Old 09-11-2018, 05:48   #53131 (permalink)
Nadeem Waris's Avatar
Member: 1080718
Sonork: 100.1596539 QQ-2710826805
Thanks Meter: 2,123
Qmobile sp 3000 Read COde Done
Operation : Read UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 26 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CA02
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : BCE80456D49CD351A2E3C240C748A4FE
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09
[0] : FLASH_DIE : 00C2 0020 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Read ExtData
Sorting ExtData
Reading UserCode
Active : No , Code : 7700
MobileTracker : ?
Done!
Elapsed: 00:00:03
Reconnect Power/Cable!
Old 09-11-2018, 05:49   #53132 (permalink)
Member: 1080718
Thanks Meter: 2,123
Huawei Y600-u20 flash done
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164040500A273F23217
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040500A273F23217
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0x0386520DACB3A7640F623CFB058B0A78
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : huaqin72_we_b2b_jb3 , Storage : EMMC
Setting : Flash Pre-Erase : Off ( Write Flash Only )
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Skip checking by User request!
BL : BatteryLevel : 3591 mV
BL : BatteryLevel Ok
SecCfg Passed , 1799
BMT remark not need. Will skip
Preloader Download skipped by user request!
PartCount : FFFFFFFF
PartErr : Not initialized , will update PMT now ...
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:01:43
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:02
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:01:56
Old 09-11-2018, 05:55   #53133 (permalink)
Member: 1080718
Thanks Meter: 2,123
Operation : Read UserCode [ v1.03 ]
MODE : From Device
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Infinity SCR SC6531E Loader v 1.2
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ]
Reading data ...
Sorting data ...
STATE : ACTIVE : CODE : 25800
Done!
Elapsed: 00:00:16
Old 09-11-2018, 05:56   #53134 (permalink)
Member: 1080718
Thanks Meter: 2,123
Qmobile i8i frp done With Cm2
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 12 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:20
Old 09-11-2018, 05:57   #53135 (permalink)
Member: 1080718
Thanks Meter: 2,123
Moto 912 reset done
Infinity-Box Android Service Tool [AST] v1.03
Operation : Reset Settings [ v1.03 ]
Mode : Format FS
Waiting for device in fastboot mode ...
1. Power off device. Press and hold 'VOL DOWN' button
2. Insert USB cable, hold button until device will be found!
Connect Ok!
Block [1] ERASE OK!
Block [2] ERASE OK!
Done!
Elapsed: 00:00:06
Old 09-11-2018, 06:02   #53136 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 14,819
Smile Qmobile K150 Format Done
Chinese Miracle II [SPD module] v 1.27
Set mode to : SPD6531
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
Phone found! [ 416 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00C8 0060 0016 0000
[0] Flash VEN : GigaDevice , GD25LQ32
[0] Flash CAP : 00400000
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:22
Old 09-11-2018, 06:14   #53137 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Qmobile Power 1 Pro FullFlash Done
FastCheck : SPD65xx
Load file...
Not found any ExtInfo data (Compressed already)
Load Ok
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : SPD6531_00400000_GD25LQ32_English__Qmobile-Power1 Pro.bin
3. Insert battery
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
======= Flashing MCU
Mapping file ...
Mapping done
Processing file : SPD6531_00400000_GD25LQ32_English__Qmobile-Power1 Pro.bin
Init ok, send data
Flashing Done!
Info : In some cases after flash required make "Format Fs / Reset Phone"
Done!
Elapsed: 00:01:16
The Following User Says Thank You to Akhtar Ali Jatt For This Useful Post:
Old 09-11-2018, 06:34   #53138 (permalink)
Member: 953334
Sonork: 100.1614005
Smile SANMENG Format Done
3. Insert battery
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
[0] Flash DIE : 00EF 0040 0016 0000
[0] Flash VEN : Winbond , W25Q32
Format Block Done!
Done!
Elapsed: 00:00:22
Old 09-11-2018, 06:40   #53139 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Smile Qmobile s1 reset frp done by cm2
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
eMMC Flash : 150100463732324D4200808DDA6DA377
[eMMC] : FLASH_INF : [SAMSUNG] , BM227
[eMMC] : FLASH_CID : 150100463732324D4200808DDA6DA377
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xE6C52A7D884BA06E1F1F29910642ADEE
EXT RAM : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:10
Old 09-11-2018, 07:01   #53140 (permalink)
Member: 1080718
Thanks Meter: 2,123
Taxiget tablate read ffw & format done
Operation : Read Flash [ v1.58 ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x87
eMMC Flash : FE014E50315858585814790AF3946121
[DA_ERROR] : DA Init failed!
Something wrong with battery or connection!
Boot Error!
Operation Failed
Elapsed: 00:00:42
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
[eMMC] : FLASH_VEN : 0xFE , OEM : 014E
[eMMC] : FLASH_INF : [MICRON] , XXXX1
[eMMC] : FLASH_CID : FE014E50315858585814790AF3946121
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000
[eMMC] : FLASH_LEN : 0x00000000E4800000
[eMMC] : FLASH_UCP : 3656 MiB [eMMC 4 GiB]
DEV RID : 0x0386520D0D10EFA9F44D7F6A8F21752B
SOC VERIFY : C1
Boot Ok!
Reading Flash Content now ...
