Old 02-12-2019, 06:22   #56731 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,030
Oppo A37FW QLM FRP Reset Done With King Infinity CM2
Card found : A19EC787 , v0137
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.14
Operation : Reset Settings [ v1.14 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 25EA2415
ID_BLOCK_I : 007050E1
ID_BLOCK_L : 925208F661CDFAF5D287495691E86860
ID_BLOCK_L : A1DC62CDCE51F90A8F6E2398EA051338
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:12
Reconnect Power/Cable!
Old 02-12-2019, 06:41   #56732 (permalink)
Member: 2880611
Thanks Meter: 2
lg x230k pattern done............
operation : Read Pattern/DP Lock [ v1.58 ]
Wait for phone...
Phone found! [ 129 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 460001154D32584E460B064285B0C09A
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM2XN
[eMMC] : FLASH_CID : 150100464E58324D42060B469AC01585
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xA983ADDBBADFA8A5902E3BBD046E298A
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Reading data ...
[Info] : PatternLock Not Set!
[Info] : DP Lock not set!
Done!
Elapsed: 00:00:11
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:27
Old 02-12-2019, 06:48   #56733 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 656
Lg m700 reset frp done by cm2
Card found : 73CA70CC , v0137
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16
Operation : Reset Settings [ v1.16 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 435 [MSM8940]
ID_BLOCK_S : 83137F99
ID_BLOCK_E : 00310000
ID_BLOCK_L : CE10BE78C06FCBF5F9A5028856A1919F
ID_BLOCK_L : 15A378141EB662E2E027AD955F9640F6
Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ]
Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HBG4a2
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:35
Old 02-12-2019, 06:54   #56734 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 656
Maxx t105 hang on logo done by cm2
Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.03
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR
SPRD mode : SC6531 : REV : E000 : NOR
Operation : Identify [ v1.03 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Infinity SCR SC6531E Loader v 1.2
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ]
IMEI[1] : 352528092261985
IMEI[2] : 352528097261980
Done!
Elapsed: 00:00:27
Operation : Format FileSystem [ v1.03 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_168 1421A0FDC_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:20
Old 02-12-2019, 07:03   #56735 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 656
Qmobile bolt t200 hang on logo done by cm2
Card found: S/N : 73CA70CC , v0137
Chinese Miracle II [SPD module] v 1.27
Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0]
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 12 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v3 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Done!
Elapsed: 00:00:39
Old 02-12-2019, 07:12   #56736 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,030
Huawei Y560-u02 Logo Stuck Fix By Flashing With Infinity CM2
Card found: S/N : A19EC787 , v0137
Infinity SC Firmware Detected
FW Size : 1639 MiB
Load Ok!
File Info
Created by Infinity-Box (c) Chinese Miracle II (c) 2017
Device Brand : HUAWEI
Device Model : HWY560-U
Device CPU : Y560-U02
Device IntName : Y560-U02
Device Version : 4.4.2
Device Compile : 11/12/2015 14:36:09
Device Project : Y560-U02V100R001C328B105
Device ExtInfo : HUAWEI Y560-U02
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : SC77xx Infinity Package
3. Insert cable
Phone found! [ 41 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v4 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x1B records
PMTManager : PMT Update Ok!
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write CodeData : dlstat.bin
Write Data ...
Write Data Ok!
Write FSImage : prodnv.img
Write Data ...
Write Data Ok!
Write CodeData : sc7731g_CP0_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Write CodeData : sc8830g_modem_CP2_WCN_14D_W14.41_P1_Release.bin
Write Data ...
Write Data Ok!
Write CodeData : logo_480x800.bin
Write Data ...
Write Data Ok!
Write CodeData : fblogo_480x800.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system.img
Write Data ...
Write Data Ok!
Write FSImage : cache.img
Write Data ...
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Erase Block : MISC
Erase block ...
Block erase Ok!
Write CodeData : sysinfo.img
Write Data ...
Write Data Ok!
Write FSImage : custom.img
Write Data ...
Write Data Ok!
Write FSImage : globalinfo.img
Write Data ...
Write Data Ok!
Write FSImage : userdata.img
Write Data ...
Write Data Ok!
