03-19-2018, 12:04 | #48631 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Voice V20 MT6572 Hanging Probelam Fix Only Formate With Infinity CM2 Card found : S/N : A19EC787 , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 169 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164048601A22DDA90E7 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x20000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A22DDA90E7 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F3956F9DA1896A56B53B628A45D4 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:28 Reconnect Power/Cable! |
03-19-2018, 12:17 | #48632 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile LT700 PRO MT6735 FRP Reset Done With Infinity CM2 Card found : S/N : A19EC787 , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 520001154D423145A0780742FF9146F2 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB1E [eMMC] : FLASH_CID : 150100524531424D420778A0F24693FF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD9C8F395DD2DF3D758F41E262AD8371A INT RAM : 0x00020000 EXT RAM : 0xC0000000 [3 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:38 Reconnect Power/Cable! |
03-19-2018, 13:38 | #48633 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Balkan Age: 50
Member: 1473716 Status: Offline Thanks Meter: 1,273 | KAZAM Trooper2_45 User Lock Reset done KAZAM Trooper2_45 User Lock Reset done Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 97 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.2017-06-20.16:16 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 110100303034473930519007B44C518F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 110100303034473930519007B44C518F [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0x7FBB5333C5ECFA791D975FA0FD0A02E4 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : KAZAM ProdName : Trooper2_45 ProdModel : Trooper2 45 Device : Trooper2_45 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.6 Done! Elapsed: 00:00:08 Reconnect Power/Cable! ------------------------------------------- Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 97 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.2017-06-20.16:16 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 110100303034473930519007B44C518F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 110100303034473930519007B44C518F [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0x7FBB5333C5ECFA791D975FA0FD0A02E4 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! LSSKY Ok! LSSDB Ok! LSSWL Ok! LSSSH Ok! LSSGS Ok! Security Settings : Clear Ok! [Info] : That feature NOT RESET "PRIVACY PASSWORD LOCK"! Use separate button! [Info] : That feature NOT RESET "FRP/GoogleLOCK"! Use separate "FRP" reset! [Info] : If phone stuck on "Logo" : 1. Wait 2-3 minutes. Power Off phone by long press "Power" button 2. Power On phone again 3. Or wait up to 3-7 minutes, until phone start by itself 4. Also recommended reboot phone twice before start use it Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
03-19-2018, 14:34 | #48634 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile X700 Pro II MT6580 FRP Reset Done With King Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 289 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A484147346132A416306C8CB383 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4GA [eMMC] : FLASH_CID : 90014A484147346132A416306C8CB383 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0xD9C8F3958E6ADC4FE74F64579AD7D3C0 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:10 Reconnect Power/Cable! |
03-19-2018, 16:01 | #48635 (permalink) |
No Life Poster Join Date: Mar 2014 Location: India
