05-19-2018, 00:34 | #49666 (permalink) |
Freak Poster Join Date: Jan 2017
Member: 2671513 Status: Offline Thanks Meter: 121 | QILIVE MY16QF2 ( Q4T10IN mt8127 nand ) : info +read flash + factory reset full ok 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 8127 BB_CPU_NME : [MediaTek] MT8127_S00 BB_CPU_EXT : 0xCA04 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8D NAND Flash : 004500DE009400930076005000080000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0055 , NAND_UNKNOWN [NAND] : FLASH_DIE : 0045 00DE 0094 0093 0076 0050 0008 [NAND] : FLASH_LEN : 0x200000000 [NAND] : FLASH_EXT : 4000/0100/01 DEV RID : 0x0D434F4D4F57157B12B0513C0E3D7DB5 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : QILIVE ProdName : Q4T10IN ProdModel : Q4T10IN Device : Q4T10IN AndroidVer: 4.4.2 MTKxCPU : MT8127 MTKxPRJ : 863728_V3.0_20150801 Done! Elapsed: 00:00:24 Reconnect Power/Cable! ******************************************** Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 8127 BB_CPU_NME : [MediaTek] MT8127_S00 BB_CPU_EXT : 0xCA04 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8D NAND Flash : 004500DE009400930076005000080000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0055 , NAND_UNKNOWN [NAND] : FLASH_DIE : 0045 00DE 0094 0093 0076 0050 0008 [NAND] : FLASH_LEN : 0x200000000 [NAND] : FLASH_EXT : 4000/0100/01 DEV RID : 0x0D434F4D4F57157B12B0513C0E3D7DB5 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... [Read Ok] : preloader_joyasz27_tb_c_mlc_kk.bin [Read Ok] : items.img [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : usrdata.img [ScatCFG] : MT8127 / V1.1.1 / joyasz27_tb_c_mlc_kk / NAND FW Size : 1043 MiB Brand : QILIVE ProdName : Q4T10IN ProdModel : Q4T10IN Device : Q4T10IN AndroidVer: 4.4.2 MTKxCPU : MT8127 MTKxPRJ : 863728_V3.0_20150801 Android Info saved Scatter saved to : M:\cm2 dump\qilive my16qf2\MT8127_NAND_QILIVE__Q4T10IN__Q4T10IN__4.4. 2__863728_V3.0_20150801 Done! Elapsed: 00:36:28 Reconnect Power/Cable! ************************************************** * Operation : Read NVRAM [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 8127 BB_CPU_NME : [MediaTek] MT8127_S00 BB_CPU_EXT : 0xCA04 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8D NAND Flash : 004500DE009400930076005000080000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0055 , NAND_UNKNOWN [NAND] : FLASH_DIE : 0045 00DE 0094 0093 0076 0050 0008 [NAND] : FLASH_LEN : 0x200000000 [NAND] : FLASH_EXT : 4000/0100/01 DEV RID : 0x0D434F4D4F57157B12B0513C0E3D7DB5 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [Info] : NAND , BaseBand Info not available! NVM Read Ok, MT8127_NAND.spnv Done! Elapsed: 00:01:13 Reconnect Power/Cable! ************************************************** Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 8127 BB_CPU_NME : [MediaTek] MT8127_S00 BB_CPU_EXT : 0xCA04 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8D NAND Flash : 004500DE009400930076005000080000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0055 , NAND_UNKNOWN [NAND] : FLASH_DIE : 0045 00DE 0094 0093 0076 0050 0008 [NAND] : FLASH_LEN : 0x200000000 [NAND] : FLASH_EXT : 4000/0100/01 DEV RID : 0x0D434F4D4F57157B12B0513C0E3D7DB5 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... MT81xx/6580 NAND : Pattern Read will take few hours! Stop operation : ForcedBigRead disabled! Done! Elapsed: 00:00:14 Reconnect Power/Cable! *********************************************** Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 8127 BB_CPU_NME : [MediaTek] MT8127_S00 BB_CPU_EXT : 0xCA04 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8D NAND Flash : 004500DE009400930076005000080000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0055 , NAND_UNKNOWN [NAND] : FLASH_DIE : 0045 00DE 0094 0093 0076 0050 0008 [NAND] : FLASH_LEN : 0x200000000 [NAND] : FLASH_EXT : 4000/0100/01 DEV RID : 0x0D434F4D4F57157B12B0513C0E3D7DB5 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! NAND Flash not supported yet! Done! Elapsed: 00:00:09 Reconnect Power/Cable! ************************************************** * Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 8127 BB_CPU_NME : [MediaTek] MT8127_S00 BB_CPU_EXT : 0xCA04 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8D NAND Flash : 004500DE009400930076005000080000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0055 , NAND_UNKNOWN [NAND] : FLASH_DIE : 0045 00DE 0094 0093 0076 0050 0008 [NAND] : FLASH_LEN : 0x200000000 [NAND] : FLASH_EXT : 4000/0100/01 DEV RID : 0x0D434F4D4F57157B12B0513C0E3D7DB5 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:33 Reconnect Power/Cable! ************************************************** * |
