Old 11-15-2017, 05:08   #46216 (permalink)
Nadeem Waris's Avatar
Member: 1080718
Sonork: 100.1596539 QQ-2710826805
Thanks Meter: 2,123
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : SC77xx Infinity Package
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 18 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC773x Android 5.x eMMC v1.0 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x17 records
PMTManager : PMT Update Ok!
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write FSImage : prodnv.img
Write Data ...
Write Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Erase block ...
Block erase Ok!
Erase block ...
Block erase Ok!
Erase block ...
Block erase Ok!
Write CodeData : sc7731g_CP0_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Write CodeData : sc8830g_modem_CP2_WCN_14D_W15.22.3_Release.bin
Write Data ...
Write Data Ok!
Write CodeData : logo_540x960.bin
Write Data ...
Write Data Ok!
Write CodeData : fblogo_540x960.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system.img
Write Data ...
Write Data Ok!
Write FSImage : cache.img
Write Data ...
FSImage : Make and Flush SPImage
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Process : Flush
Flush Ok!
Write FSImage : userdata.img
Write Data ...
Write Data Ok!
Elapsed: 00:04:09
Reconnect Power/Cable!
Old 11-15-2017, 05:10   #46217 (permalink)
Member: 1080718
Thanks Meter: 2,123
======= Flash
3. Insert cable
Phone found! [ 18 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
[FL] : Enabled NVM update. Will program all NVM images found in FW !
Flashing now
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Update NVM image : nvitem.bin
Update NVM Data Ok!
Erase block ...
Block erase Ok!
Erase block ...
Block erase Ok!
Update NVM image : nvitem_wcn.bin
Update NVM Data Ok!
Erase block ...
Block erase Ok!
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Process : Flush
Flush Ok!
Write Data ...
Write Data Ok!
Elapsed: 00:04:14
Old 11-15-2017, 06:00   #46218 (permalink)
Member: 1080718
Thanks Meter: 2,123
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 30 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 150100464A32374D42021774F48A7241
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM72J
[eMMC] : FLASH_CID : 150100464A32374D42021774F48A7241
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0x0386520DD68D0B30857236A3776094A5
INT RAM : 0x00020000
EXT RAM : 0x30000000 [768 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:09
Old 11-15-2017, 06:35   #46219 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,147
Qmobile K160 SPD6531 Call Logs Not Show Fix Only Formate With Infinity CM2
Card found: S/N : A19EC787 , v0136
Chinese Miracle II [SPD module] v 1.27
Set mode to : SPD6531
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
Phone found! [ 109 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00EF 0040 0016 0000
[0] Flash VEN : Winbond , W25Q32
[0] Flash CAP : 00400000
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:08
Old 11-15-2017, 06:46   #46220 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 14,818
Smile Qmobile M95 FullFlash Done
Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0]
Infinity SC Firmware Detected
FW Size : 1239 MiB
Load Ok!
======= Flash
3. Insert cable
Phone found! [ 6 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Flashing now
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Erase block ...
Block erase Ok!
Erase block ...
Block erase Ok!
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write CodeData : sc8830g_modem_CP2_WCN_14D_W15.16_Release.bin
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Process : Flush
Flush Ok!
Write Data ...
Write Data Ok!
Elapsed: 00:03:28
Old 11-15-2017, 07:09   #46221 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Qmobile Noir i5i FullFlash Done
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 17 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x87
eMMC Flash : 90014A4834473164040502A10E8D8149
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040502A10E8D8149
DEV RID : 0xE6C52A7D44BB711716F04F532676129B
EXT RAM : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : s4300ap , Storage : EMMC
Setting : Flash Pre-Erase : Off ( Write Flash Only )
Setting : AFF verify : Disabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Skip checking by User request!
BL : BatteryLevel : Unknown (not supported or without battery)
SecCfg Passed , 1799
BMT remark not need. Will skip
Preloader Download skipped by user request!
PartCount : 0014
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EBR2
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:29
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:02:45
Old 11-15-2017, 08:00   #46222 (permalink)
Member: 1091455
Sonork: qq 2250871952
Thanks Meter: 456
samsung b310e phone lock done
cm2
wasim mansuri
Set mode to : SPD6530_SAMSUNG
3. Insert battery
Phone found! [ 87 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
CPU ID : 6530 , FDLStat : 00C0
[0] Flash DIE : 00C8 0060 0017 0000
[0] Flash VEN : GigaDevice , GD25LQ64
[0] Flash CAP : 00800000
Format Block Done!
Done!
