Old 09-30-2018, 15:09   #53641 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 924
Qmobile s2 reset pattern done by cm2
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A483847316505075D834500B28F
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A483847316505075D834500B28F
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0x0B9C44DED8622FCF4569204CEA3C2555
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:52
Reconnect Power/Cable!
Old 09-30-2018, 15:17   #53642 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 924
Calme c760 illegal use error done by cm2
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
==== Wait for phone...
Phone found! [ 18 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00EF 0040 0016 0000
[0] Flash VEN : Winbond , W25Q32
[0] Flash CAP : 00400000
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:47
Old 09-30-2018, 15:19   #53643 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 924
Qmobile d3 illegul use error done by cm2
3. Insert battery
Phone found! [ 18 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Format Block Done!
Done!
Elapsed: 00:00:10
Old 09-30-2018, 15:49   #53644 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 14,742
Smile Qmobile D2 Format Done
Operation : Format FileSystem [ v1.03 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Infinity SCR SC6531E Loader v 1.2
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ]
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_078 09C36DC3F_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:22
The Following 3 Users Say Thank You to Akhtar Ali Jatt For This Useful Post:
Old 09-30-2018, 16:01   #53645 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,127
Qmobile Z8 QLM Invalid Imei Fix Only FLashing With Infinity CM2
Card found : A19EC787 , v0137
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.14
Loading firmware ...
Loading 1 program definition file(s) ...
Load Ok!
Operation : Flash [ v1.14 ]
ForceFlashing : Disabled
Verify FW package ...
Verification passed!
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 00E190A7
ID_BLOCK_I : 007050E1
ID_BLOCK_L : 3CC4BE58F763689B4439DBC4035ED6F6
ID_BLOCK_L : B8CB75D4D948F27396612AE3E10C1A21
Pickup loader from firmware package
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Flash Chain : 175
Flashing now
Flashing : NON-HLOS.bin
Flashing : sbl1.mbn
Flashing : sbl1.mbn
Flashing : emmc_appsboot.mbn
Flashing : rpm.mbn
Flashing : rpm.mbn
Flashing : tz.mbn
Flashing : tz.mbn
Flashing : hyp.mbn
Flashing : hyp.mbn
Flashing : misc.img
Flashing : splash.img
Flashing : chglogo.img
Flashing : sec.dat
Flashing : boot.img
Flashing : system_1.img
Flashing : system_2.img
Flashing : system_3.img
Flashing : system_4.img
Flashing : system_5.img
Flashing : system_6.img
Flashing : system_7.img
Flashing : system_8.img
Flashing : system_9.img
Flashing : system_10.img
Flashing : system_11.img
Flashing : system_12.img
Flashing : system_13.img
Flashing : system_14.img
Flashing : system_15.img
Flashing : system_16.img
Flashing : system_17.img
Flashing : system_18.img
Flashing : system_19.img
Flashing : system_20.img
Flashing : system_21.img
Flashing : system_22.img
Flashing : system_23.img
Flashing : system_24.img
Flashing : system_25.img
Flashing : system_26.img
Flashing : system_27.img
Flashing : system_28.img
Flashing : system_29.img
Flashing : system_30.img
Flashing : system_31.img
Flashing : system_32.img
Flashing : system_33.img
Flashing : persist_1.img
Flashing : cache_1.img
Flashing : cache_2.img
Flashing : cache_3.img
Flashing : cache_4.img
Flashing : cache_5.img
Flashing : recovery.img
Flashing : userdata_1.img
Flashing : userdata_2.img
Flashing : userdata_3.img
Flashing : userdata_4.img
Flashing : userdata_5.img
Flashing : userdata_6.img
Flashing : userdata_7.img
Flashing : userdata_8.img
Flashing : userdata_9.img
Flashing : userdata_10.img
Flashing : userdata_11.img
Flashing : userdata_12.img
Flashing : userdata_13.img
Flashing : userdata_14.img
Flashing : userdata_15.img
Flashing : userdata_16.img
Flashing : userdata_17.img
Flashing : userdata_18.img
Flashing : userdata_19.img
Flashing : userdata_20.img
Flashing : userdata_21.img
Flashing : userdata_22.img
Flashing : userdata_23.img
Flashing : userdata_24.img
Flashing : userdata_25.img
Flashing : userdata_26.img
Flashing : userdata_27.img
Flashing : userdata_28.img
Flashing : userdata_29.img
Flashing : userdata_30.img
