Old 07-05-2018, 06:07   #50926 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Oppo A37fW FRP Reser Done With King Infinity CM2
Operation : Reset Settings [ v1.14 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 24C0716F
ID_BLOCK_I : 007050E1
ID_BLOCK_L : 748CE610BF2B50530C6193FC3B068EBE
ID_BLOCK_L : 9BEA54F7F86BD350754015C2C02F3902
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:19
Reconnect Power/Cable!
Old 07-05-2018, 06:44   #50927 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Huawei lua u22 reset frp done with king infinity cm2
HUAWEI LUA U22 RESET FRP DONE WITH KING INFINITY CM2
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x01000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 484A0190613447418028D4328D5B6E2D
Initialize Memory ...
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x80000000
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , 2a4GA
[eMMC] : FLASH_CID : 90014A484147346132D428802D6E248D
[eMMC] : FLASH_LEN : 0x00000003AB400000
[eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB]
DEV RID : 0xA9E7A1224F4E7C21D524681477CE65C2
INT RAM : 0x00020000
EXT RAM : 0x80000000 [2 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:17
ShahiD
Old 07-05-2018, 06:45   #50928 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Qmobile l2 reset password done with king infinity cm2
QMOBILE L2 RESET PASSWORD DONE WITH KING INFINITY CM2
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
==== Wait for phone...
Phone found! [ 18 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00C8 0060 0016 0000
[0] Flash VEN : GigaDevice , GD25LQ32
[0] Flash CAP : 00400000
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:22
ShahiD
Old 07-05-2018, 06:46   #50929 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Qmobile s3 hang on logo done with king infinity cm2
QMOBILE S3 HANG ON LOGO DONE WITH KING INFINITY CM2
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
eMMC Flash : 90014A4841473265050748A1C92F7289
[eMMC] : FLASH_INF : [HYNIX] , e2GA
[eMMC] : FLASH_CID : 90014A4841473265050748A1C92F7289
[eMMC] : FLASH_LEN : 0x00000003AB800000
[eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB]
DEV RID : 0x0B9C44DE91EF3182F0C3EBF6EAFC24CC
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:53
ShahiD
Old 07-05-2018, 06:48   #50930 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Qmobile j7 pro reset frp lock done with king infinity cm2
QMOBILE J7 PRO RESET FRP LOCK DONE WITH KING INFINITY CM2
Wait for phone...
Phone found! [ 19 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 520001154D4231581A4D0742AB9D77DA
[eMMC] : FLASH_INF : [SAMSUNG] , BMB1X
[eMMC] : FLASH_CID : 150100525831424D42074D1ADA77B3AB
[eMMC] : FLASH_LEN : 0x0000000747C00000
[eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB]
DEV RID : 0xB9E2EB778953A28844FEEEF38E476E81
EXT RAM : 0xC0000000 [3 GiB]
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:13
ShahiD
Old 07-05-2018, 06:50   #50931 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Oppo a37 reset pin done with king infinity cm2
OPPO A37 RESET PIN DONE WITH KING INFINITY CM2
Operation : Reset Settings [ v1.16 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_S : 2144FD70
ID_BLOCK_L : 758FE511BC2A57520D6292F33C078FBF
ID_BLOCK_L : 1F76D87364EF5FD4E9C489464CA3BD9E
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:25
ShahiD
Old 07-05-2018, 08:21   #50932 (permalink)
gile@gile's Avatar
Member: 1473716
Thanks Meter: 1,273
Alcatel 1016G flash and IMEI Repair done
Card found: S/N : 07XXXXXX , v0137
Chinese Miracle II [SPD module] v 1.27
Set mode to : SPD6531
Operation : Check/Read Info [ v1.27 ]
3. Insert battery
Phone found! [ 70 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
[0] Flash DIE : 00EF 0040 0016 0000
[0] Flash VEN : Winbond , W25Q32
Elapsed: 00:00:07
FastCheck : SPD65xx
Load file...
Not found any ExtInfo data (Compressed already)
Load Ok
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : SPD6531_00400000_W25Q32_SERBIAN ENGLISCH__ALCATEL -1016G-.bin
3. Insert battery
Phone found! [ 70 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
======= Flashing MCU
Mapping file ...
