Old 10-02-2018, 09:05   #53671 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Qmobile lt550 reset pattern done by cm2
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 19 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC9832 eMMC LoaderV1 (c) Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:36
Reconnect Power/Cable!
Old 10-02-2018, 09:59   #53672 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Jazz js2 reset frp done by cm2
3. Insert cable
Phone found! [ 19 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v1.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Reset Ok!
Done!
Elapsed: 00:00:25
Old 10-02-2018, 10:35   #53673 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 14,775
Smile Qmobile W15 FullFlash Done
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : QMobile_W15_MP_19_11.pac
CRVersion  : BP_R1.0.0
PacCPUinfo : SC77xx
PacVersion : QMobile_W15_MP_29_10
File : fdl1.bin
File : fdl2.bin
File : nvitem.bin
File : nvitem_wcn.bin
File : u-boot-spl-16k.bin
File : SC7702_sc7731g_band128.bin
File : DSP_DM_G2.bin
File : SC8800G_x30g_wcn_dts_modem.bin
File : boot.img
File : recovery.img
File : system.img
File : userdata.img
File : LOGO.bmp
File : charge.bmp
File : prodnv.img
File : cache.img
File : u-boot.bin
3. Insert cable
Phone found! [ 268 ]
Port Opened
Sync...
Sync...
Sending FDL
PickUp loaders from pac
FDL Ready!
Boot Ver : Spreadtrum Boot Block version 1.1
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x17 records
PMTManager : PMT Update Ok!
Flashing now
[FlashProc] : ERASE
Current ID   : ERASEUBOOT
Current Part : uboot
[FlashProc] : Ok!
[FlashProc] : BOOTCODE
Current ID   : SPLLOADER
Current File : u-boot-spl-16k.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_W
Current File : SC7702_sc7731g_band128.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : DSP_W
Current File : DSP_DM_G2.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_WCN
Current File : SC8800G_x30g_wcn_dts_modem.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOT
Current File : boot.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : RECOVERY
Current File : recovery.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : SYSTEM
Current File : system.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : USERDATA
Current File : userdata.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOTLOGO
Current File : LOGO.bmp
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : FASTBOOT_LOGO
Current File : charge.bmp
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : FLASH
Current Part : wruntimenv1
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : FLASH_WCN
Current Part : wcnruntimenv1
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : PRODNV
Current File : prodnv.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : CACHE
Current File : cache.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID   : ERASEMISC
Current Part : misc
[FlashProc] : Ok!
Current ID   : UBOOTLOADER
Current File : u-boot.bin
Flashing now ...
[FlashProc] : Ok!
Elapsed: 00:02:56
The Following 2 Users Say Thank You to Akhtar Ali Jatt For This Useful Post:
Old 10-02-2018, 10:36   #53674 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,131
Qmobile I6 Metal One MT6580 FRP Reset Done With King Infinity CM2
Card found : S/N : A19EC787 , v0137
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 28 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A483847316505072AD4D220248B
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A483847316505072AD4D220248B
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xD9C8F3951D4132F64C8E2F39697FC55E
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:14
Old 10-02-2018, 10:43   #53675 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Qmobile X30 FullFlash Done
Scatter Load Ok , BaseBand : MT6572 , Project : s4050ap , Storage : EMMC
Files found : 11 , Set to Flash : 10
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 434 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 90014A48344732611101D5715EE2129F
[eMMC] : FLASH_INF : [HYNIX] , a2G4
[eMMC] : FLASH_CID : 90014A48344732611101D5715EE2129F
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID    : 0xE6C52A7D4FBB352EFC867D5207357DD1
EXT RAM    : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC
Setting : AFF verify :  Disabled
Setting : HW verify :  Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3393 mV
BL : [WARNING] : BatteryLevel LOW!!!
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x00000000E5E00000
Flash Pre-Erase Done, time used : 00:00:00
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_s4050ap.bin
Preloader Sent , Init passed
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:58
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:20
Old 10-02-2018, 11:45   #53676 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Qmobile s4 clear user locks done by cm2
Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.58 ]
Wait for phone...
Phone found! [ 25 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 150100513832334D420090B09070831F
[eMMC] : FLASH_INF : [SAMSUNG] , BM328
[eMMC] : FLASH_CID : 150100513832334D420090B09070831F
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0x0B9C44DE0803296422F5AE867C9C1A64
EXT RAM : 0x80000000 [2 GiB]
SOC VERIFY : C1
Boot Ok!
LSSDB Ok!
LSSWL Ok!
LSSSH Ok!
LSSNG Ok!
LSSNP Ok!
Security Settings : Clear Ok!
[Info] : That feature NOT RESET "PRIVACY PASSWORD LOCK"! Use separate button!
[Info] : That feature NOT RESET "FRP/GoogleLOCK"! Use separate "FRP" reset!
[Info] : If phone stuck on "Logo" :
1. Wait 2-3 minutes. Power Off phone by long press "Power" button
2. Power On phone again
3. Or wait up to 3-7 minutes, until phone start by itself
4. Also recommended reboot phone twice before start use it
Done!
