Old 03-15-2019, 07:53   #57346 (permalink)
umarnlw's Avatar
Member: 207708
Sonork: 100.1602241
Thanks Meter: 626
Q TITANO BOS FRP Done With 1 Click By CM2
Here are Logs
Youtube Link
https://www.youtube.com/watch?v=j2voAIWMdI0
The Following User Says Thank You to umarnlw For This Useful Post:
Old 03-15-2019, 08:11   #57347 (permalink)
Member: 1740570
sir can u plz provide its flash file by taking backup
Old 03-15-2019, 08:16   #57348 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 673
Qmobile e440i hang on logo done by cm2
Card found : 73CA70CC , v0137
Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ]
SPRD mode : SC6531 : REV : 0000 : NOR : [ 8MB-16MB]
Operation : Identify [ v1.04 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Infinity SCR 653x NOR v1.3(c)2019
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ]
IMEI[1] :
IMEI[2] :
Done!
Elapsed: 00:00:16
Reconnect Power/Cable!
Operation : Format FileSystem [ v1.04 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_178 8F0FFFBE2_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:19
Operation : Read Flash [ v1.04 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Read Ok, 4194304 bytes
Saved to : G:\CM2\176DEB01AEEE_SPRD_SPI_GIGADEVICE_GD25Q_4MiB .bin
Done!
Elapsed: 00:00:47
Old 03-15-2019, 11:52   #57349 (permalink)
Arslanmayo's Avatar
Member: 2478233
Thanks Meter: 190
Vivo 1812 frp reset done via cm2 ast tool
Connect Ok!
Device Info :
Vendor : vivo
Model : vivo 1812
Device : 1812
Android : 8.1.0
Product : k61v1_64_bsp
Brand : vivo
Serial : R4ZHP7UGEIHU6H5T
Build_tm : Tue Jan 8 10:22:13 CST 2019
DisplayID : O11019 release-keys
Patch Ver : O11019
SecPatch : 2018-12-05
Hardware : mt6761
MTK SVer : S01
MTK HVer : MT6761
MTK Prj : alps-mp-o1.mp7.tc19sp-V1.19_k61v1.64.bsp_P66
CPU rel : arm64-v8a
SIM Card : ABSENT,READY
BaseBand : MOLY.LR12A.R2.MP.V32.21.P78
RIL ver : android reference-ril 1.0
USB Conf : mtp,adb,acm
Sys USB : mtp,adb,acm
FS Crypt : encrypted
OEM Unlck : 1
Done!
Elapsed: 00:00:02
Operation : Reset FRP (ADB) [ v1.03 ]
Waiting for device in ADB mode ...
1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need!
2. Insert USB cable, accept AUTH on PhoneScreen, if software ask!
Connect Ok!
Device : 1812
Model : vivo 1812
FRP reset passed! Make FACTORY RESET from menu!
Done!
Elapsed: 00:00:08
The Following User Says Thank You to Arslanmayo For This Useful Post:
Old 03-15-2019, 13:09   #57350 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 673
Qmobile i2 power reset frp done by cm2
Card found: S/N : 73CA70CC , v0137
Chinese Miracle II [SPD module] v 1.27
Set mode to : SP [SC773x] eMMC [Android 6.x]
Operation : Check/Read Info [ v1.27 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 9 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name : i2_POWER
Model Brand : QMobile
Model Device: i2_POWER
AndrVersion : 6.0
BaseBand CPU: SP7731CEA
CompileDate : 11/28/2016 8:41:14 AM
Project Ver : QMobile_i2_POWER_MP_08_11
Model Ext : QMobile i2 POWER
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:27
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
3. Insert cable
Phone found! [ 9 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Failed!
Done!
Elapsed: 00:00:26
Old 03-15-2019, 13:20   #57351 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 673
Huawei mya l22 reset frp done by cm2
Card found : S/N : 73CA70CC , v0137
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x01000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 510001154D33314553B30D421DB7DDF2
Initialize Memory ...
