Old 05-30-2019, 15:09   #58591 (permalink)
m&s
m&s's Avatar
Member: 1168673
Sonork: 100.1638333
Thanks Meter: 167
Exclamation zte a520 frp v2
Card found : AC6E7D0C , v0137
Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.06
Load IDBase v123080 Ok!
UserName and/or Password not set! Can't continue!
Update failed! Check settings and/or internet connection!
Operation : Reset Settings/Format FS [ v2.06 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port (COM70)
MODE : BOOTROM
PORT : 70
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000001
BROM : SecMode : SBC
BROM : BOOTROM
MODE : ZTE : BLADE Axx [ A110-A515 ] | Manual : Enabled
Fail to disable Dog!
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6735
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
NAND : DEVICE NOT FOUND
NAND : 000000000000000000000000
eMMC : OK
eMMC : 150100464E36324D42031561E49F276D
DAInf: 4 : 2 : 155
DA : EXT_RAM NOT initialized!
eMMC : OK
eMMC : 460001154D32364E611503426D279FE4
EMI : DEV : INFINITY
EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0
INIT : 0xBC : LP/DDR3 [ 0x00000000 : [ 0 B ] ]
DRAM : DRAM: 0x40000000 [ 1,00 GB ]
DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : Receiving HW info
EMMC: 150100464E36324D42031561E49FB46D
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB
EMMC:
BOOT1 : 0x00400000 [ 4,00 MB ]
BOOT2 : 0x00400000 [ 4,00 MB ]
RPMB : 0x00080000 [ 512,00 KB ]
USER : 0x1D2000000 [ 7,28 GB ]
SRAM: 0x00020000 [ 128,00 KB ]
CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 8FCC33E84E8FD5959B75BEAA38D874F7
STATUS : BLANK FLASH
BSTYLE : EMMC FLASH BOOT
DA : USB : FULL-SPEED
DA : USB : Change Port Speed
PTFN : MediaTek DA USB VCOM (Android) (COM71)
MODE : PRELOADER PORT
PORT : 71
Boot done!
Format Ok : USERDATA
Format Ok : CACHE
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:44
Reconnect Power/Cable!
Operation : Identify [ v2.06 ]
MODE : BOOTROM
PORT : 70
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : BOOTROM
MODE : ZTE : BLADE Axx [ A110-A515 ] | Manual : Disabled
BROM : DA sent
DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 155
eMMC : OK
DA : DRAM ready!
EMMC:
PORT : 71
Boot done!
Patch Level : NRD90M
Display ID : CLR_PE_BA520_V6.0
Ver. CodeName : REL
Ver. Release : 7.0
Sec. Patch : 2018-08-05
Build Time : 1531878653
Product Model : BLADE A520
Product Brand : ZTE
Product Name : P637F10_PE_CLR
Product Device : P637F10
Product Board : MT6735
Product Manfct : ZTE
Board Platform : mt6737m
Product Info : P637F10
USERDATA : ENCRYPTED
Done!
Elapsed: 00:00:29
Card found : xxxxxx , v0137
MODE : BOOTROM
PORT : 70
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : BOOTROM
BROM : DA sent
DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 155
eMMC : OK
DA : DRAM ready!
EMMC:
PORT : 71
Boot done!
Format Ok : CACHE
Done!
Elapsed: 00:00:44
The Following 2 Users Say Thank You to m&s For This Useful Post:
Old 05-30-2019, 15:13   #58592 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 14,488
Smile LG Ls450
Operation : Reset Settings/Format FS [ v1.03 ]
2. PRESS and HOLD VOLUME UP KEY!
3. Insert USB cable, wait until Download mode screen will appear
Wait for phone...
Connection opened successfully!
Waiting for loader ...
Handshake passed!
Collect info...
Prepare passed, mode 0x01
Boot done!
Format UserData
Format Cache
Format done
Erase sFRP#3 Ok!
Done!
Elapsed: 00:00:36
Old 05-30-2019, 15:20   #58593 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 822
Lg ls755 hang on logo done by cm2
Card found : 73CA70CC , v0137
Infinity-Box LG Service Tool [ LGS ] v1.03
Wait for phone...