Mapping done
Processing file : SPD6531_00400000_W25Q32_SERBIAN ENGLISCH__ALCATEL -1016G-.bin
Init ok, send data
Flashing Done!
Info : In some cases after flash required make "Format Fs / Reset Phone"
Done!
Elapsed: 00:01:08
Operation : Repair Security [ v1.27 ]
3. Insert battery
Phone found! [ 70 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Process can take some time, please, wait
Init ok, send data
Write done!
Elapsed: 00:00:11
Old 07-05-2018, 08:26   #50933 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
G'FIVE 4 light Read Flash File Done :)
SPRD mode : SC6531 : REV : E000 : NOR
Operation : Identify [ v1.03 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource  :  InternalLibrary
BootVersion : Infinity SCR SC6531E Loader v 1.2
Port speed : 921600
FDL Flash  : Control transfered!
Boot Done!
Done!
Elapsed: 00:00:15
Operation : Read Flash [ v1.03 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ]
Read Ok, 4194304 bytes
Saved to : F:\backup files\SPRD_SPI_GIGADEVICE_GD25Q_4MiB.bin
Done!
Elapsed: 00:00:59
Download flash file from Support site
Operation: Upload
File: F:\backup files\G'five 4 light(SPD 6531E) SPRD_SPI_GIGADEVICE_GD25Q_4MiB.zip
Authentication...
Identification...
7/5/2018: 12:29:47 PM:  Uploading 3,764,113 bytes...
7/5/2018: 12:30:32 PM:  Finished
Old 07-05-2018, 09:06   #50934 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile Z10 Dead Set Re Alive DOne By Flashing With Infinity CM2
Operation : Flash [ v1.14 ]
ForceFlashing : Disabled
Verify FW package ...
Verification passed!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_S : 0BB036A5
ID_BLOCK_L : 22C2B846F17D6A654237D9C60158D8F0
ID_BLOCK_L : 6B1AA407089BC34045B0E5D2D0DFC9F2
Pickup loader from firmware package
MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ]
Boot Ok!
Flash Chain : 175
Flashing now
Flashing : NON-HLOS.bin
Flashing : sbl1.mbn
Flashing : sbl1.mbn
Flashing : emmc_appsboot.mbn
Flashing : rpm.mbn
Flashing : rpm.mbn
Flashing : tz.mbn
Flashing : tz.mbn
Flashing : hyp.mbn
Flashing : hyp.mbn
Flashing : misc.img
Flashing : splash.img
Flashing : chglogo.img
Flashing : sec.dat
Flashing : boot.img
Flashing : system_1.img
Flashing : system_2.img
Flashing : system_3.img
Flashing : system_4.img
Flashing : system_5.img
Flashing : system_6.img
Flashing : system_7.img
Flashing : system_8.img
Flashing : system_9.img
Flashing : system_10.img
Flashing : system_11.img
Flashing : system_12.img
Flashing : system_13.img
Flashing : system_14.img
Flashing : system_15.img
Flashing : system_16.img
Flashing : system_17.img
Flashing : system_18.img
Flashing : system_19.img
Flashing : system_20.img
Flashing : system_21.img
Flashing : system_22.img
Flashing : system_23.img
Flashing : system_24.img
Flashing : system_25.img
Flashing : system_26.img
Flashing : system_27.img
Flashing : system_28.img
Flashing : system_29.img
Flashing : system_30.img
Flashing : system_31.img
Flashing : system_32.img
Flashing : system_33.img
Flashing : persist_1.img
Flashing : cache_1.img
Flashing : cache_2.img
Flashing : cache_3.img
Flashing : cache_4.img
Flashing : cache_5.img
Flashing : recovery.img
Flashing : userdata_1.img
Flashing : userdata_2.img
Flashing : userdata_3.img
Flashing : userdata_4.img
Flashing : userdata_5.img
Flashing : userdata_6.img
Flashing : userdata_7.img
Flashing : userdata_8.img
Flashing : userdata_9.img
Flashing : userdata_10.img
Flashing : userdata_11.img
Flashing : userdata_12.img
Flashing : userdata_13.img
Flashing : userdata_14.img
Flashing : userdata_15.img
Flashing : userdata_16.img
Flashing : userdata_17.img
Flashing : userdata_18.img
Flashing : userdata_19.img
Flashing : userdata_20.img
Flashing : userdata_21.img
Flashing : userdata_22.img
Flashing : userdata_23.img
