Old 03-21-2019, 09:54   #57586 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 923
Qmobile d10 reset password done by cm2
Card found : S/N : 73CA70CC , v0137
Operation : Reset UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 3 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : C1254F041E52EF9CE8D8990F47728A3B
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00EC , [GigaDevice] GD25LQ32
[0] : FLASH_DIE : 00C8 0060 0016 0000
[0] : FLASH_LEN : 0x00400000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Backup done
Read ExtData
Sorting ExtData
Sort Ok, Rebuild Ok
Restore ExtData
All done
UserCode request removed
UserCode set to default ( 0000 or 1122 )
Done!
Elapsed: 00:00:12
Reconnect Power/Cable!
The Following User Says Thank You to A.G.Shahid For This Useful Post:
Old 03-21-2019, 10:24   #57587 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,125
Qmobile M350 Pro MT6580 FRP Reset Done With King Infinity CM2
Card found : S/N : A19EC787 , v0137
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 150100514531334D420D60E5B836C329
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM31E
[eMMC] : FLASH_CID : 150100514531334D420D60E5B836C329
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0xD9C8F395E9F4CC427E94CBC4E172D221
INT RAM : 0x00020000
EXT RAM : 0x80000000 [2 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:10
The Following User Says Thank You to azhergoga007 For This Useful Post:
Old 03-21-2019, 10:31   #57588 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,125
Qmobile I6 Metal 1 MT6580 FRP Reset Done With King Infinity CM2
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A48384731650507306154B09303
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A48384731650507306154B09303
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xD9C8F39502DC2038D77502AE9E42FDA1
EXT RAM : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:28
Old 03-21-2019, 11:02   #57589 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,125
Operation : Reset FRP (ADB) [ v1.03 ]
Waiting for device in ADB mode ...
1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need!
2. Insert USB cable, accept AUTH on PhoneScreen, if software ask!
Connect Ok!
Device : i6_Metal_ONE
Model : QMobile i6 Metal ONE
FRP reset passed! Make FACTORY RESET from menu!
Done!
Elapsed: 00:00:15
Old 03-21-2019, 11:30   #57590 (permalink)
fahadboss's Avatar
Member: 2441366
Thanks Meter: 84
QMobile X36 FRP Reset Done by CM2 :)
Old 03-21-2019, 11:53   #57591 (permalink)
gile@gile's Avatar
Member: 1473716
Thanks Meter: 805
Archos Access 50 Color 3G Frp Reset done
Card found: S/N : 07XXXXXX , v0137
Chinese Miracle II [SPD module] v 1.27
Set mode to : SP [SC773x] eMMC [Android 7.x]
Operation : Check/Read Info [ v1.27 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 214 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC773x eMMC Loader v7 InfinityBox
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name : SCAC50ASCLR3G_ARCHOS
Model Brand : archos
Model Device: ac50asclr3g
AndrVersion : 7.0
BaseBand CPU: SP7731CEA
CompileDate : 8/21/2017 8:44:21 AM
Project Ver : NRD90M [email protected]spermum
Model Ext : Archos Access 50 Color 3G
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:33
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:34
Old 03-21-2019, 13:26   #57592 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 923
Qmobile m95 hang on logo done by cm2
Card found: S/N : 73CA70CC , v0137
Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0]
Infinity SC Firmware Detected
FW Size : 1239 MiB
Load Ok!
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : SC77xx Infinity Package
3. Insert cable
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC773x Android 5.x eMMC v1.0 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
[FL] : Enabled NVM update. Will program all NVM images found in FW !
PMTManager : Load 0x17 records
PMTManager : PMT Update Ok!
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write FSImage : prodnv.img
Write Data ...
Write Data Ok!
Update NVM image : nvitem.bin
Update NVM Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Erase block ...
Block erase Ok!
Update NVM image : nvitem_wcn.bin
Update NVM Data Ok!
Erase block ...
Block erase Ok!
Erase block ...
Block erase Ok!
