Old 07-31-2018, 14:49   #51736 (permalink)
Ionel's Avatar
Member: 81232
Thanks Meter: 193
VFD 300 no root ......
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 1101003030344745300094CF4FE14351
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x11 , OEM : 0100
[eMMC] : FLASH_INF : [TOSHIBA] , 0EG40
[eMMC] : FLASH_CID : 1101003030344745300094CF4FE14351
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000
[eMMC] : FLASH_LEN : 0x00000000EC000000
[eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB]
DEV RID : 0x6B453BBAC241F5752C04979FA87F3C4F
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
SIM Lock Status : Locked!
Unlocking now ...
Unlock done!
Done!
Elapsed: 00:00:29
Reconnect Power/Cable!
The Following User Says Thank You to Ionel For This Useful Post:
Old 07-31-2018, 15:24   #51737 (permalink)
Member: 2125922
Sonork: 1601402
Thanks Meter: 102
Wink Gfive modle 4 light formate done with cm2 scr
Operation : Format FileSystem [ v1.02 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource  :  InternalLibrary
BootVersion : Infinity SCR SC6531E Loader v 1.2
Port speed : 921600
FDL Flash  : Control transfered!
Boot Done!
CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ]
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_119239F4F8B0_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:20
Old 07-31-2018, 15:53   #51738 (permalink)
Member: 442808
Thanks Meter: 121
Sucessfully Remove FRP OPPO A37fw
Operation : Identify [ v1.16 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 26CED57F
ID_BLOCK_L : 04FC9660CF5B40433C11E3EC2B76FECE
ID_BLOCK_L : 85F846E9EA75E56E635207FCF6393714
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Brand     : OPPO
ProdName  : A37f
ProdModel : A37f
Device    : A37f
AndroidVer: 5.1.1
SWVersion : A37fEX_11.A.30_INT_030_201712091507
Manufact. : OPPO
SysPatch  : LMY47V
DevComTime: 12/9/2017 8:58:03 AM
QLMxCPU   : MSM8916
USERData : NORMAL
GCSec    : EMPTY
Done!
Elapsed: 00:00:19
Operation : Reset Settings [ v1.16 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:25
The Following User Says Thank You to situ_saraf For This Useful Post:
Old 07-31-2018, 15:57   #51739 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,131
Kodok IM7 MT6580 FRP Reset Don With King Infinity CM2
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : F40122426977696E201000016C4D9317
[WARNING] : MEMORY_eMMC_VALIDATE_FAILED
[eMMC] : FLASH_VEN : 0xF4 , OEM : 0122
[eMMC] : FLASH_INF : [NOT_IN_BASE] , niwi
[eMMC] : FLASH_CID : F40122426977696E201000016C4D9317
[eMMC] : FLASH_LEN : 0x00000001CD000000
[eMMC] : FLASH_UCP : 7376 MiB [eMMC 8 GiB]
DEV RID : 0xD9C8F395DDDA5881D09C4FCB00F216C1
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Operation Done
Elapsed: 00:00:23
Old 07-31-2018, 16:42   #51740 (permalink)
shazzmob's Avatar
Member: 2327602
Sonork: 100.1620953
Thanks Meter: 264
Voice mobile READ CODE done with scr
VOICE MOBILE FORMAT DONE WITH SCR
READ INFO
Operation : Identify [ v1.02 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootVersion : Spreadtrum Boot Block version 1.2
Port speed : 921600
Boot Done!
IMEI[1] : 35994603533XXXX
IMEI[2] : 35994603533XXXX
Done!
Elapsed: 00:00:27
READ CODE
Operation : Read UserCode [ v1.02 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Reading data ...
Sorting data ...
STATE : ACTIVE : CODE : 2599
Done!
Elapsed: 00:00:23
Old 07-31-2018, 16:47   #51741 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,131
Lenovo A319 MT6572 Dead Set Re Alive Done By Flashing With Infinity CM2
Card found : S/N : A19EC787 , v0137
Scatter Load Ok , BaseBand : MT6572 , Project : huaqin72_cwet_1a_kk , Storage : EMMC
Files found : 11 , Set to Flash : 10
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 90014A483447326111017A14054A82E1
DRAM configured from ScatFW!