Member: 2156086 Status: Offline Sonork: 4562 Thanks Meter: 210 | Intex aqua young flashing done Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : Intex_Aqua_Young_V07_Indian_SER_20160128.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC77xx PacVersion : Intex_Aqua_Young_V07_Indian_SER_20160128 File : fdl1.bin File : fdl2.bin File : nvitem.bin File : nvitem_wcn.bin File : u-boot-spl-16k.bin File : SC7702_sc7731g_band128.bin File : DSP_DM_G2.bin File : SC8800G_x30g_wcn_dts_modem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : LOGO.bmp File : LOGO.bmp File : prodnv.img File : cache.img File : u-boot.bin 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 29 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! [FL] : Enabled NVM update. Will program all NVM images found in FW ! PMTManager : Load 0x17 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : NVM Update Current ID : NV_W Current Part : wfixnv1 [FlashProc] : Ok! [FlashProc] : NVM Update Current ID : NV_WCN Current Part : wcnfixnv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W Current File : SC7702_sc7731g_band128.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_W Current File : DSP_DM_G2.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_WCN Current File : SC8800G_x30g_wcn_dts_modem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : USERDATA Current File : userdata.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOTLOGO Current File : LOGO.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : FASTBOOT_LOGO Current File : LOGO.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH Current Part : wruntimenv1 [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH_WCN Current Part : wcnruntimenv1 [FlashProc] : Ok! [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : CACHE Current File : cache.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEMISC Current Part : misc [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : UBOOTLOADER Current File : u-boot.bin Flashing now ... [FlashProc] : Ok! Elapsed: 00:02:45 Reconnect Power/Cable! |
The Following User Says Thank You to jjamshad5 For This Useful Post: |
03-19-2018, 16:12 | #48636 (permalink) |
Freak Poster Join Date: Jan 2017
Member: 2671513 Status: Offline Thanks Meter: 121 | ENERGIZER ENERGY S600 : read info full + reda flash + read nvram ok Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D333238333B00420138E090 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM328 [eMMC] : FLASH_CID : 150100513832334D42003B3390E0A301 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x0D434F4DFCC976DD7B5F7901BFC10617 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Energizer ProdName : ENERGY_S600 ProdModel : ENERGY S600 Device : ENERGY_S600 AndroidVer: 6.0 MTKxCPU : MT6737M MTKxPRJ : alps-mp-m0.mp1-V2.84_wtk6737m.65.m0 SECURITY : IMEI_SW [1] : 35519808xxxxxxx IMEI_SW [2] : 35519808xxxxxxx BTMAC Addr : ACE6Bxxxxxxx WiFi MAC : BCE6Cxxxxxxx MODEM : BaseBand : MT6735_S00_X6069_TRX_37_LWG_V0_1_1_S161610241020_1 _lwg_n EXTRA : LCD : Not info available LCD Res : 1280x720 TOUCH [0] : GT1XX CAM [0] : sp2509_mipi_raw CAM [1] : gc5005_mipi_raw CAM [2] : gc2375_mipi_raw CAM [3] : gc8024_mipi_raw CAM [4] : gc5024_mipi_raw MODEM : x6069_trx_37_lwg_dsds LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:11 Reconnect Power/Cable! ******************************************* Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D333238333B00420138E090 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM328 [eMMC] : FLASH_CID : 150100513832334D42003B3390E0A301 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x0D434F4DFCC976DD7B5F7901BFC10617 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : Energizer ProdName : ENERGY_S600 ProdModel : ENERGY S600 Device : ENERGY_S600 AndroidVer: 6.0 MTKxCPU : MT6737M MTKxPRJ : alps-mp-m0.mp1-V2.84_wtk6737m.65.m0 [Read Ok] : preloader_x6069_trx_l601_ddm_37m65.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6737M / V1.1.2 / x6069_trx_l601_ddm_37m65 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 2629 MiB Scatter saved to : P:\cm2 dump\energizer\MT6737M__Energizer__ENERGY_S600__EN ERGY_S600__6.0__alps-mp-m0.mp1-V2.84_wtk6737m.65.m0\ All done! Done! Elapsed: 00:08:35 Reconnect Power/Cable! ******************************************* Operation : Read NVRAM [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D333238333B00420138E090 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM328 [eMMC] : FLASH_CID : 150100513832334D42003B3390E0A301 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x0D434F4DFCC976DD7B5F7901BFC10617 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [Info] : BaseBand : MT6735_S00_X6069_TRX_37_LWG_V0_1_1_S161610241020_1 _lwg_n NVM Read Ok, MT6735_S00_X6069_TRX_37_LWG_V0_1_1_S161610241020_1 _lwg_n_eMMC.spnv Done! Elapsed: 00:00:38 Reconnect Power/Cable! ************************************************* |
