Old 05-09-2019, 07:36   #58486 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Lg m700 reset frp done by cm2
Card found : 73CA70CC , v0137
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16
Operation : Reset Settings [ v1.16 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 435 [MSM8940]
ID_BLOCK_S : 83137F99
ID_BLOCK_E : 00310000
ID_BLOCK_L : CE10BE78C06FCBF5F9A5028856A1919F
ID_BLOCK_L : 15A378141EB662E2E027AD955F9640F6
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HBG4a2
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:35
Reconnect Power/Cable!
Old 05-09-2019, 08:25   #58487 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Qmobile x2 hang on logo done by cm2
Card found : S/N : 73CA70CC , v0137
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6571
BB_CPU_NME : [MediaTek] MT6571_S00
BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x8B
NAND Flash : 009800BC009000660076001600080000
eMMC Flash : NOT INSTALLED
Initialize Memory ...
DAgent sent , init HW now
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1
[NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008
[NAND] : FLASH_LEN : 0x20000000
[NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1
DEV RID : 0x0B9C44DE19C591CE296A6DFF16B806A4
INT RAM : 0x00020000
EXT RAM : 0x10000000 [256 MiB]
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:15
Old 05-09-2019, 08:31   #58488 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Club m30 reset password done by cm2
Operation : Reset UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 6 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : EA1D18EC795C750B4A0F596BC52B4E06
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09
[0] : FLASH_DIE : 00C2 0020 0016 0000
[0] : FLASH_LEN : 0x00300000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Backup done
Read ExtData
Sorting ExtData
Sort Ok, Rebuild Ok
Restore ExtData
All done
UserCode request removed
UserCode set to default ( 0000 or 1122 )
Done!
Elapsed: 00:00:10
Old 05-10-2019, 09:08   #58489 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,279
Smile MICROMAX Q326 AND:5.1 SC7731G BRUSH HANG ON LOGO Done
SUCCESSFULLY BRUSH HANG ON LOGO(MICROMAX Q326 AND:5.1 SC7731G)USB
Operation : Check/Read Info [ v1.27 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 25 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC773x Android 5.x eMMC v1.0 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name : Q326
Model Brand : Micromax
Model Device: Q326
AndrVersion : 5.1
BaseBand CPU: Q326
CompileDate : 6/30/2016 7:00:25 AM
Project Ver : Micromax_Q326_SW_V015_HW_V2.0_20160630
Model Ext : Micromax Q326
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:18
Operation : Flash [ v1.27 ]
======= Flash
Files set for flashing :
[ MCU ] : Micromax_Q326_SW_V012_HW_V2.0_20160107.pac
CRVersion : BP_R1.0.0
PacCPUinfo : SC77xx
PacVersion : Micromax_Q326_SW_V012_HW_V2.0_20160107
File : fdl1.bin
File : fdl2.bin
File : nvitem.bin
File : nvitem_wcn.bin
File : u-boot-spl-16k.bin
File : SC7702_sc7731g_band128.bin
File : DSP_DM_G2.bin
File : SC8800G_x30g_wcn_dts_modem.bin
File : boot.img
File : recovery.img
File : system.img
File : persist.img
File : userdata.img
File : LOGO.bmp
File : LOGO.bmp
File : prodnv.img
File : cache.img
File : u-boot.bin
3. Insert cable
Phone found! [ 25 ]
Port Opened
Sync...
Sync...
Sending FDL
PickUp loaders from pac
FDL Ready!
Boot Ver : Spreadtrum Boot Block version 1.1
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x18 records
PMTManager : PMT Update Ok!
Flashing now
[FlashProc] : ERASE
Current ID : ERASEUBOOT
Current Part : uboot
[FlashProc] : Ok!
