Old 01-06-2019, 06:14   #56011 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,147
Qmobile K150 SPD6531 Call Log Not Show Fix Only Formate With Infinity CM2
Card found: S/N : A19EC787 , v0137
Chinese Miracle II [SPD module] v 1.27
Set mode to : SPD6531
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
==== Wait for phone...
Phone found! [ 17 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00EF 0040 0016 0000
[0] Flash VEN : Winbond , W25Q32
[0] Flash CAP : 00400000
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:09
Reconnect Power/Cable!
The Following User Says Thank You to azhergoga007 For This Useful Post:
Old 01-06-2019, 06:33   #56012 (permalink)
rahihimkhan's Avatar
Member: 613449
Sonork: 100.1614074
Thanks Meter: 559
Q Mobile A8 format done
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
BB_CPU_NME : [MediaTek] MT6575|MT6577_S00
BB_CPU_EXT : 0xCB00 , 0x8B00 , 0xE201
Processing BROM stage
i2c Init : 0300771F
SpeedSet : 0000
VChrgSet : 0x28 , BatStat : 0x02
WD Disable stat : 0x0000
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.3.2 on BBID : 0x84
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , M00SJ
[eMMC] : FLASH_CID : 1501004E4A5330304D0077336652AF63
[eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00020000
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0x0CF2E6DE5745FCDD92109F626B6E6AA5
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear RDP
Clear Ok!
Done!
Elapsed: 00:00:11
The Following User Says Thank You to rahihimkhan For This Useful Post:
Old 01-06-2019, 07:02   #56013 (permalink)
Member: 613449
Sonork: 100.1614074
Thanks Meter: 559
TA-1034Urdu done
Card found : 900AA66C , v0122
Infinity-Box BEST Nokia [HMD] Module [NK2] v1.09
Open VPLfile : TA-1034_059Z0X8_30.04.11.vpl
Description : TA-1034 IJ
DeviceType : TA-1034
ProductCode : 059Z0X8
SoftwareVer : 30.04.11
PPM LangPack :
[1] : Urdu (Islamic Republic of Pakistan)
[2] : English (United Kingdom)
Load Ok!
Operation : Write FirmWare [ v1.09 ]
Setting : UserData erase : False
Setting : LangPack Only : True
1. Make sure device is powered off. Power off, if need. Wait 10 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM Port (COM21)
MODE : NOKIA USB SERIAL
PORT : 21
BROM : Init BROM
BROM init passed!
CHIP : MT6261 , SBID : 0xCA02 , HWVR : 0x8000 , SWVR : 0x0001
BROM : SECCFG : 0x00000007
BROM : NOKIA USB SERIAL
BROM : 0x05 BL : 0x00
BROM : MEID : F38377649710ECA9E6DA2AC3B67D8729
BROM : Run BootLoader ...
BOOT : Run BL ver. 01
BOOT : 0x05 BL : 0x01
BOOT : WD : 0005
BOOT : RTC : Setup ...
BOOT : RTC : 000E
BOOT : PRJ : N103.30.04.11.p1
BOOT : SWR : 30.04.11
AGENT : Look for suitable BootChain in DA ...
AGENT : DEFAULT AUTO
AGENT : Found MT6261
AGENT : N103.30.04.11.p1
BOOT : Sending 1st DA ...
BOOT : DA sent
BOOT : Transfer control to DA ...
DA : Agent : v03.02 on BBID : 0x8E
NOR: 00C2 : 0020 : 0016 : 0000
NOR: [MXIC] MX25L3291FWJI_09
NOR:
TSIZE : 0x00400000 [ 4.00 MB ]
PSIZE : 0x00400000 [ 4.00 MB ]
STYPE : 0x00000000
FLOTP : DA_NOR_OTP_EXIST
STATUS : OK
BSTYLE : SF_FLASH_BOOT
Boot done!
VPL SoftwareVersion : 30.04.11 [TA-1034]
DEV SoftwareVersion : 30.04.11
SWInfo compare result : SAME
Load FlashSet :
LANG : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001
CUST : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001
JUMP : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001
Prepare FlashSet :
DCR : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001
DCR : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001
DCR : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001
Prepare Target
SDS : OK : 0x003F8000 : 0x00008000
Erase Target Flash
Erase done!
Write Target Flash
Write : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001
Write : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001
Write : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001
Write done, waiting target response ...
Write flash done!
Verify Target FlashContent
Verify : TA-1034_LANG_PACK_ROM_IJ_eMP_30.04.11_001
Verify : TA-1034_CUSTPACK_ROM_IJ_eMP_30.04.11_001
Verify : TA-1034_JUMP_TABLE_IJ_eMP_30.04.11_001
Done!