Elapsed: 00:02:58
Old 02-12-2019, 07:52   #56737 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 656
Vgotel ocean 6 reset pattern & frp done by cm2
Set mode to : SP [SC773x] eMMC [Android 6.x]
3. Insert cable
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:25
Old 02-12-2019, 08:08   #56738 (permalink)
Member: 320108
Thanks Meter: 17
Gtel X6plus
Originally Posted by GtelBoss View Post
Operation : Read Firmware [ v2.00 r4 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM (Android) (COM568)
MODE : PRELOADER PORT
PORT : 568
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000005
BROM : SecMode : SBC+SDA
BROM : PRELOADER PORT
MODE : 0_base : BASE_v1712 | Manual : Enabled
AGENT : Look for suitable BootChain in DA ...
AGENT : gt6plus_DA.bin
AGENT : Found MT6757
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : PRELOADER
DA : EXT_RAM initialized!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00040000 [ 256.00 KB ]
DRAM: 0x80000000 [ 2.00 GB ]
EMMC: 150100444836444D4205C500AC73A44F
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : DH6DMB
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0xE8F800000 [ 58.24 GB ]
CHIP : MT6757 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001 , EVOL : 0x0000
RNID : 9FE554CD6F8793684AF169555B537E9B
DA : USB : HIGH-SPEED
Boot done!
Board Platform : mt6757
Build Time : 1591752340
Display ID : X6plus
Patch Level : NRD90M
Product Info : Gtel_X6plus
Ver. CodeName : REL
Ver. Release : 7.0
Sec. Patch : 2017-09-05
Product Board : X6plus
Product Brand : Gtel
Product Device : Gtel_X6plus
Product Manfct : Gtel
Product Model : Gtel X6plus
Product Name : X6plus
MT6757__Gtel__Gtel_X6plus__7.0__X6plus__NRD90M_n
Read : preloader.bin
Read : recovery.img
Read : proinfo.img
Read : efuse.img
Read : md1rom.img
Read : md1dsp.img
Read : md1arm7.img
Read : nvram.bin
Read : lk.bin
Read : boot.img
Read : logo.bin
Read : tz.img
Read : system.img
ExtSparse : Compression ratio : 15%
Read : cache.img
Read : userdata.img
FW Size : 3.61 GB
Android Info saved : _Android_info.txt
Scatter : MT6757_Android_scatter.txt
Saved to : H:\flash firmware\infinity\MT6757__Gtel__Gtel_X6plus__7.0__ X6plus__NRD90M_n\
Done!
Elapsed: 00:21:57
would you share the Da file
Old 02-12-2019, 10:42   #56739 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,030
Qmobile T360 SPD77xx Hang Log Fix Only Formate With Infinity CM2
3. Insert cable
Phone found! [ 43 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Done!
Elapsed: 00:00:20
Old 02-12-2019, 11:15   #56740 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 656
Oppo a37 reset frp done by cm2
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 266C23AA
ID_BLOCK_L : 3FC9A35BFA606D98473CD439065DD5F5
ID_BLOCK_L : 275EE04B4CD7078C01ECA11E149B95B6
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:24
Old 02-12-2019, 12:53   #56741 (permalink)
ajaystarin's Avatar
Member: 173081
Sonork: 100.1621322
Thanks Meter: 260
Panasonic eluga ray 600 frp done
PANASONIC ELUGA RAY 600 FRP DONE
Operation : Reset Settings/Format FS [ v2.04 ]
PTFN : MediaTek PreLoader USB VCOM (Android) (COM57)
PORT : 57
BROM : Init BROM
BROM init passed!
CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
BROM : SecLevel : 0x00000000
BROM : SecMode : PLAIN [+PRL]
MODE : 0_base : BASE_v1836 | Manual : Disabled
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6739
BROM : DA sent
DA : AGENT started!
DA : SYNC
SRAM: 0x00020000 [ 128.00 KB ]
DRAM: 0xC0000000 [ 3.00 GB ]
EMMC: 90014A484247346132A543EAB56D15E9
EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HBG4a2
EMMC:
USER : 0x747C00000 [ 29.12 GB ]
CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 0000000000000000
DA : USB : UNKNOWN
DA : USB : Change Port Speed
PORT : 57
Boot done!
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:22
Old 02-12-2019, 13:03   #56742 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,030
Nokia N6 TA-1021 QLM FRP Donw ADB Mode With King Infinity CM2
Infinity-Box Android Service Tool [AST] v1.03
Operation : Reset FRP (ADB) [ v1.03 ]
Waiting for device in ADB mode ...
