08-14-2018, 13:44 | #52231 (permalink) |
No Life Poster Join Date: Aug 2013 Location: CHENNAI, TAMILNADU,INDIA
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | Micromax Q386 IMEI Repair Done Via Infinity CM2 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100463832324D42002A8BE0A54333 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM228 [eMMC] : FLASH_CID : 150100463832324D42002A8BE0A54333 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x97F8A39E7E5819C335BF79E01B14404C INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Set IMEI [00] : 911507850XXXXXX Set IMEI [01] : 911507850XXXXXX Prepare finished. Security check required! Wait for phone... Phone found! [ 5 ] Sync... Repair done! Done! Elapsed: 00:00:55 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to mubarak2344 For This Useful Post: |
08-14-2018, 16:01 | #52232 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Samsung J500H ORG FRP Reset Don With King Infinity CM2 SM S/N: A19EC787 Firmware Version: 0101 Phone found on COM73 Phone In Download mode... Reset FRP Procedure started... Port open Ok! LOKE received! Prepare Ok! Enter Setup... Try download PIT... Download PIT Ok! Reset FRP done Reboot phone... Phone Disconnected |
08-14-2018, 17:26 | #52233 (permalink) |
Product Supporter Join Date: Mar 2016 Location: Bangladesh
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | OPPO 1201 Firmware Read Done By CM2 Brand : OPPO ProdName : 1201 ProdModel : 1201 Device : 1201 AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : 1201EX_11_A.09_150831 [Read Ok] : preloader_oppo82_15066.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6582 / V1.1.1 / oppo82_15066 / EMMC Android Info saved HWConfig Info saved FW Size : 1512 MiB Scatter saved to : C:\Users\acer\Desktop\New folder\MT6582__OPPO__1201__1201__4.4.2__1201EX_11_ A.09_150831\ All done! |
08-14-2018, 17:27 | #52234 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile Power 14 SPD6531 Logo Stuck Fix Only Formate With Infinity CM2 Card found: S/N : A19EC787 , v0137 Chinese Miracle II [SPD module] v 1.27 Set mode to : SPD6531 Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 77 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00EF 0040 0016 0000 [0] Flash VEN : Winbond , W25Q32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:09 Reconnect Power/Cable! |
08-14-2018, 17:27 | #52235 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Walton D8s SPD Pac Firmware Read Done By CM2 Boot Ok! Model Name : c390_hlg_a71 Model Brand : WALTON Model Device: Primo_D8s AndrVersion : 6.0 BaseBand CPU: WALTON Project Ver : MRA58K release-keys Model Ext : Primo D8s [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731C_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : sc8830g_modem_CP2_WCN_Trunk_W16.28.5_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x800.bin [Read Ok] : fblogo_480x800.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : sysinfo.img [Build Ok] : cache.img [Read Ok] : recovery.img [Build Ok] : userdata.img AndroidInfo created Firmware Size : 1776 MiB Saved to : D:\New folder (11)\WALTON_Primo_D8s_6.0_MRA58K_release-keys_Primo_D8s\ Done! |
08-14-2018, 17:30 | #52236 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | WALTON Primo E8 6.0 7731 Pac Firmware Read Done By CM2 Model Name : Primo E8 Model Brand : WALTON Model Device: Primo_E8 AndrVersion : 6.0 BaseBand CPU: WALTON Project Ver : Primo_E8_S005_24102016 Model Ext : WALTON Primo E8 [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731C_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : sc8830g_modem_CP2_WCN_Trunk_W16.23.4_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x854.bin [Read Ok] : fblogo_480x854.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : sysinfo.img [Build Ok] : cache.img [Read Ok] : recovery.img [Build Ok] : userdata.img AndroidInfo created Firmware Size : 2626 MiB Saved to : D:\WALTON_Primo_E8_6.0_Primo_E8_S005_24102016_WALT ON_Primo_E8\ Done! Elapsed: 00:11:42 |
08-14-2018, 17:31 | #52237 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | WALTON Primo EF4 Plus 6.0 Firmware Read Done By CM2 [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731C_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : sc8830g_modem_CP2_WCN_Trunk_W16.23.4_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x854.bin [Read Ok] : fblogo_480x854.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : sysinfo.img [Build Ok] : cache.img [Read Ok] : recovery.img [Build Ok] : userdata.img AndroidInfo created Firmware Size : 2631 MiB Saved to : D:\WALTON_Primo_EF4_Plus_6.0_Primo_EF4+_S007_29082 016_Primo_EF4+\ Done! |