Elapsed: 00:00:21
Old 11-15-2017, 08:29   #46223 (permalink)
jjamshad5's Avatar
Member: 2156086
Sonork: 4562
Thanks Meter: 206
lenovo s60 flashing done(warning..invalid image,enter fastboot mode solved)
Card found : Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.15
Operation : Identify [ v1.15 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 0820583A
ID_BLOCK_I : 007050E1
ID_BLOCK_L : 1A4041BDBFCFBA4B9ED339F7643308B9
ID_BLOCK_L : 027547A2ABCEF37CBD23845CD8B83E88
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Brand : Lenovo
ProdName : sisleylr
ProdModel : Lenovo S60-a
Device : sisleylr
AndroidVer: 5.0.2
Manufact. : LENOVO
SysPatch : LRX22G
DevComTime: 10/21/2015 6:59:25 AM
QLMxCPU : MSM8916
QLMxPRJ : S60-a_USR_S232_1510211432_Q2040.1_ROW
USERData : NORMAL
GCSec : NORMAL
Done!
Elapsed: 00:00:23
Loading firmware ...
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : Lenovo
Device Manufact.: LENOVO
Device Model : sisleylr
Device CPU : MSM8916
Device IntName : sisleylr
Device Version : 5.0.2
CU_SWVer : LENOVO
Device Compile : 6/1/2015 6:39:21 AM
Device Project : S60-a_USR_S220_1506011438_Q2040.1_ROW
Device ExtInfo : Lenovo S60-a
Load Ok!
Operation : Flash [ v1.15 ]
ForceFlashing : Disabled
Verify FW package ...
Verification passed!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Pickup loader from firmware package
Boot Ok!
Flash Chain : 34
Flashing now
Flashing : gpt_main0.bin
Flashing : NON-HLOS.bin
Flashing : sbl1.mbn
Flashing : sbl1.mbn
Flashing : emmc_appsboot.mbn
Flashing : rpm.mbn
Flashing : rpm.mbn
Flashing : tz.mbn
Flashing : tz.mbn
Flashing : hyp.mbn
Flashing : hyp.mbn
Flashing : sec.dat
Flashing : boot.img
Flashing : recovery.img
Flashing : splash.img
Flashing : persist.img
Flashing : misc.img
Flashing : system.img
Flashing : cache.img
Flashing : preload.img
Flashing : userdata.img
Flashing : gpt_backup0.bin
Wipe data ...
BootConfig set to 0x00
Flashing done!
Done!
Elapsed: 00:08:20
The Following User Says Thank You to jjamshad5 For This Useful Post:
Old 11-15-2017, 08:34   #46224 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,147
Archos Ac50CNE SPD77xx Logo Stuck Recover Only Formate With Infinity CM2
Set mode to : SP [SC773x] eMMC [Android 5.x]
3. Insert cable
Phone found! [ 90 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Done!
Elapsed: 00:00:21
Old 11-15-2017, 09:01   #46225 (permalink)
fahadboss's Avatar
Member: 2441366
Thanks Meter: 85
Smile Moto XT1254 (Droid Turbo) FRP Reset Done by AST
Enable ADB:
Operation : Moto ADB Enable [ v1.03 ]
Mode : Enable ADB
Waiting for NetInterface arrival ...
1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons
2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON'
3. Connect USB cable, when device boot complete!
Connect Ok!
Waiting ...
Trying link with  : 192.168.137.2
Connected to device!
Device : XT1254
Switching to FACTORY ...
Setting Unsecure mode
Waiting device ...
Connect Ok!
Device : XT1254
Setting ADB ...
Waiting device ...
Connect Ok!
Device : XT1254
Setting ADB ...
1. Disconnect cable from device, wait device reboot
2. Make "Reset FRP"
3. Disable "FACTORY MODE" after operations done!
Done!
Elapsed: 00:01:14
Operation : Identify [ v1.03 ]
Waiting for device in fastboot mode ...
1. Power off device. Press and hold 'VOL DOWN' button
2. Insert USB cable, hold button until device will be found!
Connect Ok!
Done!
Elapsed: 00:00:18
Reset FRP:
Operation : Reset FRP (ADB) [ v1.03 ]
Waiting for device in ADB mode ...
1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need!
2. Insert USB cable, accept AUTH on PhoneScreen, if software ask!
Connect Ok!
Error : Fail to init secure handshake!
Check cable, connection, drivers and AUTH dialog on device screen!
Connect Ok!
Device : quark_verizon
Model  : XT1254
FRP reset passed! Make FACTORY RESET from menu!
 -- > MOTO FRP : Don't forget to DISABLE FACTORY MODE!
Done!
