Old 03-14-2019, 12:08   #57331 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 14,278
Smile Qmobile M350 F.R.p Done
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 30 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 150100464E58324D420154E3D0E7341F
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM2XN
[eMMC] : FLASH_CID : 150100464E58324D420154E3D0E7341F
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xE6C52A7DFF067A1F2F75069F81724EE0
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:11
Reconnect Power/Cable!
Old 03-14-2019, 12:08   #57332 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Qmobile E900 Format Done
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 26 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CA02
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : F84F8442A67BD0BB2AF51C1905D43003
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09
[0] : FLASH_DIE : 00C2 0020 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Backup done
Executing FFS FORMAT now...
FAT_RANGE : 0x0039E000-0x003FDFFF , LEN : 0x00060000
DA_RET : DA_IN_PROGRESS
DA_RET : FORMAT_DONE
Done!
Elapsed: 00:00:09
Old 03-14-2019, 12:40   #57333 (permalink)
gile@gile's Avatar
Member: 1473716
Thanks Meter: 594
Konrow Just5 FRP Reset done
Card found: S/N : 07XXXXXX , v0137
Chinese Miracle II [SPD module] v 1.27
Set mode to : SP [SC773x] eMMC [Android 7.x]
Operation : Check/Read Info [ v1.27 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 214 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC773x eMMC Loader v7 InfinityBox
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name : Just5_Konrow
Model Brand : Just5
Model Device: Konrow
AndrVersion : 7.0
BaseBand CPU: JUST5
CompileDate : 8/18/2017 6:21:55 AM
Project Ver : Konrow-Just5-V02-20170818
Model Ext : Just5
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:30
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:31
Operation : Read FullFlash [ v1.27 ]
3. Insert cable
Phone found! [ 59 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
[FW_READER] : Prepare Ok!
- > Wait phone connected ...
Phone found! [ 59 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Phone found! [ 59 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Brand : Just5
AndrVersion : 7.0
BaseBand CPU: JUST5
Project Ver : Konrow-Just5-V06-20180824
Model Ext : Just5
[Read Mode] : HSUSB : 0x3000
[FW_READER] : Reading Firmware Now ...
[Read Ok] : u-boot-spl-16k.bin
[Read Ok] : u-boot.bin
[Read Ok] : prodnv.img
[Read Ok] : sc7731C_CP0_modem.bin
[Read Ok] : DSP_DM_Gx.bin
[Read Ok] : nvitem_w.bin
[Read Ok] : sc8830g_modem_CP2_WCN_Trunk_W18.01.4_Release.bin
[Read Ok] : nvitem_wcn.bin
[Read Ok] : logo_480x854.bin
[Read Ok] : fblogo_480x854.bin
[Read Ok] : boot.img
[Read Ok] : system.img
[Read Ok] : trustos.bin
[Read Ok] : vmm.bin
[Read Ok] : sysinfo.img
[Build Ok] : cache.img
[Read Ok] : recovery.img
[Read Ok] : fbootlogo3.bin
[Read Ok] : fbootlogo4.bin
[Read Ok] : fbootlogo5.bin
[Build Ok] : userdata.img
AndroidInfo created
Firmware Size : 3028 MiB
Saved to : C:\Users\korisnik\Desktop\Konrow Just5\JUST5_Konrow_7.0_Konrow-Just5-V06-20180824_Just5\
Done!
Elapsed: 00:13:06
Old 03-14-2019, 12:52   #57334 (permalink)
niaz muhammad's Avatar
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,875
LENOVO A6000 FORMAT AND SLOV LOGO HANG
Card found : CE90936C , v0137
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16
Operation : Reset Settings [ v1.16 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 119CE021
ID_BLOCK_L : A65E34C26DF9E6E1DEB35D428DD45C6C
ID_BLOCK_L : 770EB01B1C8737BC519CF12E24CBE5E6
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000001D2000000 [ eMMC 8 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:18
Old 03-14-2019, 13:56   #57335 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 673
Vgotel ocean9l hang on logo done by cm2
Card found: S/N : 73CA70CC , v0137
Set mode to : SP [SC983x] eMMC [Generic Android 7.x]
3. Insert cable
Phone found! [ 99 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC983x eMMC Loader v5.0 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Name : Ocean9L
Model Brand : VGOTEL
Model Device: Ocean9L
AndrVersion : 7.0
BaseBand CPU: OCEAN9L
CompileDate : 1/19/2018 1:26:23 AM
Project Ver : Ocean 9_V01_20180119
Model Ext : Ocean9L
Elapsed: 00:00:29
3. Insert cable
Phone found! [ 99 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Reset Ok!