08-14-2018, 17:32 | #52238 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | WALTON Primo F7 Firmware Read Done By CM2 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : WALTON ProdName : Primo_F7 ProdModel : Primo F7 Device : Primo_F7 AndroidVer: 6.0 MTKxCPU : MT6580 MTKxPRJ : ALPS.W10.24.p0 [Read Ok] : preloader_v2600.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6580 / V1.1.2 / v2600 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 2030 MiB Scatter saved to : I:\Backup\MT6580__WALTON__Primo_F7__Primo_F7__6.0_ _ALPS.W10.24.p0\ All done! Done! |
08-14-2018, 17:33 | #52239 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | WALTON Primo N2 Firmware Read Done By CM2 Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : WALTON ProdName : Primo_N2 ProdModel : Primo N2 Device : Primo_N2 AndroidVer: 6.0 MTKxCPU : MT6580 MTKxPRJ : ALPS.W10.24.p0 [Read Ok] : preloader_v3750.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6580 / V1.1.2 / v3750 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 2479 MiB Scatter saved to : J:\New folder\New folder\MT6580__WALTON__Primo_N2__Primo_N2__6.0__AL PS.W10.24.p0\ All done! |
08-14-2018, 17:34 | #52240 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | WALTON Primo NH2 Lite Firmware Read Done By CM2 Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : WALTON ProdName : Primo NH2 Lite ProdModel : Primo NH2 Lite Device : Primo NH2 Lite AndroidVer: 6.0 MTKxCPU : MT6580 MTKxPRJ : alps-mp-m0.mp1-V2.34_vsun6580.we.m_P3 [Read Ok] : preloader_vsun6580_we_m.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6580 / V1.1.2 / vsun6580_we_m / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 2080 MiB Scatter saved to : D:\Lite\MT6580__WALTON__Primo_NH2_Lite__Primo_NH2_ Lite__6.0__alps-mp-m0.mp1-V2.34_vsun6580.we.m_P3\ All done! |
08-14-2018, 17:36 | #52241 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Oppo F1f Qualcomm MSM8916 Firmware Read Done By CM2 Boot Ok! Brand : OPPO ProdName : F1f ProdModel : F1f Device : F1f AndroidVer: 5.1.1 Manufact. : OPPO QLMxCPU : MSM8916 DevInfo : MSM8916__OPPO__OPPO__ANDR_v5.1.1__F1f__F1f__F1f Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : ddr.bin [Read Ok] : sec.dat [Read Ok] : sbl1.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : hyp.mbn [Read Ok] : pnvbak.img [Read Ok] : lsplash.img [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : persist.img [Read Ok] : misc.img [Read Ok] : driver.iso [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8936 / eMMC Firmware Size : 3077 MiB Done! |
08-14-2018, 17:37 | #52242 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Lenovo A1000 SPD 7731 Firmware Read Done By CM2 Boot Ok! Model Name : A1000 Model Brand : Lenovo Model Device: A1000 AndrVersion : 5.0 BaseBand CPU: A1000 Project Ver : A1000_USR_S30666_1611211455_SPRD7731_ROW Model Ext : Lenovo A1000 [Read Mode] : HSUSB : 0x3000 [FW_READER] : Reading Firmware Now ... [Read Ok] : u-boot-spl-16k.bin [Read Ok] : u-boot.bin [Read Ok] : prodnv.img [Read Ok] : sc7731g_CP0_modem.bin [Read Ok] : DSP_DM_Gx.bin [Read Ok] : nvitem_w.bin [Read Ok] : sc8830g_modem_CP2_WCN_14D_W15.31.1_Release.bin [Read Ok] : nvitem_wcn.bin [Read Ok] : logo_480x800.bin [Read Ok] : fblogo_480x800.bin [Read Ok] : boot.img [Read Ok] : system.img [Read Ok] : oem.img [Build Ok] : cache.img [Read Ok] : recovery.img [Build Ok] : userdata.img AndroidInfo created Firmware Size : 2518 MiB Saved to : H:\primo\New folder (5)\A1000_A1000_5.0_A1000_USR_S30666_1611211455_SP RD7731_ROW_Lenovo_A1000\ Done! |
08-14-2018, 17:38 | #52243 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Lenovo A2010-a Firmware Read Done By CM2 Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : Lenovo ProdName : A2010-a ProdModel : Lenovo A2010-a Device : A2010-a AndroidVer: 5.1 MTKxCPU : MT6735M MTKxPRJ : A2010-a-t_USR_S253_1509171800_MP3V1_8G_ROW [Read Ok] : preloader_al712row.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6735M / V1.1.2 / al712row / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 2071 MiB Scatter saved to : D:\L\MT6735M__Lenovo__Lenovo_A2010-a__A2010-a__5.1__A2010-a-t_USR_S253_1509171800_MP3V1_8G_ROW\ All done! |
08-14-2018, 17:39 | #52244 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | Blu Desh M Firmware Read Done By CM2 Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : BLU ProdName : BLU_DASH_M ProdModel : BLU DASH M Device : BLU_DASH_M AndroidVer: 5.1 MTKxCPU : MT6580 MTKxPRJ : ALPS.L1.MP6.V2_TINNO6580.WE.L [Read Ok] : preloader_s5030.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6580 / V1.1.2 / s5030 / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 970 MiB Scatter saved to : E:\MT6580__BLU__BLU_DASH_M__BLU_DASH_M__5.1__ALPS. L1.MP6.V2_TINNO6580.W E.L\ |
08-14-2018, 17:40 | #52245 (permalink) |
Member: 2548908 Status: Offline Sonork: 100.1672479 Thanks Meter: 761 | BLU LIFE ONE M Updat User+Cache Firmware Read Done By CM2 Brand : BLU ProdName : s9203 ProdModel : BLU LIFE ONE M Device : s9203 AndroidVer: 4.2.1 MTKxCPU : MT6589 MTKxPRJ : ALPS.JB2.MP.V1.2 [Read Ok] : preloader_s9203.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6589 / V1.0.0 / s9203 / EMMC FW Size : 675 MiB |
