Old 08-05-2018, 05:26   #51841 (permalink)
Nadeem Waris's Avatar
Member: 1080718
Sonork: 100.1596539 QQ-2710826805
Thanks Meter: 2,027
Samsung j7 clone remove pattern lock done with cm2
Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.58 ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 7001004D4D4330344702052836F55071
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x70 , OEM : 0100
[eMMC] : FLASH_INF : [KINGSTON] , G40CM
[eMMC] : FLASH_CID : 7001004D4D4330344702052836F55071
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000
[eMMC] : FLASH_LEN : 0x00000000E2C00000
[eMMC] : FLASH_UCP : 3628 MiB [eMMC 4 GiB]
DEV RID : 0x0386520D335B6505187F225E3748C5D3
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
LSSDB Ok!
LSSWL Ok!
LSSSH Ok!
LSSKY Ok!
LSSGS Ok!
Security Settings : Clear Ok!
[Info] : That feature NOT RESET "PRIVACY PASSWORD LOCK"! Use separate button!
[Info] : That feature NOT RESET "FRP/GoogleLOCK"! Use separate "FRP" reset!
[Info] : If phone stuck on "Logo" :
1. Wait 2-3 minutes. Power Off phone by long press "Power" button
2. Power On phone again
3. Or wait up to 3-7 minutes, until phone start by itself
4. Also recommended reboot phone twice before start use it
Done!
Elapsed: 00:00:19
Reconnect Power/Cable!
Old 08-05-2018, 05:27   #51842 (permalink)
Member: 1080718
Thanks Meter: 2,027
OLEA X2 Hanging Pro Done With CM2
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
eMMC Flash : F40122426977696E20100001AF08A40F
[WARNING] : MEMORY_eMMC_VALIDATE_FAILED
[eMMC] : FLASH_VEN : 0xF4 , OEM : 0122
[eMMC] : FLASH_INF : [NOT_IN_BASE] , niwi
[eMMC] : FLASH_CID : F40122426977696E20100001AF08A40F
[eMMC] : FLASH_LEN : 0x00000001CD000000
[eMMC] : FLASH_UCP : 7376 MiB [eMMC 8 GiB]
DEV RID : 0x0386520DF0DF1E17E6C736C99EE18C6B
EXT RAM : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:01:13
Old 08-05-2018, 05:27   #51843 (permalink)
Member: 1080718
Thanks Meter: 2,027
Qmobile I4 remove Pincode Done With Cm2
Card found: S/N : 7BD0661F , v0136
Chinese Miracle II [SPD module] v 1.27
Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0]
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 20 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v3 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0003
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Done!
Elapsed: 00:00:22
Old 08-05-2018, 05:28   #51844 (permalink)
Member: 1080718
Thanks Meter: 2,027
VGOTEL I700 Read COde DOne With CM2
Card found : S/N : 7BD0661F , v0136
Operation : Read UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 26 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : A96763E8B9F44B8C5BA7AE1B966A8495
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV
[0] : FLASH_DIE : 00EF 0070 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Read ExtData
Sorting ExtData
Reading UserCode
Active : Yes , Code : 1117
PLock|MobTrack : Not active
Done!
Elapsed: 00:00:17
Old 08-05-2018, 05:28   #51845 (permalink)
gsmpointhrp's Avatar
Member: 416286
Sonork: 100.1622339
Thanks Meter: 753
LAVA IRIS 702 flash done
Wait for phone...
