Old 05-15-2019, 14:19   #58621 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Oppo r9 reset frp done by cm2
Card found : 73CA70CC , v0137
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16
Operation : Reset Settings [ v1.16 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 625 [MSM8953]
ID_BLOCK_S : D25FD0AE
ID_BLOCK_I : 000460E1
ID_BLOCK_L : 677ABA3C6D0F681B96C435A407EE60C7
ID_BLOCK_L : F2B7CB2D56257C600928CC625F3692C0
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ]
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RC14MB
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:14
Reconnect Power/Cable!
Old 05-15-2019, 14:36   #58622 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Qmobile s2 reset frp done by cm2
Card found : S/N : 73CA70CC , v0137
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A483847316505075D834500B28F
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A483847316505075D834500B28F
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0x0B9C44DED8622FCF4569204CEA3C2555
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:52
Old 05-16-2019, 14:09   #58623 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Qmobile 3310 classic hang on logo done by cm2
Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ]
SPRD mode : SC6531 : REV : E001 : NOR : [ 4MB-8MB ]
Operation : Identify [ v1.04 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Infinity SCR 6531EFM v1.1 (c)2019
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ]
IMEI[1] :
IMEI[2] :
Done!
Elapsed: 00:00:23
Operation : Format FileSystem [ v1.04 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_197 E7FAB8143_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:20
Operation : Read Flash [ v1.04 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Read Ok, 4194304 bytes
Saved to : E:\Mix Flash Files\SPRD_SPI_WINBOND_W25Q_4MiB.bin
Done!
Elapsed: 00:00:49
Old 05-16-2019, 14:59   #58624 (permalink)
Arafat Mashaka's Avatar
Member: 750759
Sonork: 75101010
Thanks Meter: 169
Samsung Note4 clone Flash done
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 42 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x87
eMMC Flash : 1501004B3758564D420144E757DEB149
[eMMC] : FLASH_INF : [SAMSUNG] , BMVX7
[eMMC] : FLASH_CID : 1501004B3758564D420144E757DEB149
DEV RID : 0x5DDAA24B3F57255674A494DAF486DE2C
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : alps
ProdName : lcsh82_cwet_kk
ProdModel : SM-N910U
Device : lcsh82_cwet_kk
AndroidVer: 4.4.2
MTKxCPU : MT6582
MTKxPRJ : ALPS.KK1.MP1.V2.10
Done!
Elapsed: 00:00:09
Scatter Load Ok , BaseBand : MT6582 , Project : lcsh82_cwet_kk , Storage : EMMC
Files found : 11 , Set to Flash : 10
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 42 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : lcsh82_cwet_kk , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 4145 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x00000001CEE00000
Flash Pre-Erase Done, time used : 00:00:04
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_lcsh82_cwet_kk.bin
Preloader Sent , Init passed
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:03:32
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:42
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:04:38
Old 05-16-2019, 20:43   #58625 (permalink)
Member: 579243
Thanks Meter: 19
oppo a73 new security baseband repair tp method
Operation : Identify [ v2.06 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek USB Port_V1632 (COM5)
MODE : BOOTROM
PORT : 5
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x000000E5
BROM : SecMode : SBC+SDA+ARB
BROM : BOOTROM
MODE : Oppo : F5 | Manual : Disabled
BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 4000 0036 F7: 102D 0000 00: 1005 0000 F3: 4000 0036 F7: 102D 0000 01: 102A 0001
BROM : SOCID : BDA8AC04BE3ECBC03B492E14DB692BA07B199AD49967650E09 A7AE55D0920A82
BROM : SLA
BROM : SLA Passed!
BROM : SLA CHLNG not used
AGENT : Look for suitable BootChain in DA ...