[FlashProc] : BOOTCODE
Current ID : SPLLOADER
Current File : u-boot-spl-16k.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_W
Current File : SC7702_sc7731g_band128.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : DSP_W
Current File : DSP_DM_G2.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : MODEM_WCN
Current File : SC8800G_x30g_wcn_dts_modem.bin
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOT
Current File : boot.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : RECOVERY
Current File : recovery.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : SYSTEM
Current File : system.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : PERSIST
Current File : persist.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : USERDATA
Current File : userdata.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : BOOTLOGO
Current File : LOGO.bmp
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : FASTBOOT_LOGO
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : FLASH
Current Part : wruntimenv1
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : FLASH_WCN
Current Part : wcnruntimenv1
[FlashProc] : Ok!
[FlashProc] : CODE
Current ID : PRODNV
Current File : prodnv.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : IMAGE
Current ID : CACHE
Current File : cache.img
Flashing now ...
[FlashProc] : Ok!
[FlashProc] : ERASE
Current ID : ERASEMISC
Current Part : misc
[FlashProc] : Ok!
Current ID : UBOOTLOADER
Current File : u-boot.bin
Flashing now ...
[FlashProc] : Ok!
Elapsed: 00:05:30
THANKS INFINITY-BOX TEAM
The Following 3 Users Say Thank You to gracy_elec For This Useful Post:
Old 05-10-2019, 09:15   #58490 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,279
Smile VIVO Y55S 1610 AND:6.0.1 SnapDragon 425 [MSM8917] BRUSH HANG ON LOGO Done
SUCCESSFULLY BRUSH HANG ON LOGO(VIVO Y55S 1610 AND:6.0.1 SnapDragon 425 [MSM8917])USB
Operation : Identify [ v1.16 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 425 [MSM8917]
ID_BLOCK_S : 112794E4
ID_BLOCK_L : 4D88B352DD4091CD49A3C92DC9F4481B
ID_BLOCK_L : E0A53FD222D0E7A021BE5213BC506537
Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003A3E00000 [ eMMC 16 GiB ]
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RE1BMB
Boot Ok!
Brand : vivo
ProdName : PD1613BF_EX
ProdModel : vivo 1610
Device : msm8937_32
AndroidVer: 6.0.1
Manufact. : vivo
SysPatch : MMB29M
DevComTime: 5/25/2017 12:23:20 PM
QLMxCPU : MSM8937
USERData : ENCRYPTED
GCSec : EMPTY
Done!
Elapsed: 00:00:13
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:17
The Following 2 Users Say Thank You to gracy_elec For This Useful Post:
Old 05-10-2019, 09:22   #58491 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,279
Smile ELITE MAX AND:6.0.1 SnapDragon 430 [MSM8937] BRUSH PATTERN & FRP Done
SUCCESSFULLY BRUSH PATTERN & FRP(ELITE MAX AND:6.0.1 SnapDragon 430 [MSM8937])USB
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 430 [MSM8937]
ID_BLOCK_S : 41698236
ID_BLOCK_L : B3B52FD786EC1914F3A8A8B572C94981
ID_BLOCK_L : 2053FD4C41D07A8B0EE9A21B698492B9
Boot Ok!
Brand : Android
ProdName : msm8937_64
ProdModel : Elite Max
Device : msm8937_64
AndroidVer: 6.0.1
Manufact. : unknown
SysPatch : MMB29M
DevComTime: 11/18/2016 5:55:18 AM
QLMxCPU : MSM8937
GCSec : NORMAL
Done!
Elapsed: 00:00:13
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:17
Old 05-10-2019, 09:27   #58492 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,279
Smile VIVO Y55L 1603 AND:6.0.1 SnapDragon 430 [MSM8937] BRUSH PATTERN & FRP Done
SUCCESSFULLY BRUSH PATTERN & FRP(VIVO Y55L 1603 AND:6.0.1 SnapDragon 430 [MSM8937])USB
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_S : 00BD461B
ID_BLOCK_L : 04D3F81B8609C68410D890629EBD3142
ID_BLOCK_L : 96DB51A45CA68D369F282879D63EF349
Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : QE13MB
Boot Ok!