Handshake passed!
Collect info...
Boot done!
Format UserData
Format Cache
Format done
Erase FRP#0 block Ok!
Done!
Elapsed: 00:00:15
Old 05-31-2019, 07:39   #58594 (permalink)
Member: 1640892
Sonork: 100.1651734
Thanks Meter: 22
Itel a16 done with cm2sp2
Card found : B5873186 , v0137
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.00r1
Operation : Identify [ v2.00r1 ]
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Sedning Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sedning Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : Control transfered!
Boot Done!
Done!
Elapsed: 00:00:54
Operation : Format FS / Reset Settings [ v2.00r1 ]
Mode : Reset FRP
Wait for device ...
Device not found!
Remove battery, cable. Check cable and connection. Repeat operation!
Mode : Reset FRP
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Wipe Ok : FRP
Done!
Elapsed: 00:00:50
The Following 3 Users Say Thank You to baruga For This Useful Post:
Old 05-31-2019, 09:50   #58595 (permalink)
Member: 974244
Thanks Meter: 25
feature phone code read by cm2
Card found : S/N : E3B1B8F3 , v0137
Operation : Read UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 238 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 423C7E80A65012FC427692E5EA6198BD
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV
[0] : FLASH_DIE : 00EF 0070 0016 0000
[0] : FLASH_LEN : 0x00400000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Read ExtData
Sorting ExtData
Reading UserCode
Active : Yes , Code : 1166
PLock|MobTrack : Not active
Done!
Elapsed: 00:00:06
Old 05-31-2019, 10:17   #58596 (permalink)
Member: 974244
Thanks Meter: 25
Ferp Pace privacy removed without loss of user data
Operation : Read Pattern/DP Lock [ v1.58 ]
Wait for phone...
Phone found! [ 142 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 150100464531324D4207222CDAD3B329
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM21E
[eMMC] : FLASH_CID : 150100464531324D4207222CDAD3B329
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0x9BE78CE178859A446D2FBF9E52F7C6DC
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Reading data ...
[Info] : PatternLock Not Set!
[Info] : DP Lock not set!
Done!
Elapsed: 00:00:21
Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.58 ]
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
LSSDB Ok!
LSSWL Ok!
LSSSH Ok!
LSSNP Ok!
LSSNG Ok!
Security Settings : Clear Ok!
[Info] : That feature NOT RESET "PRIVACY PASSWORD LOCK"! Use separate button!
[Info] : That feature NOT RESET "FRP/GoogleLOCK"! Use separate "FRP" reset!
[Info] : If phone stuck on "Logo" :
1. Wait 2-3 minutes. Power Off phone by long press "Power" button
2. Power On phone again
3. Or wait up to 3-7 minutes, until phone start by itself
4. Also recommended reboot phone twice before start use it
Done!
Elapsed: 00:00:19
q
Old 05-31-2019, 10:22   #58597 (permalink)
Member: 974244
Thanks Meter: 25
Gionee F103 Pro read firmware done 1.5
Operation : Read Flash [ v1.58 ]
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x93
eMMC Flash : 510001154D333238D2A400423F9A696A
[eMMC] : FLASH_INF : [SAMSUNG] , BM328
[eMMC] : FLASH_CID : 150100513832334D4200A4D26A69733F
DEV RID : 0x9BE78CE1B296973E9F98B42B24167D39
EXT RAM : 0x80000000 [2 GiB]
SOC VERIFY : C1
Boot Ok!
Reading Flash Content now ...
xGPT : Normalize settings Ok!