Done!
Elapsed: 00:00:32
Old 03-14-2019, 13:58   #57336 (permalink)
Member: 1714226
Thanks Meter: 35
Smile Q5 Clear UserLocks with Cm2
Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.58 ]
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A483447326111014323E8EE23A1
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , a2G4
[eMMC] : FLASH_CID : 90014A483447326111014323E8EE23A1
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0x09E7E7325423CF14DE51D8600367293D
EXT RAM : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
LSSDB Ok!
LSSWL Ok!
LSSSH Ok!
LSSGS Ok!
Security Settings : Clear Ok!
[Info] : That feature NOT RESET "PRIVACY PASSWORD LOCK"! Use separate button!
[Info] : That feature NOT RESET "FRP/GoogleLOCK"! Use separate "FRP" reset!
[Info] : If phone stuck on "Logo" :
1. Wait 2-3 minutes. Power Off phone by long press "Power" button
2. Power On phone again
3. Or wait up to 3-7 minutes, until phone start by itself
4. Also recommended reboot phone twice before start use it
Done!
Elapsed: 00:00:22
The Following 2 Users Say Thank You to rubelgsm For This Useful Post:
Old 03-14-2019, 14:35   #57337 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 3,949
OALE X1 Write Factory FIrmware Done :)
[FL] : Total size : 0x501E259C [ 1.25 GB ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MTK USB Port (COM128)
MODE : BOOTROM
PORT : 128
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
     CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     TYPE : LEGACY MTK
BROM : SecLevel : 0x00000000
BROM : SecMode  : PLAIN [+PRL]
BROM : BOOTROM
MODE : 0_base : BASE_v1712 | Manual : Disabled
Fail to disable Dog!
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6580
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
NAND : DEVICE NOT FOUND
NAND : 000000000000000000000000
eMMC : OK
eMMC : 422201F46E6977693732102081843631
DAInf: 4 : 2 : 156
DA : EXT_RAM NOT initialized!
eMMC : OK
eMMC : F40122426977696E2010323731368481
     EMI : DEV : MT6752
     EMI : SRC : preloader_gxq6580_weg_l.bin
     EMI : CNT : 0001
INIT : 0xBC : PRELOADER_INFO [ 0x00000000 :  [ 0 B ] ]
DRAM : DRAM: 0x40000000 [ 1.00 GB ]
     DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : Receiving HW info
        EMMC: F40122426977696E2010323731368481
        EMMC: VEN : BIWIN | OEM : 2201 | DEV : Biwin
        EMMC:
              BOOT1  : 0x00400000 [ 4.00 MB ]
              BOOT2  : 0x00400000 [ 4.00 MB ]
              RPMB   : 0x00400000 [ 4.00 MB ]
              USER   : 0x1CD000000 [ 7.20 GB ]
        SRAM: 0x00020000 [ 128.00 KB ]
        CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : 8E4EC244487160761499032B41F744A7
 STATUS : BLANK FLASH
 BSTYLE : EMMC FLASH BOOT
DA : USB : FULL-SPEED
DA : USB : Change Port Speed
PTFN : DA USB VCOM Port (COM184)
MODE : PRELOADER PORT
PORT : 184
Boot done!
[FL] : HW verification passed!
[FL] : Pre-Flash backup
Backup sensetive data [ 10 ]
Backup path : Backup\MT6580__8E4EC244487160761499032B41F744A7\
[3] Read : NVRAM
[14] Read : NVDATA
[2] Read : PROINFO
[7] Read : LK
[4] Read : PROTECT1
[5] Read : PROTECT2
[0] Read : PRELOADER
Backup done!
[FL] : Pre-Flash backup passed!
SEC_DL : False (CUST)
SEC_DL : SECURE USB DL DISABLED
SEC_ID : 0x35464646304237304435444533464335
[FL] : Pre-Erase
Erase : 0x0000000000000000 : 0x0000000000080000
Erase : 0x0000000001C80000 : 0x00000001CA2C0000
[FL] : RePartition
[FL] : RePartition Ok!