Elapsed: 00:00:17
Old 10-02-2018, 11:47   #53677 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Qmobile m88 hang on logo done by cm2
3. Insert cable
Phone found! [ 19 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v3 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
UserData : PART_MOUNT failed! Part Damaged! Will use Repair Mode!
Mount : /cache
State : 0x0001
Done!
Elapsed: 00:00:20
Old 10-02-2018, 11:48   #53678 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Qmobile m2 reset password done by cm2
Operation : Format FileSystem [ v1.03 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Infinity SCR SC6531E Loader v 1.2
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ]
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_1F9 933925818_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:19
Old 10-02-2018, 13:54   #53679 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,131
Lenovo A6000 QLM FRP Reset Done With King Infinity CM2
Card found : A19EC787 , v0137
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.14
Operation : Reset Settings [ v1.14 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 079C6AEE
ID_BLOCK_I : 007050E1
ID_BLOCK_L : FB0D679F3EA4D1DC8BE0107DBA811139
ID_BLOCK_L : 770EB01B1C8737BC519CF12E24CBE5E6
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:12
Old 10-02-2018, 14:19   #53680 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,131
Mango Kig 2SCR SPD Logo Stuck Fix Only Formate With Infinity CM2
1. Power off device
Wait for device ...
Device not found!
Remove battery, cable. Check cable and connection. Repeat operation!
1. Power off device
Wait for device ...
Device Connected!
ERROR : Protocol HandShake failed!
Error : Fail to init protocol!
1. Power off device
Wait for device ...
Device not found!
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
ERROR : FDL NOT started!
Error : Loader send failed!
Wrong model selected! Select correct one!
SPRD mode : SC6531 : REV : C000 : NOR
1. Power off device
Wait for device ...
Device Connected!
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootVersion : Spreadtrum Boot Block version 1.2
Port speed : 921600
Boot Done!
CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ]
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_009 554ADAB0C_NVM.nv
Format FFS Done!
Done!
Elapsed: 00:00:18
Old 10-02-2018, 14:42   #53681 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,131
Haier IRON MT6580 FRP Reset Done With King Infinity CM2
Wait for phone...
Phone found! [ 28 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 150100523331314D42000CCBFA37C16F
[eMMC] : FLASH_INF : [SAMSUNG] , BM113
[eMMC] : FLASH_CID : 150100523331314D42000CCBFA37C16F
[eMMC] : FLASH_LEN : 0x00000003AB400000
[eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB]
DEV RID : 0xD9C8F395C80A1CD0F5EB437F33D5E66D
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:11
Old 10-02-2018, 15:13   #53682 (permalink)
Member: 895181
Sonork: 13579
Thanks Meter: 2
vivo v9 pd1723 pattern,frp remove success cm2
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 625 [MSM8953]
ID_BLOCK_S : C59D00F0
ID_BLOCK_L : 5984AF46D154EDB945B7C559B5E85C17
ID_BLOCK_L : 763BB144BC466DD6BF08C89936DED3A9
Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ]
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RH64AB
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:24
Old 10-02-2018, 15:50   #53683 (permalink)
Member: 2125922
Sonork: 1601402
Thanks Meter: 102
OALE X3 FORMATE DONE WITH CM2 MTK
Wait for phone...
Phone found! [ 67 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : F501004D4D4331364708007513056483
[WARNING] : MEMORY_eMMC_VALIDATE_FAILED
[eMMC] : FLASH_VEN : 0xF5 , OEM : 0100
[eMMC] : FLASH_INF : [NOT_IN_BASE] , G61CM
[eMMC] : FLASH_CID : F501004D4D4331364708007513056483
[eMMC] : FLASH_LEN : 0x0000000390000000
[eMMC] : FLASH_UCP : 14592 MiB [eMMC 16 GiB]
DEV RID : 0xA951A0A90565D6FE582281F2D10B4E76
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:48
Old 10-02-2018, 16:35   #53684 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,131
Qmobile E400 Pro SPD6531 Illegal Use Only Fix Formate With Infinity CM2
Card found: S/N : A19EC787 , v0137
Chinese Miracle II [SPD module] v 1.27
Set mode to : SPD6531
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
Phone found! [ 10 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00C8 0060 0016 0000
[0] Flash VEN : GigaDevice , GD25LQ32
[0] Flash CAP : 00400000
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:07
Old 10-02-2018, 17:40   #53685 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,131
Qorld First Qmobile J1 MT6737 FRP Done By Singel Click With Infinity CM2
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
SecCfgVal : 0x01000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00
Running DA ver.4.2 on BBID : 0x9B
eMMC Flash : 484A0190613447387758A532BF010484
[eMMC] : FLASH_INF : [HYNIX] , 2a4G8
[eMMC] : FLASH_CID : 90014A483847346132A55877840434BF
DEV RID : 0xD9C8F395FD7660B3AB82CABD8FE09F53
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:13
Download Da File
Qmobile+J1+Da+File+MT6737.rar
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-29-2010 21:17
Page generated in 0.87894 seconds with 9 queries
