Old 11-13-2017, 05:33   #46141 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,129
Qmobile E4 MT6261 Read Code Done With Great Infinity CM2
Card found : S/N : A19EC787 , v0136
Operation : Read UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 77 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6250_S0000
BB_CPU_SN : 83A7D2935C1263D1987711008979C7B3
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
InitRes : 00000000
DEV[0] : C200 2500 3600 0000
DEV[1] : 0000 0000 0000 0000
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E
[0] : FLASH_DIE : 00C2 0025 0036 0000
[0] : FLASH_LEN : 0x00400000
INT_RAM : 0x0000D400
EXT_RAM : 0x00400000
Read ExtData
Sorting ExtData
Reading UserCode
Active : No , Code : 0789
PLock|MobTrack : Not active or LID not exists
Done!
Elapsed: 00:00:10
Reconnect Power/Cable!
Old 11-13-2017, 05:57   #46142 (permalink)
buffer2k11's Avatar
Member: 2604648
Thanks Meter: 318
SWIFT-TAB II 12WB3G (TMPA) done
Operation : Reset Settings [ v2.01 ]
----- > Phone/Tablet :
1. Power Off device
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable! Press 'POWER_ON' button for a few second!
----- > IoT/Box :
1. Reset device power
2. PRESS and HOLD 'RESET' KEY!
3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second!
Wait for device ...
Device Connected!
Interface test : Passed
Device mode : Normal [ LOADER OPEN ]
Machine : RK3066
Device  : SWIFT-TAB II 12WB3G
ExtInfo : 4.0.4
SoC CPU : 300A
SoC PDT : 2011
SoC SWN : 1111
SoC REV : V101
Flash CSx  : 0x00
Flash Type : 2C88044BA9 [ NAND ]
Flash Vend : MICRON
Flash Size : 0x0000000200000000 ( 8.00 GiB )
Flash Info : 2097152/8192/30/24/15
Connect Ok!
Wiping UserData ...
Wipe DATA Ok!
Done!
Elapsed: 00:00:05
Old 11-13-2017, 05:59   #46143 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,129
Alcatel Pop 5051D MT6580 Pattren read Done With Infinity CM2
Operation : Read Pattern/DP Lock [ v1.58 ]
Wait for phone...
Phone found! [ 91 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 150100513732534D4200B8E590B1237B
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BMS27
[eMMC] : FLASH_CID : 150100513732534D4200B8E590B1237B
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xD9C8F395ADC87C1DABE8C82310716494
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Reading data ...
Get Locks ...
PatternLock Sequnce : 235741968
Done!
Elapsed: 00:00:15
Old 11-13-2017, 07:04   #46144 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,129
Oppo R2001 MT6572 Dead Set Re Alive Done With King Infinity CM2
Scatter Load Ok , BaseBand : MT6582 , Project : oppo82_13081 , Storage : EMMC
Files found : 14 , Set to Flash : 13
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 77 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Running DA ver.4.2 on BBID : 0x87
eMMC Flash : 90014A4834473164040502A24A14B1C1
DRAM configured from ScatFW!
DRAM initialize passed!
DRAM size : 0x40000000
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040502A24A14B1C1
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xD9C8F3956C4726BDBB45FFFFE0476A24
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : oppo82_13081 , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
Switching to HSUSB
HSUSB Init Ok
BL : Check HW compatibility
BL : Skip checking by User request!
BL : BatteryLevel : 4039 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x00000000E5E00000
Flash Pre-Erase Done, time used : 00:00:05
SecCfg Passed , 1799
BMT remark not need. Will skip
Preloader Download skipped by user request!
PartCount : 0017
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EBR2
Image Flash Ok
Flash now : RESERVE2
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash now : FAT
Image Flash Ok
Flash Write Done, time used : 00:02:34
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : EBR2
Verify Passed : RESERVE2
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Verify Passed : FAT
Data Verify Done, time used : 00:00:37
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:35
Old 11-13-2017, 09:55   #46145 (permalink)
Member: 107148
Thanks Meter: 37
Please Need Flash File
Old 11-13-2017, 10:14   #46146 (permalink)
muzammal mudass's Avatar
Member: 1819120
Sonork: 100.1648344
Thanks Meter: 1,344
Qmobile SP2000 Read Flash File Done With Great CM2
Operation : Read Flash [ v1.58 ]
Wait for phone...
Phone found! [ 9 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 58B57E32803B0AE01F2DFBBA29AD7094
Setting...
BROM stage done
DA_INFO   : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV
[0] : FLASH_DIE : 00EF 0070 0016 0000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
Reading Flash Content now ...