05-19-2018, 04:58 | #49667 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile N175 MT6261 Read Code Done By King Infinity CM2 Card found : S/N : A19EC787 , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Read UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 222 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 4D971FE32FEF339255F7198F8D2931EF BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 7862 Privacy Lock :_ Done! Elapsed: 00:00:04 Reconnect Power/Cable! |
05-19-2018, 05:27 | #49668 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile E400 PRo SPD6531 Logo Resetart Recover Done Only Formate With Infinity CM2 Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 268 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:07 Reconnect Power/Cable! |
05-19-2018, 06:41 | #49669 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile I9 MT6582 Hanging Probelam Fix Only Formate With Infinity CM2 Card found : S/N : A19EC787 , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 100 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 110100303034473930515427E4D4C0F3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 110100303034473930515427E4D4C0F3 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F395DE8A747A697C72EA4712A3B9 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : QMobile ProdName : QMobile i9 ProdModel : QMobile i9 Device : QMobile i9 AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.KK1.MP1.V2.10 Done! Elapsed: 00:00:05 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 100 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 110100303034473930515427E4D4C0F3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 110100303034473930515427E4D4C0F3 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0xD9C8F395DE8A747A697C72EA4712A3B9 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:30 Reconnect Power/Cable! |
05-19-2018, 08:30 | #49670 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | OALE X2 MT6580 FRP Reset Done With King Infinity CM2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 289 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : F40122426977696E20103237313664AF [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0xF4 , OEM : 0122 [eMMC] : FLASH_INF : [NOT_IN_BASE] , niwi [eMMC] : FLASH_CID : F40122426977696E20103237313664AF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001CD000000 [eMMC] : FLASH_UCP : 7376 MiB [eMMC 8 GiB] DEV RID : 0xD9C8F3951CBD6B07ABAF2AE1AF8BC2CD INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:35 Reconnect Power/Cable! |
05-19-2018, 08:39 | #49671 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Qmobile l1 format done Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 76 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0040 0016 0000 [0] Flash VEN : Winbond , W25Q32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:08 Reconnect Power/Cable! |
05-19-2018, 09:04 | #49672 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | MI REDMI NOTE 3 FLASH AND RECOVER HANG ON LOGO Done SUCCESSFULLY FLASH AND RECOVER HANG ON LOGO(MI REDMI NOTE3)USB THANKS INFINITY-BOX TEAM |
The Following User Says Thank You to gracy_elec For This Useful Post: |
05-19-2018, 09:23 | #49673 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile S2 Plus MT6580 FRP Reset Done With King Infinity CM2 Card found : S/N : A19EC787 , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 45010044533130313601049E4898C27D Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , 6101S [eMMC] : FLASH_CID : 45010044533130313601049E4898C27D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0xD9C8F395F27E6963EF779846120A916C INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:52 Reconnect Power/Cable! |