Brand : vivo
ProdName : PD1613F_EX
ProdModel : vivo 1603
Device : msm8937_32
AndroidVer: 6.0.1
Manufact. : vivo
SysPatch : MMB29M
DevComTime: 7/7/2018 12:10:18 PM
QLMxCPU : MSM8937
GCSec : NORMAL
Done!
Elapsed: 00:00:13
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:42
Old 05-10-2019, 09:33   #58493 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,279
Smile SONY XPERIA XA F3116 AND:7.0 MT6755 BRUSH FRP Done
SUCCESSFULLY BRUSH FRP(SONY XPERIA XA F3116 AND:7.0 MT6755)USB
Infinity-Box Android Service Tool [AST] v1.03
Operation : Identify (ADB) [ v1.03 ]
Waiting for device in ADB mode ...
1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need!
2. Insert USB cable, accept AUTH on PhoneScreen, if software ask!
Connect Ok!
Device Info :
Vendor : Sony
Model : F3116
Device : F3116
Android : 7.0
Product : tuba
Brand : Sony
Serial : RQ3003HC5Y
Build_tm : Tue Jun 27 11:56:55 CST 2017
DisplayID : 33.3.A.0.131
Patch Ver : 33.3.A.0.131
SecPatch : 2017-05-05
Hardware : mt6755
MTK SVer : S01
MTK HVer : MT6755
MTK Prj : alps-mp-n0.mp103.tc9sp-V2.26_cci55.64.sm10.n_TMP1
CPU rel : arm64-v8a
SIM Card : ABSENT,ABSENT
BaseBand : MOLY.LR11.W1603.MD.TC9.SM10SM20.CAF.SP.V1.P1, 2017/06/16 00:26
RIL ver : android reference-ril 1.0
USB Conf : mtp,adb
Sys USB : mtp,adb
FS Crypt : encrypted
OEM Unlck : 1
Done!
Elapsed: 00:00:05
Operation : Reset FRP (ADB) [ v1.03 ]
Connect Ok!
Device : F3116
Model : F3116
FRP reset passed! Make FACTORY RESET from menu!
Done!
Elapsed: 00:00:10
Old 05-10-2019, 09:43   #58494 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,279
Smile MOTO G6 XT1925-13 SDM450 BRUSH PATTERN & FRP Done
SUCCESSFULLY BRUSH PATTERN & FRP(MOTO G6 XT1925-13 SDM450)USB
Operation : Identify [ v1.03 ]
Waiting for device in fastboot mode ...
1. Power off device. Press and hold 'VOL DOWN' button
2. Insert USB cable, hold button until device will be found!
Connect Ok!
Main Info ============
CPU : SDM450
CID : 0x0032
IMEI : 3518XXXXXXXX394
UID : 82ADE47600000000000000000000
Model Info ============
DevModel : XT1925-13
IntName : ali
SW Info ============
DevSWVer : Blur_Version.27.81.56.ali.retail.en.US
DevQCVer : LA.UM.6.6.r1-04400-89xx.0
BaseBand : M450_03.08.10.51R ALI_INDIADSDS_CUST
BootLDRv : moto-sdm450-C3.09
HW Info ============
eMMCInfo : 64GB SAMSUNG RH64AB RV=08 PV=05 FV=0000000000000005
DRAMInfo : 4GB SAMSUNG LP3 DIE=8Gb M5=01 M6=06 M7=00 M8=5F
Lock Info ============
WarrantyVoid : no
FRP Lock : protected (144)
Done!
Elapsed: 00:00:04
Operation : Reset Settings [ v1.03 ]
Mode : Format FS
Connect Ok!
Block [1] ERASE OK!
Block [2] ERASE OK!
Done!