DRAM initialize passed!
DRAM size : 0x20000000
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , a2G4
[eMMC] : FLASH_CID : 90014A483447326111017A14054A82E1
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xD9C8F395B9FA39E83A067CA34812BA37
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : huaqin72_cwet_1a_kk , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
Switching to HSUSB
HSUSB Init Ok
BL : Check HW compatibility
BL : Skip checking by User request!
BL : BatteryLevel : 3687 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x0000000094840000
Flash Pre-Erase Done, time used : 00:00:01
SecCfg Passed , 1799
BMT remark not need. Will skip
Preloader Download skipped by user request!
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:04:27
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:01:10
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:05:57
Old 07-31-2018, 16:58   #51742 (permalink)
shazzmob's Avatar
Member: 2327602
Sonork: 100.1620953
Thanks Meter: 264
Samsung s7262 hang on logo recover via flashing with sm
SAMSUNG S7262 HANG ON LOGO RECOVER VIA FLASHING WITH SM
Phone found on COM30
Phone In Download mode...
Port open Ok!
LOKE received!
Prepare Ok!
Enter Setup...
Setup Done!
Try download PIT...
Download PIT Ok!
Start flashing!
Flashing sboot.bin
Flashing param.lfs
Flashing boot.img
Flashing recovery.img
Flashing system.img
Flashing modem.bin
Flashing cache.img
Flashing hidden.img
Flashing done
Reboot phone...
The Following 2 Users Say Thank You to shazzmob For This Useful Post:
Old 07-31-2018, 18:06   #51743 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,131
Qmobile I6 Metal 1 MT6580 FRP Reset Done With King Infinity CM2
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A4838473165050730C45C4CB359
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A4838473165050730C45C4CB359
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xD9C8F395285552BC42C6A3A5E720A86F
EXT RAM : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:13
Old 07-31-2018, 18:17   #51744 (permalink)
Member: 580077
Sonork: 100.1591941
Thanks Meter: 158
g610f frp ok adb mode
Connect ADB - Ok
Phone found on COM229
Read Info...
Modem Busy Now...  Read Info Canceled
Reset FRP/ REACTIVATION LOCK - Done
Reboot Phone...
The Following 2 Users Say Thank You to nori2007 For This Useful Post:
Old 07-31-2018, 18:31   #51745 (permalink)
Member: 2125922
Sonork: 1601402
Thanks Meter: 102
Wink Qmobile a290 flash done with cm2 mtk
======= Flash
Wait for phone...
Phone found! [ 72 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A48344732611101BB465C383295
[eMMC] : FLASH_CID : 90014A48344732611101BB465C383295
DEV RID    : 0xA951A0A980F2EFF5C4561D48B168C3E1
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : s5201ap , Storage : EMMC
Setting : AFF verify :  Disabled
BL : BatteryLevel : 3788 mV
Erase : 0x0000000002900000-0x00000000E5E00000
Flash Pre-Erase Done, time used : 00:00:09
PartCount : 0012
Repartition Done!
Use FLN Mode
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:44
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:12
Old 07-31-2018, 19:15   #51746 (permalink)
Member: 2125922
Sonork: 1601402
Thanks Meter: 102
Wink
Operation : Read User Code [ v1.27 ]
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
 ====  Wait for phone...
Phone found! [ 64 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00EF 0040 0016 0000
[0] Flash VEN : Winbond , W25Q32
[0] Flash CAP : 00400000
Check data... Can take some time
User Code : 2525
Done!
Elapsed: 00:00:06
Old 07-31-2018, 21:31   #51747 (permalink)
mubarak2344's Avatar
Member: 2001848
Sonork: 100.1658212
Thanks Meter: 573
MOTO X Play XT1562 Frp Reset Done Via Infinity CM2
Operation : Moto ADB Enable [ v1.03 ]
Mode : Enable ADB
Waiting for NetInterface arrival ...
1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons
2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON'
3. Connect USB cable, when device boot complete!
Connect Ok!
Waiting ...
Trying link with : 192.168.137.2
Connected to device!
