Old 12-03-2017, 06:19   #46696 (permalink)
Nadeem Waris's Avatar
Member: 1080718
Sonork: 100.1596539 QQ-2710826805
Thanks Meter: 2,091
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 16 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 11010030303447393051624EADD551F9
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x11 , OEM : 0100
[eMMC] : FLASH_INF : [TOSHIBA] , 09G40
[eMMC] : FLASH_CID : 11010030303447393051624EADD551F9
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000
[eMMC] : FLASH_LEN : 0x00000000EC000000
[eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB]
DEV RID : 0x0386520DE64405EE2B8EBB400561A07B
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : s5501 , Storage : EMMC
Setting : Flash Pre-Erase : Off ( Write Flash Only )
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Skip checking by User request!
BL : BatteryLevel : 4029 mV
BL : BatteryLevel Ok
SecCfg Passed , 1799
BMT remark not need. Will skip
Preloader Download skipped by user request!
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:03:35
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:57
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:04:44
Reconnect Power/Cable!
Old 12-03-2017, 06:21   #46697 (permalink)
Member: 1080718
Thanks Meter: 2,091
SM S/N: 7BD0661F Version: 0100
Phone found on COM8 ,d
Phone In Download mode...
Reset FRP Procedure started...
Port open Ok!
LOKE received!
Prepare Ok!
Enter Setup...
Try download PIT...
Download PIT Ok!
Reset FRP done
Reboot phone...
Phone Disconnected
Old 12-03-2017, 07:43   #46698 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,129
Samsung Org G532F Logo Stuck Fix Only Flashing With Infinity CM2
Phone found on COM78
Port open Ok!
LOKE received!
Prepare Ok!
Enter Setup...
Setup Done!
Try download PIT...
Download PIT Ok!
Start flashing!
Flashing preloader.img
Flashing lk.bin
Flashing param.bin
Flashing trustzone.bin
Flashing efuse.img
Flashing boot.img
Flashing recovery.img
Flashing system.img
Flashing secro.img
Flashing userdata.img
Flashing md1dsp.img
Flashing md1rom.img
Flashing cache.img
Flashing hidden.img
Flashing done
Reboot phone...
Phone Disconnected
Old 12-03-2017, 08:45   #46699 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,129
China Vinlo P8 SPD6531 Logo Stuck Recover Fix Only Formate With Infinity CM2
Card found: S/N : A19EC787 , v0136
Chinese Miracle II [SPD module] v 1.27
Set mode to : SPD6531
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
==== Wait for phone...
Phone found! [ 109 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00EF 0060 0017 0000
[0] Flash VEN : Winbond , W25Q64
[0] Flash CAP : 00800000
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:41
Old 12-03-2017, 08:47   #46700 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,129
Qmobile I5 MT6580 Full Momery Fix Done Only Formate With Infinity CM2
Card found : S/N : A19EC787 , v0136
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 11010030303447393051D054138C51FB
[eMMC] : FLASH_CID : 11010030303447393051D054138C51FB
DEV RID : 0xD9C8F395BAE8476EEDD1A8164F265DD9
EXT RAM : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:23
Old 12-03-2017, 08:49   #46701 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 3,985
QMobile M95 write factory firmware Done :)
Set mode to : SP [SC773x] eMMC [Generic]
Operation : FlashIC ReadOnly/BadBlock Test [ v1.25 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
Device boot not done
Check Drivers
Try again
3. Insert cable
Phone found! [ 5 ]
Open Port Failed!
3. Insert cable
Phone found! [ 5 ]
Port Opened
Sync...
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v3 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
Prepare test data ...
Test flow #0 ...
Test flow passed!
Test flow #1 ...
Test flow passed!
Test flow #2 ...
Test flow passed!
Test flow #3 ...
Test flow passed!
Test flow #4 ...
Test flow passed!
Test flow #5 ...
Test flow passed!
Finalize Ok!
Test passed successfully!
Elapsed: 00:00:19
Operation : Check/Read Info [ v1.25 ]
3. Insert cable
Phone found! [ 5 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name  : scx35_sp7731geaplus_dt
Model Brand : QMobile
Model Device: scx35_sp7731gea
AndrVersion : 4.4.3
BaseBand CPU: SP7731GEA
CompileDate : 7/31/2015 12:00:38 PM
Project Ver : KOT49H 14B_test-keys
Model Ext   : QMobile M95
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:21
Loading    : M95 v1 by Nasir Mobiles.pac
CRVersion  : BP_R1.0.0
PacCPUinfo : SC77xx
PacVersion : M95 v1 by Nasir Mobiles
FastCheck  : 0x00537684CD
Loading files ...