Flashing : userdata_24.img
Flashing : userdata_25.img
Flashing : userdata_26.img
Flashing : userdata_27.img
Flashing : userdata_28.img
Flashing : userdata_29.img
Flashing : userdata_30.img
Flashing : userdata_31.img
Flashing : userdata_32.img
Flashing : userdata_33.img
Flashing : userdata_34.img
Flashing : userdata_35.img
Flashing : userdata_36.img
Flashing : userdata_37.img
Flashing : userdata_38.img
Flashing : userdata_39.img
Flashing : userdata_40.img
Flashing : userdata_41.img
Flashing : userdata_42.img
Flashing : userdata_43.img
Flashing : userdata_44.img
Flashing : userdata_45.img
Flashing : userdata_46.img
Flashing : userdata_47.img
Flashing : userdata_48.img
Flashing : userdata_49.img
Flashing : userdata_50.img
Flashing : userdata_51.img
Flashing : userdata_52.img
Flashing : userdata_53.img
Flashing : userdata_54.img
Flashing : userdata_55.img
Flashing : userdata_56.img
Flashing : userdata_57.img
Flashing : userdata_58.img
Flashing : userdata_59.img
Flashing : userdata_60.img
Flashing : userdata_61.img
Flashing : userdata_62.img
Flashing : userdata_63.img
Flashing : userdata_64.img
Flashing : userdata_65.img
Flashing : userdata_66.img
Flashing : userdata_67.img
Flashing : userdata_68.img
Flashing : userdata_69.img
Flashing : userdata_70.img
Flashing : userdata_71.img
Flashing : userdata_72.img
Flashing : userdata_73.img
Flashing : userdata_74.img
Flashing : userdata_75.img
Flashing : userdata_76.img
Flashing : userdata_77.img
Flashing : userdata_78.img
Flashing : userdata_79.img
Flashing : userdata_80.img
Flashing : userdata_81.img
Flashing : userdata_82.img
Flashing : userdata_83.img
Flashing : userdata_84.img
Flashing : userdata_85.img
Flashing : userdata_86.img
Flashing : userdata_87.img
Flashing : userdata_88.img
Flashing : userdata_89.img
Flashing : userdata_90.img
Flashing : userdata_91.img
Flashing : userdata_92.img
Flashing : userdata_93.img
Flashing : userdata_94.img
Flashing : userdata_95.img
Flashing : userdata_96.img
Flashing : userdata_97.img
Flashing : userdata_98.img
Flashing : userdata_99.img
Flashing : userdata_100.img
Flashing : userdata_101.img
Flashing : userdata_102.img
Flashing : userdata_103.img
Flashing : userdata_104.img
Flashing : userdata_105.img
Flashing : gpt_main0.bin
Flashing : gpt_backup0.bin
Flash sequence completed!
Applying patches for storage # 0
Records : 26
Patch sequence completed!
BootConfig set to 0x00
Flashing done!
Done!
Elapsed: 00:06:15
Old 07-05-2018, 09:09   #50935 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Lenovo S850 MT6582 Pattren Read Done With King Infinity CM2
Card found : S/N : A19EC787 , v0137
Operation : Read Pattern/DP Lock [ v1.58 ]
Wait for phone...
Phone found! [ 193 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x87
eMMC Flash : 1501004B3858564D4201BF62C6257177
[eMMC] : FLASH_INF : [SAMSUNG] , BMVX8
[eMMC] : FLASH_CID : 1501004B3858564D4201BF62C6257177
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0xD9C8F395B747531B31F4CC8602F47A60
EXT RAM : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
Reading data ...
Get Locks ...
PatternLock Sequnce : 125478
Done!
Elapsed: 00:00:12
Old 07-05-2018, 09:34   #50936 (permalink)
shazzmob's Avatar
Member: 2327602
Sonork: 100.1620953
Thanks Meter: 276
Samsung sm-j120a frp reset in download mode just one click with infinity sm
samsung sm-j120a frp reset in download mode just one click with infinity sm
The Following 4 Users Say Thank You to shazzmob For This Useful Post:
Old 07-05-2018, 10:56   #50937 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
BMM B3 READ PASSWORD & FIRMWARE DONE
SPRD mode : SC6531 : REV : C000 : NOR
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootVersion : Spreadtrum Boot Block version 1.2
Port speed : 921600
Boot Done!
