12-22-2018, 07:23 | #55546 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dera Ismail Khan (KPK) Pak
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | TA-1034Urdu done Description : TA-1034 IJ DeviceType : TA-1034 ProductCode : 059Z0X8 SoftwareVer : 30.04.11 PPM LangPack : [1] : Urdu (Islamic Republic of Pakistan) [2] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.09 ] Setting : UserData erase : False Setting : LangPack Only : True 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM Port (COM115) MODE : NOKIA USB SERIAL PORT : 115 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 8D8DAAD3C119408C37AD41C6D4F47666 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.30.04.11.p1 BOOT : SWR : 30.04.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : N103.30.04.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8E NOR: 00EF : 0070 : 0016 : 0000 NOR: [Winbond] SF_W25Q32JV NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 30.04.11 [TA-1034] DEV SoftwareVersion : 30.04.11 SWInfo compare result : SAME Load FlashSet : LANG : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001 CUST : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001 JUMP : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001 Prepare FlashSet : DCR : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001 DCR : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001 DCR : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 Erase Target Flash Erase done! Write Target Flash Write : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001 Write : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001 Write : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001 Verify : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001 Verify : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001 Done! Elapsed: 00:00:39 Reconnect Power/Cable! |
12-22-2018, 07:28 | #55547 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Venture_V12 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 460001154D32364563BB0342513FFFD4 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM26E [eMMC] : FLASH_CID : 150100464536324D4203BB63D4FFB451 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x0CF2E6DE22ADD7A00069784DF80FC164 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : VGOTEL ProdName : Venture_V12 ProdModel : Venture V12 Device : Venture_V12 AndroidVer: 7.0 MTKxCPU : MT6737M MTKxPRJ : alps-mp-n0.mp1-V1.0.2_vs6737m.35.n_P66 Done! Elapsed: 00:00:06 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 460001154D32364563BB0342513FFFD4 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM26E [eMMC] : FLASH_CID : 150100464536324D4203BB63D4FFB451 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x0CF2E6DE22ADD7A00069784DF80FC164 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:37 Reconnect Power/Cable! |
12-22-2018, 07:31 | #55548 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Qmobile i6i F.R.p Done Operation : Reset Settings/Format FS [ v2.02 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM608) MODE : PRELOADER PORT PORT : 608 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 460001154D37324AA8D202429383189A DAInf: 4 : 2 : 156 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464A32374D4202D2A89A188393 EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FJ27MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0xE9000000 [ 3.64 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x30000000 [ 768.00 MB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 84254BD58105B2B711A7EF31959BBC20 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Done! Elapsed: 00:00:30 Reconnect Power/Cable! |
12-22-2018, 08:34 | #55549 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Rm839 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Resetting selected items... Operating mode is OK, no need change... Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:05 |