File : Infinity_fdl1.bin
File : Infinity_fdl2.bin
File : nvitem_w.bin
File : nvitem_wcn.bin
File : prodnv.img
File : u-boot-spl-16k.bin
File : sc7731g_CP0_modem.bin
File : DSP_DM_Gx.bin
File : sc8830g_modem_CP2_WCN_14D_W15.16_Release.bin
File : logo_540x960.bin
File : fblogo_540x960.bin
File : boot.img
File : system.img
File : cache.img
File : recovery.img
File : userdata.img
File : u-boot.bin
File : SC77xx.xml
Load Ok!
Operation : Flash [ v1.25 ]
======= Flash
Files set for flashing :
[ MCU ] : M95 v1 by Nasir Mobiles.pac
PacCPUinfo : SC77xx
File : nvitem_w.bin
File : prodnv.img
File : boot.img
File : system.img
File : cache.img
File : recovery.img
File : userdata.img
File : u-boot.bin
3. Insert cable
Phone found! [ 5 ]
Port Opened
Sync...
Sync...
Sending FDL
PickUp loaders from pac
FDL Ready!
Boot Ver : Spreadtrum Boot Block version 1.1
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
[FL] : Enabled NVM update. Will program all NVM images found in FW !
PMTManager : Load 0x17 records
PMTManager : PMT Update Ok!
Flashing now
[FlashProc] : NVM Update
Current ID   : NV_W
Current Part : wfixnv1
[FlashProc] : Ok!
Current ID   : NV_WCN
Current Part : wcnfixnv1
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : PRODNV
Current File : prodnv.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : BOOTCODE
Current ID   : SPLLOADER
Current File : u-boot-spl-16k.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_W
Current File : sc7731g_CP0_modem.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : DSP_W
Current File : DSP_DM_Gx.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_WCN
Current File : sc8830g_modem_CP2_WCN_14D_W15.16_Release.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOTLOGO
Current File : logo_540x960.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : FASTBOOT_LOGO
Current File : fblogo_540x960.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOT
Current File : boot.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : SYSTEM
Current File : system.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : CACHE
Current File : cache.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : RECOVERY
Current File : recovery.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : USERDATA
Current File : userdata.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : ERASEUBOOT
Current Part : uboot
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : FLASH
Current Part : wruntimenv1
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : FLASH_WCN
Current Part : wcnruntimenv1
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : ERASEMISC
Current Part : misc
[FlashProc] : Ok!
Current ID   : UBOOTLOADER
Current File : u-boot.bin
Flashing now ...
[FlashProc] : Ok!
Elapsed: 00:03:56
Old 12-03-2017, 09:15   #46702 (permalink)
Member: 654997
Thanks Meter: 3,985
Samsung G532F Remove FRP Lock Done :)
Phone found on COM46    	A
Read Info...
Read Info - ok
Connect ADB - Ok
Model - SM-G532F
Product - grandpplteser
CPU - MT6737T
Phone version - G532FXWU1APJ1
Android version - 6.0.1
CSC country code - KSA
CSC sales  code -
Phone serial No - R58J31BC15P
Phone SIM Slot count - 2
Phone IMEI -  Not readed
Phone not Rooted
Connect ADB - Ok
Reset FRP/ REACTIVATION LOCK - Done
Reboot Phone...
Phone Disconnected
SM-V 1.08
Old 12-03-2017, 09:32   #46703 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,129
Qmobile Power8 SPD6531 Logo Stck Recover Done Only Formate With Infinity CM2
3. Insert battery
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
[0] Flash DIE : 00C8 0060 0016 0000
[0] Flash VEN : GigaDevice , GD25LQ32
[0] Flash CAP : 00400000
Format Block Done!
Done!
Elapsed: 00:00:12
Old 12-03-2017, 10:50   #46704 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,129
Rivo Rx58 MT6580 FRP Reset Done With King Infinity CM2
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
eMMC Flash : 110100303034474530012509D8B213F5
[eMMC] : FLASH_INF : [TOSHIBA] , 0EG40
[eMMC] : FLASH_CID : 110100303034474530012509D8B213F5
DEV RID : 0xD9C8F395638A16336E9BCE6E4B175E79
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:12
Old 12-03-2017, 10:56   #46705 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,129
Qmobile H67 SPD6531 Logo Stuck Recover Only Formate With Infinity CM2
3. Insert battery
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Format Block Done!
