11-12-2017, 08:06 | #46126 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Lenovo Tab A3000GV MT6582 Logo Stuck Recove Done Only Formate With Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 91 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473264040501A19C817191 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040501A19C817191 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F3958863241DC8216AD6F86CFB7D INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:45 Reconnect Power/Cable! |
11-12-2017, 08:49 | #46127 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile Z9 QLM Only Red Lite Show Recover Fix By Flashing With Infinity CM2 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0BBB5170 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 758FE511BC2A57520D6292F33C078FBF ID_BLOCK_L : 96ED53FAFF66C85D70BF10C9DB2AC407 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Flash Chain : 175 Flashing now Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : hyp.mbn Flashing : hyp.mbn Flashing : misc.img Flashing : splash.img Flashing : chglogo.img Flashing : sec.dat Flashing : boot.img Flashing : system_1.img Flashing : system_2.img Flashing : system_3.img Flashing : system_4.img Flashing : system_5.img Flashing : system_6.img Flashing : system_7.img Flashing : system_8.img Flashing : system_9.img Flashing : system_10.img Flashing : system_11.img Flashing : system_12.img Flashing : system_13.img Flashing : system_14.img Flashing : system_15.img Flashing : system_16.img Flashing : system_17.img Flashing : system_18.img Flashing : system_19.img Flashing : system_20.img Flashing : system_21.img Flashing : system_22.img Flashing : system_23.img Flashing : system_24.img Flashing : system_25.img Flashing : system_26.img Flashing : system_27.img Flashing : system_28.img Flashing : system_29.img Flashing : system_30.img Flashing : system_31.img Flashing : system_32.img Flashing : system_33.img Flashing : persist_1.img Flashing : cache_1.img Flashing : cache_2.img Flashing : cache_3.img Flashing : cache_4.img Flashing : cache_5.img Flashing : recovery.img Flashing : userdata_1.img Flashing : userdata_2.img Flashing : userdata_3.img Flashing : userdata_4.img Flashing : userdata_5.img Flashing : userdata_6.img Flashing : userdata_7.img Flashing : userdata_8.img Flashing : userdata_9.img Flashing : userdata_10.img Flashing : userdata_11.img Flashing : userdata_12.img Flashing : userdata_13.img Flashing : userdata_14.img Flashing : userdata_15.img Flashing : userdata_16.img Flashing : userdata_17.img Flashing : userdata_18.img Flashing : userdata_19.img Flashing : userdata_20.img Flashing : userdata_21.img Flashing : userdata_22.img Flashing : userdata_23.img Flashing : userdata_24.img Flashing : userdata_25.img Flashing : userdata_26.img Flashing : userdata_27.img Flashing : userdata_28.img Flashing : userdata_29.img Flashing : userdata_30.img Flashing : userdata_31.img Flashing : userdata_32.img Flashing : userdata_33.img Flashing : userdata_34.img Flashing : userdata_35.img Flashing : userdata_36.img Flashing : userdata_37.img Flashing : userdata_38.img Flashing : userdata_39.img Flashing : userdata_40.img Flashing : userdata_41.img Flashing : userdata_42.img Flashing : userdata_43.img Flashing : userdata_44.img Flashing : userdata_45.img Flashing : userdata_46.img Flashing : userdata_47.img Flashing : userdata_48.img Flashing : userdata_49.img Flashing : userdata_50.img Flashing : userdata_51.img Flashing : userdata_52.img Flashing : userdata_53.img Flashing : userdata_54.img Flashing : userdata_55.img Flashing : userdata_56.img Flashing : userdata_57.img Flashing : userdata_58.img Flashing : userdata_59.img Flashing : userdata_60.img Flashing : userdata_61.img Flashing : userdata_62.img Flashing : userdata_63.img Flashing : userdata_64.img Flashing : userdata_65.img Flashing : userdata_66.img Flashing : userdata_67.img Flashing : userdata_68.img Flashing : userdata_69.img Flashing : userdata_70.img Flashing : userdata_71.img Flashing : userdata_72.img Flashing : userdata_73.img Flashing : userdata_74.img Flashing : userdata_75.img Flashing : userdata_76.img Flashing : userdata_77.img Flashing : userdata_78.img Flashing : userdata_79.img Flashing : userdata_80.img Flashing : userdata_81.img Flashing : userdata_82.img Flashing : userdata_83.img Flashing : userdata_84.img Flashing : userdata_85.img Flashing : userdata_86.img Flashing : userdata_87.img Flashing : userdata_88.img Flashing : userdata_89.img Flashing : userdata_90.img Flashing : userdata_91.img Flashing : userdata_92.img Flashing : userdata_93.img Flashing : userdata_94.img Flashing : userdata_95.img Flashing : userdata_96.img Flashing : userdata_97.img Flashing : userdata_98.img Flashing : userdata_99.img Flashing : userdata_100.img Flashing : userdata_101.img Flashing : userdata_102.img Flashing : userdata_103.img Flashing : userdata_104.img Flashing : userdata_105.img Flashing : gpt_main0.bin Flashing : gpt_backup0.bin Flash sequence completed! Applying patches for storage # 0 Records : 26 Patch sequence completed! BootConfig set to 0x00 Flashing done! Done! Elapsed: 00:07:01 Reconnect Power/Cable! |