Read Flash now
Read Ok , 4194304 bytes read
Check and collect compile info
File_Info   : FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_MP_V2_F9.bin
FileVersion : MAUI.11C.W13.52.MP.V2.F9
Saved to : C:\InfinityBox\CM2MTK\Read_out\FISE61D_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_MP_V2_F9.bin
Done!
Elapsed: 00:00:21
Muzammal Mudasser
The Following User Says Thank You to muzammal mudass For This Useful Post:
Old 11-13-2017, 10:35   #46147 (permalink)
Yusuf Lawal's Avatar
Member: 1677653
Thanks Meter: 1,949
ITEL IT5625 FORMAT & READ FLASH DONE
Operation : Check/Read Info [ v1.27 ]
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
 ====  Wait for phone...
Phone found! [ 12 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00C8 0060 0017 0000
[0] Flash VEN : GigaDevice , GD25LQ64
[0] Flash CAP : 00800000
Elapsed: 00:00:10
Operation : Format File System / Reset Settings [ v1.27 ]
3. Insert battery
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:15
Operation : Read FullFlash [ v1.27 ]
3. Insert battery
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Read Flash Content
Read Ok , collect info
Platform : MOCOR_12C.W13.04.14_Debug
G2803A_it5625_64X64_240X320BAR_EnFrPoArSwHa
Project  : it5625-G2803A-EnFrPoArSwHa-20170705
HWInfo   : fp6531_bar
Compile  : 07-05-2017 20:33:35
Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00800000_MOCOR_12C.W13.04.14_Debug_G2803A_it5625_64X64_240X320BAR_EnFrPoArSwHa_07052017203335.bin
Done!
Elapsed: 00:00:31
Old 11-13-2017, 12:23   #46148 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,129
Qmobile S6s MT6580 FRP Reset Done With King Infinity CM2
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 91 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 150100514531334D4207B6FBE40793D9
[eMMC] : FLASH_INF : [SAMSUNG] , BM31E
[eMMC] : FLASH_CID : 150100514531334D4207B6FBE40793D9
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0xD9C8F395F58F30D8EC648E7131EA091A
EXT RAM : 0x80000000 [2 GiB]
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:19
Old 11-13-2017, 12:51   #46149 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,129
Voice V22 MT6572 Logo Stuck Recover Done Only Formate With Innfinity CM2
Wait for phone...
Phone found! [ 91 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 7001004D4D4330344758E7E84C21516D
[eMMC] : FLASH_VEN : 0x70 , OEM : 0100
[eMMC] : FLASH_INF : [KINGSTON] , G40CM
[eMMC] : FLASH_CID : 7001004D4D4330344758E7E84C21516D
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000
[eMMC] : FLASH_LEN : 0x00000000E6800000
[eMMC] : FLASH_UCP : 3688 MiB [eMMC 4 GiB]
DEV RID : 0xD9C8F395E43402AD9C13F96AB5A9261E
EXT RAM : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:24
Old 11-13-2017, 13:38   #46150 (permalink)
awanbrother's Avatar
Member: 2505147
Thanks Meter: 148
Thumbs up QMobile_Z8 MSM8916 read flash file done ny great cm2
Operation : Read Flash [ v1.15 ]
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 0BB49889
ID_BLOCK_I : 007050E1
ID_BLOCK_L : 1EE69C7AD5414E79261BF5DA257CF4D4
ID_BLOCK_L : 6FE6A803F49FCF4479B419D6DCD3CD0E
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Brand : QMobile Z8
ProdName : QMobile Z8
ProdModel : QMobile Z8
Device : l5510
AndroidVer: 5.0.2
Manufact. : QMobile Z8
QLMxCPU : MSM8916
DevInfo : MSM8916__QMobile_Z8__QMobile_Z8__ANDR_v5.0.2__l551 0
Reading Flash Content ...
[Read Ok] : gpt_main0.bin
[Read Ok] : NON-HLOS.bin
[Read Ok] : sbl1.mbn
[Read Ok] : emmc_appsboot.mbn
[Read Ok] : rpm.mbn
[Read Ok] : tz.mbn
[Read Ok] : hyp.mbn
[Read Ok] : misc.img
[Read Ok] : splash.img
[Read Ok] : fs_gc.img
[Read Ok] : sec.dat
[Read Ok] : boot.img
[Read Ok] : system.img
[Read Ok] : persist.img
[Read Ok] : cache.img
[Read Ok] : recovery.img
[Read Ok] : oem.img
[Read Ok] : userdata.img
[Read Ok] : gpt_backup0.bin
Android Info saved!
Read finished!
Configuration : MSM8916 / eMMC
Firmware Size : 2226 MiB
Done!
Elapsed: 00:03:17
Old 11-13-2017, 13:46   #46151 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,129
Qmobile I6 Metal 1 MT6580 FRP Reset Done With King Infinity CM2
Wait for phone...
