12-30-2017, 16:58 | #47251 (permalink) |
No Life Poster Join Date: Aug 2009 Location: madhya pradesh
Member: 1091455 Status: Offline Sonork: qq 2250871952 Thanks Meter: 769 | moto e3 power 1cklick frp done cm2 Start at : [12/30/2017 / 9:20:50 PM] Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 21 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D333145FD270742BB8E396A Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D420727FD6A39A3BB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x289AD737DDAF1D8E1A5EE648FB96338B INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
The Following User Says Thank You to wasim786mansure For This Useful Post: |
12-30-2017, 19:06 | #47252 (permalink) |
No Life Poster Join Date: Apr 2008 Location: nigeria
Member: 757064 Status: Offline Sonork: 11111111 Thanks Meter: 365 | fero A5002 frp successfull remove . ==== Wait for phone... Phone found! [ 154 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : A5002 Model Brand : fero Model Device: A5002 AndrVersion : 6.0 BaseBand CPU: SP7731CEA CompileDate : 3/7/2017 1:59:35 AM Project Ver : FSA5002v0010_2017-02-27 Model Ext : A5002 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:31 Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 154 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000001396F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:41 Reconnect Power/Cable! |
The Following User Says Thank You to skyulock For This Useful Post: |
12-30-2017, 20:56 | #47253 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | TECNO M3 PRIVACY LOCK RESET DONE Card found : S/N : A6XXXXX5 , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 7001004D4D43303447582C687845918D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D43303447582C687845918D [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB [eMMC 4 GiB] DEV RID : 0xDEC55C3757F8EFEDD3065350A0086DB9 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : TECNO ProdName : TECNO-M3 ProdModel : TECNO-M3 Device : g130_base AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : M3-G130-H1BOM-20141021 SECURITY : IMEI_SW [1] : 353879068811520 IMEI_SW [2] : 353879068811538 BTMAC Addr : 30AABDF995F7 WiFi MAC : 30AABDF8F827 EXTRA : LCD [0] : g130 LCD Res : 480 #800x320 #480 TOUCH [0] : g130 TOUCH [1] : GT9XX_hotknot CAM [0] : ov5645_mipi_yuv CAM [1] : gc0328_yuv CAM [2] : hm5065_yuv CAM [3] : gc0308_yuv MODEM : G130_2100_MODEM LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB sw_TZ am_ET om_ET ti_ET Done! Elapsed: 00:00:12 Reconnect Power/Cable! Operation : Reset Privacy Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 7001004D4D43303447582C687845918D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D43303447582C687845918D [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB [eMMC 4 GiB] DEV RID : 0xDEC55C3757F8EFEDD3065350A0086DB9 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Process block #1 Process block #2 Privacy Lock reset Ok! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
12-30-2017, 23:59 | #47254 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | frp zte A610 done Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 18 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 440001453130344614890136C3441289 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , 6104F [eMMC] : FLASH_CID : 450100444634303136018914891283C3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0x09ADE14136C42FC1501E3523ADA1A084 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
The Following User Says Thank You to chipscell25 For This Useful Post: |
12-31-2017, 06:35 | #47255 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile M350 MT6580 FRP Reset Done With King Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100463732324D4200F999EC13A3C5 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D4200F999EC13A3C5 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F39502A2ADF94F75F6FFEAF3B5B8 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:40 Reconnect Power/Cable! |
The Following User Says Thank You to azhergoga007 For This Useful Post: |
12-31-2017, 06:59 | #47256 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Qmobile Noir X35 Format Done Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 32 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 45010053454D3034473A039AAA0312B9 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , G40ME [eMMC] : FLASH_CID : 45010053454D3034473A039AAA0312B9 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0xE6C52A7DEF07C0E6061A044598F0C6AB INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post: |
12-31-2017, 07:01 | #47257 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Lenovo P1ma40 MT6735 FRP Reset Done With King Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D33323833EB0042418516DE Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM328 [eMMC] : FLASH_CID : 150100513832334D4200EB33DE16A241 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD9C8F3950497436C59D9AD6A54684F49 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:50 Reconnect Power/Cable! |
12-31-2017, 07:06 | #47258 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Qmobile X32 V3 Format Done Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Android 6.x] Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 11 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000012ABF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:37 Reconnect Power/Cable! |
12-31-2017, 08:05 | #47259 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Samsung Org E310B SPD6530 Read Code Done With King Infinity CM2 Card found: S/N : A19EC787 , v0136 Chinese Miracle II [SPD module] v 1.27 Set mode to : SPD6530_SPD6500 Operation : Read User Code [ v1.27 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 90 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6530 , FDLStat : 00C0 [0] Flash DIE : 00C8 0060 0017 0000 [0] Flash VEN : GigaDevice , GD25LQ64 [0] Flash CAP : 00800000 Check data... Can take some time User Code : 78660 Done! Elapsed: 00:00:09 Reconnect Power/Cable! |