11-12-2017, 09:47 | #46128 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,419 | QMobile E50 Read user Code Done Operation : Read UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 13 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 0EF39F63BA9ADEA11C632504E8167D2E BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 5522 PLock|MobTrack : Not active Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
11-12-2017, 09:48 | #46129 (permalink) | |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,419 | Huawei Y220-U10 Format Done Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 009800BC009000660076001500010000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0097 , NAND_UNKNOWN [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1 DEV RID : 0xE6C52A7DBE1088609CED10356EC6612F INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : HUAWEI ProdName : Y220-U10 ProdModel : Y220-U10 Device : HWY220-U AndroidVer: 2.3.6 MTKxCPU : MT6572 MTKxPRJ : Y220-U10V100R001C466B207SP01 SECURITY : IMEI_SW [1] : 860976000420547 IMEI_SW [2] : 860976000460295 BTMAC Addr : 509F27BBD2C9 WiFi MAC : 509F27BA4C29 Done! Elapsed: 00:00:08 Reconnect Power/Cable! Quote:
11-12-2017, 11:23 | #46130 (permalink) |
No Life Poster Join Date: Sep 2013 Location: KERALA, INDIA
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 789 | Hotwav venus x1 successfully formated security code Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 16 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000005DBFB000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
11-12-2017, 13:20 | #46131 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,293 | Oppo F1f Remove User Locks With All data safe Oppo F1f Remove User Lock(Password) With out lost any bite of data Possible with infinity cm2 Only Thanks You Team Reset User Locks Code: Operation : Reset UserLocks [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 610 [MSM8936] ID_BLOCK_S : 0755C887 ID_BLOCK_I : 0090B0E1 ID_BLOCK_L : 1CE49E78D743487B2419FBE4237EF6D6 ID_BLOCK_L : 0C47C96055FC6EE71AD5BE777DB0AEAD Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8936 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Direct access : Ok! Processing step #1 Processing step #2 Processing step #3 Processing step #4 Processing step #5 Processing step #6 Processing step #7 UserLocks reset passed! 1. Power On phone, wait 30-50 second, press and hold PowerOn button until device restart! 2. To disable/remove fingerprints enter in Settings -> FingerPrint, set any password, remove fingerprints 3. In some cases require reboot phone twice or wait up to 5 minutes! Done! Elapsed: 00:00:34 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to Deepesh Sharma For This Useful Post: |
11-12-2017, 13:42 | #46132 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Motorolla Xt1254 FRP Reset Done With King Infinity CM2 Card found : A19EC787 , v0136 Infinity-Box Android Service Tool [AST] v1.02 Operation : Enable ADB (Moto) [ v1.02 ] Waiting for NetInterface arrival ... 1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons 2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON' 3. Connect USB cable, when device boot complete! Connect Ok! Waiting ... Trying link with : 192.168.137.2 Connected to device! Device : XT1254 VerInfo : QUARK_CUST Version : Blur_Version.24.91.5.quark_verizon.verizon.en.US Enabling ADB ... 1. Disconnect cable from device, press and hold 'VOLUME_DOWN' and 'POWER_ON' 2. Select 'FACTORY MODE' and press 'POWER ON'! 3. Wait for device boot completely! Done! Elapsed: 00:00:09 Operation : Reset FRP (ADB) [ v1.02 ] Waiting for device in ADB mode ... 1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need! 2. Insert USB cable, accept AUTH on PhoneScreen, if software ask! Connect Ok! Device : quark_verizon Model : XT1254 FRP reset passed! Make FACTORY RESET from menu! Done! Elapsed: 00:00:12 |
11-12-2017, 14:08 | #46135 (permalink) |
No Life Poster Join Date: Apr 2008