Elapsed: 00:00:29
Old 01-06-2019, 07:14   #56014 (permalink)
Member: 613449
Sonork: 100.1614074
Thanks Meter: 559
QMobile X32 Frp done
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4838473165050731C9C91983AF
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A4838473165050731C9C91983AF
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0x0CF2E6DE53FD819002D543729BB1A553
EXT RAM : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : QMobile
ProdName : X32
ProdModel : QMobile X32
Device : X32
AndroidVer: 6.0
MTKxCPU : MT6580
MTKxPRJ : ALPS.W10.24.p0
MODEM :
BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V57_P5_1_wg_n
EXTRA :
LCD : Not info available
LCD Res : 800x480
TOUCH [0] : ektf2k
TOUCH [1] : ft6336
CAM [0] : sp2508_mipi_raw
CAM [1] : gc2355_mipi_raw
CAM [2] : sp0a20blx_mipi_yuv
CAM [3] : sp0a20kmj_mipi_yuv
CAM [4] : ov5670_mipi_raw
MODEM : STOM_MODEM =mt6580_v2500an_hspa_B1B8_pk_V57
LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES hdpi
Done!
Elapsed: 00:00:09
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:30
Old 01-06-2019, 07:37   #56015 (permalink)
Member: 613449
Sonork: 100.1614074
Thanks Meter: 559
Nokia 1 Frp Done
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
SecCfgVal : 0x01000000
BromVer : 0x00FF
BLVersion : 0x0002
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
DA Select done, will use SecMode DA
Running DA ver.4.2 on BBID : 0x9B
eMMC Flash : 484A019061344738D0C6A532EF5D7481
[eMMC] : FLASH_INF : [HYNIX] , 2a4G8
[eMMC] : FLASH_CID : 90014A483847346132A5C6D0817415EF
DEV RID : 0x0CF2E6DEAB1F108881278B7AB708B502
SOC VERIFY : C1
Boot Ok!
Brand : Nokia
ProdName : Frontier_00WW
ProdModel : Nokia 1
Device : FRT
AndroidVer: 8.1.0
Done!
Elapsed: 00:00:08
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0002
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:14
Old 01-06-2019, 07:57   #56016 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 3,988
QMobile I7i Format / Repair Done :)
Set mode to : [AltLDR] SP [SC773x] eMMC [Android 5.x]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
 -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
Phone found! [ 26 ]
Port Opened
Sync...
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v4 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Done!
Elapsed: 00:00:28
The Following User Says Thank You to syed tuqeer For This Useful Post:
Old 01-06-2019, 07:59   #56017 (permalink)
Member: 654997
Thanks Meter: 3,988
Samsung SM-J730F Remove FRP lock Done :)
Read Info...
Read Info - ok
Connect ADB - Ok
Model - SM-J730F
Product - j7y17ltexx
CPU - exynos7870
Phone version - J730FXWU2ARE2
Android version - 7.0
CSC country code - UAE
CSC sales  code -
Phone serial No - R28JB3Z3K8J
Phone SIM Slot count - 2
Phone IMEI -  Not readed
Phone not Rooted
Connect ADB - Ok
Reset FRP/ REACTIVATION LOCK - Done
Reboot Phone...
Phone Disconnected
Phone found on COM83 launch to compl0
Phone In Download mode...
Phone Disconnected
Read Info...
Read Info - ok
Phone Disconnected
Old 01-06-2019, 08:47   #56018 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,147
Oppo A37fw QLM Pattren Read Done With King Infinity CM2
Card found : A19EC787 , v0137
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.14
Operation : Read PatternLock [ v1.14 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 26E7B1EA
ID_BLOCK_I : 007050E1
ID_BLOCK_L : FF09639B3AA0ADD887FC1479C69D1535
ID_BLOCK_L : A2D17FCEC352FC098C6B2CE5EF06103B
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Read Ok! Trying decrypt ...
PatternLock sequence : 21587
Done!
Elapsed: 00:00:12
Old 01-06-2019, 09:17   #56019 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,147
InFocus M370 QLM FRP Reset Done With King Infinity CM2
Operation : Reset Settings [ v1.14 ]
Wait for phone...
Device not found!
Check cable, connection and drivers!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 210 [MSM8x09]
ID_BLOCK_S : 04176E1A
ID_BLOCK_I : 009600E1
ID_BLOCK_L : AF5933CB6AF0FDE8D78C444996ED6565
ID_BLOCK_L : F2810F9E9302AC39DC1B7CB5BF76606B
Running FireHose on BBID : MSM8909 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ]
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Boot Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:35
Old 01-06-2019, 09:17   #56020 (permalink)
Member: 613449
Sonork: 100.1614074
Thanks Meter: 559
TA-1034Urdu done
PPM LangPack :
Load Ok!
PORT : 21
BROM : Init BROM
BROM init passed!
CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001
BROM : MEID : E1DB097E397578EC4F7404415D4A0E8A
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : DA sent
NOR: 00C8 : 0060 : 0016 : 0000
NOR: [GigaDevice] GD25LQ32
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
Load FlashSet :
Prepare FlashSet :
Prepare Target
Erase Target Flash
Erase done!