Elapsed: 00:00:12
Operation : Moto ADB Enable [ v1.03 ]
Mode : Enable Factory
Connect Ok!
Operation done!
-- > Info : Wait till device boot, make "Enable ADB" operation after
-- > Info : Don't forget DISABLE "FACTORY MODE" after make "RESET FRP"!
Done!
Elapsed: 00:00:05
Mode : Enable ADB
Waiting for NetInterface arrival ...
1. Power off device. Press and hold 'VOL DOWN' and 'POWER ON' buttons
2. Select by 'VOL DOWN' or 'VOL UP' FACTORY MODE , press 'POWER ON'
3. Connect USB cable, when device boot complete!
Connect Ok!
Waiting ...
Trying link with : 192.168.137.2
Connected to device!
Device : XT1925-13
Switching to FACTORY ...
Setting Unsecure mode
Waiting device ...
Connect Ok!
Device : XT1925-13
Setting ADB ...
Waiting device ...
Connect Ok!
Device : XT1925-13
Setting ADB ...
1. Disconnect cable from device, wait device reboot
2. Make "Reset FRP"
3. Disable "FACTORY MODE" after operations done!
Done!
Elapsed: 00:01:42
Connect Ok!
Device : ali
Model : moto g(6)
-- > MOTO FRP : Don't forget to DISABLE FACTORY MODE!
Done!
Elapsed: 00:00:12
Mode : Disable Factory
Connect Ok!
Operation done!
Done!
Elapsed: 00:00:05
Old 05-10-2019, 11:57   #58495 (permalink)
localizator's Avatar
Member: 2550141
Thanks Meter: 992
Thumbs up DOOGEE X60L AND:7.0 MT6735 BRUSH FRP Done
SUCCESSFULLY BRUSH FRP(DOOGEE X60L AND:7.0 MT6735)USB
Operation : Identify [ v2.06 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM (Android) (COM120)
MODE : PRELOADER PORT
PORT : 120
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
     CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     TYPE : LEGACY MTK
BROM : SecLevel : 0x00000000
BROM : SecMode  : PLAIN [+PRL]
BROM : PRELOADER PORT
MODE : 0_base : BASE_v1712 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6735
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
NAND : DEVICE NOT FOUND
NAND : 000000000000000000000000
eMMC : OK
eMMC : 150100523331314D4201B522DAB3AC2F
DAInf: 4 : 2 : 155
     DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : Receiving HW info
        EMMC: 150100523331314D4201B522DAB3222F
        EMMC: VEN : SAMSUNG | OEM : 01 | DEV : R311MB
        EMMC:
              BOOT1  : 0x00400000 [ 4,00 MB ]
              BOOT2  : 0x00400000 [ 4,00 MB ]
              RPMB   : 0x00400000 [ 4,00 MB ]
              USER   : 0x3A3E00000 [ 14,56 GB ]
        SRAM: 0x00020000 [ 128,00 KB ]
        DRAM: 0x80000000 [ 2,00 GB ]
        CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : 2897B4F4B9C1382CA3210AF3F8630144
 STATUS : BLANK FLASH
 BSTYLE : EMMC FLASH BOOT
DA : USB : HIGH-SPEED
Boot done!
Patch Level    : NRD90M
Ver. CodeName  : REL
Ver. Release   : 7.0
Sec. Patch     : 2019-04-05
Build Time     : 1555401301
Product Model  : X60L
Product Brand  : DOOGEE
Product Board  : t596_dg_d5506_x60l_n_37m35
Product Manfct : DOOGEE
Board Platform : mt6737m
Product Info   : t596_dg_x60l
Display ID     : DOOGEE-X60L-android7.0-20190416
Product Name   : t596_dg_x60l
Product Device : t596_dg_x60l
USERDATA : PLAIN ( NOT encrypted )
IMEI[0] : 356538090367318
IMEI[1] : 356538090367326
IMEI[2] : 868969010014520
NVRAM check : Passed!