Phone found! [ 91 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A4838473165050734D3DC081367
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A4838473165050734D3DC081367
DEV RID : 0xD9C8F395A56B3B86040D9A48361A9D06
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:11
The Following User Says Thank You to azhergoga007 For This Useful Post:
Old 11-13-2017, 13:52   #46152 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,129
Lenovo A2010a MT6735 FRP Reset Done With Infinity CM2
Wait for phone...
Phone found! [ 91 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x93
eMMC Flash : 510001154D53323770F10042A72DB7D4
[eMMC] : FLASH_CID : 150100513732534D4200F170D4B772A7
DEV RID : 0xD9C8F395E350AB6D6044ACEEC5153B7A
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:14
Old 11-13-2017, 14:27   #46153 (permalink)
mohsinsomeone's Avatar
Member: 1785307
Thanks Meter: 97
Motorola Moto G4 Play XT1609 (vzw) Enable Factory & Reset FRP DONE
Enable Factory:
Operation : Moto ADB Enable [ v1.03 ]
Mode : Enable Factory
Waiting for device in fastboot mode ...
1. Power off device. Press and hold 'VOL DOWN' button
2. Insert USB cable, hold button until device will be found!
Connect Ok!
Operation done!
 -- > Info : Wait till device boot, make "Enable ADB" operation after
 -- > Info : Don't forget DISABLE "FACTORY MODE" after make "RESET FRP"!
Done!
Elapsed: 00:00:07
Enable ADB:
Mode : Enable ADB
Waiting for NetInterface arrival ...
1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons
2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON'
3. Connect USB cable, when device boot complete!
Connect Ok!
Waiting ...
Trying link with  : 192.168.137.2
Connected to device!
Device : XT1609
Switching to FACTORY ...
Setting Unsecure mode
Waiting device ...
Connect Ok!
Device : XT1609
Setting ADB ...
Waiting device ...
Connect Ok!
Device : XT1609
Setting ADB ...
1. Disconnect cable from device, wait device reboot
2. Make "Reset FRP"
3. Disable "FACTORY MODE" after operations done!
Done!
Elapsed: 00:00:53
Reset FRP:
Operation : Reset FRP (ADB) [ v1.03 ]
Waiting for device in ADB mode ...
1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need!
2. Insert USB cable, accept AUTH on PhoneScreen, if software ask!
Connect Ok!
Device : harpia_vzw
Model  : XT1609
FRP reset passed! Make FACTORY RESET from menu!
 -- > MOTO FRP : Don't forget to DISABLE FACTORY MODE!
Done!
Elapsed: 00:00:13
Disable Factory:
Mode : Disable Factory
Connect Ok!
Operation done!
Done!
Elapsed: 00:00:06
The Following User Says Thank You to mohsinsomeone For This Useful Post:
Old 11-13-2017, 14:40   #46154 (permalink)
helpo's Avatar
Member: 2175357
Sonork: QQ:2157039171
Thanks Meter: 396
Thumbs up tecno w5 spd remove frb succefully
1. Remove battery. Insert battery back
2. Insert cable
3. In case of SVC init problems - connect with hold "VolDown" button!
Phone found! [ 29 ]
Port Opened
Sync...
InitSvc Done
Wait for phone...
Sync...
Phone Initial Info :
Platform : MOCORTM_14B_7731C_W16.43.2_Debug
Project  : sc7731C_CP0_modem
HWInfo   : sc7731C_CP0_modem
Compile  : 10-19-2016 14:00:16
Phone Security Info :
IMEI [1] : 3***
IMEI [2] : 3***
BT_ADDR  : 000000000000
SelfInfo :
BatVoltage : 3.475 V
Done
Settings : SmartFormat is On
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
 -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
Phone found! [ 29 ]
Port Opened
Sync...
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC773x eMMC Loader v7 InfinityBox
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:20
The Following User Says Thank You to helpo For This Useful Post:
Old 11-13-2017, 14:55   #46155 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,129
Qmobile X5 MT6571 Logo Stuck Recover Fix Only Formate With Infinity CM2
Wait for phone...
Phone found! [ 91 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6571
BB_CPU_NME : [MediaTek] MT6571_S00
BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x8B
NAND Flash : 009800BC009000660076001600080000
eMMC Flash : NOT INSTALLED
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1
[NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008
[NAND] : FLASH_LEN : 0x20000000
[NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1
DEV RID : 0xD9C8F3955B0D432A1E829DBBDF194746
EXT RAM : 0x10000000 [256 MiB]
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:18
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-29-2010 21:17
Page generated in 0.81257 seconds with 9 queries