Phone found! [ 29 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 150100463732324D4200658360CE34F1
[eMMC] : FLASH_INF : [SAMSUNG] , BM227
[eMMC] : FLASH_CID : 150100463732324D4200658360CE34F1
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID    : 0x5583D1949140F02F897E431653CC2FDE
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6580 , Project : lava6580_sp462 , Storage : EMMC
Setting : AFF verify :  Enabled
Setting : HW verify :  Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3638 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 1
Erase : 0x0000000001C80000-0x00000001CF300000
Flash Pre-Erase Done, time used : 00:00:04
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_lava6580_sp462.bin
Preloader Sent , Init passed
PartCount : 0014
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : LK
Image Flash Ok
Flash now : BOOT
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : SECRO
Image Flash Ok
Flash now : SYSTEM
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USERDATA
Image Flash Ok
Flash Write Done, time used : 00:07:21
Processing : Verify
Verify Passed : LK
Verify Passed : BOOT
Verify Passed : RECOVERY
Verify Passed : LOGO
Verify Passed : SECRO
Verify Passed : SYSTEM
Verify Passed : CACHE
Verify Passed : USERDATA
Data Verify Done, time used : 00:00:03
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:07:45
Old 08-05-2018, 05:30   #51846 (permalink)
Member: 416286
Sonork: 100.1622339
Thanks Meter: 753
Qmobile hang on logo done
Wait for phone...
Phone found! [ 20 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
BromVer   : 0x00FF
BLVersion : 0x0002
Processing DA stage
DAgent configured successfully
Connection agent : PRELOADER
Link with DAgent established
[eMMC] : FLASH_INF : [SAMSUNG] , BMB6E
[eMMC] : FLASH_CID : 150100474536424D4203053CAA3C7429
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID    : 0x5583D19457CDB5B785CED1E140638FC5
INT RAM    : 0x00000000
EXT RAM    : 0x80000000 [2 GiB]
[NAND] : FLASH : NOT INSTALLED
[UFSM] : FLASH : NOT INSTALLED
[HSUSB] : MODE : HIGH-SPEED
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:25
Old 08-05-2018, 07:19   #51847 (permalink)
Member: 1080718
Thanks Meter: 2,027
Lg D850 flash done with cm2
Operation : Flash [ v1.03 ]
Forced Flash : Disabled
Factory Reset : Enabled
2. PRESS and HOLD VOLUME UP KEY!
3. Insert USB cable, wait until Download mode screen will appear
Wait for phone...
Connection opened successfully!
Waiting for loader ...
Handshake passed!
Collect info...
Prepare passed, mode 0x00
Boot done!
[INFO] : Low Battery level ignored by user request!
Loading firmware
Load ok!
Checking compatibility
Checking passed!
Prepare device
Prepare Passed!
Secure prepare skipped!
Start flashing device
Flash : PrimaryGPT
Flash : modem
Flash : sbl1
Flash : dbi
Flash : aboot
Flash : rpm
Flash : tz
Flash : boot
Flash : persist
Flash : recovery
Flash : rct
Flash : misc
Flash : laf
Flash : factory
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : system
Flash : cache
Flash : cache
Flash : cache
Flash : cache
Flash : cache
Flash : cache
Flash : cache
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : userdata
Flash : BackupGPT
Processing Post-Flashing tune
Flash done!
Done!
Elapsed: 00:03:05
Old 08-05-2018, 07:36   #51848 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 822
Qmobile i7i hang on logo done with king infinity cm2
QMOBILE I7I HANG ON LOGO DONE WITH KING INFINITY CM2
3. Insert cable
Phone found! [ 36 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Done!
Elapsed: 00:00:21
ShahiD
Old 08-05-2018, 07:39   #51849 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 822
Oppo f5 reset pattern done with king infinity cm2
OPPO F5 RESET PATTERN DONE WITH KING INFINITY CM2
Operation : Reset Settings/Format FS [ v2.00 r4 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MTK USB Port (COM18)
MODE : BOOTROM
PORT : 18
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x000000E5
BROM : SecMode : SBC+SDA+SEL
BROM : BOOTROM
MODE : Oppo : F5 | Manual : Disabled
BROM : SLA
BROM : SLA Passed!
AGENT : Look for suitable BootChain in DA ...