[FL] : Flashing now ...
Write : PRELOADER
Update bootloader code ...
Update bootloader Ok!
Write : LK
Write : BOOT
Write : RECOVERY
Write : LOGO
Write : SECRO
Write : SYSTEM
Write : CACHE
Write : USERDATA
CHK : 0x00059794 : 0xADDC : LK
CHK : 0x00691800 : 0xE77A : BOOT
CHK : 0x0074B000 : 0x71C2 : RECOVERY
CHK : 0x003CB7FC : 0x1F96 : LOGO
CHK : 0x00021000 : 0x136D : SECRO
CHK : 0x60000000 : 0x7EDA : SYSTEM
CHK : 0x10000000 : 0x70CA : CACHE
CHK : 0x60000000 : 0x51B4 : USERDATA
[FL] : RePartition
[FL] : Flashing finished!
Done!
Elapsed: 00:04:26
Old 03-14-2019, 14:37   #57338 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,038
China Tab Gtide F802 MT6572 FRP Reset Done With King Infinity CM2
Card found : S/N : A19EC787 , v0137
Wait for phone...
Phone found! [ 258 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 150100385750443352003E565130141F
[eMMC] : FLASH_INF : [SAMSUNG] , R3DPW
[eMMC] : FLASH_CID : 150100385750443352003E565130141F
DEV RID : 0xD9C8F39574BA6362834E646C506B7BE1
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:34
Old 03-14-2019, 14:54   #57339 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,038
Qmobile QTab Q300 MT6580 Hanging Probelam Fix Done With KIng Infinity CM2
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x87
eMMC Flash : 15010038574D42335201F935BC9F5103
[eMMC] : FLASH_INF : [SAMSUNG] , R3BMW
[eMMC] : FLASH_CID : 15010038574D42335201F935BC9F5103
DEV RID : 0xD9C8F395C146EB8E15A85AB7942026EE
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:40
Old 03-14-2019, 15:00   #57340 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 673
Oppo r9 reset frp done by cm2
Card found : 73CA70CC , v0137
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 625 [MSM8953]
ID_BLOCK_S : D25FD0AE
ID_BLOCK_I : 000460E1
ID_BLOCK_L : 677ABA3C6D0F681B96C435A407EE60C7
ID_BLOCK_L : F2B7CB2D56257C600928CC625F3692C0
Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ]
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RC14MB
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:14
Old 03-14-2019, 15:04   #57341 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 673
Qmobile w50 hang on logo done by cm2
Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0]
3. Insert cable
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v3 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Model Name : sp7731geahdplusoversea
Model Brand : QMobile
Model Device: scx35_sp7731gea_hd
AndrVersion : 5.1
BaseBand CPU: SP7731GEA_HD
CompileDate : 10/30/2015 3:49:17 AM
Project Ver : QMobileW50_MP_10_30
Model Ext : QMobile W50
Elapsed: 00:00:18
3. Insert cable
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Done!
Elapsed: 00:00:33
Old 03-15-2019, 05:49   #57342 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Moto Xt912 Reset Done
Operation : Reset Settings [ v1.03 ]
Mode : Format FS
Waiting for device in fastboot mode ...
1. Power off device. Press and hold 'VOL DOWN' button
2. Insert USB cable, hold button until device will be found!
Connect Ok!
Block [1] ERASE OK!
Block [2] ERASE OK!
Done!
Elapsed: 00:00:07
Old 03-15-2019, 06:25   #57343 (permalink)
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,875
QMOBILE Z8 WRITE FLASH DON
Loading firmware ...
Loading 1 program definition file(s) ...
Load Ok!
Operation : Flash [ v1.16 ]
ForceFlashing : Disabled
Verify FW package ...
Verification passed!
Wait for phone...
BREAK : Device not found!
HINT : Check cable, connection and drivers!
Wait for phone...
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_S : 01F48FBC
ID_BLOCK_L : C93B51AD0896838E792E262FE8B3C30B
ID_BLOCK_L : AFA668C3B45F8F04B97459969C130D4E
Pickup loader from firmware package
MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ]
Boot Ok!