03-19-2018, 16:38 | #48637 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile X32 MT6580 FRP Reset Done With Great Infinity CM2 Card found : S/N : A19EC787 , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847316505072BA3F04E33AB Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A483847316505072BA3F04E33AB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F3953E8BDCDD0A3A81DB656BC711 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:37 Reconnect Power/Cable! |
03-19-2018, 19:07 | #48639 (permalink) |
No Life Poster Join Date: Jul 2014 Location: EARTH
Member: 2221849 Status: Offline Sonork: offline Thanks Meter: 279 | NOKIA 6 FRP REMOVE DONE Code: Operation : Reset Settings [ v1.15 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 430 [MSM8937] ID_BLOCK_S : 4FCBCD18 ID_BLOCK_I : 0004F0E1 ID_BLOCK_L : 9492474B55D3EF7831EE6761F7F62BE9 ID_BLOCK_L : DDE7800408ED3746A427F72EBB51A08F Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RX1BMB Boot Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:15 Reconnect Power/Cable! |
03-19-2018, 19:10 | #48641 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | ITEL IT1508 FORMAT DONE Card found: S/N : A6XXXXX5 , v0136 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP [SC773x] eMMC [Android 6.x] Operation : Check/Read Info [ v1.27 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 17 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : itel_it1508C Model Brand : Itel Model Device: itel_it1508C AndrVersion : 5.1 CompileDate : 11/3/2016 11:18:07 AM Project Ver : LMY47D release-keys Model Ext : itel it1508 ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:25 Reconnect Power/Cable! Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 17 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v2.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x00000001569F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
03-19-2018, 22:09 | #48642 (permalink) |
Member: 2671513 Status: Offline Thanks Meter: 121 | SUPERTAB K7 KIDS KRC1022 : read info + read flash + flash ok Infinity-Box RockChip Service Tool [RKT] v2.01 Operation : Identify [ v2.01 ] ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Interface test : Passed Device mode : Normal [ LOADER OPEN ] Machine : RK312X Device : SUPERTABK7 ExtInfo : 6.0.0 SoC CPU : 312A SoC PDT : 2014 SoC SWN : 0730 SoC REV : V100 Flash CSx : 0x00 Flash Type : ADDE14AB42 [ NAND ] Flash Vend : HYNIX Flash Size : 0x0000000210000000 ( 8,25 GiB ) Flash Info : 4194304/16384/32/40/1 Connect Ok! Brand : SuperTab ProdName : esp8089 ProdModel : SuperTabK7 Device : esp8089 AndroidVer: 6.0.1 Manufact. : SuperTab SysPatch : MXC89K RKTxCPU : RK312X Done! Elapsed: 00:00:08 ************************************************** ***** Operation : Read Firmware [ v2.01 ] ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Interface test : Passed Device mode : Normal [ LOADER OPEN ] Machine : RK312X Device : SUPERTABK7 ExtInfo : 6.0.0 SoC CPU : 312A SoC PDT : 2014 SoC SWN : 0730 SoC REV : V100 Flash CSx : 0x00 Flash Type : ADDE14AB42 [ NAND ] Flash Vend : HYNIX Flash Size : 0x0000000210000000 ( 8,25 GiB ) Flash Info : 4194304/16384/32/40/1 Connect Ok! Brand : SuperTab ProdName : esp8089 ProdModel : SuperTabK7 Device : esp8089 AndroidVer: 6.0.1 Manufact. : SuperTab SysPatch : MXC89K RKTxCPU : RK312X DevInfo : RK312X__SuperTab__SuperTab__ANDR_v6.0.1__SuperTabK 7__esp8089__esp8089 Reading Flash Content ... [Read Ok] : param.cfg [Read Ok] : u-boot.img [Read Ok] : misc.img [Read Ok] : resource.raw [Read