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x80000000
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM31E
[eMMC] : FLASH_CID : 150100514531334D420DB353F2DD841D
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0xB9E2EB77E68A3B3D1F62EDDF3E78564D
INT RAM : 0x00020000
EXT RAM : 0x80000000 [2 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:20
Old 03-15-2019, 13:37   #57352 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 673
Qmobile x2 hang on logo done by cm2
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6571
BB_CPU_NME : [MediaTek] MT6571_S00
BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x8B
NAND Flash : 009800BC009000660076001600080000
eMMC Flash : NOT INSTALLED
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1
[NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008
[NAND] : FLASH_LEN : 0x20000000
[NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1
DEV RID : 0xD9C8F3952846265A8067E905B90A65BE
EXT RAM : 0x10000000 [256 MiB]
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:14
Old 03-15-2019, 13:47   #57353 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 1,767
LG Magna (LG-H502F) APP ERROR SOLVED BY READ FLASH AND FLASHING
HI
BY
noony1
GEM-FLASH
Card found : S/N : 42A8DF25 , v0137
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 52 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
DA Select done, will use SecMode DA
Running DA ver.4.2 on BBID : 0x87
eMMC Flash : 150100513732534D420043E96AADA201
[eMMC] : FLASH_INF : [SAMSUNG] , BMS27
[eMMC] : FLASH_CID : 150100513732534D420043E96AADA201
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0x40FFEB145A8C1BFB395BB0CF4060F2BF
EXT RAM : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : lge
ProdName : my90ds_global_com
ProdModel : LG-H502
Device : my90ds
AndroidVer: 6.0
SWVersion : LGH502AT-00-V20d-GLOBAL-COM-JUN-03-2016+0
CU_SWVer : H50220d
MTKxCPU : MT6582
MTKxPRJ : alps-mp-m0.mp2.tc1sp-release
MODEM :
BaseBand : MT6582_S00_MOLY_WR8_W1338_MD_WG_TC01_MUSE82Y_SP_V12_1_wg_n
EXTRA :
LCD [0] : r69338_hd720_dsi_vdo_jdi
LCD Res : 1280x720
TOUCH [0] : GT9XX
CAM [0] : ov8858_mipi_raw
CAM [1] : ov8858s_mipi_raw
CAM [2] : hi842_mipi_raw
CAM [3] : ov5670_mipi_raw
CAM [4] : hi553_mipi_raw
MODEM : my90ds_hspa
LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES
Done!
Elapsed: 00:00:19
Operation : Read Flash [ v1.58 ]
Wait for phone...
Phone found! [ 52 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading Flash Content now ...
Brand : lge
ProdModel : LG-H502
Device : my90ds
AndroidVer: 6.0
CU_SWVer : H50220d
MTKxCPU : MT6582
[Read Ok] : preloader_muse6582_y90_m.bin
[Read Ok] : MBR
[Read Ok] : EBR1
[Read Ok] : lk.bin
[Read Ok] : lk_bak.bin
[Read Ok] : laf.img
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : secro.img
[Read Ok] : logo.bin
[Read Ok] : EBR2
[Read Ok] : EBR3
[Read Ok] : persist.img
[Read Ok] : lgfota.img
[Read Ok] : cust.img
[Read Ok] : factory.img
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : userdata.img
[ScatCFG] : MT6582 / V1.1.1 / muse6582_y90_m / EMMC
Android Info saved
FW Size : 2657 MiB
Scatter saved to : C:\Users\WIN7\Desktop\MT6582__lge__LG-H502__my90ds__6.0__LGH502AT-00-V20d-GLOBAL-COM-JUN-03-2016+0\
All done!
Done!
Elapsed: 00:13:16
Scatter Load Ok , BaseBand : MT6582 , Project : muse6582_y90_m , Storage : EMMC
Files found : 19 , Set to Flash : 18
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : lge
Device Model : my90ds
Device CPU : MT6582
Device IntName : my90ds_global_com
Device Version : 6.0
CU_SWVer : H50220d
Device Compile : 03/06/2016 11:49:28 أ
Device Project : alps-mp-m0.mp2.tc1sp-release
Device ExtInfo : LG-H502
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 52 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : muse6582_y90_m , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3898 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 4
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000003900000-0x0000000004900000
Erase : 0x0000000008280000-0x0000000002480000
Erase : 0x000000000AB00000-0x00000001C5500000
Flash Pre-Erase Done, time used : 00:00:08
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_muse6582_y90_m.bin
Preloader Sent , Init passed
PartCount : 0024
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : UBOOTBAK
Image Flash Ok
Flash now : LAF
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EBR2
Image Flash Ok
Flash now : EBR3
Image Flash Ok
Flash now : PERSIST
Image Flash Ok
Flash now : LGFOTA
Image Flash Ok
Flash now : CUST
Image Flash Ok
Flash now : FACTORY
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:13:10
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : UBOOTBAK
Verify Passed : LAF
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : EBR2
Verify Passed : EBR3
Verify Passed : PERSIST
Verify Passed : LGFOTA
Verify Passed : CUST
Verify Passed : FACTORY
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:01:26
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:14:57
The Following User Says Thank You to profkefah For This Useful Post:
Old 03-15-2019, 14:58   #57354 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 673
Qmobile g5 reset password done by cm2
Operation : Reset UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 8 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : AEAE7EABB1600DCE5FA3BDC71008E879
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV
[0] : FLASH_DIE : 00EF 0070 0016 0000
[0] : FLASH_LEN : 0x00400000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Backup done
Read ExtData
Sorting ExtData
Sort Ok, Rebuild Ok
Restore ExtData
All done
UserCode request removed
UserCode set to default ( 0000 or 1122 )
Done!