Write CodeData : sc7731g_CP0_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Write CodeData : sc8830g_modem_CP2_WCN_14D_W15.16_Release.bin
Write Data ...
Write Data Ok!
Write CodeData : logo_540x960.bin
Write Data ...
Write Data Ok!
Write CodeData : fblogo_540x960.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system.img
Write Data ...
Write Data Ok!
Write FSImage : cache.img
Write Data ...
FSImage : Make and Flush SPImage
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Process : Flush
Flush Ok!
Write FSImage : userdata.img
Write Data ...
Write Data Ok!
Elapsed: 00:04:19
Old 03-21-2019, 13:30   #57593 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 923
Qmobile x30 hang on logo done by cm2
Card found : 73CA70CC , v0137
Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.05
Load IDBase v319103 Ok!
Update configuration ...
Update Ok!
Operation : Identify [ v2.05 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM Port (COM81)
MODE : PRELOADER PORT
PORT : 81
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6572 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000000
BROM : SecMode : PLAIN [+PRL]
BROM : PRELOADER PORT
MODE : 0_base : BASE_v1712 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6572
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
NAND : DEVICE NOT FOUND
eMMC : OK
eMMC : 484A019061324734C69F011111629581
DAInf: 4 : 2 : 136
DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : Receiving HW info
EMMC: 90014A483447326111019FC681956211
EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H4G2a
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0xE9000000 [ 3.64 GB ]
SRAM: 0x00020000 [ 128.00 KB ]
DRAM: 0x20000000 [ 512.00 MB ]
CHIP : MT6572 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 8157A6EAB1DEC6CC0141CC331694EFB
STATUS : BLANK FLASH
BSTYLE : EMMC FLASH BOOT
DA : USB : HIGH-SPEED
Boot done!
Patch Level : KOT49H
Display ID : ALPS.KK1.MP7.V1
Ver. CodeName : REL
Ver. Release : 4.4.2
Build Time : 1430722225
Product Model : QMobile X30
Product Brand : TINNO
Product Name : QMobile X30
Product Device : QMobile X30
Product Board : s4050ap
Product Manfct : QMobile
Product Info : s4050ap
USERDATA : PLAIN ( NOT encrypted )
Done!
Elapsed: 00:00:16
Preloader [HW DEV] Info :
EMI : DEV : MT6572
EMI : SRC : preloader_s4050ap.bin
EMI : CNT : 0002
EMI : [00] : eMCP : eMMC+LP/DDR2 , ID : 110100303034474530 : VEN : TOSHIBA | DEV : 004GE0 : RAM : [ 512.00 MB ]
EMI : [01] : eMCP : eMMC+LP/DDR2 , ID : 90014A483447326111 : VEN : HYNIX | DEV : H4G2a : RAM : [ 512.00 MB ]
Operation : Write Flash [ v2.05 ]
Repartition : Enabled
Flash Verify : Disabled
Reg.Pre-Erase : Enabled
Verify HW/SW : Enabled
SData Backup : Disabled
Safe UserData : Disabled
Files :11
[FL] : Set : preloader_s4050ap.bin
[FL] : Set : MBR
[FL] : Set : EBR1
[FL] : Set : lk.bin
[FL] : Set : boot.img
[FL] : Set : recovery.img
[FL] : Set : secro.img
[FL] : Set : logo.bin
[FL] : Set : system.img
[FL] : Set : cache.img
[FL] : Set : userdata.img
[FL] : Total size : 0x3E18C654 [ 993.55 MB ]
PORT : 81
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 136
DA : DRAM ready!
EMMC:
Boot done!
[FL] : HW verification passed!
SEC_DL : False (CUST)
SEC_DL : SECURE USB DL DISABLED
SEC_ID : 0x35464646304237304435444533464335
[FL] : Pre-Erase
Erase : 0x0000000000C00000 : 0x0000000000100000
Erase : 0x0000000002900000 : 0x00000000E5E00000
[FL] : RePartition
[FL] : RePartition Ok!
[FL] : Flashing now ...
Write : PRELOADER
Update bootloader code ...
Update bootloader Ok!