1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need!
2. Insert USB cable, accept AUTH on PhoneScreen, if software ask!
Connect Ok!
Device : TA-1021_00WW
Model : TA-1021
FRP reset passed! Make FACTORY RESET from menu!
Done!
Elapsed: 00:00:12
Old 02-12-2019, 14:34   #56743 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 656
Copy nokia 108 hang on logo done by cm2
Card found : S/N : 73CA70CC , v0137
Operation : Check / Read Info [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 6 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6250_S0000
BB_CPU_SN : 7E451368E27559E21D8753F2E3E31584
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
InitRes : 00000000
DEV[0] : C200 2500 3600 0000
DEV[1] : 0000 0000 0000 0000
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00DB , [MX] MX25U3235E
[0] : FLASH_DIE : 00C2 0025 0036 0000
[0] : FLASH_LEN : 0x00400000
INT_RAM : 0x0000D400
EXT_RAM : 0x00400000
File_Info : L108_NOKIA_PCB01_gprs_MT6250_S00.NOKIA_108_V1_3.bi n
FileVersion : nokia_108_v1.3
Done!
Elapsed: 00:00:13
Wait for phone...
Phone found! [ 6 ]
Sync...
Boot Info :
BB_CPU_ID : 625A
BB_CPU_HW : CA01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
InitRes : 00000000
SOC_VERIFY : 0xC1
Backup done
Executing FFS FORMAT now...
FAT_RANGE : 0x003AB000-0x003FFFFF , LEN : 0x00055000
DA_RET : DA_IN_PROGRESS
DA_RET : FORMAT_DONE
Done!
Elapsed: 00:00:15
Old 02-12-2019, 14:38   #56744 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 656
Kibosun k50 reset password done by cm2
SCRD mode : AUTO
Operation : Reset Settings [ v1.03 ]
----- > Powered On :
1. Power On device
2. Connect USB cable
3. When device show StorageMode : Press '0' button for a 5 second!
----- > Powered Off :
1. Insert USB cable
2. Wait when device show Charge icon
Wait for device ...
Device Connected!
BOOT_PWR0 : 0x00600000
BOOT_INIT : 0x81C0024C
BOOT_MODE : DOWNLOAD
BOOT_INTV : 6533G-FPTRUNK-W16.44.2
InternalVersion: g8bec5c4c
Setting BOOTROM mode
BOOT_MODE : BOOTROM
Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G
MEMD for flsh_spi32m Branch: none
Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ]
Performing MemoryInit
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot IV : 0xFBA2A250
Boot done!
Preparing PMT
Verifying PMT
Erasing 1474560 bytes
FileSystem format done!
Done!
Elapsed: 00:00:59
Old 02-12-2019, 14:42   #56745 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 656
Qmobile z14 reset frp done by cm2
Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.04
Load IDBase v123080 Ok!
Update configuration ...
Update Ok!
Operation : Identify [ v2.04 ]
PTFN : MediaTek PreLoader USB VCOM Port (COM15)
PORT : 15
BROM : Init BROM
BROM init passed!
CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001
MODE : 0_base : BASE_v1712 | Manual : Disabled
AGENT : Found MT6755
BROM : DA sent
DA : AGENT started!
DA : SYNC
EMMC: 150100525831344D4207B53FCABC8341
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RX14MB
EMMC:
CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : EA0E56C9331BFD763900E3A1DFA969E4
Boot done!
Board Platform : mt6755
Build Time : 1469292502
Display ID : Z14
Patch Level : MRA58K
Product Info : gionee6755_66_m
Ver. CodeName : REL
Ver. Release : 6.0
Sec. Patch : 2016-06-01
Product Board : Z14
Product Brand : QMobile
Product Device : Z14
Product Manfct : QMobile
Product Model : Z14
Product Name : Z14
USERDATA : ENCRYPTED
Done!
Elapsed: 00:00:20
PORT : 15
BROM : Init BROM
BROM init passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
EMMC:
Boot done!
Format Ok : USERDATA
Format Ok : CACHE
Format Ok : PRIVACY
Done!
Elapsed: 00:01:01
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-29-2010 21:17
Page generated in 0.48627 seconds with 9 queries
