Old 11-28-2017, 05:39   #46561 (permalink)
Nadeem Waris's Avatar
Member: 1080718
Sonork: 100.1596539 QQ-2710826805
Thanks Meter: 2,051
Card found: S/N : 7BD0661F , v0136
Chinese Miracle II [SPD module] v 1.27
Set mode to : SP [SC773x] eMMC [Android 6.x]
Start at : [11/27/2017 / 4:32:37 PM]
Operation : Read FullFlash [ v1.27 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 15 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Detected eMMC Flash , Structure detect Ok!
[FW_READER] : Prepare Ok!
- > Wait phone connected ...
Phone found! [ 15 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Phone found! [ 15 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Name : i7i_PRO
Model Brand : QMobile
Model Device: i7i_PRO
AndrVersion : 6.0
BaseBand CPU: SP7731CEA
Project Ver : QMobile i7i PRO_MP_05_09
Model Ext : QMobile i7i PRO
[Read Mode] : HSUSB : 0x3000
[FW_READER] : Reading Firmware Now ...
[Read Ok] : u-boot-spl-16k.bin
[Read Ok] : u-boot.bin
[Read Ok] : prodnv.img
[Read Ok] : sc7731C_CP0_modem.bin
[Read Ok] : DSP_DM_Gx.bin
[Read Ok] : nvitem_w.bin
[Read Ok] : sc8830g_modem_CP2_WCN_Trunk_W16.23.4_Release.bin
[Read Ok] : nvitem_wcn.bin
[Read Ok] : logo_480x854.bin
[Read Ok] : fblogo_480x854.bin
[Read Ok] : boot.img
[Read Ok] : system.img
[Read Ok] : sysinfo.img
[Build Ok] : cache.img
[Read Ok] : recovery.img
[Build Ok] : userdata.img
AndroidInfo created
Firmware Size : 2636 MiB
Saved to : C:\Users\WARIS COM\Desktop\SP7731CEA_i7i_PRO_6.0_QMobile_i7i_PRO_ MP_05_09_QMobile_i7i_PRO\
Done!
Elapsed: 00:11:53
Reconnect Power/Cable!
Old 11-28-2017, 05:39   #46562 (permalink)
Member: 1080718
Thanks Meter: 2,051
Qmobile i7i pro flash done with cm2
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : SC77xx Infinity Package
3. Insert cable
Phone found! [ 15 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x19 records
PMTManager : PMT Update Ok!
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write FSImage : prodnv.img
Write Data ...
Write Data Ok!
Write CodeData : sc7731C_CP0_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Write CodeData : sc8830g_modem_CP2_WCN_Trunk_W16.23.4_Release.bin
Write Data ...
Write Data Ok!
Write CodeData : logo_480x854.bin
Write Data ...
Write Data Ok!
Write CodeData : fblogo_480x854.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system.img
Write Data ...
Write Data Ok!
Erase Block : PERSIST
Erase block ...
Block erase Ok!
Write CodeData : sysinfo.img
Write Data ...
Write Data Ok!
Write FSImage : cache.img
Write Data ...
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Erase Block : MISC
Erase block ...
Block erase Ok!
Write FSImage : userdata.img
Write Data ...
Write Data Ok!
Elapsed: 00:07:31
Old 11-28-2017, 05:42   #46563 (permalink)
Member: 1080718
Thanks Meter: 2,051
Phone found on COM5
Phone In Download mode...
Reset FRP Procedure started...
Port open Ok!
LOKE received!
Prepare Ok!
Enter Setup...
Try download PIT...
Download PIT Ok!
Reset FRP done
Reboot phone...
Phone Disconnected
Old 11-28-2017, 05:48   #46564 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,125
Qmobile S250 MT6261 Logo Stuck Recover Done Only Formate With Infinity CM2
Card found : S/N : A19EC787 , v0136
Operation : Format FileSystem [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 77 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : B6403190F2CA9017373DCFE01CDD3770
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09
[0] : FLASH_DIE : 00C2 0020 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Backup done
Executing FFS FORMAT now...
FAT_RANGE : 0x003B3000-0x003FDFFF , LEN : 0x0004B000
DA_RET : DA_IN_PROGRESS
DA_RET : FORMAT_DONE
Done!
Elapsed: 00:00:06
Old 11-28-2017, 07:30   #46565 (permalink)
srworld's Avatar
Member: 207734
Sonork: 100.1612198
Thanks Meter: 109
samsung A9 pro reset success
Port open Ok!
LOKE received!
Prepare Ok!
Enter Setup...
Try download PIT...
Download PIT Ok!
Reset FRP done
Reboot phone...
Phone Disconnected
Phone found on COM527
Read Info...