Write : MBR
Write : EBR1
Write : UBOOT
Write : BOOTIMG
Write : RECOVERY
Write : SEC_RO
Write : LOGO
Write : ANDROID
Write : CACHE
Write : USRDATA
[FL] : RePartition
[FL] : Flashing finished!
Done!
Elapsed: 00:03:03
Old 03-21-2019, 13:36   #57594 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 923
Qmobile i6 metal one reset frp done by cm2
Set mode to : SP [SC773x] eMMC [Android 6.x]
3. Insert cable
Phone found! [ 18 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Reset Ok!
Done!
Elapsed: 00:00:43
Old 03-21-2019, 14:10   #57595 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 923
Vgotel i525 reset password done by cm2
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 3 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_SN : E652E461F816BC5BFF3ECDF58AD5416D
Setting...
BROM stage done
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV
[0] : FLASH_DIE : 00EF 0070 0016 0000
File_Info : RDR61D_F118_PCB01_gprs_MT6261_S00.VGOTEL_VMATE_I52 5_V07.bin
FileVersion : VGOTEL_VMATE_i525_V07
Done!
Elapsed: 00:00:06
Wait for phone...
Phone found! [ 3 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
SOC_VERIFY : 0xC1
Backup done
Read ExtData
Sorting ExtData
Sort Ok, Rebuild Ok
Restore ExtData
All done
Done!
Elapsed: 00:00:11
Operation : Read Flash [ v1.58 ]
Wait for phone...
Phone found! [ 3 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
SOC_VERIFY : 0xC1
Reading Flash Content now ...
Read Flash now
Read Ok , 4194304 bytes read
Check and collect compile info
Saved to : C:\InfinityBox\CM2MTK\Read_out\RDR61D_F118_PCB01_g prs_MT6261_S00.VGOTEL_VMATE_I525_V07.bin
Done!
Elapsed: 00:00:14
Old 03-21-2019, 14:31   #57596 (permalink)
okb
Member: 2697682
Thanks Meter: 46
Talking Itel a14 flashed successfully by cm2 while other tool failed
3. Insert cable
Phone found! [ 11 ]
Port Opened
Sync...
Sync...
Sending FDL
PickUp loaders from pac
FDL Ready!
Boot Ver : Spreadtrum Boot Block version 1.1
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : PMT Update skipped by user!
Flashing now
[FlashProc] : NVM Update
Current ID : NV_W
Current Part : w_fixnv1
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : PRODNV
Current File : prodnv.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : ERASEUBOOT
Current Part : uboot
[FlashProc] : Ok!
[FlashProc] : BOOTCODE
Current ID : SPLLOADER
Current File : u-boot-spl-16k-sign.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : VBMETA
Current File : vbmeta-sign.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_W
Current File : SC9600_pike2_pubcp_PLD_base_nv_modem.dat
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_W_DELTANV
Current File : delta_nv.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : DSP_GSM
Current File : PIKE2_DM_DSP.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : DFS
Current File : pike2_cm4.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : GPS_GL
Current File : gnssbdmodem.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : GPS_BD
Current File : gnssmodem.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_WCN
Current File : PM_pike2_cm4.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOT
Current File : boot.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : RECOVERY
Current File : recovery.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : SYSTEM
Current File : system.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : USERDATA
Current File : userdata.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOTLOGO
Current File : logo.bmp
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : FASTBOOT_LOGO
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : CACHE
Current File : cache.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : VENDOR
Current File : vendor.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : FLASH_W
Current Part : w_runtimenv1
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : ERASEMISC
Current Part : misc
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : TRUSTOS
Current File : tos-sign.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : SML
Current File : sml-sign.bin
Flashing now ...
[FlashProc] : Ok!
Current ID : UBOOTLOADER
Current File : u-boot-sign.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : PERSIST
Current File : persist.img
Flashing now ...
[FlashProc] : Ok!