AGENT : DA_PL_CRYPTO.bin
AGENT : Found MT6763
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : MT6763
EMI : SRC : preloader_oppo6763_17031.bin
EMI : CNT : 000F
EMI : [00] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 0 B ]
EMI : [01] : eMCP : eMMC+LP/DDR4 , ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ]
EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ]
EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ]
EMI : [04] : eMCP : eMMC+LP/DDR4 , ID : 150100334836434D42 : VEN : SAMSUNG | DEV : 3H6CMB : RAM : [ 6.00 GB ]
EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ]
EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ]
EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3.00 GB ]
EMI : [08] : eMCP : eMMC+LP/DDR3 , ID : 150100474536424D42 : VEN : SAMSUNG | DEV : GE6BMB : RAM : [ 3.00 GB ]
EMI : [09] : eMCP : eMMC+LP/DDR3 , ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ]
EMI : [0A] : eMCP : eMMC+LP/DDR3 , ID : 13014E53304A394237 : VEN : UNKNOWN | DEV : S0J9B7 : RAM : [ 3.00 GB ]
EMI : [0B] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ]
EMI : [0C] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ]
EMI : [0D] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ]
EMI : [0E] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ]
EMI : Init EMI from PRELOADER
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00040000 [ 256.00 KB ]
DRAM: 0xC0000000 [ 3.00 GB ]
EMMC: 90014A484247346132A529885CA1A41F
EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HBG4a2
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x747C00000 [ 29.12 GB ]
CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000
RNID : FB56BD8076A2B5BCC4855D2670D6376
DA : USB : HIGH-SPEED
Boot done!
Format Ok : USERDATA
Format Ok : CACHE
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:35
ShahiD
Old 08-05-2018, 09:36   #51850 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,078
OALE X2 MT6580 FRP Reset Done With King Infinity CM2
Card found : S/N : A19EC787 , v0137
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 880103455042313030444DA323605409
[eMMC] : FLASH_VEN : 0x88 , OEM : 0103
[eMMC] : FLASH_INF : [FORESEE] , 001BP
[eMMC] : FLASH_CID : 880103455042313030444DA323605409
[eMMC] : FLASH_LEN : 0x00000001CE100000
[eMMC] : FLASH_UCP : 7393 MiB [eMMC 8 GiB]
DEV RID : 0xD9C8F395DB6BE1852150AE8C57B31E88
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:01:27
Old 08-05-2018, 09:43   #51851 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 14,488
Smile VGoTel Ocean 9 format Done
3. Insert cable
Phone found! [ 264 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC983x eMMC Loader v5.0 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:35
Old 08-05-2018, 10:30   #51852 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,078
Oppo A37fw QLM Pattren Read Done With King
Operation : Read PatternLock [ v1.14 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 25FAF324
ID_BLOCK_I : 007050E1
ID_BLOCK_L : A14339C570FEEBE6C1B65E4780DB5B73
ID_BLOCK_L : D1AC12BDBE21891ABF7E53889A150348
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Read Ok! Trying decrypt ...
PatternLock sequence : 32598
Done!
Elapsed: 00:00:36
Old 08-05-2018, 11:14   #51853 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,078
Maxx T106 2SCR Pin Code Reset Done With King Infinity CM2
Card found : A19EC787 , v0137
Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.03
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR
SPRD mode : SC6531 : REV : E000 : NOR
Operation : Format FileSystem [ v1.03 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Infinity SCR SC6531E Loader v 1.2
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ]
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_079 5192B7145_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:15
Old 08-05-2018, 11:16   #51854 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,078
Qmobile I5 MT6582 Logo Stuck Fix Only Formate With Infinity CM2
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x87
eMMC Flash : 90014A4834473164040501A2FFB49131
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040501A2FFB49131
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xD9C8F395B120E02BDCAF932FC8567C6E
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:40
Old 08-05-2018, 12:58   #51855 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,078
Qmobile X32 MT6580 FRP Reset Done With King Infinity CM2
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A483847316505072B29504533C7
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A483847316505072B29504533C7
DEV RID : 0xD9C8F395EE84548ACF9B6BB97259B732
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:34
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.92169 seconds with 9 queries