Operation : Reset Settings/Format FS [ v2.06 ]
PORT : 120
BROM : Init BROM
BROM init passed!
     TYPE : LEGACY MTK
BROM : DA sent
     DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 155
     DA : DRAM ready!
        EMMC:
Boot done!
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:12
The Following User Says Thank You to localizator For This Useful Post:
Old 05-10-2019, 12:14   #58496 (permalink)
Member: 2700903
Nokia TA-1008
Hi i am having a problem connecting the handset to the PC i have the software and an live account with infinity best 2. But i can not get the PC to read that the handset is connected it just stays on the connect handset the handset just goes into a charging mode i have tried powered off and powered on. do i have to hold down a button to connect or use a certain USB cable?
Any help will be grateful thank you.
Old 05-10-2019, 12:25   #58497 (permalink)
yuranc8's Avatar
Member: 2680008
Thanks Meter: 494
Thumbs up Tecno KA7 MT6580 DEAD BOOT RECOVERY DONE + AUTH
Operation : Identify [ v2.05 ]
PTFN : MediaTek PreLoader USB VCOM (Android) (COM15)
PORT : 15
BROM : Init BROM
BROM init passed!
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000005
BROM : SecMode : SBC+SDA
MODE : 0_base : BASE_v1712 | Manual : Enabled
AGENT : DA_SWSEC.bin
AGENT : Found MT6580
BROM : DA sent
DA : AGENT started!
eMMC : OK
eMMC : 460001154D323645F0AB0342C516B0A8
DAInf: 4 : 2 : 156
DA : DRAM ready!
EMMC: 150100464536324D4203ABF0A8B016C5
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FE62MB
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x3A3E00000 [ 14.56 GB ]
SRAM: 0x00020000 [ 128.00 KB ]
DRAM: 0x40000000 [ 1.00 GB ]
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : B8ECBB72F429233CF53813091C91FD25
Boot done!
USERDATA : EMPTY ( ERASED )
Done!
Elapsed: 00:00:33
Operation : Write Flash [ v2.05 ]
Repartition : Enabled
Flash Verify : Disabled
Reg.Pre-Erase : Enabled
Verify HW/SW : Disabled
SData Backup : Disabled
Safe UserData : Disabled
Files :13
[FL] : Set : preloader_ka7_h8024.bin
[FL] : Set : lk-sign.img
[FL] : Set : boot-sign.img
[FL] : Set : recovery-sign.img
[FL] : Set : logo-sign.bin
[FL] : Set : odmdtbo-sign.img
[FL] : Set : vendor-sign.img
[FL] : Set : tee-sign.img
[FL] : Set : secro-sign.img
[FL] : Set : system-sign.img
[FL] : Set : cache-sign.img
[FL] : Set : userdata-sign.img
[FL] : Total size : 0x66C7F6C0 [ 1.61 GB ]
PORT : 15
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 156
DA : DRAM ready!
EMMC:
Boot done!
SEC_DL : True (CUST)
SEC_DL : SECURE USB DL ENABLED
SEC_ID : 0x63616334633434326462376361623562
[FL] : Pre-Erase
Erase : 0x0000000000000000 : 0x0000000000080000
Erase : 0x0000000004C80000 : 0x00000000FD380000
[FL] : RePartition
[FL] : RePartition Ok!
SecInit : LK
SecInit : BOOT
SecInit : RECOVERY
SecInit : LOGO
SecInit : ODMDTBO
SecInit : VENDOR
SecInit : TEE1
SecInit : TEE2
SecInit : SECRO
SecInit : SYSTEM
SecInit : CACHE
SecInit : USERDATA
[FL] : Flashing now ...
Write : PRELOADER
Update bootloader code ...
Update bootloader Ok!