Done!
Elapsed: 00:00:10
Old 12-03-2017, 11:57   #46706 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,129
Lenovo A7600 MT6572 FRP Reset Done With Great King Infinity CM2
Wait for phone...
Phone found! [ 8 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6752
BB_CPU_NME : [MediaTek] MT6732|MT6752_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x8F
eMMC Flash : 150100523758314D42094814FA213241
[eMMC] : FLASH_INF : [SAMSUNG] , BM1X7
[eMMC] : FLASH_CID : 150100523758314D42094814FA213241
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xD9C8F3959DD75A4D05203FE0B4699758
EXT RAM : 0x80000000 [2 GiB]
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:39
Old 12-03-2017, 13:36   #46707 (permalink)
bright hlatini's Avatar
Member: 1614640
Thanks Meter: 462
ALCATE OT 5045X FRP UNLOCK DONE
Card found : S/N : XXXXXXX , v0135
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x93
eMMC Flash : 504E01FE35394A31A61B124B995A6A59
[eMMC] : FLASH_VEN : 0xFE , OEM : 014E
[eMMC] : FLASH_INF : [MICRON] , K59J1
[eMMC] : FLASH_CID : FE014E50314A39354B121BA6596A5399
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000001D3000000
[eMMC] : FLASH_UCP : 7472 MiB [eMMC 8 GiB]
DEV RID : 0xD2FF4FA47CFEA845F8B7EBB95B76DD65
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : TCL
ProdName : 5045X
ProdModel : 5045X
Device : PIXI4_5_4G
AndroidVer: 6.0
MTKxCPU : MT6735
MTKxPRJ : alps-mp-m0.mp1-V2.39.1_jhz6735m.35u.m_P54
SECURITY :
IMEI_OTP [1] : 35XXXXXXXXXXXX
MODEM :
BaseBand : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V79_P21_1_lwg _n
EXTRA :
LCD : Not info available
LCD Res : 854x480
TOUCH [0] : GT1XX
CAM [0] : ov5670_mipi_raw
CAM [1] : ov5670af_mipi_raw
CAM [2] : s5k5e8yx_mipi_raw
CAM [3] : s5k5e8yxff_mipi_raw
CAM [4] : ov2680_mipi_raw
CAM [5] : gc2355_mipi_raw
CAM [6] : gc0310_mipi_yuv
CAM [7] : sp2508_mipi_raw
CAM [8] : sp2509_mipi_raw
MODEM : jhz6735_65t_m_lttg_dsds jhz6735_65t_m_lwg_dsds
LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES
Done!
Elapsed: 00:00:10
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:13
The Following User Says Thank You to bright hlatini For This Useful Post:
Old 12-03-2017, 14:34   #46708 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,129
Qmobile Z12 MT6735 FRP Reset Done With Infinity CM2
Wait for phone...
Phone found! [ 289 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 520001154D42313213A106421331C5DC
[eMMC] : FLASH_INF : [SAMSUNG] , BMB12
[eMMC] : FLASH_CID : 150100523231424D4206A113DCC51313
[eMMC] : FLASH_LEN : 0x0000000747C00000
[eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB]
DEV RID : 0xD9C8F395F9B13C1440C5A7C999EE0F02
EXT RAM : 0xC0000000 [3 GiB]
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:47
Old 12-03-2017, 14:40   #46709 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,129
Qmobile S2 MT6580 FRP Reset Done With King Infinity CM2
Wait for phone...
Phone found! [ 92 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A48384731650507CAA118D49267
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A48384731650507CAA118D49267
DEV RID : 0xD9C8F395E29FE7E8232643B37F529674
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:46
Old 12-03-2017, 15:10   #46710 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,129
Qmobile Super Phone SP100 MT6261 Read Code Done With King Infinity CM2
Operation : Read UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 169 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 2E5667BE766FE27D72488A5AEBD56B8C
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV
[0] : FLASH_DIE : 00EF 0070 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Read ExtData
Sorting ExtData
Reading UserCode
Active : Yes , Code : 2946
PLock|MobTrack : Not active
Done!
Elapsed: 00:00:04
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-29-2010 21:17
Page generated in 0.87872 seconds with 9 queries