Flashing : userdata_31.img
Flashing : userdata_32.img
Flashing : userdata_33.img
Flashing : userdata_34.img
Flashing : userdata_35.img
Flashing : userdata_36.img
Flashing : userdata_37.img
Flashing : userdata_38.img
Flashing : userdata_39.img
Flashing : userdata_40.img
Flashing : userdata_41.img
Flashing : userdata_42.img
Flashing : userdata_43.img
Flashing : userdata_44.img
Flashing : userdata_45.img
Flashing : userdata_46.img
Flashing : userdata_47.img
Flashing : userdata_48.img
Flashing : userdata_49.img
Flashing : userdata_50.img
Flashing : userdata_51.img
Flashing : userdata_52.img
Flashing : userdata_53.img
Flashing : userdata_54.img
Flashing : userdata_55.img
Flashing : userdata_56.img
Flashing : userdata_57.img
Flashing : userdata_58.img
Flashing : userdata_59.img
Flashing : userdata_60.img
Flashing : userdata_61.img
Flashing : userdata_62.img
Flashing : userdata_63.img
Flashing : userdata_64.img
Flashing : userdata_65.img
Flashing : userdata_66.img
Flashing : userdata_67.img
Flashing : userdata_68.img
Flashing : userdata_69.img
Flashing : userdata_70.img
Flashing : userdata_71.img
Flashing : userdata_72.img
Flashing : userdata_73.img
Flashing : userdata_74.img
Flashing : userdata_75.img
Flashing : userdata_76.img
Flashing : userdata_77.img
Flashing : userdata_78.img
Flashing : userdata_79.img
Flashing : userdata_80.img
Flashing : userdata_81.img
Flashing : userdata_82.img
Flashing : userdata_83.img
Flashing : userdata_84.img
Flashing : userdata_85.img
Flashing : userdata_86.img
Flashing : userdata_87.img
Flashing : userdata_88.img
Flashing : userdata_89.img
Flashing : userdata_90.img
Flashing : userdata_91.img
Flashing : userdata_92.img
Flashing : userdata_93.img
Flashing : userdata_94.img
Flashing : userdata_95.img
Flashing : userdata_96.img
Flashing : userdata_97.img
Flashing : userdata_98.img
Flashing : userdata_99.img
Flashing : userdata_100.img
Flashing : userdata_101.img
Flashing : userdata_102.img
Flashing : userdata_103.img
Flashing : userdata_104.img
Flashing : userdata_105.img
Flashing : gpt_main0.bin
Flashing : gpt_backup0.bin
Flash sequence completed!
Applying patches for storage # 0
Records : 26
Patch sequence completed!
BootConfig set to 0x00
Flashing done!
Done!
Elapsed: 00:06:14
Old 09-30-2018, 17:22   #53646 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,424
First In The World Jazz Digit 1 PinLock Remove
Read Info
Operation : Identify [ v1.16 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon Mobile 205 [MSM8905]
ID_BLOCK_S : 0D258533
ID_BLOCK_L : B0B02AD483EF1417F0A5AFB07FCA4A82
ID_BLOCK_L : FC973990850CBE37CA256EA7AD405E7D
Use CM2 Internal Loader
Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000000E9000000 [ eMMC 4 GiB ]
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Boot Ok!
Brand     : JAZZ
ProdName  : jazz
ProdModel : Digit1
Device    : msm8909_512
AndroidVer: 4.4.4
Manufact. : JAZZ
SysPatch  : KTU84P
DevComTime: 3/26/2018 10:50:53 AM
QLMxCPU   : MSM8909
QLMxPRJ   : JAZZ_Q8905A_1812_V110T_PK_20180326-1850
USERData : NORMAL
GCSec    : NORMAL
Done!
Elapsed: 00:00:16
Format
Operation : Reset Settings [ v1.16 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:40
Old 09-30-2018, 17:26   #53647 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,424
Read Info
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Brand     : JAZZ
ProdName  : jazz
ProdModel : Digit1
AndroidVer: 4.4.4
Manufact. : JAZZ
SysPatch  : KTU84P
QLMxCPU   : MSM8909
USERData : NORMAL
GCSec    : NORMAL
Done!
Elapsed: 00:00:16
Format
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:40
Old 09-30-2018, 17:40   #53648 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,127
Qmobile X700 Pro Lite MT6580 FRP Reset Done With King Infinity CM2
Card found : S/N : A19EC787 , v0137
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A4838473165050755E5367893E7
[eMMC] : FLASH_CID : 90014A4838473165050755E5367893E7
DEV RID : 0xD9C8F395F05D0EF701EC000F118C2ED5
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:13
Old 09-30-2018, 17:57   #53649 (permalink)
YMS-RYK's Avatar
Member: 1489718
Sonork: 100.1652829 QQ 3237590752
Thanks Meter: 1,478
vgotel i251 spd 6531e read file & format done with king box cm2
Read Flash File
Operation : Read Flash [ v1.03 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ]
Read Ok, 4194304 bytes
Saved to : C:\Users\YASIR ADNAN\Desktop\SPRD_SPI_WINBOND_W25Q_4MiB.bin
Done!
