01-06-2018, 07:49 | #47356 (permalink) |
Freak Poster Join Date: Dec 2015 Location: MansehrA KPK (Pakistan) Age: 29
Member: 2505147 Status: Offline Sonork: [email protected] Thanks Meter: 183 | QMobile_I8i _6.0 reset frp done Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 42 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000133CF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:45 Reconnect Power/Cable! |
01-06-2018, 07:52 | #47357 (permalink) |
Member: 2505147 Status: Offline Sonork: [email protected] Thanks Meter: 183 | oppo a33 msm8916 AndroidVer: 5.1.1 reset frp done Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 1CB3508E ID_BLOCK_I : 007050E1 ID_BLOCK_L : 1BED877FDE44717C2B00F0DD1A61F1D9 ID_BLOCK_L : 6EE5AB02F79EC04578B718D1D3D2CC0F Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to awanbrother For This Useful Post: |
01-06-2018, 07:53 | #47358 (permalink) |
Member: 2505147 Status: Offline Sonork: [email protected] Thanks Meter: 183 | q mobile s2 still on logo recover done by great cm2 operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473165050796A1810892F7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A4838473165050796A1810892F7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xB5C479DF0E24597182C3ED21702F34A9 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6580 , Project : s5250 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3735 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001C80000-0x0000000003320000 Erase : 0x00000000050A0000-0x00000001CBEE0000 Flash Pre-Erase Done, time used : 00:00:03 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s5250.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0014 Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:04:25 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : SECRO Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:00:12 Update RomInfo done Done! Elapsed: 00:05:16 Reconnect Power/Cable! |
The Following User Says Thank You to awanbrother For This Useful Post: |
01-06-2018, 07:54 | #47359 (permalink) |
Member: 2505147 Status: Offline Sonork: [email protected] Thanks Meter: 183 | q mobile s2 reset frp done Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473165050796A1810892F7 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A4838473165050796A1810892F7 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xB5C479DF0E24597182C3ED21702F34A9 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
01-06-2018, 07:55 | #47360 (permalink) |
Member: 2505147 Status: Offline Sonork: [email protected] Thanks Meter: 183 | LG-H810_msm8992 read fimware and reset frp done Operation : Read Firmware [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x01 Boot done! DevInfo : MSM8992__LG-H810__H81021z__V21z__AOSv6.0__LGH810AT-00-V21z-ATT-US-JUL-15-2016-ARB03+0 Reading Flash Content ... [Read Ok] : gpt_main.bin [Read Ok] : NON-HLOS.bin [Read Ok] : pmic.bin [Read Ok] : sbl1.mbn [Read Ok] : tz.mbn [Read Ok] : deploy.mbn [Read Ok] : hyp.mbn [Read Ok] : rpm.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : misc.img [Read Ok] : persist.img [Read Ok] : fs_gc.img [Read Ok] : ddr.bin [Read Ok] : sec.dat [Read Ok] : laf.img [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : persist_lg.img [Read Ok] : calibration.img [Read Ok] : rawdata.img [Read Ok] : fact.img [Read Ok] : system.img [Read Ok] : gpt_backup.bin Android Info saved! Read finished! Configuration : MSM8992 / 6.0 / V21z Firmware Size : 4767 MiB Done! Elapsed: 00:04:49 Operation : Reset Settings/Format FS [ v1.03 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x01 Boot done! Format UserData Format Cache Format done Erase FRP#1 block Ok! Reconnect Power/Cable! Done! Elapsed: 00:00:14 |
The Following 3 Users Say Thank You to awanbrother For This Useful Post: |
01-06-2018, 07:56 | #47361 (permalink) |
Member: 2505147 Status: Offline Sonork: [email protected] Thanks Meter: 183 | samsung j500f reset frp done Phone found on COM13 Phone In Download mode... Phone Disconnected Phone found on COM20 Phone In Download mode... Reset FRP Procedure started... Port open Ok! LOKE received! Prepare Ok! Enter Setup... Try download PIT... Download PIT Ok! Reset FRP done Reboot phone... Phone Disconnected Phone found on COM25 Phone In Download mode... Connect ADB - Ok Model - SM-J500F Product - j5ltexx CPU - MSM8916 Phone version - J500FXXU1APB4 Android version - 5.1.1 CSC country code - UAE CSC sales code - XSG Phone serial No - RV8H11HQRSE Phone SIM Slot count - 2 Phone IMEI - Not readed Phone not Rooted |