Read Info - ok
Connect ADB - Ok
Model - SM-A910F
Product - a9xproltedx
CPU - MSM8976
Phone version - A910FXXU1AQE2
Android version - 6.0.1
CSC country code - India
CSC sales code -
Phone serial No - RZ8H903V4BL
Phone SIM Slot count - 2
Phone IMEI - Not readed
Phone not Rooted
Phone Disconnected
Old 11-28-2017, 09:30   #46566 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 14,723
Smile Qmobile S100 Format Done
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
Phone found! [ 39 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00EF 0040 0016 0000
[0] Flash VEN : Winbond , W25Q32
[0] Flash CAP : 00400000
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:10
Old 11-28-2017, 09:31   #46567 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Samsung I9060I Flashing Done
Phone found on COM24 nications Port/CO
Port open Ok!
LOKE received!
Prepare Ok!
Enter Setup...
Setup Done!
Try download PIT...
Download PIT Ok!
Start flashing!
Flashing boot.img
Flashing recovery.img
Flashing system.img
Flashing SPRDCP.img
Flashing SPRDDSP.img
Flashing cache.img
Flashing hidden.img
Flashing done
Reboot phone...
Phone Disconnected
Old 11-28-2017, 10:00   #46568 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,125
Wiko s5201ap MT6572 Hanging Probelm Fix Only Formta With Infinty CM2
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A483447326111013EE7CDB2A275
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , a2G4
[eMMC] : FLASH_CID : 90014A483447326111013EE7CDB2A275
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xD9C8F3955CC696380D7E03C4619CD306
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:39
Old 11-28-2017, 11:55   #46569 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,125
Qmobile Golden SPD6531 Logo Stuck Recover Fix Only Formate With Infinity CM2
Card found: S/N : A19EC787 , v0136
Set mode to : SPD6531
3. Insert battery
Phone found! [ 109 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
[0] Flash DIE : 00C8 0060 0016 0000
[0] Flash VEN : GigaDevice , GD25LQ32
Format Block Done!
Done!
Elapsed: 00:00:07
Old 11-28-2017, 14:28   #46570 (permalink)
Member: 1639426
Sonork: khurram136
Thanks Meter: 71
I life tablet imei repair but after some time imei null again.
Card found: S/N : D44A8988 , v0135
Chinese Miracle II [SPD module] v 1.24
Operation : Repair Security [ v1.24 ]
3. Insert cable
Device boot not done
Check Drivers
Try again
Elapsed: 00:00:39
3. Insert cable
Phone found! [ 105 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC773x Android 5.x eMMC v1.0 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Write new security data :
IMEI1 : 358039062778408
IMEI2 : 358039063078402
Step #1 Ok
Step #2 Ok
Write done!
Elapsed: 00:00:36
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
IMEI1 : 358039063434340
IMEI2 : 358039063074443
Step #1 Ok
Step #2 Ok
Write done!
Elapsed: 00:00:27
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Step #1 Ok
Step #2 Ok
Write done!
Elapsed: 00:00:22
please help
Old 11-28-2017, 15:03   #46571 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 923
Smile Qmobile x4 pro read password done with king infinity cm2
QMOBILE X4 PRO READ PASSWORD DONE WITH KING INFINITY CM2
Operation : Read UserCode [ v1.58 ]
Wait for phone...
Phone found! [ 21 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_SN : DEDEFD7069F6B3A4DB70F32BBAD7C98D
Setting...
BROM stage done
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV
[0] : FLASH_DIE : 00EF 0070 0016 0000
Read ExtData
Sorting ExtData
Reading UserCode
Active : Yes , Code : 2569
MobileTracker : 0000 , Privacy Lock : 2569
Done!
Elapsed: 00:00:09
If You Like My Post Press Thanks
ShahiD
Old 11-28-2017, 15:07   #46572 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 923
Smile Haier g30 hang on logo done with king infinity cm2
HAIER G30 HANG ON LOGO DONE WITH KING INFINITY CM2
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 45010053454D3034473AF00339455291
[eMMC] : FLASH_VEN : 0x45 , OEM : 0100
[eMMC] : FLASH_INF : [SANDISK] , G40ME
[eMMC] : FLASH_CID : 45010053454D3034473AF00339455291
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000EC000000
[eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB]
DEV RID : 0x0B9C44DE75DA1DF100BBD7A27F826AF6
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : Haier
ProdName : G30
ProdModel : G30
Device : G30
AndroidVer: 4.4.2
MTKxCPU : MT6572
MTKxPRJ : G30-H01-S023-PK
MODEM :
BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V62_P6_1_wg_n
EXTRA :
LCD [0] : ili9806e_fwvga_dsi_vdo_zgd
LCD [1] : ili9806e_fwvga_dsi_vdo_huashi
LCD Res : 854x480
TOUCH [0] : ft6306_yuye
TOUCH [1] : GT9XX_hotknot
CAM [0] : gc2145_mipi_yuv_m11
CAM [1] : hi541_mipi_yuv_m11
CAM [2] : ov5645_mipi_yuv_m11 sp2529_mipi_yuv_m11
CAM [3] : s5k4ecgx_mipi_yuv
CAM [4] : #s5k8aayx_yuv
MODEM : huiyue72_w_kk_hspa_m11_b1b8_pk
LOCALE : en_US ur_PK fa_IR
Done!