12-22-2018, 08:39 | #55550 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Rm-632 Phone found! Series 60 Device detected! read info... - Ok Operating mode is OK, no need change... Reading Product Profile sets... 0 - 127 1 - 0 4 - 0 7 - 1 9 - 0 34 - 0 35 - 1 56 - 0 61 - 0 65 - 0 66 - 0 69 - 1 70 - 0 71 - 1 73 - 2 78 - 0 79 - 1 100 - 1 130 - 5 131 - 7 135 - 0 138 - 0 139 - 1 145 - 0 146 - 0 147 - 0 156 - 1 157 - 1 158 - 1 164 - 0 165 - 0 166 - 0 168 - 0 177 - 0 183 - 0 192 - 0 202 - 4 205 - 0 206 - 0 211 - 0 212 - 0 214 - 0 217 - 0 219 - 1 220 - 0 228 - 0 SETS 1 Readed 46 element(s) Saved as C:\InfinityBox\BEST\RM-632 Nokia E5-00_352023040198570.pp Done! Elapsed: 00:00:00 Reading PM from field 0 to 400 Field [1] 28 Record(s) Record 0: 114 byte(s) readed - Ok Record 2: 10 byte(s) readed - Ok Record 4: 110 byte(s) readed - Ok Record 6: 10 byte(s) readed - Ok Record 7: 214 byte(s) readed - Ok Record 8: 110 byte(s) readed - Ok Record 13: 10 byte(s) readed - Ok Record 16: 208 byte(s) readed - Ok Record 18: 208 byte(s) readed - Ok Record 20: 208 byte(s) readed - Ok Record 22: 16 byte(s) readed - Ok Record 23: 4 byte(s) readed - Ok Record 24: 84 byte(s) readed - Ok Record 26: 110 byte(s) readed - Ok Record 28: 10 byte(s) readed - Ok Record 29: 10 byte(s) readed - Ok Record 31: 208 byte(s) readed - Ok Record 33: 36 byte(s) readed - Ok Record 34: 376 byte(s) readed - Ok Record 35: 16 byte(s) readed - Ok Record 37: 4 byte(s) readed - Ok Record 39: 36 byte(s) readed - Ok Record 40: 16 byte(s) readed - Ok Record 41: 182 byte(s) readed - Ok Record 42: 4 byte(s) readed - Ok Record 43: 36 byte(s) readed - Ok Record 44: 182 byte(s) readed - Ok Record 45: 182 byte(s) readed - Ok Field [2] 1 Record(s) Record 0: 2080 byte(s) readed - Ok Field [4] 9 Record(s) Record 1: 1020 byte(s) readed - Ok Record 3: 10 byte(s) readed - Ok Record 4: 8 byte(s) readed - Ok Record 5: 8 byte(s) readed - Ok Record 6: 8 byte(s) readed - Ok Record 9: 5 byte(s) readed - Ok Record 18: 80 byte(s) readed - Ok Record 19: 4 byte(s) readed - Ok Record 28: 2 byte(s) readed - Ok Field [6] 1 Record(s) Record 0: 32 byte(s) readed - Ok Field [8] 10 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 16 byte(s) readed - Ok Record 2: 16 byte(s) readed - Ok Record 3: 128 byte(s) readed - Ok Record 4: 128 byte(s) readed - Ok Record 5: 8 byte(s) readed - Ok Record 7: 4 byte(s) readed - Ok Record 8: 8 byte(s) readed - Ok Record 9: 8 byte(s) readed - Ok Record 10: 32 byte(s) readed - Ok Field [11] 5 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 4 byte(s) readed - Ok Record 2: 4 byte(s) readed - Ok Record 3: 4 byte(s) readed - Ok Record 4: 1058 byte(s) readed - Ok Field [12] 1 Record(s) Record 0: 102 byte(s) readed - Ok Field [26] 2 Record(s) Record 0: 16 byte(s) readed - Ok Record 1: 68 byte(s) readed - Ok Field [31] 1 Record(s) Record 4: 8 byte(s) readed - Ok Field [44] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [50] 3 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 22 byte(s) readed - Ok Record 2: 22 byte(s) readed - Ok Field [54] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 2: 24 byte(s) readed - Ok Field [88] 1 Record(s) Record 0: 36 byte(s) readed - Ok Field [96] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 20 byte(s) readed - Ok Field [107] 6 Record(s) Record 0: 41 byte(s) readed - Ok Record 1: 89 byte(s) readed - Ok Record 2: 89 byte(s) readed - Ok Record 3: 70 byte(s) readed - Ok Record 25: 236 byte(s) readed - Ok Record 26: 12 byte(s) readed - Ok Field [117] 11 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 3 byte(s) readed - Ok Record 2: 6 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Record 4: 9 byte(s) readed - Ok Record 5: 10 byte(s) readed - Ok Record 6: 8 byte(s) readed - Ok Record 8: 42 byte(s) readed - Ok Record 13: 3 byte(s) readed - Ok Record 14: 3 byte(s) readed - Ok Record 16: 40 byte(s) readed - Ok Field [120] 4 Record(s) Record 0: 944 byte(s) readed - Ok Record 1: 160 byte(s) readed - Ok Record 2: 130 byte(s) readed - Ok Record 3: 112 byte(s) readed - Ok Field [153] 7 Record(s) Record 0: 68 byte(s) readed - Ok Record 1: 68 byte(s) readed - Ok Record 2: 68 byte(s) readed - Ok Record 3: 68 byte(s) readed - Ok Record 4: 68 byte(s) readed - Ok Record 5: 68 byte(s) readed - Ok Record 6: 68 byte(s) readed - Ok Field [193] 4 Record(s) Record 2: 8 byte(s) readed - Ok Record 3: 32 byte(s) readed - Ok Record 4: 32 byte(s) readed - Ok Record 9: 64 byte(s) readed - Ok Field [217] 1 Record(s) Record 0: 32 byte(s) readed - Ok Field [239] 18 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 3284 byte(s) readed - Ok Record 2: 3284 byte(s) readed - Ok Record 3: 3284 byte(s) readed - Ok Record 4: 3284 byte(s) readed - Ok Record 5: 3284 byte(s) readed - Ok Record 6: 3284 byte(s) readed - Ok Record 7: 3284 byte(s) readed - Ok Record 8: 3284 byte(s) readed - Ok Record 9: 3284 byte(s) readed - Ok Record 10: 3284 byte(s) readed - Ok Record 11: 3284 byte(s) readed - Ok Record 12: 3284 byte(s) readed - Ok Record 13: 3284 byte(s) readed - Ok Record 14: 3284 byte(s) readed - Ok Record 15: 3284 byte(s) readed - Ok Record 16: 3284 byte(s) readed - Ok Record 21: 218 byte(s) readed - Ok Field [291] 1 Record(s) Record 0: 92 byte(s) readed - Ok Field [308] 7 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 8192 byte(s) readed - Ok Record 3: 1 byte(s) readed - Ok Record 4: 1 byte(s) readed - Ok Record 6: 1 byte(s) readed - Ok Record 7: 1 byte(s) readed - Ok Record 9: 40 byte(s) readed - Ok Field [309] 7 Record(s) Record 0: 4 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Record 2: 12 byte(s) readed - Ok Record 3: 36 byte(s) readed - Ok Record 4: 12 byte(s) readed - Ok Record 7: 12 byte(s) readed - Ok Record 17: 12 byte(s) readed - Ok Field [313] 1 Record(s) Record 0: 173 byte(s) readed - Ok Field [322] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [327] 1 Record(s) Record 0: 2 byte(s) readed - Ok Field [329] 1 Record(s) Record 0: 8392 byte(s) readed - Ok Field [334] 1 Record(s) Record 0: 1 byte(s) readed - Ok Field [341] 3 Record(s) Record 0: 1 byte(s) readed - Ok Record 3: 4 byte(s) readed - Ok Record 4: 4518 byte(s) readed - Ok Field [354] 1 Record(s) Record 0: 15 byte(s) readed - Ok Field [356] 2 Record(s) Record 0: 2 byte(s) readed - Ok Record 1: 8 byte(s) readed - Ok Field [360] 3 Record(s) Record 0: 1 byte(s) readed - Ok Record 1: 2 byte(s) readed - Ok Record 2: 3 byte(s) readed - Ok Field [369] 1 Record(s) Record 0: 40 byte(s) readed - Ok Saved as C:\InfinityBox\BEST\Backup\RM-632 Nokia E5-00_352023040198570_0_400.pm Done! Elapsed: 00:00:02 Reading Phone Info.... Connected phone - Nokia E5-00 Software ver : V ICPR82_11w16.3.13 15-06-12 RM-632 (c) Nokia IMEI : 352023040198570 XappVer : 000008F2 Ape Ver : 101.003 APE Var : 101.003101.003.25.01101.003.C00.01 APE ADSP: 256 DSP Ver : 12w24 APE Test: 0.025 PPM : CNT : Product SN : CWD914313 Product code : 0595791 Base Prd.code: 0590165 Module code : 0204475 Long Prod.SN : 0 Hardware info======= HWID : 1000 Retu : 35 Tahvo : 00 Battery: 4007 mV APE HW: 256 Lock info =========== IMEI : 352023040198570 IMEI spNet : 3A 25 20 03 04 91 58 07 IMEI svNet : 33 25 20 03 04 91 58 37 F0 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= Error collect lock info, try again CRT308 Backup Created SDD key status : Ok CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Resetting selected items... Check phone mode... Phone in Local mode Seting Test mode... wait... Test mode set Settings Full Factory Defaults... Set OK! Settings Software Upgrade Defaults... Set OK! Settings Service Centre Defaults... Set OK! Settings Production Tune Defaults... Set OK! Settings User Data Defaults... Set OK! Settings Leave Factory defaults... Set OK! Elapsed: 00:00:08 Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Bad file : rm632_101.003_U004.000_prd.uda.fpsx Bad Flash files detected, will break procedure Core : v2.29 , BB5XG FlashEngine : v10.5 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm632_101.003_prd.core.fpsx PPM : rm632_101.003_28.01_MEA_C_prd.rofs2.fpsx PPM2 : rm632_101.003_C00.01_DEFAULT_prd.rofs3.fpsx Flashing phone now... [Gen] Rules accepted for : RAPUxx Generation Check files done... -> SWversion check skipped : Manual mode selected Backup CRT308 data... CRT308 Backup Created SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok Check communication with phone.... ADL req restart Communication verify done... Preparing... Gathering phone info... Check communication with