01-06-2018, 07:58 | #47362 (permalink) |
Member: 2505147 Status: Offline Sonork: [email protected] Thanks Meter: 183 | q mobile i6 metal hd reset screen lock done Brand : QMobile ProdName : i6_Metal_HD ProdModel : i6 Metal HD Device : i6_Metal_HD AndroidVer: 6.0 MTKxCPU : MT6580 MTKxPRJ : ALPS.W10.24.p0 Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100463832324D42005DCDD833732F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM228 [eMMC] : FLASH_CID : 150100463832324D42005DCDD833732F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xB5C479DF07391C16DAF8559D71B61B33 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! LSSDB Ok! LSSWL Ok! LSSSH Ok! LSSNG Ok! LSSNP Ok! Security Settings : Clear Ok! [Info] : That feature NOT RESET "PRIVACY PASSWORD LOCK"! Use separate button! [Info] : That feature NOT RESET "FRP/GoogleLOCK"! Use separate "FRP" reset! [Info] : If phone stuck on "Logo" : 1. Wait 2-3 minutes. Power Off phone by long press "Power" button 2. Power On phone again 3. Or wait up to 3-7 minutes, until phone start by itself 4. Also recommended reboot phone twice before start use it Done! Elapsed: 00:00:20 Reconnect Power/Cable |
01-06-2018, 08:00 | #47363 (permalink) |
Member: 2505147 Status: Offline Sonork: [email protected] Thanks Meter: 183 | kechaoda k116 read code done Operation : Read UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 12 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 4D828021A288220F5D562ACDFD6CB6CE BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV [0] : FLASH_DIE : 00EF 0070 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 1236 PLock|MobTrack : Not active Done! Elapsed: 00:00:18 Reconnect Power/Cable! |
01-06-2018, 08:01 | #47364 (permalink) |
Member: 2505147 Status: Offline Sonork: [email protected] Thanks Meter: 183 | q mobile update to 5.0.2 done by great cm2 Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : QMobile Z8 Device Manufact.: QMobile Z8 Device Model : l5510 Device CPU : MSM8916 Device IntName : QMobile Z8 Device Version : 5.0.2 CU_SWVer : QMobile Z8 Device Compile : 8/25/2015 1:46:27 AM Device ExtInfo : QMobile Z8 Load Ok! Operation : Flash [ v1.16 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0B9BF383 ID_BLOCK_L : 00E09A64D35F44472015FFE02F7AFAD2 ID_BLOCK_L : 760DB31A1F8628BD509FF0293BCAE4E7 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Flash Chain : 33 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : hyp.mbn Flashing : hyp.mbn Flashing : misc.img Flashing : splash.img Flashing : sec.dat Flashing : boot.img Flashing : system.img Flashing : persist.img Flashing : cache.img Flashing : recovery.img Flashing : oem.img Flashing : userdata.img Flashing : gpt_backup0.bin Wipe data ... BootConfig set to 0x00 Flashing done! Done! Elapsed: 00:06:06 Reconnect Power/Cable! |
01-06-2018, 08:03 | #47365 (permalink) |
Member: 2505147 Status: Offline Sonork: [email protected] Thanks Meter: 183 | Nokia E7-00 flashing dony by infinty best --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 0D00020EF2DC03443E58E860C3928A020B14F779 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00680020 Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : 8EABFDA6B8A757034233978C16A93B892CE2D4FA ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 357909044301852 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\357909044301852_CR T.rpl === SW Version Check === - > REFLASHING === SW Version Check === ===Flashing [MCU]=== Erase : Processing RM-626_111.040.1511_79u_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:09 Write : Processing RM-626_111.040.1511_79u_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [SOS+DECOMP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS+IVE3A] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 517 blocks TIME : Write time : 00:00:21 MCU Write done ADL: Request programm status NAND status : 0000000B / 0000000B / 00000000 ===Flashing [PPM]=== Erase : Processing RM-626_111.040.1511_28.01_MEA_A_ArabicQwerty_79u_prd. rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM-626_111.040.1511_28.01_MEA_A_ArabicQwerty_79u_prd. rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 195 blocks TIME : Write time : 00:00:08 PPM Write done ADL: Request programm status NAND status : 0000000B / 0000000B / 00000000 ===Flashing [APE]=== Erase : Processing RM626_APE_ONLY_ENO_11w36_v0.037.