Brand : GIONEE
ProdName : F103_Pro
ProdModel : F103 Pro
Device : GIONEE_GBL7360
AndroidVer: 6.0
MTKxCPU : MT6735
MTKxPRJ : GBL7360GA_0301_T5810
[Read Ok] : preloader_gionee6735_66c_m0.bin
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : logo.bin
[Read Ok] : secro.img
[Read Ok] : tz1.img
[Read Ok] : tz2.img
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : userdata.img
[ScatCFG] : MT6735 / V1.1.2 / gionee6735_66c_m0 / EMMC
Android Info saved
MAUI Meta DB saved
HWConfig Info saved
FW Size : 4193 MiB
Scatter saved to : C:\Users\princejt\Desktop\vol music\CM2\MT6735__GIONEE__F103_Pro__GIONEE_GBL7360 __6.0__GBL7360GA_0301_T5810\
All done!
Done!
Elapsed: 00:13:28
Old 05-31-2019, 10:27   #58598 (permalink)
Member: 974244
Thanks Meter: 25
Hauwei y360 imei done 1.58
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Device boot not done
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:35
Wait for phone...
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:35
Wait for phone...
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:35
Wait for phone...
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:35
Wait for phone...
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:32
Operation : Repair Security [ v1.58 ]
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 1501004E4A325A4D42025BABDA3B73E7
[eMMC] : FLASH_INF : [SAMSUNG] , BMZ2J
[eMMC] : FLASH_CID : 1501004E4A325A4D42025BABDA3B73E7
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0x9BE78CE1209FE9C84C722CC7B945BC17
EXT RAM : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
Set IMEI [00] : 354343234565436
Set IMEI [01] : 356547863432324
Prepare finished. Security check required!
Wait for phone...
Sync...
Check Drivers
Try again
Error while post-checking procedure! Check drivers and battery charge!
In some cases - need reconnect mobile (just re-insert cable) on this step
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading data ...
Get Locks ...
PatternLock Sequnce : 3256
Done!
Elapsed: 00:00:16
Old 05-31-2019, 10:49   #58599 (permalink)
Member: 953334
Sonork: 100.1614005
Smile Commando Format Done
Operation : Reset Settings [ v1.04 ]
----- > Powered On :
1. Power On device
2. Connect USB cable
3. When device show StorageMode : Press '0' button for a 5 second!
----- > Powered Off :
1. Insert USB cable
2. Wait when device show Charge icon
Wait for device ...
Device Connected!
BOOT_PWR0 : 0x00600000
BOOT_INIT : 0x81C0024C
BOOT_MODE : DOWNLOAD
BOOT_INTV : 6533G-FPTRUNK-W16.44.2
InternalVersion: g8bec5c4c
Setting BOOTROM mode
BOOT_MODE : BOOTROM
Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G
MEMD for flsh_spi32m Branch: none
Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ]
Performing MemoryInit
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot IV : 0xFBA2A250
Boot done!
Preparing PMT
Verifying PMT
Erasing 1474560 bytes
FileSystem format done!
Done!
Elapsed: 00:00:33
Old 05-31-2019, 11:07   #58600 (permalink)
Member: 974244
Thanks Meter: 25
Tecno L8 reset
Card found : E3B1B8F3 , v0137
PTFN : Mobistel PreLoader USB VCOM Port (COM142)
PORT : 142
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000000
BROM : SecMode : PLAIN [+PRL]
BROM : PRELOADER PORT
MODE : 0_base : BASE_v1712 | Manual : Disabled
AGENT : Found MT6580
BROM : DA sent
DA : AGENT started!
eMMC : OK
eMMC : 460001154D323645860203425F74E1CC
DAInf: 4 : 2 : 156
DA : DRAM ready!
EMMC: 150100464536324D42030286CCE1745F
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FE62MB
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x3A3E00000 [ 14.56 GB ]
SRAM: 0x00020000 [ 128.00 KB ]
DRAM: 0x40000000 [ 1.00 GB ]
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : B3C0543948B0EB30C1C703214B2670C4
DA : USB : HIGH-SPEED
Boot done!
Done!
Elapsed: 00:00:21
Info : Operation break by user!
PORT : 142
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
DA : AGENT started!
eMMC : OK
eMMC : 460001154D3232388FD300424F439ED6
DAInf: 4 : 2 : 156
DA : DRAM ready!
EMMC: 150100463832324D4200D38FD69E434F
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : F822MB
EMMC:
RNID : 5E4DD339AF4662C5561A16611A066FCD
Boot done!