Device : XT1562
Switching to FACTORY ...
Setting Unsecure mode
Waiting device ...
Connect Ok!
Device : XT1562
Setting ADB ...
Waiting device ...
Connect Ok!
Device : XT1562
Setting ADB ...
1. Disconnect cable from device, wait device reboot
2. Make "Reset FRP"
3. Disable "FACTORY MODE" after operations done!
Done!
Elapsed: 00:01:00
Operation : Reset FRP (ADB) [ v1.03 ]
Waiting for device in ADB mode ...
1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need!
2. Insert USB cable, accept AUTH on PhoneScreen, if software ask!
Connect Ok!
Device : lux_retasia_ds
Model : XT1562
FRP reset passed! Make FACTORY RESET from menu!
-- > MOTO FRP : Don't forget to DISABLE FACTORY MODE!
Done!
Elapsed: 00:00:13
The Following 4 Users Say Thank You to mubarak2344 For This Useful Post:
Old 07-31-2018, 22:00   #51748 (permalink)
Yusuf Lawal's Avatar
Member: 1677653
Thanks Meter: 1,963
TECNO CX AIR REPAIR SECURITY DONE
Card found : S/N : A6936825 , v0137
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Device boot not done
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:27
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x93
eMMC Flash : 510001154D333145A46C0D42912289E0
[eMMC] : FLASH_INF : [SAMSUNG] , BM31E
[eMMC] : FLASH_CID : 150100514531334D420D6CA4E0896491
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0xDEC55C37DA4E76872C91C6E91D44BAFD
EXT RAM : 0x80000000 [2 GiB]
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : TECNO
ProdName : H3713
ProdModel : TECNO CX Air
Device : TECNO-CX-Air
AndroidVer: 7.0
MTKxCPU : MT6737M
MTKxPRJ : CXAir-H3713A-N-170713V106
SECURITY :
IMEI_SW [1] : 000000000000000
IMEI_SW [2] : 000000000000000
BTMAC Addr : 04946B3AA953
WiFi MAC : 04946B3A43C3
Done!
Elapsed: 00:00:13
Operation : Repair Security [ v1.58 ]
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
IMEI [00] : 000000000000000
IMEI [01] : 000000000000000
Set IMEI [00] : 3572010834XXXXX
Set IMEI [01] : 3572010834XXXXX
Prepare finished. Security check required!
Wait for phone...
Phone found! [ 6 ]
Sync...
Repair done!
Done!
Elapsed: 00:00:51
The Following User Says Thank You to Yusuf Lawal For This Useful Post:
Old 08-01-2018, 06:27   #51749 (permalink)
Nadeem Waris's Avatar
Member: 1080718
Sonork: 100.1596539 QQ-2710826805
Thanks Meter: 2,116
KACHAODA K116 read code done
Operation : Read UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 53 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 84A5B42781BE24CFB1C7111FCE6493CE
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV
[0] : FLASH_DIE : 00EF 0070 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Read ExtData
Sorting ExtData
Reading UserCode
Active : Yes , Code : 6633
PLock|MobTrack : Not active
Done!
Elapsed: 00:00:03
Operation : Read Flash [ v1.58 ]
Wait for phone...
Phone found! [ 53 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
SOC_VERIFY : 0xC1
Reading Flash Content now ...
Read Flash now
Read Ok , 4194304 bytes read
Check and collect compile info
File_Info : HONGYU61D_BTD_11C_PCB01_gprs_MT6261_S00.C116C_KECH AODA_04_20170414.bin
FileVersion : C116C_KECHAODA_04_20170414
Saved to : C:\InfinityBox\CM2MTK\Read_out\HONGYU61D_BTD_11C_P CB01_gprs_MT6261_S00.C116C_KECHAODA_04_20170414.bi n
Done!
Elapsed: 00:00:11
Old 08-01-2018, 06:56   #51750 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,131
Qmobile I8i SPD77XX FRP Reset Done With King Infinity CM2
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
Phone found! [ 43 ]
Port Opened
Sync...
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:30
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-29-2010 21:17
Page generated in 0.83026 seconds with 9 queries