phone... Reboot.... Connection opened successfully Waiting for communication response... [BootRom] : 1st boot Ok! ASIC ID: 000000030000022600010007600C192102031104 CPU ID : RAPU v11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 12200113C0910344C1FF3CE45770C14AF8F2F6D6 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B Use RAPUv11_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv11_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 352023040198570 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\352023040198570_2n d.rpl === SW Version Check === - > REFLASHING === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm632_101.003_prd.core.fpsx Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm632_101.003_prd.core.fpsx CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [SOS+PMML] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [SOS*UPDAPP] CMT: Writing Hash CERT [SOS*DSP0] CMT: Writing Hash CERT [LDSP] CMT: Writing Hash CERT [SOS*ISASW] CMT: Writing Hash CERT [SOS+CORE] CMT: Writing Hash CERT [SOS+ROFS1] Total writen 433 blocks TIME : Write time : 00:00:18 MCU Write done ADL: Request programm status NAND status : 00000005 / 00000005 / 00000000 ===Flashing [PPM]=== Erase : Processing rm632_101.003_28.01_MEA_C_prd.rofs2.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm632_101.003_28.01_MEA_C_prd.rofs2.fpsx CMT: Writing Hash CERT [SOS+ROFS2] Total writen 202 blocks TIME : Write time : 00:00:09 PPM Write done ADL: Request programm status NAND status : 00000005 / 00000005 / 00000000 ===Flashing [PPM2]=== Erase : Processing rm632_101.003_C00.01_DEFAULT_prd.rofs3.fpsx Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm632_101.003_C00.01_DEFAULT_prd.rofs3.fpsx CMT: Writing Hash CERT [SOS+ROFS3] Total writen 35 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000005 / 00000005 / 00000000 ADL: Close_Session Content: 000300000000050000000500000000 ADL: Reboot Flashing done! Total flash time : 00:00:31 Reboot phone now... Reading Phone Info.... Connected phone - Nokia E5-00 Software Info: V ICPR82_11w16.3.13 15-06-12 RM-632 (c) Nokia IMEI: 352023040198570 Ape Version: 101.003 Product code: 0595791 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:00:54 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok |
12-22-2018, 08:42 | #55551 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Disable Factory XT1767 Operation : Moto ADB Enable [ v1.03 ] Mode : Disable Factory Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Operation done! Done! Elapsed: 00:00:11 |
12-22-2018, 08:50 | #55552 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | QMobile M350 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 7001004548384345380112C679CD7387 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 8EC8H [eMMC] : FLASH_CID : 7001004548384345380112C679CD7387 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001C8000000 [eMMC] : FLASH_UCP : 7296 MiB [eMMC 8 GiB] DEV RID : 0x0CF2E6DE959B56A389BEE47B419CC99F INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : QMobile ProdName : QMobile M350 ProdModel : QMobile M350 Device : QMobile M350 AndroidVer: 5.1 MTKxCPU : MT6580 MTKxPRJ : ALPS.L1.MP6.V2_GINR6580.WE.L_P24 MODEM : BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V6_P3_1_wg_n EXTRA : LCD : Not info available LCD Res : 1280x720 TOUCH [0] : focaltech CAM [0] : s5k4h5yc_mipi_raw CAM [1] : ov8858_mipi_raw CAM [2] : ov5670_mipi_raw CAM [3] : hi551_mipi_raw MODEM : E150_WG_B18_Edge LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES en_IN Done! Elapsed: 00:00:18 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 7001004548384345380112C679CD7387 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 8EC8H [eMMC] : FLASH_CID : 7001004548384345380112C679CD7387 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001C8000000 [eMMC] : FLASH_UCP : 7296 MiB [eMMC 8 GiB] DEV RID : 0x0CF2E6DE959B56A389BEE47B419CC99F INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:33 Reconnect Power/Cable! |