12-31-2017, 08:18 | #47260 (permalink) |
No Life Poster Join Date: Nov 2016 Location: GUJARAT
Member: 2643730 Status: Offline Thanks Meter: 1,115 | intex aqua 4.5e baseband unknown done by cm2 Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 70 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : NOT INSTALLED eMMC Flash : 70010053313030303408123CC49C4339 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 40001 [eMMC] : FLASH_CID : 70010053313030303408123CC49C4339 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E4000000 [eMMC] : FLASH_UCP : 3648 MiB [eMMC 4 GiB] DEV RID : 0x10681B2810B6E2B2396509A7DC5480C2 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6571 , Project : vsun71_e_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : Unknown (not supported or without battery) BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001400000-0x0000000000100000 Erase : 0x0000000003100000-0x000000009EA60000 Flash Pre-Erase Done, time used : 00:00:01 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_vsun71_e_kk.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:27 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:03 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:01 Reconnect Power/Cable! |
The Following User Says Thank You to djj007 For This Useful Post: |
12-31-2017, 08:35 | #47261 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Qmobile X700 Pro Format Done Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 32 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 13014E52314A39364E1054CFC0EE223D [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x13 , OEM : 014E [eMMC] : FLASH_INF : [NOT_IN_BASE] , N69J1 [eMMC] : FLASH_CID : 13014E52314A39364E1054CFC0EE223D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0xE6C52A7D0EE251EF474DAAC279FC476D INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:10 Reconnect Power/Cable! |
12-31-2017, 09:16 | #47262 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile LT15 MT6582 Logo Stuck Fix Only Userdata Or Cash With Infinity CM2 Card found : S/N : A19EC787 , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847316505070DA1011F6205 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A483847316505070DA1011F6205 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F3956135D0DB180332B6E1A7C8CD INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear RDP Clear Ok! Done! Elapsed: 00:00:11 Reconnect Power/Cable! |
12-31-2017, 09:27 | #47263 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | doogee x30 mt 6580 frp off Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 77 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100514531334D4207609F6A09B3C3 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x80000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D4207609F6A09B3C3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x354F6386F3C4E7C02EEF403AF511F1AF INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : DOOGEE ProdName : X30 ProdModel : X30 Device : X30 AndroidVer: 7.0 MTKxCPU : MT6580 MTKxPRJ : DOOGEE-X30-Android7.0-20170717 SECURITY : IMEI_SW [1] : 351545090004390 IMEI_SW [2] : 351545090004408 BTMAC Addr : 96B1466580CB WiFi MAC : 000000000000 Done! Elapsed: 00:00:20 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 77 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100514531334D4207609F6A09B3C3 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x80000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D4207609F6A09B3C3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x354F6386F3C4E7C02EEF403AF511F1AF INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
The Following User Says Thank You to genci titi 2002 For This Useful Post: |
12-31-2017, 10:28 | #47264 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile I5 MT6580 Full Momery Fix Done Only Formate With Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 11010030303447393051D7D6304B514D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 11010030303447393051D7D6304B514D [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F3951EFAE33CFB645BCF9E8AE7F6 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:31 Reconnect Power/Cable! |
12-31-2017, 11:41 | #47265 (permalink) |
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | vfd500 frp off Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 3000011137473830C1AF0030F7ADB58E Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 07G80 [eMMC] : FLASH_CID : 11010030303847373000AFC18EB543F7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x354F6386044B1C5DCB58F559DE6E1F09 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Vodafone ProdName : Smart_turbo7 ProdModel : VFD 500 Device : VFD500 AndroidVer: 6.0 MTKxCPU : MT6735 MTKxPRJ : alps-mp-m0.mp1-V2.39.1_jhz6735m.35u.vf.m_P92 SECURITY : IMEI_OTP [1] : 357911070610131 MODEM : BaseBand : MT6735_1_lwg_n EXTRA : LCD : Not info available LCD Res : 854x480 TOUCH [0] : GT1XX CAM [0] : ov5670_mipi_raw CAM [1] : s5k5e8yxff_mipi_raw CAM [2] : gc2355_mipi_raw CAM [3] : sp2508_mipi_raw MODEM : jhz6735m_35u_vf_m jhz6735_65t_vf_m_lttg_dsds jhz6735_65t_vf_m_lwg_dsds LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 3000011137473830C1AF0030F7ADB58E Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 07G80 [eMMC] : FLASH_CID : 11010030303847373000AFC18EB543F7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x354F6386044B1C5DCB58F559DE6E1F09 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:39 Reconnect Power/Cable! |
