Old 04-16-2019, 14:25   #58066 (permalink)
Member: 2812901
Thanks Meter: 359
Tecno KA7 screen lock and FRP done by Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.05 .......................
Card found : 5B5B5Bxx , v0137
Load IDBase v46104 Ok!
Operation : Reset Settings/Format FS [ v2.05 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM (Android) (COM5)
MODE : PRELOADER PORT
PORT : 5
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000005
BROM : SecMode : SBC+SDA
BROM : PRELOADER PORT
MODE : 0_base : BASE_v1712 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6580
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : 0x00002001 : DA SEND ERROR!
ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE!
INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO/SWSEC
Error : Fail to init protocol!
Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable!
Operation : Identify [ v2.05 ]
PORT : 5
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
MODE : TECNO : Tecno KA7 | Manual : Disabled
AGENT : MTK_AllInOne_DA_SP.bin
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
NAND : DEVICE NOT FOUND
NAND : 000000000000000000000000
eMMC : OK
eMMC : 460001154D32364534C90342C9850807
DAInf: 4 : 2 : 156
DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : Receiving HW info
EMMC: 150100464536324D4203C93470885C9
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FE62MB
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x3A3E00000 [ 14.56 GB ]
SRAM: 0x00020000 [ 128.00 KB ]
DRAM: 0x40000000 [ 1.00 GB ]
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 3A873F4CA851F919A60E0F1FC7E385C1
STATUS : BLANK FLASH
BSTYLE : EMMC FLASH BOOT
DA : USB : HIGH-SPEED
Boot done!
Patch Level : O11019
Display ID : KA7-H8024ABC-GO-181227V193
Ver. CodeName : REL
Ver. Release : 8.1.0
Sec. Patch : 2018-12-05
Build Time : 1545840469
Product Model : TECNO KA7
Product Brand : TECNO
Product Name : H8024
Product Device : TECNO-KA7-GO
Product Manfct : TECNO MOBILE LIMITED
Product Info : TECNO-KA7-GO
Board Platform : mt6580
USERDATA : ENCRYPTED
Done!
Elapsed: 00:00:18
PORT : 5
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 156
DA : DRAM ready!
EMMC:
Boot done!
Format Ok : USERDATA
Done!
Elapsed: 00:00:19
Info : Operation break by user!
PORT : 5
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 156
DA : DRAM ready!
EMMC:
Boot done!
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:30
Old 04-16-2019, 14:26   #58067 (permalink)
Member: 2812901
Thanks Meter: 359
Itel A11 userlock and FRP done by Chinese Miracle II [SPD module] v 1.27
Card found: S/N : 5B5B5Bxx , v0137
Set mode to : SP [SC773x] eMMC [Android 6.x]
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 14 ]
Open Port Failed!
3. Insert cable
Phone found! [ 14 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:33
Old 04-16-2019, 14:51   #58068 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 14,521
Smile Qmobile e2 Format Done
Operation : Format FileSystem [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 26 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 3B682B463B8CBAD5D29234E2380BACE5
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV
[0] : FLASH_DIE : 00EF 0070 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Backup done
Executing FFS FORMAT now...
FAT_RANGE : 0x003AC000-0x003FDFFF , LEN : 0x00052000
DA_RET : DA_IN_PROGRESS
DA_RET : FORMAT_DONE
Done!
Elapsed: 00:00:18
Old 04-16-2019, 14:58   #58069 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 863
QMOBILE X700i HANG ON LOGO DONE BY CM2
Card found : S/N : 73CA70CC , v0137
Scatter Load Ok , BaseBand : MT6580 , Project : d5110_qmobile , Storage : EMMC
Files found : 9 , Set to Flash : 8
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : QMobile
Device Model : d5110_qmobile
Device CPU : MT6580
Device IntName : d5110_qmobile
Device Version : 5.1
Device Compile : 7/17/2015 12:51:50 PM
Device Project : ALPS.L1.MP6.V2_RGK6580.WE.L_P2
Device ExtInfo : QMobile X700i
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 150100523832314D4200E003CA6E722B
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM128
[eMMC] : FLASH_CID : 150100523832314D4200E003CA6E722B
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0x0CF2E6DE176B77EE19AD1C77DEB15E93
INT RAM : 0x00020000
EXT RAM : 0x80000000 [2 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6580 , Project : d5110_qmobile , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3550 mV
BL : [WARNING] : BatteryLevel LOW!!!
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000001C80000-0x0000000003320000
Erase : 0x00000000050A0000-0x000000039DCE0000
Flash Pre-Erase Done, time used : 00:00:08
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_d5110_qmobile.bin
Preloader Sent , Init passed
PartCount : 0014
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : LK
Image Flash Ok
Flash now : BOOT
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : SECRO
Image Flash Ok
Flash now : SYSTEM
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USERDATA
Image Flash Ok
Flash Write Done, time used : 00:08:34
Processing : Verify
Verify Passed : LK
Verify Passed : BOOT
Verify Passed : RECOVERY
Verify Passed : LOGO
Verify Passed : SECRO
Verify Passed : SYSTEM
Verify Passed : CACHE
Verify Passed : USERDATA
Data Verify Done, time used : 00:00:03
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:08:57
Old 04-16-2019, 15:07   #58070 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 863
Qmobile xl8 reset password done by cm2
Operation : Reset UserCode [ v1.58 ]
Wait for phone...