Flash Chain : 165
Flashing now
Flashing : NON-HLOS.bin
Flashing : sbl1.mbn
Flashing : sbl1.mbn
Flashing : emmc_appsboot.mbn
Flashing : rpm.mbn
Flashing : rpm.mbn
Flashing : tz.mbn
Flashing : tz.mbn
Flashing : hyp.mbn
Flashing : hyp.mbn
Flashing : splash.img
Flashing : sec.dat
Flashing : boot.img
Flashing : system_1.img
Flashing : system_2.img
Flashing : system_3.img
Flashing : system_4.img
Flashing : system_5.img
Flashing : system_6.img
Flashing : system_7.img
Flashing : system_8.img
Flashing : system_9.img
Flashing : system_10.img
Flashing : system_11.img
Flashing : system_12.img
Flashing : system_13.img
Flashing : system_14.img
Flashing : system_15.img
Flashing : system_16.img
Flashing : system_17.img
Flashing : system_18.img
Flashing : system_19.img
Flashing : system_20.img
Flashing : system_21.img
Flashing : system_22.img
Flashing : system_23.img
Flashing : system_24.img
Flashing : system_25.img
Flashing : persist_1.img
Flashing : cache_1.img
Flashing : cache_2.img
Flashing : cache_3.img
Flashing : cache_4.img
Flashing : recovery.img
Flashing : userdata_1.img
Flashing : userdata_2.img
Flashing : userdata_3.img
Flashing : userdata_4.img
Flashing : userdata_5.img
Flashing : userdata_6.img
Flashing : userdata_7.img
Flashing : userdata_8.img
Flashing : userdata_9.img
Flashing : userdata_10.img
Flashing : userdata_11.img
Flashing : userdata_12.img
Flashing : userdata_13.img
Flashing : userdata_14.img
Flashing : userdata_15.img
Flashing : userdata_16.img
Flashing : userdata_17.img
Flashing : userdata_18.img
Flashing : userdata_19.img
Flashing : userdata_20.img
Flashing : userdata_21.img
Flashing : userdata_22.img
Flashing : userdata_23.img
Flashing : userdata_24.img
Flashing : userdata_25.img
Flashing : userdata_26.img
Flashing : userdata_27.img
Flashing : userdata_28.img
Flashing : userdata_29.img
Flashing : userdata_30.img
Flashing : userdata_31.img
Flashing : userdata_32.img
Flashing : userdata_33.img
Flashing : userdata_34.img
Flashing : userdata_35.img
Flashing : userdata_36.img
Flashing : userdata_37.img
Flashing : userdata_38.img
Flashing : userdata_39.img
Flashing : userdata_40.img
Flashing : userdata_41.img
Flashing : userdata_42.img
Flashing : userdata_43.img
Flashing : userdata_44.img
Flashing : userdata_45.img
Flashing : userdata_46.img
Flashing : userdata_47.img
Flashing : userdata_48.img
Flashing : userdata_49.img
Flashing : userdata_50.img
Flashing : userdata_51.img
Flashing : userdata_52.img
Flashing : userdata_53.img
Flashing : userdata_54.img
Flashing : userdata_55.img
Flashing : userdata_56.img
Flashing : userdata_57.img
Flashing : userdata_58.img
Flashing : userdata_59.img
Flashing : userdata_60.img
Flashing : userdata_61.img
Flashing : userdata_62.img
Flashing : userdata_63.img
Flashing : userdata_64.img
Flashing : userdata_65.img
Flashing : userdata_66.img
Flashing : userdata_67.img
Flashing : userdata_68.img
Flashing : userdata_69.img
Flashing : userdata_70.img
Flashing : userdata_71.img
Flashing : userdata_72.img
Flashing : userdata_73.img
Flashing : userdata_74.img
Flashing : userdata_75.img
Flashing : userdata_76.img
Flashing : userdata_77.img
Flashing : userdata_78.img
Flashing : userdata_79.img
Flashing : userdata_80.img
Flashing : userdata_81.img
Flashing : userdata_82.img
Flashing : userdata_83.img
Flashing : userdata_84.img
Flashing : userdata_85.img
Flashing : userdata_86.img
Flashing : userdata_87.img
Flashing : userdata_88.img
Flashing : userdata_89.img
Flashing : userdata_90.img
Flashing : userdata_91.img
Flashing : userdata_92.img
Flashing : userdata_93.img
Flashing : userdata_94.img
Flashing : userdata_95.img
Flashing : userdata_96.img
Flashing : userdata_97.img
Flashing : userdata_98.img
Flashing : userdata_99.img
Flashing : userdata_100.img
Flashing : userdata_101.img
Flashing : userdata_102.img
Flashing : userdata_103.img
Flashing : userdata_104.img
Flashing : userdata_105.img
Flashing : userdata_106.img
Flashing : gpt_main0.bin
Flashing : gpt_backup0.bin
Flash sequence completed!