12-22-2018, 08:52 | #55553 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | An Other M350 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100463732324D420042F8D30633A3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D420042F8D30633A3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x0CF2E6DEFB0EB8FDFDA316E36ACFDDBE INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : QMobile ProdName : QMobile M350 ProdModel : QMobile M350 Device : QMobile M350 AndroidVer: 5.1 MTKxCPU : MT6580 MTKxPRJ : ALPS.L1.MP6.V2_GINR6580.WE.L_P24 MODEM : BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V6_P3_1_wg_n EXTRA : LCD : Not info available LCD Res : 1280x720 TOUCH [0] : focaltech CAM [0] : s5k4h5yc_mipi_raw CAM [1] : ov8858_mipi_raw CAM [2] : ov5670_mipi_raw CAM [3] : hi551_mipi_raw MODEM : E150_WG_B18_Edge LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES en_IN Done! Elapsed: 00:00:09 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 150100463732324D420042F8D30633A3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D420042F8D30633A3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x0CF2E6DEFB0EB8FDFDA316E36ACFDDBE INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:33 Reconnect Power/Cable! |
12-22-2018, 09:36 | #55554 (permalink) |
No Life Poster Join Date: Jul 2016 Location: Pakistan
Member: 2603633 Status: Offline Sonork: family Thanks Meter: 214 | Gretel M31 only one click reset Gretel M31 only one click reset ... |
The Following User Says Thank You to haseebkakar For This Useful Post: |
12-22-2018, 09:37 | #55555 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | Qmobile Eco 200 2SPDR3 Logo Stuck Fix Only Formate With Infinity CM2 Card found: S/N : A19EC787 , v0137 Chinese Miracle II [SPD module] v 1.27 Set mode to : SPD6531 Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 18 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0100 [0] Flash DIE : 00C8 0060 0016 0000 [0] Flash VEN : GigaDevice , GD25LQ32 [0] Flash CAP : 00400000 Verify data... Can take some time Init Ok, formatting DIN area ... Format Block Done! Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
12-22-2018, 10:45 | #55557 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | oppo A1601 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from IDB! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4GB [eMMC] : FLASH_CID : 90014A484247346132A40B64A53983DB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x0CF2E6DEE914FC01C5CAF64F80E9410C INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! [AP] : Initial info read Ok! Brand : OPPO ProdName : A1601 ProdModel : A1601 Device : A1601 AndroidVer: 5.1 MTKxCPU : MT6755 MTKxPRJ : A1601EX_11_A.19_161011 EXTRA : LCD : Not info available LCD Res : M_HEIGHT=1280xM_WIDTH=720 TOUCH [0] : STOM_KERNEL_TOUCHPANEL=GT1XX CAM [0] : STOM_HAL_IMGSENSOR=s5k3l8_mipi_raw CAM [1] : imx258_mipi_raw CAM [2] : ov8865_mipi_raw CAM [3] : s5k3p3sp_mipi_raw MODEM : oppo6750_15331_lwg Done! Elapsed: 00:00:18 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 13 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from IDB! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4GB [eMMC] : FLASH_CID : 90014A484247346132A40B64A53983DB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x0CF2E6DEE914FC01C5CAF64F80E9410C INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:24 Reconnect Power/Cable! |
12-22-2018, 10:48 | #55558 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | QMobile X32 power Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000011B1F7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:23 Reconnect Power/Cable! |
12-22-2018, 10:49 | #55559 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Q Mobile black two Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000129CF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
12-22-2018, 10:51 | #55560 (permalink) |
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Rm1035 Flashing done Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC7731 Crev eMMC Loader v1.0 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x0000000129CF7000 State : 0x0001 Mount : /cache Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Android 5.x/6.x : Reset FRP Lock Reset Ok! Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