Write : LK
Write : BOOT
Write : RECOVERY
Write : LOGO
Write : ODMDTBO
Write : VENDOR
Write : TEE1
Write : TEE2
Write : SECRO
Write : SYSTEM
Write : CACHE
Write : USERDATA
SEC_DL : WRITE INFO : OK
[FL] : RePartition
[FL] : Flashing finished!
Done!
Elapsed: 00:02:32
PORT : 15
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 156
DA : DRAM ready!
EMMC:
Boot done!
Patch Level : O11019
Display ID : KA7-H8024ABC-GO-181012V173
Ver. CodeName : REL
Ver. Release : 8.1.0
Sec. Patch : 2018-10-05
Build Time : 1539325710
Product Model : TECNO KA7
Product Brand : TECNO
Product Name : H8024
Product Device : TECNO-KA7-GO
Product Manfct : TECNO MOBILE LIMITED
Product Info : TECNO-KA7-GO
Board Platform : mt6580
USERDATA : ENCRYPTED
Done!
Elapsed: 00:03:17
The Following User Says Thank You to yuranc8 For This Useful Post:
Old 05-10-2019, 13:51   #58498 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Qmobile infinity c reset frp done by cm2
Card found: S/N : 73CA70CC , v0137
Chinese Miracle II [SPD module] v 1.27
Set mode to : SP [SC773x] eMMC [Android 7.x]
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
3. Insert cable
Phone found! [ 18 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC773x eMMC Loader v7 InfinityBox
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:26
Old 05-10-2019, 13:56   #58499 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Vgo tel i10 classic hang on logo done by cm2
Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ]
SPRD mode : SC6531 : REV : E001 : NOR : [ 4MB-8MB ]
Operation : Identify [ v1.04 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Infinity SCR 6531EFM v1.1 (c)2019
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [GIGADEVICE] : GD25Q32 : 0x00400000 [ 4MiB ]
IMEI[1] :
IMEI[2] :
Done!
Elapsed: 00:00:20
Operation : Format FileSystem [ v1.04 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_006 6AB76D796_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:21
Operation : Read Flash [ v1.04 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Read Ok, 4194304 bytes
Saved to : E:\Mix Flash Files\SPRD_SPI_GIGADEVICE_GD25Q_4MiB.bin
Done!
Elapsed: 00:00:55
Old 05-10-2019, 14:06   #58500 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 929
Qmobile i6i hang on logo done by cm2
Scatter Load Ok , BaseBand : MT6580 , Project : s5030 , Storage : EMMC
Files found : 9 , Set to Flash : 8
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : QMobile
Device Model : QMobile
Device CPU : MT6580
Device IntName : QMobile i6i
Device Version : 5.1
Device Compile : 6/20/2016 2:31:53 PM
Device Project : ALPS.L1.MP6.V2_TINNO6580.WE.L
Device ExtInfo : QMobile i6i
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 150100464A32374D4202F527683683DD
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM72J
[eMMC] : FLASH_CID : 150100464A32374D4202F527683683DD
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xB9E2EB775AA2E483E18AC5FAAACB5D1F
EXT RAM : 0x30000000 [768 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6580 , Project : s5030 , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3599 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 1
Erase : 0x0000000001C80000-0x00000000E6300000
Flash Pre-Erase Done, time used : 00:00:02
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_s5030.bin
Preloader Sent , Init passed
PartCount : 0014
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : LK
Image Flash Ok
Flash now : BOOT
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : SECRO
Image Flash Ok
Flash now : SYSTEM
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USERDATA
Image Flash Ok
Flash Write Done, time used : 00:03:04
Processing : Verify
Verify Passed : LK
Verify Passed : BOOT
Verify Passed : RECOVERY
Verify Passed : LOGO
Verify Passed : SECRO
Verify Passed : SYSTEM
Verify Passed : CACHE
Verify Passed : USERDATA
Data Verify Done, time used : 00:00:04
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:27
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-29-2010 21:17
Page generated in 0.97008 seconds with 9 queries
