thanks Meter: 124
itel it5020 unlock scourty code done with EDL Cable with CM2
here is loge
3. Insert battery
Phone found! [ 7 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
[0] Flash DIE : 00EF 0060 0017 0000
[0] Flash VEN : Winbond , W25Q64
[0] Flash CAP : 00800000
Format Block Done!
Done!
Elapsed: 00:00:52
The Following User Says Thank You to NadeemSandhu1 For This Useful Post:
Old 10-26-2017, 13:16   #45771 (permalink)
gile@gile's Avatar
Member: 1473716
Thanks Meter: 805
Oukitel C3 FRP Reset done
Card found : S/N : 07XXXXXX , v0136
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 1140 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 8801034E436172642022D51E71227407
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x88 , OEM : 0103
[eMMC] : FLASH_INF : [FORESEE] , draC
[eMMC] : FLASH_CID : 8801034E436172642022D51E71227407
[eMMC] : FLASH_LEN : 0x00000001CE100000
[eMMC] : FLASH_UCP : 7393 MiB [eMMC 8 GiB]
DEV RID : 0x7FBB5333F32B7F5BA5DB81874411A972
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : OUKITEL
ProdName : full_hct6580_weg_c_m
ProdModel : C3
Device : hct6580_weg_c_m
AndroidVer: 6.0
MTKxCPU : MT6580
MTKxPRJ : OUKITEL-C3-V1.6-20170829
Done!
Elapsed: 00:00:06
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:12
The Following User Says Thank You to [email protected] For This Useful Post:
Old 10-26-2017, 13:43   #45772 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,125
Qmobile W15 SPD77xx Logo Stuck Fix Done Only Formate With Infinity CM2
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
Phone found! [ 9 ]
Port Opened
Sync...
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC773x Android 5.x eMMC v1.0 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount :
State : 0x0001
Cache : PART_MOUNT failed! Part Damaged! Will use Repair Mode!
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Done!
Elapsed: 00:00:30
The Following 2 Users Say Thank You to azhergoga007 For This Useful Post:
Old 10-26-2017, 13:48   #45773 (permalink)
Deepesh Sharma's Avatar
Member: 1301233
Sonork: 100.1614172
Thanks Meter: 9,200
Kimfly A5+ Read Flash FIle
Read Full Flash
Operation : Read FullFlash [ v1.27 ]
3. Insert battery
Phone found! [ 40 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ver : Spreadtrum Boot Block version 1.2    Boot Ok
Read Flash Content
Read Ok , collect info
Platform : MOCOR_12B_6531.W13.07_Release
ExtInfo  : Kimfly
Project  : SC6531_PDA
HWInfo   : SC6531_PDA
Compile  : 04-15-2016 20:20:27
Set FileInfo :
Model Vendor : Kimfly
Model Name   : A5+
ExtInfo Data : Eng.
Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00800000_MOCOR_12B_6531.W13.07_Release_04152016202027_Eng.__Kimfly-A5+.bin
Done!
The Following 2 Users Say Thank You to Deepesh Sharma For This Useful Post:
Old 10-26-2017, 13:50   #45774 (permalink)
Crazy Poster
Member: 2020341
Thanks Meter: 22
Nokia 5-TA-1053 Frp Reset Done By Cm2
The Following 2 Users Say Thank You to hsooan For This Useful Post:
Old 10-26-2017, 13:54   #45775 (permalink)
Crazy Poster
Member: 2020341
Thanks Meter: 22
Nokia 5-TA-1053 Flash Done By Cm2
Old 10-26-2017, 13:56   #45776 (permalink)
Crazy Poster
Member: 2020341
Thanks Meter: 22
Nokia 5 TA-1053 Read FW By CM2
The Following User Says Thank You to hsooan For This Useful Post:
Old 10-26-2017, 14:01   #45777 (permalink)
meerl329's Avatar
Member: 2752651
Thanks Meter: 176
Qnet Neo Read And Write Firmware Sucessfull
The Following 2 Users Say Thank You to meerl329 For This Useful Post:
Old 10-26-2017, 14:12   #45778 (permalink)
meerl329's Avatar
Member: 2752651
Thanks Meter: 176
Starmobile Play Click Unlock Network And Read Firmware Done
Old 10-26-2017, 14:21   #45779 (permalink)
meerl329's Avatar
Member: 2752651
Thanks Meter: 176
LG-K430DSY Made In China Password Remove
Old 10-26-2017, 14:34   #45780 (permalink)
meerl329's Avatar
Member: 2752651
Thanks Meter: 176
Cherry Mobile Flare J2 Mini FRP And Read Firmware Sucess
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-29-2010 21:17
Page generated in 0.49773 seconds with 9 queries
