Old 09-29-2018, 14:08   #53626 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,127
Oppo A83 MT6763 Pattren Reset Done With King Infinty CM2
Card found : A19EC787 , v0137
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.14
Operation : Read PatternLock [ v1.14 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 1BC48775
ID_BLOCK_I : 007050E1
ID_BLOCK_L : 72F2E816C12D5A553267E9F6310888C0
ID_BLOCK_L : 9FF658F3E46FDF54694409C6CC233D1E
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Read Ok! Trying decrypt ...
PatternLock sequence : 3256
Done!
Elapsed: 00:00:13
Reconnect Power/Cable!
Old 09-29-2018, 14:15   #53627 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,127
Qmobile X700 Pro Lite MT6580 FRP Reset Done With King Infinity CM2
Card found : S/N : A19EC787 , v0137
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 150100513832334D42003FB6F282A38F
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM328
[eMMC] : FLASH_CID : 150100513832334D42003FB6F282A38F
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0xD9C8F3958700D36DC5D951A218DB40A4
INT RAM : 0x00020000
EXT RAM : 0x80000000 [2 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:48
Old 09-29-2018, 16:03   #53628 (permalink)
lyes_albert's Avatar
Member: 2669781
Thanks Meter: 1,628
OT 5065D__{Read Pattern Sequence}__flawlessly done....
Full logs of the operation/
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 210 [MSM8x09]
ID_BLOCK_S : 007C693F
ID_BLOCK_L : 44BCD6208F1B0003FC51A3AC6B36BE8E
ID_BLOCK_L : 572E903B3CA7179C31FCD10E04EB85C6
Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ]
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Boot Ok!
PatternLock sequence : 1236987
Done!
Elapsed: 00:00:18
The Following User Says Thank You to lyes_albert For This Useful Post:
Old 09-29-2018, 16:50   #53629 (permalink)
Member: 2366316
Sonork: family
Thanks Meter: 8
Thumbs up X-TIGI V4 Reset FRP Successfully done
X-TIGI V4 Reset FRP done
Operation : Reset Settings/Format FS [ v2.00 r3 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM188)
MODE : BOOTROM
PORT : 188
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6570 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000000
BROM : SecMode : PLAIN [+PRL]
BROM : BOOTROM
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6570
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : INFINITY
EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0
EMI : CNT : 0003
EMI : Init EMI from INTERNAL DB
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00020000 [ 128.00 KB ]
DRAM: 0x20000000 [ 512.00 MB ]
EMMC: 8801034E436172642017C906B72F1439
EMMC: VEN : FORESEE | OEM : 301 | DEV : NCard
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x1CE100000 [ 7.22 GB ]
CHIP : MT6570 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 3EEE764DBFD1F05BC1A5C844C51AFB06
DA : USB : FULL-SPEED
Boot done!
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:44
The Following User Says Thank You to chikwado111 For This Useful Post:
Old 09-29-2018, 17:27   #53630 (permalink)
Member: 2643730
Thanks Meter: 360
videocon bazoomba7(v2ua) FEATURE PHONE LOCK REMOVED BY CM2 1ST WORLD
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
==== Wait for phone...
Phone found! [ 23 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00C8 0060 0016 0000
[0] Flash VEN : GigaDevice , GD25LQ32
[0] Flash CAP : 00400000
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:14
Old 09-29-2018, 17:43   #53631 (permalink)
Member: 79032
Thanks Meter: 10
licence
hi
i have to format pc and reinstall best but when connect says 10 minutes to receive email with the licence but nothing came,
can you help
thanks
Old 09-29-2018, 19:38   #53632 (permalink)
bendou's Avatar
Member: 165971
Thanks Meter: 60
redmi note 4 account removed by qlm 1.16
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 625 [MSM8953]
ID_BLOCK_S : A105AF51
ID_BLOCK_L : CD8A1935878E7225AC20B0F76BDB2314
ID_BLOCK_L : CF2943E235040EDC9B62A7A2DD4995C8
Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ]
Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HBG4a2
Boot Ok!
MIAccount reset passed!
Device may relock back on WiFi/Network enable!
Done!
Elapsed: 00:00:42
remove battery
Old 09-30-2018, 07:18   #53633 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 924
Lenovo k6 reset pattern done by cm2
Operation : Reset Settings [ v1.16 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 430 [MSM8937]
ID_BLOCK_S : 3762C395
ID_BLOCK_E : 00007A2A
ID_BLOCK_L : 472B1AE0D492DD363B7854880396A5DC
ID_BLOCK_L : C0AB8960750C31BE7FE55A9E1A7AFC4A
Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ]
Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HAG4a2
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:24
Old 09-30-2018, 08:56   #53634 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,127
Qmobile Power1 Pro SPD6531 Illegal Use Only Fix Only Formate With Ininity CM2
3. Insert battery
Phone found! [ 10 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Format Block Done!
Done!
Elapsed: 00:00:10
The Following User Says Thank You to azhergoga007 For This Useful Post:
Old 09-30-2018, 09:46   #53635 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 924
Samsung j910 hang on logo done by cm2
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 1501004E35575A4D42014618D0F1B021
[eMMC] : FLASH_INF : [SAMSUNG] , BMZW5
[eMMC] : FLASH_CID : 1501004E35575A4D42014618D0F1B021
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xD4F31DC16CC0372325EEEDD37E78B1A6
EXT RAM : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : j7209 , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Skip checking by User request!
BL : BatteryLevel : 4028 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000001400000-0x0000000000100000
Erase : 0x0000000003100000-0x00000000E2620000
Flash Pre-Erase Done, time used : 00:00:02
SecCfg Passed , 1799
BMT remark not need. Will skip
Preloader Download skipped by user request!
