Old 11-21-2017, 08:51   #46381 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,150
Qmobile E600 MT6261 Read Code Done With King Infinity CM2
Card found : S/N : A19EC787 , v0136
Operation : Read UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 77 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 387031C5359F0C892DF330948A8FB96B
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09
[0] : FLASH_DIE : 00C2 0020 0016 0000
[0] : FLASH_LEN : 0x00300000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Read ExtData
Sorting ExtData
Reading UserCode
Active : Yes , Code : 1122
PLock|MobTrack : Not active
Done!
Elapsed: 00:00:05
Reconnect Power/Cable!
The Following User Says Thank You to azhergoga007 For This Useful Post:
Old 11-21-2017, 12:30   #46382 (permalink)
Member: 2781045
Hola Amigos De Gsm Forum Como Puedo desbloquear Con InfinityBox
Old 11-21-2017, 12:48   #46383 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Smile Call me c345 reset password done with king infinity cm2
CALL ME C345 RESET PASSWORD DONE WITH KING INFINITY CM2
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
==== Wait for phone...
Phone found! [ 18 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00EF 0040 0016 0000
[0] Flash VEN : Winbond , W25Q32
[0] Flash CAP : 00400000
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:11
If You Like My Post Press Thanks
ShahiD
The Following 2 Users Say Thank You to A.G.Shahid For This Useful Post:
Old 11-21-2017, 12:51   #46384 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Smile Galaxy j5 prime reset frp done with king infinity cm2
GALAXY J5 PRIME RESET FRP DONE WITH KING INFINITY CM2
Phone found on COM14
Phone In Download mode...
Reset FRP Procedure started...
Port open Ok!
LOKE received!
Prepare Ok!
Enter Setup...
Try download PIT...
Download PIT Ok!
Reset FRP done
Reboot phone...
ShahiD
Old 11-21-2017, 12:55   #46385 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Smile Qmobile i2 pro hang on logo done with king infinity cm2
QMOBILE I2 PRO HANG ON LOGO DONE WITH KING INFINITY CM2
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
Phone found! [ 28 ]
Port Opened
Sync...
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v3 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0000
Mount : /cache
State : 0x0000
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Done!
Elapsed: 00:00:48
ShahiD
Old 11-21-2017, 12:57   #46386 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Smile Qmobile i6i hang on logo done with king infinity cm2
QMOBILE I6I HANG ON LOGO DONE WITH KING INFINITY CM2
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 24 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 150100464A32374D4202A92AC462A2EB
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM72J
[eMMC] : FLASH_CID : 150100464A32374D4202A92AC462A2EB
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xB9E2EB77EBD7A0D3DB76F10C3BCF8A52
INT RAM : 0x00020000
EXT RAM : 0x30000000 [768 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:31
ShahiD
The Following 3 Users Say Thank You to A.G.Shahid For This Useful Post:
Old 11-21-2017, 13:00   #46387 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Smile Qmobile i7i hang on logo done with king infinity cm2
QMOBILE I7I HANG ON LOGO DONE WITH KING INFINITY CM2
Chinese Miracle II [SPD module] v 1.27
Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0]
3. Insert cable
Phone found! [ 14 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Done!
Elapsed: 00:00:33
ShahiD
Old 11-21-2017, 13:04   #46388 (permalink)
Nadeem Waris's Avatar
Member: 1080718
Sonork: 100.1596539 QQ-2710826805
Thanks Meter: 2,123
Wait for phone...
Phone found! [ 16 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x93
eMMC Flash : 520001154D423145B51E0742E32AA8C8
[eMMC] : FLASH_INF : [SAMSUNG] , BMB1E
[eMMC] : FLASH_CID : 150100524531424D42071EB5C8A873E3
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0x0386520D10DC2B92D4CE128647F7E452
EXT RAM : 0xC0000000 [3 GiB]
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:11
Old 11-21-2017, 13:05   #46389 (permalink)
Member: 1080718
Thanks Meter: 2,123
Wait for phone...
Phone found! [ 27 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 5200011541423133B83D06425B1C71A8
[eMMC] : FLASH_INF : [SAMSUNG] , BAB13
[eMMC] : FLASH_CID : 150100523331424142063DB8A871A35B
DEV RID : 0x0386520D8DB244CBBED99D5A824EDA16
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:11
Old 11-21-2017, 13:05   #46390 (permalink)
Member: 1080718
Thanks Meter: 2,123
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 90014A4834473261110101B6A5054225
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , a2G4
[eMMC] : FLASH_CID : 90014A4834473261110101B6A5054225
DEV RID : 0x0386520DA83B47E866DF1D183DC5B2DF
EXT RAM : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC
Setting : Flash Pre-Erase : Off ( Write Flash Only )
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Skip checking by User request!
BL : BatteryLevel : 4073 mV
BL : BatteryLevel Ok
SecCfg Passed , 1799
BMT remark not need. Will skip
Preloader Download skipped by user request!