Elapsed: 00:01:03
Format
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_0869E6437862_NVM.nv
Format FFS Done!
Done!
Elapsed: 00:00:25
The Following 2 Users Say Thank You to YMS-RYK For This Useful Post:
Old 10-01-2018, 07:25   #53650 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 924
Meizu m5 reset frp done by cm2
Operation : Reset Settings/Format FS [ v2.00 r4 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM (Android) (COM25)
MODE : PRELOADER PORT
PORT : 25
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000007
BROM : SecMode : SBC+SLA+SDA
BROM : PRELOADER PORT
MODE : Meizu : M3s_M5n_U10 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : DA_PL.bin
AGENT : Found MT6755
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : PRELOADER
DA : EXT_RAM initialized!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00040000 [ 256.00 KB ]
DRAM: 0x80000000 [ 2.00 GB ]
EMMC: 150100514531334D420DA4D7B88DC333
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE13MB
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x3A3E00000 [ 14.56 GB ]
CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0008 , EVOL : 0x0000
RNID : A4C66C24F813E599A78C8580317A04DC
DA : USB : HIGH-SPEED
Boot done!
Format Ok : USERDATA
Format Ok : CACHE
Format Ok : RESET PROTECTION
Format Ok : PRIVACY
Done!
Elapsed: 00:00:34
Old 10-01-2018, 07:39   #53651 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 924
Vivo y65 reset pattern done by cm2
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 425 [MSM8917]
ID_BLOCK_S : 90F08057
ID_BLOCK_L : C01F04DF4ACD0240DC1C5CBE5A41F58E
ID_BLOCK_L : A9EE649B6999D86968E51B2483093C7E
Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ]
Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : GE6BMB
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:34
Old 10-01-2018, 08:18   #53652 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,127
Lenovo A319 MT6572 Dead Set Re Alive Done With Infinity CM2
Scatter Load Ok , BaseBand : MT6572 , Project : huaqin72_cwet_1a_kk , Storage : EMMC
Files found : 11 , Set to Flash : 10
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 90014A48344732611101BA11B0AB82BD
[eMMC] : FLASH_INF : [HYNIX] , a2G4
[eMMC] : FLASH_CID : 90014A48344732611101BA11B0AB82BD
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xD9C8F3952EE111907AAB4EE0FED8C207
EXT RAM : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : huaqin72_cwet_1a_kk , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3702 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x0000000094840000
Flash Pre-Erase Done, time used : 00:00:03
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_huaqin72_cwet_1a_kk.bin
Preloader Sent , Init passed
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:04:43
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:01:10
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:06:13
Old 10-01-2018, 08:42   #53653 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,127
Qmobile L7 SPD6531 Illegal use Done Only Formate With Infinity CM2
Card found: S/N : A19EC787 , v0137
Chinese Miracle II [SPD module] v 1.27
Set mode to : SPD6531
3. Insert battery
Phone found! [ 10 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
Format Block Done!
Done!
Elapsed: 00:00:09
Old 10-01-2018, 09:09   #53654 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,127
Qmobile I9 MT6582 Hanging Probelam Fix Only Formate With Infinity CM2
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x87
eMMC Flash : 11010030303447393051D3CB6289616D
[eMMC] : FLASH_VEN : 0x11 , OEM : 0100
[eMMC] : FLASH_INF : [TOSHIBA] , 09G40
[eMMC] : FLASH_CID : 11010030303447393051D3CB6289616D
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000
[eMMC] : FLASH_LEN : 0x00000000EC000000
[eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB]
DEV RID : 0xD9C8F3958C906D2CAF0D8B2C369E824C
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:19
Old 10-01-2018, 10:20   #53655 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 924
Qmobile x30 hang on logo done by cm2
Scatter Load Ok , BaseBand : MT6572 , Project : s4050ap , Storage : EMMC
Ready to Flash!
======= Flash
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A483447326111019FC681956211
[eMMC] : FLASH_CID : 90014A483447326111019FC681956211
DEV RID : 0x0B9C44DE07789D1A30F7A1F2FA6EE6FC
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC
BL : BatteryLevel : 3772 mV
Erase : 0x0000000002900000-0x00000000E5E00000
Flash Pre-Erase Done, time used : 00:00:02
Use : preloader_s4050ap.bin
PartCount : 0012
Repartition Done!
Use FLN Mode
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:52
Processing : Verify
Verify Passed : MBR
Data Verify Done, time used : 00:00:40
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:54
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-29-2010 21:17
Page generated in 0.90011 seconds with 9 queries