Phone found! [ 3 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_SN : 7155D9A00D5172C9C9B654AA1B0DED46
Setting...
BROM stage done
SOC_VERIFY : 0xC1
Backup done
Read ExtData
Sorting ExtData
Sort Ok, Rebuild Ok
Restore ExtData
All done
UserCode request removed
UserCode set to default ( 0000 or 1122 )
Done!
Elapsed: 00:00:16
Old 04-17-2019, 05:31   #58071 (permalink)
niaz muhammad's Avatar
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,897
l820l format frp reset don
Card found : CE90936C , v0137
Infinity-Box LG Service Tool [ LGS ] v1.03
Operation : Reset Settings/Format FS [ v1.03 ]
2. PRESS and HOLD VOLUME UP KEY!
3. Insert USB cable, wait until Download mode screen will appear
Wait for phone...
Connection opened successfully!
Waiting for loader ...
Handshake passed!
Collect info...
Prepare passed, mode 0x01
Boot done!
Format UserData
Format Cache
Format done
Erase FRP#0 block Ok!
Erase FRP#1 block Ok!
Done!
Elapsed: 00:00:29
Old 04-17-2019, 05:39   #58072 (permalink)
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,897
lg 820l reed firmware don
Operation : Read Firmware [ v1.03 ]
Wait for phone...
Handshake passed!
Collect info...
Boot done!
DevInfo : MT6753__LG-F820L__F820L10g__V10g__AOSv6.0.1__LGF820LAT-00-V10g-LGU-KR-SEP-25-2017+0
Reading Flash Content ...
[Read Ok] : gpt_main.bin
[Read Ok] : lgmsnv.bin
[Read Ok] : ftm.img
[Read Ok] : nvitems.bin
[Read Ok] : lk.img
[Read Ok] : laf.img
[Read Ok] : para.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : lsplash.img
[Read Ok] : secro.img
[Read Ok] : tz.bin
[Read Ok] : persist_lg.img
[Read Ok] : fact.img
[Read Ok] : persist.img
[Read Ok] : swfuse.bin
[Read Ok] : system.img
[Read Ok] : gpt_backup.bin
Android Info saved!
Read finished!
Configuration : MT6753 / 6.0.1 / V10g
Firmware Size : 3340 MiB
Done!
Elapsed: 00:03:49
Old 04-17-2019, 05:51   #58073 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Lenovo A7000-a Format Done
PTFN : MediaTek PreLoader USB VCOM (Android) (COM30)
PORT : 30
BROM : Init BROM
BROM init passed!
CHIP : MT6752 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000000
BROM : SecMode : PLAIN [+PRL]
AGENT : Found MT6752
BROM : DA sent
DA : AGENT started!
eMMC : OK
eMMC : 520001154D3132384A7E004297A2B6E4
DAInf: 4 : 2 : 143
DA : DRAM ready!
EMMC: 150100523832314D42007E4AE4B6A297
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : R821MB
EMMC:
DRAM: 0x80000000 [ 2.00 GB ]
CHIP : MT6752 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 , EVOL : 0x0000
RNID : 4D40626461B54D05653CAF9C5D236CC2
Boot done!
Format Ok : CACHE
Done!
Elapsed: 00:00:41
Old 04-17-2019, 06:21   #58074 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 863
Qmobile m95 hang on logo done by cm2
Card found: S/N : 73CA70CC , v0137
Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0]
Infinity SC Firmware Detected
FW Size : 1239 MiB
Load Ok!
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : SC77xx Infinity Package
3. Insert cable
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC773x Android 5.x eMMC v1.0 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
[FL] : Enabled NVM update. Will program all NVM images found in FW !
PMTManager : Load 0x17 records
PMTManager : PMT Update Ok!
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write FSImage : prodnv.img
Write Data ...
Write Data Ok!
Update NVM image : nvitem.bin
Update NVM Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Erase block ...
Block erase Ok!
Update NVM image : nvitem_wcn.bin
Update NVM Data Ok!
Erase block ...
Block erase Ok!
Erase block ...
Block erase Ok!
Write CodeData : sc7731g_CP0_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Write CodeData : sc8830g_modem_CP2_WCN_14D_W15.16_Release.bin
Write Data ...
Write Data Ok!
Write CodeData : logo_540x960.bin
Write Data ...
Write Data Ok!
Write CodeData : fblogo_540x960.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system.img
Write Data ...
Write Data Ok!
Write FSImage : cache.img
Write Data ...