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing RM626_APE_ONLY_ENO_11w36_v0.037.fpsx CMT: Writing Hash CERT [SOS*ENO] Total writen 20 blocks TIME : Write time : 00:00:00 APE Write done ADL: Request programm status NAND status : 0000000B / 0000000B / 00000000 ADL: Close_Session Content: 0003000000000B0000000B00000000 ADL: Reboot Flashing done! Total flash time : 00:00:40 Reboot phone now... Reading Phone Info.... Connected phone - Nokia E7-00 Software Info: V 79_sr1_12w18.5 27-07-12 RM-626 (c) Nokia IMEI: 357909044301852 Ape Version: 111.040.1511 Product code: 059C9G6 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Battery voltage is enough for start Set phone to Normal mode... AfterFlash operations done ;D Done! Elapsed: 00:02:01 Connect phone on selected interface... |
01-06-2018, 08:38 | #47366 (permalink) |
Member: 2505147 Status: Offline Sonork: [email protected] Thanks Meter: 183 | q mobilei5i still on logo recoverd done by great cm2 Scatter Load Ok , BaseBand : MT6582 , Project : s4300ap , Storage : EMMC Files found : 13 , Set to Flash : 12 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040501A183B8814F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040501A183B8814F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0xD1BDA592F10F6D026BF33F5B08F53556 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : s4300ap , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3962 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E5E00000 Flash Pre-Erase Done, time used : 00:00:05 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_s4300ap.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0014 Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash now : FAT Image Flash Ok Flash Write Done, time used : 00:03:18 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : EBR2 Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Verify Passed : FAT Data Verify Done, time used : 00:00:53 Update RomInfo done Done! Elapsed: 00:04:42 Reconnect Power/Cable! |
01-06-2018, 08:46 | #47367 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile A300 MT6572 Dead Set Recover DOne By Flashing With Infinity CM2 Card found : S/N : A19EC787 , v0136 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6572 , Project : s7810bp , Storage : EMMC Files found : 11 , Set to Flash : 10 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : QMobile Device Model : QMobile A300 Device CPU : MT6572 Device IntName : A300 Device Version : 4.2.2 Device Compile : 12/12/2013 6:05:11 AM Device Project : ALPS.JB3.MP.V1.P65 Device ExtInfo : QMobile A300 Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:29 Reconnect Power/Cable! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164048601A3AA802111 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A3AA802111 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F395CC5DDF9272907A737F22A13C INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : s7810bp , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3857 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000600000-0x0000000000100000 Erase : 0x0000000002300000-0x00000000E3E00000 Flash Pre-Erase Done, time used : 00:00:04 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0013 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:03:13 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:04 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:37 Reconnect Power/Cable! |
The Following User Says Thank You to azhergoga007 For This Useful Post: |