Elapsed: 00:00:16
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:30
ShahiD
Old 11-28-2017, 15:09   #46573 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 923
Smile Qmobile x700 pro clear frp done with king infinity cm2
QMOBILE X700 PRO CLEAR FRP DONE WITH KING INFINITY CM2
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
eMMC Flash : 150100513832334D4200281DC87A8373
[eMMC] : FLASH_INF : [SAMSUNG] , BM328
[eMMC] : FLASH_CID : 150100513832334D4200281DC87A8373
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0x0B9C44DEC47E1EFB7E1E444DC8E68BC0
EXT RAM : 0x80000000 [2 GiB]
SOC VERIFY : C1
Boot Ok!
Brand : QMobile
ProdName : X700_PRO
ProdModel : QMobile X700 PRO
Device : X700_PRO
AndroidVer: 6.0
MTKxCPU : MT6580
MTKxPRJ : alps-mp-m0.mp1-V2.34_rgk6580.we.m
MODEM :
BaseBand : MT6580_S00_D5170_M1_QMOBILE_G4_W5_MP_V0_0_2_S16051 8_1_wg_n
EXTRA :
LCD : Not info available
LCD Res : 854x480
TOUCH [0] : GT1XX
CAM [0] : gc5005_mipi_raw
CAM [1] : gc2365_mipi_raw
CAM [2] : hi553_mipi_raw
CAM [3] : sp2509_mipi_raw
CAM [4] : hi545_2lane_mipi_raw
CAM [5] : sub_hi553_mipi_raw
MODEM : d5170_qmobile_g4_w5_hspa
LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES
Done!
Elapsed: 00:00:12
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:12
ShahiD
Old 11-28-2017, 15:12   #46574 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 923
Smile Qmobile s3 hang on logo done with king infinity cm2
QMOBILE S3 HANG ON LOGO DONE WITH KING INFINITY CM2
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A4841473265050748A1C92F7289
[eMMC] : FLASH_INF : [HYNIX] , e2GA
[eMMC] : FLASH_CID : 90014A4841473265050748A1C92F7289
[eMMC] : FLASH_LEN : 0x00000003AB800000
[eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB]
DEV RID : 0x0B9C44DE91EF3182F0C3EBF6EAFC24CC
SOC VERIFY : C1
Boot Ok!
Brand : QMobile
ProdName : QMobile_S3
ProdModel : QMobile S3
Device : QMobile_S3
AndroidVer: 5.1
MTKxCPU : MT6580
MTKxPRJ : ALPS.L1.MP6.V2_RGK6580.WE.L_P2
MODEM :
BaseBand : MT6580_S00_D5192_G4_W5_MP_V0_0_6_S150912_1_wg_n
EXTRA :
LCD Res : 1280x720
TOUCH [0] : GT1XX
CAM [0] : ov5648_mipi_raw
CAM [1] : sub_ov5648_mipi_raw
CAM [2] : hi545_2lane_mipi_raw
CAM [3] : sub_hi545_2lane_mipi_raw
CAM [4] : ov8858_mipi_raw
CAM [5] : #gc2755_mipi_raw
CAM [6] : gc0310_mipi_yuv imx179_mipi_raw ov8865_mipi_2lane_raw
MODEM : d5192_g4_w5_hspa
Done!
Elapsed: 00:00:18
Wait for phone...
Phone found! [ 38 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:53
ShahiD
Old 11-28-2017, 15:13   #46575 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 923
Smile Qmobile x2 hang on logo done with king infinity cm2
QMOBILE X2 HANG ON LOGO DONE WITH KING INFINITY CM2
Wait for phone...
Phone found! [ 40 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6571
BB_CPU_NME : [MediaTek] MT6571_S00
BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x8B
NAND Flash : 009800BC009000660076001600080000
eMMC Flash : NOT INSTALLED
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1
[NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008
[NAND] : FLASH_LEN : 0x20000000
[NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1
DEV RID : 0x0B9C44DEBB0999DE6763A32FA9B713CB
EXT RAM : 0x10000000 [256 MiB]
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Brand : QMobile
ProdName : s3510ap
ProdModel : QMobile X2
Device : s3510ap
AndroidVer: 4.4.2
MTKxCPU : MT6571
MTKxPRJ : ALPS.KK1.MP7.V1
Done!
Elapsed: 00:00:10
Wait for phone...
Phone found! [ 40 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6571
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:14
ShahiD
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-29-2010 21:17
Page generated in 0.85728 seconds with 9 queries