FSImage : Make and Flush SPImage
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Process : Flush
Flush Ok!
Write FSImage : userdata.img
Write Data ...
Write Data Ok!
Elapsed: 00:04:19
Old 04-17-2019, 06:27   #58075 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 863
Qmobile e4 hang on logo done by cm2
Wait for phone...
Phone found! [ 3 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_SN : 333CE31F96A60EA25D61B6B3D810BF3C
Setting...
BROM stage done
SOC_VERIFY : 0xC1
Backup done
FAT_RANGE : 0x0039E000-0x003FDFFF , LEN : 0x00060000
Done!
Elapsed: 00:00:11
Old 04-17-2019, 11:03   #58076 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 863
Qmobile z8 reset frp done by cm2
Card found : 73CA70CC , v0137
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16
Operation : Reset Settings [ v1.16 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 13C4F629
ID_BLOCK_L : BE463CDA75E1EE19C6BB55BA85DC5474
ID_BLOCK_L : 9FF658F3E46FDF54694409C6CC233D1E
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:17
Old 04-17-2019, 11:07   #58077 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 863
Qmobile x36 reset frp done by cm2
Set mode to : SP [SC773x] eMMC [Android 7.x]
Operation : Check/Read Info [ v1.27 ]
3. Insert cable
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC773x eMMC Loader v7 InfinityBox
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name : QMobile_X36
Model Brand : QMobile
Model Device: QMobile_X36
AndrVersion : 7.0
BaseBand CPU: X36
CompileDate : 9/20/2017 4:27:17 AM
Project Ver : NRD90M
Model Ext : QMobile X36
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:57
3. Insert cable
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Reset Ok!
Done!
Elapsed: 00:00:54
Old 04-17-2019, 11:19   #58078 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 863
Qmobile i6 matle one hang on logo done by cm2
FW Size : 2874 MiB
Load Ok!
File Info
Device Model : i6_Metal_ONE_new
Device CPU : i6_Metal_ONE
Device IntName : i6_Metal_ONE
Device Version : 6.0
Device Compile : 12/15/2016 10:31:38 AM
Device Project : MRA58K release-keys
Device ExtInfo : QMobile i6 Metal ONE
======= Flash
3. Insert cable
Phone found! [ 12 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x19 records
Flashing now
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write CodeData : sc7731C_CP0_modem.bin
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Write CodeData : sc8830g_modem_CP2_WCN_Trunk_W16.28.5_Release.bin
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Write CodeData : logo_480x854.bin
Write Data ...
Write Data Ok!
Write CodeData : fblogo_480x854.bin
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Erase Block : PERSIST
Erase block ...
Block erase Ok!
Write CodeData : sysinfo.img
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Erase Block : MISC
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Elapsed: 00:07:11
Old 04-17-2019, 11:50   #58079 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 863
Vgotel i8 reset password done by cm2
Wait for phone...
Phone found! [ 3 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_SN : AA04E1066E3F1B5BC148DAE91B6EE036
Setting...
BROM stage done
SOC_VERIFY : 0xC1
[0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09
[0] : FLASH_DIE : 00C2 0020 0016 0000
Backup done
Read ExtData
Sorting ExtData
Sort Ok, Rebuild Ok
Restore ExtData
All done
Done!
Elapsed: 00:00:12
Old 04-17-2019, 13:03   #58080 (permalink)
Member: 2812901
Thanks Meter: 359
INFINIX NOTE 4 X571 FRP DONE BY Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.05 ...............................................
Card found : 5B5B5BXX , v0137
Update configuration ...
Socket Error # 11001
Host not found.
Update failed! Check settings and/or internet connection!
PTFN : MediaTek PreLoader USB VCOM (Android) (COM4)
PORT : 4
BROM : Init BROM
BROM init passed!
CHIP : MT6753 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : LEGACY MTK
AGENT : Found MT6753
BROM : DA sent
DA : AGENT started!
eMMC : OK
eMMC : 150100525831424D420785ED9700C041
DAInf: 4 : 2 : 155
DA : DRAM ready!
EMMC: 150100525831424D420785ED97006441
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RX1BMB
EMMC:
USER : 0x747C00000 [ 29.12 GB ]
DRAM: 0xC0000000 [ 3.00 GB ]
CHIP : MT6753 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 74DAC4C7613DFEC6F805CB5E3BD036B0
Boot done!
Patch Level : NRD90M
Display ID : X571-H5311A-N-170727V180
Ver. CodeName : REL
Ver. Release : 7.0
Sec. Patch : 2017-07-05
Build Time : 1501136538
Product Model : Infinix X571
Product Brand : Infinix
Product Name : H5311
Product Device : Infinix-X571
Product Manfct : Infinix
Board Platform : mt6753
Product Info : Infinix-X522
Done!
Elapsed: 00:00:27
PORT : 4
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 155
DA : DRAM ready!
EMMC:
Boot done!
Done!
Elapsed: 00:00:26
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.51648 seconds with 9 queries