Ok] : kernel.img [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : backup.img [Read Ok] : system.img [Read Ok] : fota_upd.img [Read Ok] : userdata) Android Info saved! Read finished! Configuration : RK312X / ADDE14AB42 [ NAND ] Firmware Size : 2768 MiB Done! Elapsed: 00:11:49 **************************************** Loading firmware ... Detected RockChip Infinity package Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : SuperTab Device Manufact.: SuperTab Device Model : esp8089 Device CPU : RK312X Device IntName : esp8089 Device Version : 6.0.1 CU_SWVer : SuperTab Device Compile : 22/05/2017 08:26:59 Device ExtInfo : SuperTabK7 Load Ok! Operation : Write Firmware [ v2.01 ] ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Interface test : Passed Device mode : Normal [ LOADER OPEN ] Machine : RK312X Device : SUPERTABK7 ExtInfo : 6.0.0 SoC CPU : 312A SoC PDT : 2014 SoC SWN : 0730 SoC REV : V100 Flash CSx : 0x00 Flash Type : ADDE14AB42 [ NAND ] Flash Vend : HYNIX Flash Size : 0x0000000210000000 ( 8,25 GiB ) Flash Info : 4194304/16384/32/40/1 Connect Ok! Loading firmware Skip IDB processing Initialize PMT ... PMT initialized! Flashing : u-boot.img Flashing : misc.img Flashing : resource.raw Flashing : kernel.img Flashing : boot.img Flashing : recovery.img Flashing : backup.img Flashing : system.img Flashing : fota_upd.img Wiping UserData Wipe DATA Ok! Flashing finished! Done! Elapsed: 00:06:56 ********************************************** |
03-20-2018, 06:16 | #48643 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile 3G5 MT6276 Logo Stuck Fix Only Formate With Infinity CM2 Card found : S/N : A19EC787 , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 161 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6276 BB_CPU_HW : CB00 BB_CPU_SW : 0101 BB_CPU_SB : 8A00 BB_CPU_NM : [MediaTek] MT6276_S0000 BROM Protocol Version : FF Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x80 SOC_VERIFY : 0xC1 BOOT_STYLE : NAND_FLASH_BOOT NAND Flash IC initialized FLASH_VEN : 0x0076 , [MXIC] MX63U1GD12EAXNI00 FLASH_DIE0 : 00C2 00B1 0080 0055 FLASH_DIE1 : 0002 0000 0000 0000 FLASH_LEN : 0x08000000 INT_RAM : 0x00015000 EXT_RAM : 0x04000000 Executing FFS FORMAT now... FAT_RANGE : 0x05000000-0x07EFFFFF , LEN : 0x02F00000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE NAND Status : 5A000000 / 5A000000 / 5A000000 / 5A000000 Done! Elapsed: 00:00:29 Reconnect Power/Cable! |
03-20-2018, 06:25 | #48644 (permalink) |
No Life Poster Join Date: Nov 2016 Location: GUJARAT
Member: 2643730 Status: Offline Thanks Meter: 1,115 | vivo y55l patten lock removed by cm2 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 430 [MSM8937] ID_BLOCK_S : 1290279F ID_BLOCK_L : 88577C9702855A08946414E602398DC6 ID_BLOCK_L : 490E847B897978C9C805FB8423E9DC9E Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HAG4a2 Boot Ok! Format USER ... Format CACHE ... Format Ok! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
03-20-2018, 08:05 | #48645 (permalink) |
Insane Poster Join Date: May 2010 Location: kepri
Member: 1310144 Status: Offline Thanks Meter: 15 | OnePlus A5000 OREO Full Wipe Done Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 835 [MSM8998] ID_BLOCK_S : 5DCCEA98 ID_BLOCK_E : 2A7041DB ID_BLOCK_L : 3F9CA3BB16A80E572E23C4303713F32E ID_BLOCK_L : 5540F762E0E666CF6E527CCED2FE7FF2 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8996 , FLASH : UFS , mVER : 1 ExtInfo : 0x0001C000/0001C000/00001000/00001000/00001000 UFS Device : SAMSUNG KLUDG8V1EE-B0C1 0400 UFS SectSize : 0x1000 UFS Size : 0x0000001DCC000000 : 119,19 GiB --------------UFS Device Info-------------- UFS Total Active LU: 0x6 UFS wManufacturerID: 0x1ce UFS Boot Partition Enabled: 0x1 UFS LU Write Protect: 0x0 UFS Boot LUN ID: = 0x0 UFS Memory Type: 0x0 UFS LU Total Blocks: 0x0 UFS Supported Memory Types: 0x800f UFS LUN Enable Bitmask: 0x3f UFS bConfigDescrLock: 0x0 Boot Ok! Format USER ... Format CACHE ... Format Ok! Remove FRP Reset Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:20 Reconnect Power/Cable! |