Elapsed: 00:00:13
Br,
Fahad Ahmad
The Following User Says Thank You to fahadboss For This Useful Post:
Old 11-15-2017, 09:25   #46226 (permalink)
helpo's Avatar
Member: 2175357
Sonork: QQ:2157039171
Thanks Meter: 407
Blu vivo 5 mini rest frb
Wait for phone...
Phone found! [ 228 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00
Running DA ver.4.2 on BBID : 0x9C
eMMC Flash : 70010045483845413401010D1A7844F3
[eMMC] : FLASH_VEN : 0x70 , OEM : 0100
[eMMC] : FLASH_INF : [KINGSTON] , 4AE8H
[eMMC] : FLASH_CID : 70010045483845413401010D1A7844F3
[eMMC] : FLASH_LEN : 0x00000001C8000000
[eMMC] : FLASH_UCP : 7296 MiB [eMMC 8 GiB]
DEV RID    : 0xD54A11CD619D1A6047E17D596DC33BAC
EXT RAM    : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:11
The Following User Says Thank You to helpo For This Useful Post:
Old 11-15-2017, 10:54   #46227 (permalink)
Member: 1043111
Sonork: 1000.2
Thanks Meter: 367
true smart 4.0 gen c 4.0 androin 7.0 done.
Operation : Reset FRP [ v1.03 ]
Mode : Remove SPD GENERIC FRP
Connect Ok!
FRP Erase Ok!
Done!
Elapsed: 00:00:07
Old 11-15-2017, 11:38   #46228 (permalink)
Member: 1080718
Thanks Meter: 2,123
Operation : Read Flash [ v1.58 ]
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 1501004E35585A4D4201C77AC602A121
[eMMC] : FLASH_INF : [SAMSUNG] , BMZX5
[eMMC] : FLASH_CID : 1501004E35585A4D4201C77AC602A121
DEV RID : 0x0386520DEE8C4C52DB1E768E9C92BA30
SOC VERIFY : C1
Boot Ok!
Reading Flash Content now ...
Brand : samsung
ProdName : lenovo72_we_jb3
ProdModel : GT-I8552
Device : lenovo72_we_jb3
AndroidVer: 4.2.2
MTKxCPU : MT6572
MTKxPRJ : ALPS.JB3.MP.V1
[Read Ok] : preloader_lenovo72_we_jb3.bin
[Read Ok] : MBR
[Read Ok] : EBR1
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : secro.img
[Read Ok] : logo.bin
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : userdata.img
[ScatCFG] : MT6572 / V1.1.1 / lenovo72_we_jb3 / EMMC
Android Info saved
MAUI Meta DB saved
HWConfig Info saved
FW Size : 952 MiB
Scatter saved to : C:\Users\WARIS COM\Desktop\MT6572__samsung__GT-I8552__lenovo72_we_jb3__4.2.2__ALPS.JB3.MP.V1\
All done!
Done!
Elapsed: 00:05:28
Old 11-15-2017, 11:39   #46229 (permalink)
Member: 1080718
Thanks Meter: 2,123
Operation : Remove Viruses [SmartAV] [ v1.58 ]
SmartAV Conf : 100/80/2000
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
SmartAV Init Ok!
Scanning FileSystem now , please wait
Scan Done, infected files found : 8
Removing infected files and scripts ...
SmartAV Report : Removed 8 infected files!
Making additional operations ...
Special Op #1 : Clear Recovery Data Ok!
Special Op #2 : Clear UserData Ok!
Special Op #3 : PostFix Ok!
Done!
Done!
Elapsed: 00:01:07
Operation : Scan APPs [DDirect] [ v1.58 ]
Wait for phone...
Phone found! [ 49 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x20000000
SOC VERIFY : C1
Boot Ok!
USBDL : Init HSUSB Ok
DDirect : Init Ok!
Collect and verify data according Dictionary
Collect done : 0x0004
[DDCleaner Info] : Files to remove : 4
[DDCleaner Info] : Additional garbage detected : 0
Removing files ...
[DDCleaner] : Removed 4
All Done!
Done!
Elapsed: 00:01:00
Wait for phone...
Phone found! [ 49 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:32
Old 11-15-2017, 11:39   #46230 (permalink)
Member: 1080718
Thanks Meter: 2,123
Operation : Reset UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 29 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : CB2E5A9D02D9D9817ACC6B0D2A27D131
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09
[0] : FLASH_DIE : 00C2 0020 0016 0000
[0] : FLASH_LEN : 0x00300000
SDS_INFO : 0x002FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Backup done
Read ExtData
Sorting ExtData
Sort Ok, Rebuild Ok
Restore ExtData
All done
UserCode request removed
UserCode set to default ( 0000 or 1122 )
Done!
Elapsed: 00:00:22
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.75990 seconds with 9 queries