Elapsed: 00:00:11
Old 03-16-2019, 05:34   #57355 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,038
Qmobile S2 MT6580 FRP Reset Done With King Infinity CM2
Card found : S/N : A19EC787 , v0137
Wait for phone...
Phone found! [ 258 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
eMMC Flash : 90014A4838473165050711A1392C82D7
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A4838473165050711A1392C82D7
DEV RID : 0xD9C8F39585E57C56900D28103F9F813A
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:49
Old 03-16-2019, 06:37   #57356 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,038
Infinix X510 MT6580 FRP Reset Done With King Infinity CM2
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 15010051385853414206A593D0F0A2E3
[eMMC] : FLASH_INF : [SAMSUNG] , BASX8
[eMMC] : FLASH_CID : 15010051385853414206A593D0F0A2E3
DEV RID : 0xD9C8F395CD8BFED092A5CCD65DFF3453
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:58
Old 03-16-2019, 07:20   #57357 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,038
Qmobile I2 Pro SPD77XX FRP Reset Done With King Infinity CM2
3. Insert cable
Phone found! [ 41 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v3 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Done!
Elapsed: 00:00:24
Old 03-16-2019, 07:30   #57358 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,038
Vell-com Wtch SPD6531 Logo Stuck Fix Only Formate With King Infinity CM2
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
Phone found! [ 41 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00C8 0060 0016 0000
[0] Flash VEN : GigaDevice , GD25LQ32
[0] Flash CAP : 00400000
Verify data... Can take some time
Init Ok, formatting DIN area ...
Format Block Done!
Done!
Elapsed: 00:00:11
Old 03-16-2019, 08:07   #57359 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,038
Telenor Infinity K MT673 Unlock Done With Kiing Infinity CM2
Operation : SP Unlock [ v1.58 ]
Mode : Direct Unlock
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 460001154D32314588A70D42AB0B2FE0
[eMMC] : FLASH_INF : [SAMSUNG] , BM21E
[eMMC] : FLASH_CID : 150100464531324D420DA788E02F54AB
DEV RID : 0xD9C8F395577720F507D8BC3DCECF37FD
SOC VERIFY : C1
Boot Ok!
SIM Lock Status : Locked!
Unlocking now ...
Unlock done!
Done!
Elapsed: 00:00:32
Old 03-16-2019, 09:33   #57360 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,038
Qmobile X25 MT6572 Dead Set ReAlive Done With King Infinity CM2
Wait for phone...
Phone found! [ 131 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 90014A4834473164040503A213A0B139
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040503A213A0B139
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xD9C8F395E4B82F74C43B55518D7D6DF1
EXT RAM : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
Brand : QMobile
ProdName : X25
ProdModel : QMobile X25
Device : X25
AndroidVer: 4.4.2
MTKxCPU : MT6572
MTKxPRJ : ALPS.KK1.MP6.V1
Done!
Elapsed: 00:00:05
Scatter Load Ok , BaseBand : MT6572 , Project : mtk_android , Storage : EMMC
Files found : 17 , Set to Flash : 16
Ready to Flash!
======= Flash
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : mtk_android , Storage : EMMC
BL : Skip checking by User request!
BL : BatteryLevel : 4015 mV
Total blocks to Erase : 1
Erase : 0x0000000000C00000-0x00000000E7B00000
Flash Pre-Erase Done, time used : 00:00:06
Preloader Download skipped by user request!
PartCount : 0012
Repartition Done!
Use FLN Mode
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : PRO_INFO
Image Flash Ok
Flash now : NVRAM
Image Flash Ok
Flash now : PROTECT_F
Image Flash Ok
Flash now : PROTECT_S
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : MISC
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EXPDB
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:09:06
Processing : Verify
Verify Passed : MBR
Verify Passed : PRO_INFO
Verify Passed : NVRAM
Verify Passed : PROTECT_F
Verify Passed : PROTECT_S
Verify Passed : MISC
Verify Passed : EXPDB
Data Verify Done, time used : 00:02:25
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:11:53
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.56792 seconds with 9 queries