01-06-2018, 08:52 | #47368 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | OALE X2 read factory firmware/reset user code Done :) Code: Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 26 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48384731650507000D3556B2F1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A48384731650507000D3556B2F1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x2BFA537D58CE716E2DC23928F3A51429 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : alps ProdName : full_gxq6580_weg_l ProdModel : gxq6580_weg_l Device : gxq6580_weg_l AndroidVer: 5.1 MTKxCPU : MT6580 MTKxPRJ : ALPS.L1.MP6.V2_GXQ6580.WEG.L_P69 Done! Elapsed: 00:00:10 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 26 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48384731650507000D3556B2F1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A48384731650507000D3556B2F1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x2BFA537D58CE716E2DC23928F3A51429 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : alps ProdName : full_gxq6580_weg_l ProdModel : gxq6580_weg_l Device : gxq6580_weg_l AndroidVer: 5.1 MTKxCPU : MT6580 MTKxPRJ : ALPS.L1.MP6.V2_GXQ6580.WEG.L_P69 [Read Ok] : preloader_gxq6580_weg_l.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6580 / V1.1.2 / gxq6580_weg_l / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 1432 MiB Scatter saved to : F:\backup files\MT6580__alps__gxq6580_weg_l__gxq6580_weg_l__5.1__ALPS.L1.MP6.V2_GXQ6580.WEG.L_P69\ All done! Done! Elapsed: 00:06:48 Reconnect Power/Cable! Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 26 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48384731650507000D3556B2F1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A48384731650507000D3556B2F1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x2BFA537D58CE716E2DC23928F3A51429 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! LSSDB Ok! LSSWL Ok! LSSSH Ok! LSSKY Ok! LSSGS Ok! Security Settings : Clear Ok! [Info] : That feature NOT RESET "PRIVACY PASSWORD LOCK"! Use separate button! [Info] : That feature NOT RESET "FRP/GoogleLOCK"! Use separate "FRP" reset! [Info] : If phone stuck on "Logo" : 1. Wait 2-3 minutes. Power Off phone by long press "Power" button 2. Power On phone again 3. Or wait up to 3-7 minutes, until phone start by itself 4. Also recommended reboot phone twice before start use it Done! Elapsed: 00:00:22 Reconnect Power/Cable! Code: Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : alps Device Model : gxq6580_weg_l Device CPU : MT6580 Device IntName : full_gxq6580_weg_l Device Version : 5.1 Device Compile : 7/19/2017 5:16:38 AM Device Project : ALPS.L1.MP6.V2_GXQ6580.WEG.L_P69 Device ExtInfo : gxq6580_weg_l |
The Following User Says Thank You to syed tuqeer For This Useful Post: |
01-06-2018, 09:52 | #47369 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 34 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A0190653247414034070599649199 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A48414732650507344099915399 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0x354F6386F712464EFB18968494C087FC INT RAM : 0x00020000 EXT RAM : 0xC0000000 [3 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! LSSDB Ok! LSSWL Ok! LSSSH Ok! LSSNG Ok! LSSNP Ok! Security Settings : Clear Ok! |
The Following User Says Thank You to genci titi 2002 For This Useful Post: |
01-06-2018, 10:52 | #47370 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Balkan Age: 50
Member: 1473716 Status: Offline Thanks Meter: 1,273 | Wiko Sunny frp reset done Card found : S/N : 07XXXXXX , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 97 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9C NAND Flash : NOT INSTALLED eMMC Flash : 70010056313030303850156D3B87438D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 80001 [eMMC] : FLASH_CID : 70010056313030303850156D3B87438D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001C3000000 [eMMC] : FLASH_UCP : 7216 MiB [eMMC 8 GiB] DEV RID : 0x7FBB5333CA6E556B5E4B0D9469290018 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:16 Reconnect Power/Cable! --------------------------------------------- Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 97 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9C NAND Flash : NOT INSTALLED eMMC Flash : 70010056313030303850156D3B87438D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 80001 [eMMC] : FLASH_CID : 70010056313030303850156D3B87438D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001C3000000 [eMMC] : FLASH_UCP : 7216 MiB [eMMC 8 GiB] DEV RID : 0x7FBB5333CA6E556B5E4B0D9469290018 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:35 Reconnect Power/Cable! |
The Following User Says Thank You to gile@gile For This Useful Post: |