Done!
Elapsed: 00:00:21
PORT : 142
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 156
DA : DRAM ready!
EMMC:
Boot done!
Done!
Elapsed: 00:00:25
Old 05-31-2019, 11:13   #58601 (permalink)
Member: 974244
Thanks Meter: 25
LA7 frp removed by 2.06
PORT : 142
BROM : Init BROM
BROM init passed!
CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000005
BROM : SecMode : SBC+SDA
AGENT : Selected AGENT doesn't have required configuration!
Check and select CORRECT SETTINGS for your device!
PORT : 142
PRELOADER : ACK confirm FAIL!
BROM : Init BROM
BROM init passed!
MODE : 0_base : BASE_v1712 | Manual : Enabled
AGENT : DA_SWSEC.bin
AGENT : Found MT6739
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : PRELOADER
DA : EXT_RAM initialized!
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
SRAM: 0x00040000 [ 256.00 KB ]
DRAM: 0x80000000 [ 2.00 GB ]
EMMC: 150100514536334D4203FCD3E4B75531
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE63MB
EMMC:
CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 59AAA01519E7A438A137601D169A353B
Boot done!
Done!
Elapsed: 00:00:26
Old 05-31-2019, 15:25   #58602 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 822
Qmobile e2 noir reset pattern done by cm2
Card found : S/N : 73CA70CC , v0137
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 520001154142313305680642B13CF0C4
[eMMC] : FLASH_INF : [SAMSUNG] , BAB13
[eMMC] : FLASH_CID : 150100523331424142066805C4F0A3B1
DEV RID : 0x0B9C44DE4E2760155A2B3DCE5226AC0A
EXT RAM : 0xC0000000 [3 GiB]
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:50
Old 05-31-2019, 15:32   #58603 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 822
Qmobile i6i hang on logo done by cm2
Scatter Load Ok , BaseBand : MT6580 , Project : s5030 , Storage : EMMC
Files found : 9 , Set to Flash : 8
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : QMobile
Device Model : QMobile
Device CPU : MT6580
Device IntName : QMobile i6i
Device Version : 5.1
Device Compile : 6/20/2016 2:31:53 PM
Device Project : ALPS.L1.MP6.V2_TINNO6580.WE.L
Device ExtInfo : QMobile i6i
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 20 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 150100464A32374D4202F527683683DD
[eMMC] : FLASH_INF : [SAMSUNG] , BM72J
[eMMC] : FLASH_CID : 150100464A32374D4202F527683683DD
DEV RID : 0xB9E2EB775AA2E483E18AC5FAAACB5D1F
EXT RAM : 0x30000000 [768 MiB]
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6580 , Project : s5030 , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3599 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 1
Erase : 0x0000000001C80000-0x00000000E6300000
Flash Pre-Erase Done, time used : 00:00:02
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_s5030.bin
Preloader Sent , Init passed
PartCount : 0014
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : LK
Image Flash Ok
Flash now : BOOT
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : SECRO
Image Flash Ok
Flash now : SYSTEM
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USERDATA
Image Flash Ok
Flash Write Done, time used : 00:03:04
Processing : Verify
Verify Passed : LK
Verify Passed : BOOT
Verify Passed : RECOVERY
Verify Passed : LOGO
Verify Passed : SECRO
Verify Passed : SYSTEM
Verify Passed : CACHE
Verify Passed : USERDATA
Data Verify Done, time used : 00:00:04
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:27
Old 05-31-2019, 16:05   #58604 (permalink)
Member: 2233266
Thanks Meter: 162
bytwo bs400 frp done
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A4834473164048602A22D46805D
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164048602A22D46805D
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : 0x3A62B5453E54D9AA5B29C16900FCC013
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:28
Old 05-31-2019, 17:10   #58605 (permalink)
Member: 2635143
Thanks Meter: 150
Oukitel U20 Plus - FRP Reset Done !!!!!
The Following User Says Thank You to Dr FlasH For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.57121 seconds with 9 queries