Elapsed: 00:05:12
The Following 3 Users Say Thank You to okb For This Useful Post:
Old 03-21-2019, 15:06   #57597 (permalink)
fahadboss's Avatar
Member: 2441366
Thanks Meter: 84
QMobile i6 Metal One v2 FRP Reset done by CM2 :)
Old 03-21-2019, 15:57   #57598 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,125
Qmobile X2 MT6571 Hang Logo Fix Only Formate With Infinity CM2
Wait for phone...
Phone found! [ 258 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6571
BB_CPU_NME : [MediaTek] MT6571_S00
BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x8B
NAND Flash : 009800BC009000660076001600080000
eMMC Flash : NOT INSTALLED
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1
[NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008
[NAND] : FLASH_LEN : 0x20000000
[NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1
DEV RID : 0xD9C8F3950583617AB394111289766111
EXT RAM : 0x10000000 [256 MiB]
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:13
Old 03-21-2019, 16:23   #57599 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 923
Qmobile w7 reset pattern done by cm2
Set mode to : SP [SC7715] NAND [Generic]
3. Insert cable
Phone found! [ 35 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC7715 Loader NAND v1.1 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Detected NAND Flash , Structure detect Ok!
Formatting NAND Flash
Format UserData
Format Ok!
Format Cache
Format Ok!
Done!
Elapsed: 00:00:45
Old 03-21-2019, 16:32   #57600 (permalink)
sikandar.mehdi's Avatar
Member: 2080403
Sonork: 100.1645596
Thanks Meter: 50
OPPO A83 new security formate don with test point
Card found : 7D288E76 , v0137
Load IDBase v123080 Ok!
Operation : Reset Settings/Format FS [ v2.05 ]
PTFN : MediaTek USB Port (COM96)
MODE : BOOTROM
PORT : 96
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x000000E5
BROM : SecMode : SBC+SDA+ARB
BROM : BOOTROM
MODE : Oppo : F5 | Manual : Disabled
BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 4000 0036 F7: 102D 0000 00: 1005 0000 F3: 4000 0036 F7: 102D 0000 01: 102A 0001
BROM : SOCID : 1FAB024E192979AE5B8E4FF41EFC36C2CFC1413EED3F0351D1 061A36662CFFCD
BROM : SLA
BROM : SLA Passed!
BROM : SLA CHLNG not used
AGENT : DA_PL_CRYPTO.bin
AGENT : Found MT6763
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : MT6763
EMI : SRC : preloader_oppo6763_17031.bin
EMI : CNT : 000F
EMI : [00] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 0 B ]
EMI : [01] : eMCP : eMMC+LP/DDR4 , ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4.00 GB ]
EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4.00 GB ]
EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4.00 GB ]
EMI : [04] : eMCP : eMMC+LP/DDR4 , ID : 150100334836434D42 : VEN : SAMSUNG | DEV : 3H6CMB : RAM : [ 6.00 GB ]
EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4.00 GB ]
EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3.00 GB ]
EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3.00 GB ]
EMI : [08] : eMCP : eMMC+LP/DDR3 , ID : 150100474536424D42 : VEN : SAMSUNG | DEV : GE6BMB : RAM : [ 3.00 GB ]
EMI : [09] : eMCP : eMMC+LP/DDR3 , ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4.00 GB ]
EMI : [0A] : eMCP : eMMC+LP/DDR3 , ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3.00 GB ]
EMI : [0B] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ]
EMI : [0C] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4.00 GB ]
EMI : [0D] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3.00 GB ]
EMI : [0E] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6.00 GB ]
EMI : Init EMI from PRELOADER
EMI : EXT_RAM CFG Passed!
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
SRAM: 0x00040000 [ 256.00 KB ]
DRAM: 0x70000000 [ 1.75 GB ]
EMMC: 150100524836344142051F0AE04435E9
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RH64AB
EMMC:
USER : 0xE8F800000 [ 58.24 GB ]
CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 19ADF6E1E9B7BDD9D7B874E2AB10712A
Boot done!
Format Ok : USERDATA
Format Ok : CACHE
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:02:28
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-29-2010 21:17
Page generated in 0.84703 seconds with 9 queries