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:03:05
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:40
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:56
Old 11-21-2017, 13:06   #46391 (permalink)
Member: 1080718
Thanks Meter: 2,123
Wait for phone...
Phone found! [ 199 ]
Sync...
Boot Info :
BB_CPU_ID : 6260
BB_CPU_HW : CB00
BB_CPU_SW : 0000
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6260_S0000
BB_CPU_SN : 5A57D9178047E7378E4E53D576187AEE
BROM Status : 0000
Comm Status : 0000
EXBL Status : Alive [ USB Load Active ]
Switch to BL done
BL Version : 01
Setting...
Setting done , result code 0x8000
BROM stage done
DA_eMP_NkP.fg
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW
[0] : FLASH_DIE : 00EF 0060 0018 0000
[0] : FLASH_LEN : 0x01000000
Executing FFS FORMAT now...
FAT_RANGE : 0x00C80000-0x00FF3FFF , LEN : 0x00374000
DA_RET : DA_IN_PROGRESS
DA_RET : FORMAT_DONE
Done!
Elapsed: 00:00:51
Old 11-21-2017, 13:06   #46392 (permalink)
Member: 1080718
Thanks Meter: 2,123
3. Insert cable
Phone found! [ 41 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Done!
Elapsed: 00:00:40
Old 11-21-2017, 13:06   #46393 (permalink)
Member: 1080718
Thanks Meter: 2,123
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC773x Android 5.x eMMC v1.0 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
- > Wait phone connected ...
Phone found! [ 18 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Name : 4531
Model Brand : TELENOR
Model Device: 4531
AndrVersion : 5.1
BaseBand CPU: 4531
Project Ver : 4531_TELENOR_SMART_MAX_V1.0.5_2016_06_15
Model Ext : Smart MAX
[Read Mode] : HSUSB : 0x3000
[FW_READER] : Reading Firmware Now ...
[Read Ok] : u-boot-spl-16k.bin
[Read Ok] : u-boot.bin
[Read Ok] : prodnv.img
[Read Ok] : sc7731g_CP0_modem.bin
[Read Ok] : DSP_DM_Gx.bin
[Read Ok] : nvitem_w.bin
[Read Ok] : sc8830g_modem_CP2_WCN_14D_W15.31.1_Release.bin
[Read Ok] : nvitem_wcn.bin
[Read Ok] : logo_480x854.bin
[Read Ok] : fblogo_720x1280.bin
[Read Ok] : boot.img
[Read Ok] : system.img
[Build Ok] : cache.img
[Read Ok] : recovery.img
[Build Ok] : userdata.img
AndroidInfo created
Firmware Size : 1574 MiB
Saved to : C:\Users\WARIS COM\Desktop\4531_4531_5.1_4531_TELENOR_SMART_MAX_V 1.0.5_2016_06_15_Smart_MAX\
Done!
Elapsed: 00:06:33
Old 11-21-2017, 13:07   #46394 (permalink)
Member: 1080718
Thanks Meter: 2,123
Phone found! [ 18 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Done!
Elapsed: 00:00:18
Old 11-22-2017, 04:20   #46395 (permalink)
ORITECH's Avatar
Member: 2462860
Thanks Meter: 61
xiomi mi6 sagit
success remoove mi account
and enable to login with new account
on miui 9 !!!
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.15
Operation : Reset Settings [ v1.15 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Error : Fail to init protocol!
Check cable, connection and drivers!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 835 [MSM8998]
ID_BLOCK_S : AC1AB561
ID_BLOCK_I : 0005E0E1
ID_BLOCK_L : 0D171F8FEA033B70AD7559A9EA12C6F8
ID_BLOCK_L : EE73384B4E2A6D375C8299BF39BC9817
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8996 , FLASH : UFS , mVER : 1
ExtInfo : 0x0001C000/0001C000/00001000/00001000/00001000
UFS Device : SAMSUNG KLUDG8V1EE-B0C1 0400
UFS SectSize : 0x1000
--------------UFS Device Info--------------
UFS Total Active LU: 0x6
UFS wManufacturerID: 0x1ce
UFS Boot Partition Enabled: 0x1
UFS LU Write Protect: 0x0
UFS Boot LUN ID: = 0x0
UFS Memory Type: 0x0
UFS LU Total Blocks: 0x0
UFS Supported Memory Types: 0x800f
UFS LUN Enable Bitmask: 0x3f
UFS bConfigDescrLock: 0x0
Boot Ok!
MIAccount reset passed!
Complete reset :
> If device lock after WiFi - use RESET MI APP
> PowerOn device, NOT power WiFi, SIM and etc. Make device setup
> Reset MI APP. Device will not have MIServices anymore
Done!
Elapsed: 00:00:16
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.75030 seconds with 9 queries