Brand : alps
ProdName : unknown
ProdModel : MID
Device : MT8312
AndroidVer: 4.2.2
MTKxCPU : MT6582
MTKxPRJ : ALPS.JB5.TABLET.MP.V1
[Read Ok] : preloader_yecon82_tb_twn_12_jb5.bin
[Read Ok] : MBR
[Read Ok] : EBR1
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : secro.img
[Read Ok] : logo.bin
[Read Ok] : EBR2
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : userdata.img
[ScatCFG] : MT6582 / V1.1.1 / yecon82_tb_twn_12_jb5 / EMMC
Android Info saved
MAUI Meta DB saved
HWConfig Info saved
FW Size : 726 MiB
Scatter saved to : C:\Users\WARIS GSM\Desktop\MT6582__alps__MID__MT8312__4.2.2__ALPS .JB5.TABLET.MP.V1\
All done!
Done!
Elapsed: 00:04:29
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:16
Old 09-11-2018, 07:06   #53141 (permalink)
Member: 1080718
Thanks Meter: 2,123
Qmobile i6i reset pattern lcok done
Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.58 ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 150100464A32374D4202F9999A7E439D
[eMMC] : FLASH_INF : [SAMSUNG] , BM72J
[eMMC] : FLASH_CID : 150100464A32374D4202F9999A7E439D
DEV RID : 0x0386520D8DE9A3F5D2C461300F74CBA3
EXT RAM : 0x30000000 [768 MiB]
SOC VERIFY : C1
Boot Ok!
LSSDB Ok!
LSSWL Ok!
LSSSH Ok!
LSSGS Ok!
LSSKY Ok!
Security Settings : Clear Ok!
[Info] : That feature NOT RESET "PRIVACY PASSWORD LOCK"! Use separate button!
[Info] : That feature NOT RESET "FRP/GoogleLOCK"! Use separate "FRP" reset!
[Info] : If phone stuck on "Logo" :
1. Wait 2-3 minutes. Power Off phone by long press "Power" button
2. Power On phone again
3. Or wait up to 3-7 minutes, until phone start by itself
4. Also recommended reboot phone twice before start use it
Done!
Elapsed: 00:00:15
Old 09-11-2018, 07:30   #53142 (permalink)
Member: 1080718
Thanks Meter: 2,123
Nokia 108 remove pass done
Wait for phone...
Phone found! [ 658 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6250_S0000
BB_CPU_SN : 3CE95132B9ADC5EEA949EDCC51E23BF4
BROM Status : 1012
Comm Status : 0000
EXBL Status : Alive [ USB Load Active ]
Switch to BL done
BL Version : 01
Setting...
Setting done , result code 0x8000
BROM stage done
DA_eMP_NkB.fg
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV
[0] : FLASH_DIE : 00EF 0040 0016 0000
Executing FFS FORMAT now...
FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000
DA_RET : DA_IN_PROGRESS
DA_RET : FORMAT_DONE
Done!
Elapsed: 00:00:21
Old 09-11-2018, 08:08   #53143 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,147
Qmobile I6 Metal One MT6580 FRP Reset Done With King Infinity CM2
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A483847316505070714EC262457
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A483847316505070714EC262457
DEV RID : 0xD9C8F3951B9631A8CF522EBB657DE38C
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:34
Old 09-11-2018, 08:39   #53144 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,147
Qmobile S1 MT6580 Hanging Probelam Fix Done By Formate With Infinity CM2
Card found : S/N : A19EC787 , v0137
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A4838473165050729A14C0A72CF
[eMMC] : FLASH_CID : 90014A4838473165050729A14C0A72CF
DEV RID : 0xD9C8F395EF50A84A5BA04E325A698DD9
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:35
Old 09-11-2018, 09:13   #53145 (permalink)
Member: 2775355
Thanks Meter: 168
World First Simcom TPS390 Read/Write Flash Done
Card found : S/N : AADB7CD5 , v0136
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A48384731650507312AA427B38F
[eMMC] : FLASH_CID : 90014A48384731650507312AA427B38F
DEV RID : 0xD28D48C7BB77FBDEE959DE4D9B905DE1
SOC VERIFY : C1
Boot Ok!
Brand : alps
ProdName : TPS390
ProdModel : TPS390
Device : simcom72_cwet_kk
AndroidVer: 4.4.2
MTKxCPU : MT6572
MTKxPRJ : ALPS.KK1.MP7.V1
[Read Ok] : preloader_simcom72_cwet_kk.bin
[Read Ok] : MBR
[Read Ok] : EBR1
[Read Ok] : lk.bin
[ScatCFG] : MT6572 / V1.1.1 / simcom72_cwet_kk / EMMC
Android Info saved
MAUI Meta DB saved
HWConfig Info saved
FW Size : 678 MiB
Scatter saved to : C:\Users\KSJ Phone FastFixing\Documents\Desktop\MT6572__alps__TPS390_ _simcom72_cwet_kk__4.4.2__ALPS.KK1.MP7.V1\
All done!
Done!
Elapsed: 00:03:58
Scatter Load Ok , BaseBand : MT6572 , Project : simcom72_cwet_kk , Storage : EMMC
Files found : 11 , Set to Flash : 10
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : alps
Device Model : simcom72_cwet_kk
Device CPU : MT6572
Device IntName : TPS390
Device Version : 4.4.2
Device Compile : 4/19/2018 9:14:18 AM
Device Project : ALPS.KK1.MP7.V1
Device ExtInfo : TPS390
Ready to Flash!
======= Flash
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : simcom72_cwet_kk , Storage : EMMC
Setting : AFF verify : Disabled
BL : Check eMMC compatibility
BL : BatteryLevel : 3626 mV
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x00000001CEE00000
Flash Pre-Erase Done, time used : 00:00:01
Sending Preloader ...
Use : preloader_simcom72_cwet_kk.bin
Preloader Sent , Init passed
PartCount : 0013
Update PMT by user request
Repartition Done!
Use FLN Mode
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:01:18
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:01:42
The Following User Says Thank You to KSJphoneFastFix For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.51209 seconds with 9 queries