CS0_MEM : SPI : [MACRONIX] : MX25U128 : 0x01000000 [ 16MiB ]
IMEI[1] : 35XXXXXXXXXXX
IMEI[2] : 35XXXXXXXXXXX
Done!
Elapsed: 00:00:23
READ PASSWORD
Operation : Read UserCode [ v1.03 ]
MODE : From Device
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Reading data ...
Sorting data ...
STATE : ACTIVE : CODE : 1434
Done!
Elapsed: 00:00:33
READ DUMP
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Read Ok, 16777216 bytes
Saved to : C:\Users\KIRUMIRA\Desktop\SPRD_SPI_MACRONIX_MX25U_16MiB.bin
Done!
Elapsed: 00:03:09
READ NV
Operation : Read NVM [ v1.03 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Reading NVM ..
NVM details :
IMEI[1] : 35XXXXXXXXXXXX
IMEI[2] : 35XXXXXXXXXXXX
BT_ADDR : 011010159925
Read Ok!
Saved to : C:\Users\KIRUMIRA\Desktop\01000000_NVM.nv
Done!
Elapsed: 00:00:38
Old 07-05-2018, 12:28   #50938 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
QTab Q800 Pattern Read
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 7001004D4D43303847580F54BFA25175
[eMMC] : FLASH_VEN : 0x70 , OEM : 0100
[eMMC] : FLASH_INF : [KINGSTON] , G80CM
[eMMC] : FLASH_CID : 7001004D4D43303847580F54BFA25175
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000
[eMMC] : FLASH_LEN : 0x00000001CD000000
[eMMC] : FLASH_UCP : 7376 MiB [eMMC 8 GiB]
DEV RID    : 0xD5229C25DEFE841A3C59695BDB09ACD3
SOC VERIFY : C1
Boot Ok!
Reading data ...
Get Locks ...
PatternLock Sequnce : 741236985
Done!
Elapsed: 00:00:20
Old 07-05-2018, 12:30   #50939 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
OPPO A37F Pattern Read
Operation : Read PatternLock [ v1.16 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 260ADCA6
ID_BLOCK_L : 23C5BF47F67C69644338D8C50259D9F1
ID_BLOCK_L : C1BC02ADAE31992AAF0E43B88A657358
MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ]
Boot Ok!
Read Ok! Trying decrypt ...
PatternLock sequence : 4568
Done!
Elapsed: 00:00:24
Old 07-05-2018, 12:31   #50940 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
Motorola XT1565 Frp Reset
Operation : Moto ADB Enable [ v1.03 ]
Mode : Enable ADB
Waiting for NetInterface arrival ...
1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons
2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON'
3. Connect USB cable, when device boot complete!
Connect Ok!
Waiting ...
Trying link with  : 192.168.137.2
Connected to device!
Device : XT1565
Switching to FACTORY ...
Setting Unsecure mode
Waiting device ...
Connect Ok!
Device : XT1565
Setting ADB ...
Waiting device ...
Connect Ok!
Device : XT1565
Setting ADB ...
1. Disconnect cable from device, wait device reboot
2. Make "Reset FRP"
3. Disable "FACTORY MODE" after operations done!
Done!
Elapsed: 00:01:00
Operation : Reset FRP (ADB) [ v1.03 ]
Waiting for device in ADB mode ...
1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need!
2. Insert USB cable, accept AUTH on PhoneScreen, if software ask!
Connect Ok!
Device : lux_verizon
Model  : XT1565
FRP reset passed! Make FACTORY RESET from menu!
 -- > MOTO FRP : Don't forget to DISABLE FACTORY MODE!
Done!
Elapsed: 00:00:29
Mode : Disable Factory
Waiting for device in fastboot mode ...
1. Power off device. Press and hold 'VOL DOWN' button
2. Insert USB cable, hold button until device will be found!
Connect Ok!
Operation done!
Done!
Elapsed: 00:00:07
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.75342 seconds with 10 queries