Write Target Flash
Write flash done!
Done!
Elapsed: 00:00:32
Old 01-06-2019, 09:19   #56021 (permalink)
lyes_albert's Avatar
Member: 2669781
Thanks Meter: 1,661
Nokia 3310 Clone/RDA_{hang at grey screen}_successfully flashed....
Full logs of the operation/
Firmware Link/ https://androidhost.ru/SQi
Wait for device ...
Device Connected!
BOOT_PWR0 : 0x00200000
BOOT_INIT : 0x70622986
BOOT_MODE : BOOTROM
Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G
MEMD for flsh_spi32m Branch: none
Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ]
Performing MemoryInit
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot IV : 0xFBA2A250
Boot done!
Flashing MCU code area
Region Flash done!
Flashing USERDATA code area
Region Flash done!
Flashing CALIBRATION code area
Region Flash done!
Flashing FACTORY code area
Region Flash done!
Programming completed!
Done!
Elapsed: 00:00:40
The Following 3 Users Say Thank You to lyes_albert For This Useful Post:
Old 01-06-2019, 09:47   #56022 (permalink)
Member: 613449
Sonork: 100.1614074
Thanks Meter: 559
QMobile ENERGY X1 FRP Done
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A483847316505074E8AC07424D7
[eMMC] : FLASH_CID : 90014A483847316505074E8AC07424D7
DEV RID : 0x0CF2E6DECA8D31362CFE272C5313750E
SOC VERIFY : C1
Boot Ok!
Brand : QMobile
ProdName : ENERGY_X1
ProdModel : QMobile ENERGY X1
Device : ENERGY_X1
AndroidVer: 6.0
MTKxCPU : MT6580
MODEM :
BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V57_P24_1_wg_n
EXTRA :
LCD Res : 854x480
TOUCH [0] : EKTF2K_V3800
TOUCH [1] : FT6336_V3800
CAM [0] : STOM_HAL_IMGSENSOR
CAM [1] : =s5k4h8_mipi_raw
CAM [2] : hi842_mipi_raw
CAM [3] : s5k5e2ya_mipi_raw
CAM [4] : ov5670_mipi_raw_cmk
CAM [5] : hi553_mipi_raw_sunwin
CAM [6] : s5k5e2ya_mipi_raw_sub
CAM [7] : sp2509_mipi_raw_cmk
MODEM : STOM_MODEM =mt6580_V3610_QMB_PK_hspa_modem_B15
LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES xhdpi
Done!
Elapsed: 00:00:17
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:12
Old 01-06-2019, 09:57   #56023 (permalink)
Member: 613449
Sonork: 100.1614074
Thanks Meter: 559
QTab_V7 FORMATING DONE
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 150100464E58324D4201C4C7EC8834DF
[eMMC] : FLASH_INF : [SAMSUNG] , BM2XN
[eMMC] : FLASH_CID : 150100464E58324D4201C4C7EC8834DF
DEV RID : 0x0CF2E6DEC4F9734437203FFE6E381C92
SOC VERIFY : C1
Boot Ok!
Brand : QTab
ProdName : QTab_V7
ProdModel : QTab V7
Device : qtab8321_9719e
AndroidVer: 5.1
MTKxCPU : MT6580
MTKxPRJ : ALPS.L1.MP6.V2.11.1_SANSEN8321.EMMC_P15
MODEM :
BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V13_P4_1_wg_n
EXTRA :
LCD Res : 600x1024
TOUCH [0] : gslX68X_9709_cts
CAM [0] : sp2509_mipi_raw
CAM [1] : sp2509front_mipi_raw
MODEM : sansen8321_tb_l_hspa_2100
Done!
Elapsed: 00:00:07
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:35
Old 01-06-2019, 10:25   #56024 (permalink)
Member: 613449
Sonork: 100.1614074
Thanks Meter: 559
Q Mobile X30 Flashing
Scatter Load Ok , BaseBand : MT6572 , Project : s4050ap , Storage : EMMC
Files found : 11 , Set to Flash : 10
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 90014A48344732611101A8D9D6C2225F
[eMMC] : FLASH_INF : [HYNIX] , a2G4
[eMMC] : FLASH_CID : 90014A48344732611101A8D9D6C2225F
DEV RID : 0x0CF2E6DEC7A308F9639061D923319E7D
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : s4050ap , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3901 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x00000000E5E00000
Flash Pre-Erase Done, time used : 00:00:16
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_s4050ap.bin
Preloader Sent , Init passed
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:51
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:40
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:04:04
Old 01-06-2019, 10:58   #56025 (permalink)
Ankit Verma's Avatar
Member: 506648
Sonork: 100.1614254
Thanks Meter: 644
How to Flash LYF F90M by Infinity CM2 Dongle
Thanks To Infinity Team
http://www.youtube.com/watch?v=QuW4MKLSybw
The Following User Says Thank You to Ankit Verma For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.57409 seconds with 9 queries