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:01:15
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:24
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:02:01
The Following User Says Thank You to A.G.Shahid For This Useful Post:
Old 09-30-2018, 09:54   #53636 (permalink)
Member: 2643730
Thanks Meter: 360
Micromax a110 too many patten attemp done by cm2 without data loss
Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.58 ]
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
BB_CPU_NME : [MediaTek] MT6575|MT6577_S00
BB_CPU_EXT : 0xCB00 , 0x8B00 , 0xE201
i2c Init : 0300771F
SpeedSet : 0000
VChrgSet : 0x28 , BatStat : 0x02
WD Disable stat : 0x0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.3.2 on BBID : 0x84
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , HYNIX
[eMMC] : FLASH_CID : 90014A2058494E594816A1000B3C504D
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : 0x10681B28D06D1E54E8A0A7CF30C93884
SOC VERIFY : C1
Boot Ok!
LSSDB Ok!
LSSWL Ok!
LSSSH Ok!
LSSKY Ok!
LSSGS Ok!
Security Settings : Clear Ok!
[Info] : That feature NOT RESET "PRIVACY PASSWORD LOCK"! Use separate button!
[Info] : That feature NOT RESET "FRP/GoogleLOCK"! Use separate "FRP" reset!
[Info] : If phone stuck on "Logo" :
1. Wait 2-3 minutes. Power Off phone by long press "Power" button
2. Power On phone again
3. Or wait up to 3-7 minutes, until phone start by itself
4. Also recommended reboot phone twice before start use it
Done!
Elapsed: 00:00:28
Old 09-30-2018, 10:00   #53637 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 924
Huawei mya l22 reset frp done by cm2
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
SecCfgVal : 0x01000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
Running DA ver.4.2 on BBID : 0x93
eMMC Flash : 510001154D33314553B30D421DB7DDF2
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x80000000
[eMMC] : FLASH_INF : [SAMSUNG] , BM31E
[eMMC] : FLASH_CID : 150100514531334D420DB353F2DD841D
DEV RID : 0xB9E2EB77E68A3B3D1F62EDDF3E78564D
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:20
Old 09-30-2018, 10:30   #53638 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,127
Qmobile K135 SPD6531 Illegal USe Only DOne Only Formate With Infinity CM2
Card found: S/N : A19EC787 , v0137
Chinese Miracle II [SPD module] v 1.27
Set mode to : SPD6531
3. Insert battery
Phone found! [ 10 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Format Block Done!
Done!
Elapsed: 00:00:11
Old 09-30-2018, 10:42   #53639 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 924
Qmobile m95 hang on logo done by cm2
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : SC77xx Infinity Package
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
Phone found! [ 19 ]
Port Opened
Sync...
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC773x Android 5.x eMMC v1.0 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
[FL] : Enabled NVM update. Will program all NVM images found in FW !
PMTManager : Load 0x17 records
PMTManager : PMT Update Ok!
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write FSImage : prodnv.img
Write Data ...
Write Data Ok!
Update NVM image : nvitem.bin
Update NVM Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Erase block ...
Block erase Ok!
Update NVM image : nvitem_wcn.bin
Update NVM Data Ok!
Erase block ...
Block erase Ok!
Erase block ...
Block erase Ok!
Write CodeData : sc7731g_CP0_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Write CodeData : sc8830g_modem_CP2_WCN_14D_W15.16_Release.bin
Write Data ...
Write Data Ok!
Write CodeData : logo_540x960.bin
Write Data ...
Write Data Ok!
Write CodeData : fblogo_540x960.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system.img
Write Data ...
Write Data Ok!
Write FSImage : cache.img
Write Data ...
FSImage : Make and Flush SPImage
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Process : Flush
Flush Ok!
Write FSImage : userdata.img
Write Data ...
Write Data Ok!
Elapsed: 00:04:19
Old 09-30-2018, 11:30   #53640 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,026
Arrow mobiistar_C1 FRP Reset Done
Operation : Identify [ v2.00 r4 ]
PTFN : MediaTek USB Port_V1632 (COM37)
MODE : BOOTROM
PORT : 37
BROM : Init BROM
BROM init passed!
     CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
BROM : BOOTROM
MODE : 0_base : BASE_v1816 | Manual : Disabled
AGENT : Found MT6739
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : CNT : 0003
        DRAM: 0x80000000 [ 2.00 GB ]
        EMMC: 150100514536334D4203669690465523
        EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE63MB
        EMMC:
              USER   : 0x3A3E00000 [ 14.56 GB ]
        CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : 3E5B82BA1C122E1B13113E3279E4C384
DA : USB : HIGH-SPEED
Boot done!
Patch Level    : O11019
Display ID     : Mobiistar_C1_IN_V1.14
Ver. CodeName  : REL
Ver. Release   : 8.1.0
Sec. Patch     : 2018-05-05
Build Time     : 1534858986
Product Model  : mobiistar C1
Product Brand  : mobiistar
Product Name   : mobiistar_C1
Product Device : mobiistar_C1
Product Board  : mobiistar
Product Manfct : mobiistar
Product Info   : mobiistar_C1
Product Board  : k39tv1_bsp
Board Platform : mt6739
USERDATA : ENCRYPTED
Done!
Elapsed: 00:00:18
Operation : Reset Settings/Format FS [ v2.00 r4 ]
MODE : BOOTROM
PORT : 37
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : DA sent
     DA : AGENT started!
DA : SYNC
     DA : MODE : BROM
     EMI : CNT : 0003
        EMMC:
Boot done!
Done!
Elapsed: 00:00:17
The Following 2 Users Say Thank You to VIJAY2U2 For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-29-2010 21:17
Page generated in 0.82553 seconds with 9 queries