Member: 740220 Status: Offline Sonork: 100.1654997 Thanks Meter: 253 | successfully read firmware qmobile x32 power 6.0 Set mode to : SP [SC773x] eMMC [Android 6.x] Operation : Read FullFlash [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 18 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Model Name : X32_Power Model Brand : QMobile Model Device: X32_Power AndrVersion : 6.0 BaseBand CPU: X32_POWER Project Ver : MRA58K release-keys Model Ext : QMobile X32 Power [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731C_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : sc8830g_modem_CP2_WCN_Trunk_W16.28.5_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x800.bin [Read Ok] : fblogo_480x800.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : sysinfo.img [Build Ok] : cache.img [Read Ok] : recovery.img [Build Ok] : userdata.img AndroidInfo created Firmware Size : 2824 MiB Saved to : C:\InfinityBox\CM2SPD\Flash\X32_POWER_X32_Power_6. 0_MRA58K_release-keys_QMobile_X32_Power_1712112017\ Done! Elapsed: 00:31:42 Reconnect Power/Cable! |
11-12-2017, 14:10 | #46136 (permalink) |
Member: 740220 Status: Offline Sonork: 100.1654997 Thanks Meter: 253 | successfully Format File System / Reset Settings Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 18 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000011B1F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:31 Reconnect Power/Cable! |
11-12-2017, 14:49 | #46137 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,419 | Samsung Clone j2 Fullflash Done Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483447316404860FA2E62470BB Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A483447316404860FA2E62470BB [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0xE6C52A7D8AD3BCA096F2443E9CA92416 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : lightning89_wet_jb3 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Disabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3767 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000880000-0x0000000000100000 Erase : 0x0000000002580000-0x00000000E3B80000 Flash Pre-Erase Done, time used : 00:00:03 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_lightning89_wet_jb3.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash now : FAT Image Flash Ok Flash Write Done, time used : 00:02:18 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:02:36 Reconnect Power/Cable! |
11-12-2017, 14:52 | #46138 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,419 | Qmobile j5 Clone Format Done Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483447316404860FA2E62470BB Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A483447316404860FA2E62470BB [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0xE6C52A7D8AD3BCA096F2443E9CA92416 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:17 Reconnect Power/Cable! |
11-12-2017, 14:53 | #46139 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,419 | Qmobile X6i 3G Format Done Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 25 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7715 Loader NAND v1.1 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected NAND Flash , Structure detect Ok! Formatting NAND Flash Format UserData Format Ok! Format Cache Format Ok! Done! Elapsed: 00:00:51 Reconnect Power/Cable! |
11-12-2017, 15:20 | #46140 (permalink) |
Freak Poster Join Date: Dec 2015 Location: MansehrA KPK (Pakistan) Age: 29
Member: 2505147 Status: Offline Sonork: [email protected] Thanks Meter: 182 | OPPO A57 (CPH1701) AndroidVer: 6.0.1 READ FLASH AND RESET FRP DONE Operation : Read Flash [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 435 [MSM8940] ID_BLOCK_S : 32541145 ID_BLOCK_I : 0006B0E1 ID_BLOCK_L : F931A01C3232495AA12D3597307B3451 ID_BLOCK_L : F0F35A57D6B41D8D9C9972795D2CAE1D Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RX1BMB Boot Ok! Brand : Android ProdName : CPH1701 ProdModel : CPH1701 Device : CPH1701 AndroidVer: 6.0.1 SWVersion : CPH1701EX_11.A.30_INT_030_201709301307 Manufact. : OPPO QLMxCPU : MSM8937 DevInfo : MSM8937__OPPO__Android__ANDR_v6.0.1__CPH1701__CPH1 701__CPH1701__CPH1701EX_11.A.30_INT_030_2017093013 07 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : devcfg.mbn [Read Ok] : adspso.bin [Read Ok] : pnvbak.img [Read Ok] : lsplash.img [Read Ok] : ddr.bin [Read Ok] : sec.dat [Read Ok] : emmc_appsboot.mbn [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : cache.img [Read Ok] : system.img [Read Ok] : persist.img [Read Ok] : misc.img [Read Ok] : mdtp.img [Read Ok] : cmnlib.mbn [Read Ok] : cmnlib64.mbn [Read Ok] : keymaster.mbn [Read Ok] : ap.mbn [Read Ok] : driver.iso [Read Ok] : reserve4.bin [Read Ok] : reserve_exp1.bin [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin [Read Ok] : gpt_main2.bin [Read Ok] : cdt.mbn [Read Ok] : gpt_backup2.bin Android Info saved! Read finished! Configuration : MSM8937 / eMMC Firmware Size : 4579 MiB Done! Elapsed: 00:06:08 Reconnect Power/Cable! Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 435 [MSM8940] ID_BLOCK_S : 32541145 ID_BLOCK_I : 0006B0E1 ID_BLOCK_L : F931A01C3232495AA12D3597307B3451 ID_BLOCK_L : F0F35A57D6B41D8D9C9972795D2CAE1D Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RX1BMB Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