05-19-2018, 10:01 | #49674 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | MOTO/LENOVO XT1663 FLASH AND RECOVER HANG ON LOGO Done SUCCESSFULLY FLASH AND RECOVER HANG ON LOGO(MOTO/LENOVO XT1663)USB THANKS INFINITY-BOX TEAM |
05-19-2018, 10:14 | #49675 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | OPPO F3 CPH-1609 PATTERN LOCK REMOVE Done SUCCESSFULLY REMOVE PATTERN LOCK(OPPO F3 CPH-1609)USB THANKS INFINITY-BOX TEAM |
05-19-2018, 10:31 | #49676 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,692 | leagoo p1 android 7 remove frp 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.2017-06-20.16:16 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9C NAND Flash : NOT INSTALLED eMMC Flash : 1501004B3758564D4201272AD41D81D1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D4201272AD41D81D1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x354F6386191AADFF835A0703EF8BD7BD INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : LEAGOO ProdName : t592_otd_p1 ProdModel : P1 Device : t592_otd_p1 AndroidVer: 7.0 MTKxCPU : MT6580 MTKxPRJ : alps-mp-n0.mp2-V1_wtk6580.we.n_P11 SECURITY : IMEI_SW [1] : 351954090038657 IMEI_SW [2] : 351954090038665 BTMAC Addr : CC7314A1F211 WiFi MAC : CC731421C77A Done! Elapsed: 00:00:13 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.2017-06-20.16:16 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9C NAND Flash : NOT INSTALLED eMMC Flash : 1501004B3758564D4201272AD41D81D1 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX7 [eMMC] : FLASH_CID : 1501004B3758564D4201272AD41D81D1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x354F6386191AADFF835A0703EF8BD7BD INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:41 Reconnect Power/Cable! |
05-19-2018, 12:55 | #49677 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dera Ismail Khan (KPK) Pak
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | logicom s732(M711R) RK3066 Great Flashing with Great Cm2 Operation : Write Firmware [ v2.01 ] ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Interface test : Passed Device mode : Normal [ LOADER OPEN ] Machine : RK3066 Device : S732 ExtInfo : 4.2.2 SoC CPU : 302A SoC PDT : 2013 SoC SWN : 0529 SoC REV : V101 Flash CSx : 0x00 Flash Type : 2C44444BA9 [ NAND ] Flash Vend : MICRON Flash Size : 0x000000010A000000 ( 4.16 GiB ) Flash Info : 2097152/8192/32/40/1 Connect Ok! Loading firmware UnionImage container info : File [1] : RK3026Loader(L)_V2.13.bin File [2] : parameter File [3] : Image/misc.img File [4] : Image/kernel.img File [5] : Image/boot.img File [6] : Image/recovery.img File [7] : Image/system.img File [8] : backupimage/backup.img File [9] : update-script File [10] : recover-script Skip IDB processing Initialize PMT ... Flashing : Image/misc.img Flashing : Image/kernel.img Flashing : Image/boot.img Flashing : Image/recovery.img Flashing : backupimage/backup.img Flashing : Image/system.img Flashing finished! Done! Elapsed: 00:02:07 File Link https://www.4shared.com/archive/1Q1qnoPnba/logicom_s732_M711R_.html |
The Following User Says Thank You to rahihimkhan For This Useful Post: |
05-19-2018, 13:00 | #49678 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Operation : Read UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 89 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CA02 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 3641F078F40EFFAC358DA0A9E5F39085 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09 [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS_INFO : 0x003FE000 , 0x00002000 INT_RAM : 0x0000D000 EXT_RAM : 0x00400000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 75321480 Privacy Lock :P Done! Elapsed: 00:00:08 Reconnect Power/Cable! |
05-19-2018, 13:20 | #49679 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | OPPO A37F READ PATTERN LOCK Done SUCCESSFULLY READ PATTERN LOCK(OPPO A37F)USB THANKS INFINITY-BOX TEAM |
05-19-2018, 13:27 | #49680 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | MI REDMI 3S LAND MI ACCOUNT REMOVE Done SUCCESSFULLY REMOVE MI ACCOUNT(MI REDMI 3S LAND)USB THANKS INFINITY-BOX TEAM |