Applying patches for storage # 0
Records : 26
Patch sequence completed!
BootConfig set to 0x00
Flashing done!
Done!
Elapsed: 00:04:27
Old 03-15-2019, 06:38   #57344 (permalink)
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,875
HUAWEI TAG-AL00 REED FLASH AND RESET COD DON
Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.05
Load IDBase v123080 Ok!
Update configuration ...
Update Ok!
Operation : Identify [ v2.05 ]
PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM23)
PORT : 23
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
     CHIP : MT6753 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     TYPE : LEGACY MTK
BROM : PRELOADER PORT
MODE : Huawei : TAG Series [ TAG-xx ] | Manual : Disabled
AGENT : Found MT6753
BROM : DA sent
     DA : AGENT started!
eMMC : OK
eMMC : 1101003031364733320082D3BD625895
DAInf: 4 : 2 : 147
     DA : DRAM ready!
        EMMC: 1101003031364733320082D3BD62B295
        EMMC: VEN : TOSHIBA | OEM : 01 | DEV : 016G32
        EMMC:
              USER   : 0x3AB400000 [ 14.68 GB ]
        DRAM: 0x80000000 [ 2.00 GB ]
        CHIP : MT6753 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : 8D5C512ABF4DD18AB8648E81B2C2239F
DA : USB : HIGH-SPEED
Boot done!
Patch Level    : HUAWEITAG-AL00
Display ID     : TAG-AL00C92B166
Ver. CodeName  : REL
Ver. Release   : 5.1
Sec. Patch     : 2016-10-05
Build Time     : 1480475976
Product Model  : HUAWEI TAG-AL00
Product Brand  : HUAWEI
Product Name   : TAG-AL00
Product Device : HWTAG-L6753
Product Board  : TAG-AL00
Product Manfct : HUAWEI
Board Platform : mt6753
Product Info   : hq6753_66t_b2c_l1
USERDATA : PLAIN ( NOT encrypted )
Done!
Elapsed: 00:00:17
Operation : Read Firmware [ v2.05 ]
PORT : 23
BROM : Init BROM
BROM init passed!
     TYPE : LEGACY MTK
BROM : DA sent
     DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 147
     DA : DRAM ready!
        EMMC:
Boot done!
Ver. CodeName  : REL
Ver. Release   : 5.1
MT6753__HUAWEI__HUAWEI_TAG-AL00__5.1__TAG-AL00C92B166__HUAWEITAG-AL00__hq6753_66t_b2c_l1
SecureDevice : Paired type!
-> INFO : That device WILL dead after ReadOut Flashing!
-> INFO : Only partial flashing ( f.e. SYSTEM, VENDOR and etc. ) available!
-> INFO : In most cases you can "unsecure" device in Engineer mode
Read : preloader.bin
Read : proinfo.img
Read : nvram.bin
Read : lk.bin
Read : boot.img
Read : recovery.img
Read : logo.bin
Read : secro.img
Read : tz.img
Read : system.img
ExtSparse : Compression ratio : 26%
Read : cache.img
Read : userdata.img
FW Size  : 2.01 GB
Android Info saved : _Android_info.txt
Scatter  : MT6753_Android_scatter.txt
Saved to : G:\HUAWEI\TAG-AL00\urdu all ok\MT6753__HUAWEI__HUAWEI_TAG-AL00__5.1__TAG-AL00C92B166__HUAWEITAG-AL00__hq6753_66t_b2c_l1\
Done!
Elapsed: 00:04:41
Old 03-15-2019, 07:50   #57345 (permalink)
umarnlw's Avatar
Member: 207708
Sonork: 100.1602241
Thanks Meter: 626
Qmobile S6 FRP Reset Done With 1 Click By CM2
Here are logs
Youtube Link
https://www.youtube.com/watch?v=pL_1MOIg5sY&t=30s
The Following User Says Thank You to umarnlw For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.52030 seconds with 9 queries