AGENT : DA_PL_CRYPTO.bin
AGENT : Found MT6763
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : DEV : MT6763
EMI : SRC : preloader_oppo6763_17031.bin
EMI : CNT : 000F
EMI : [00] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 0 B ]
EMI : [01] : eMCP : eMMC+LP/DDR4 , ID : 150100444836444D42 : VEN : SAMSUNG | DEV : DH6DMB : RAM : [ 4,00 GB ]
EMI : [02] : eMCP : eMMC+LP/DDR3 , ID : 150100525836344D42 : VEN : SAMSUNG | DEV : RX64MB : RAM : [ 4,00 GB ]
EMI : [03] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344142 : VEN : SAMSUNG | DEV : RH64AB : RAM : [ 4,00 GB ]
EMI : [04] : eMCP : eMMC+LP/DDR4 , ID : 150100334836434D42 : VEN : SAMSUNG | DEV : 3H6CMB : RAM : [ 6,00 GB ]
EMI : [05] : eMCP : eMMC+LP/DDR3 , ID : 150100524836344D42 : VEN : SAMSUNG | DEV : RH64MB : RAM : [ 4,00 GB ]
EMI : [06] : eMCP : eMMC+LP/DDR3 , ID : 150100474436424D42 : VEN : SAMSUNG | DEV : GD6BMB : RAM : [ 3,00 GB ]
EMI : [07] : eMCP : eMMC+LP/DDR3 , ID : 150100475836424D42 : VEN : SAMSUNG | DEV : GX6BMB : RAM : [ 3,00 GB ]
EMI : [08] : eMCP : eMMC+LP/DDR3 , ID : 150100474536424D42 : VEN : SAMSUNG | DEV : GE6BMB : RAM : [ 3,00 GB ]
EMI : [09] : eMCP : eMMC+LP/DDR3 , ID : 150100524436344D42 : VEN : SAMSUNG | DEV : RD64MB : RAM : [ 4,00 GB ]
EMI : [0A] : eMCP : eMMC+LP/DDR3 , ID : 13014E53304A394237 : VEN : MICRON | DEV : S0J9B7 : RAM : [ 3,00 GB ]
EMI : [0B] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4,00 GB ]
EMI : [0C] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 4,00 GB ]
EMI : [0D] : DRAM : EXTERNAL DRAM [LP/DDR3] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 3,00 GB ]
EMI : [0E] : DRAM : EXTERNAL DRAM [LP/DDR4] , UNDEFINED : VEN : UNKNOWN | DEV : : RAM : [ 6,00 GB ]
EMI : Init EMI from PRELOADER
EMI : EXT_RAM CFG Passed!
DA : BOOT to 2nd DA ...
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
DA : Receiving HW info
SRAM: 0x00040000 [ 256,00 KB ]
DRAM: 0xC0000000 [ 3,00 GB ]
EMMC: 150100525836344D4203C8F7C4E62485
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : RX64MB
EMMC:
BOOT1 : 0x00400000 [ 4,00 MB ]
BOOT2 : 0x00400000 [ 4,00 MB ]
RPMB : 0x00400000 [ 4,00 MB ]
USER : 0x747C00000 [ 29,12 GB ]
CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0000 , EVOL : 0x0000
RNID : DCF424B4D79D093DABE7FD6B2E11951
DA : USB : HIGH-SPEED
Boot done!
Patch Level : N6F26Q
Ver. CodeName : REL
Ver. Release : 7.1.1
Sec. Patch : 2018-10-05
Build Time : 1539797161
Product Manfct : OPPO
Board Platform : mt6763
Product Model : OPPO CPH1723
Product Brand : OPPO
Product Name : CPH1723
Product Device : M6763A
Product Board : full_oppo6763_17031
Product Info : oppo6763_17031
SW Version : A.30
SW OTA Version : M6763A_11.A.30_0300_201810172338
SW OTA Name : CPH1723EX_11_A.30_181017
Display ID : CPH1723EX_11_A.30_181017
Kernel Info : 4.4.22-G201810172338
USERDATA : ENCRYPTED
NVRAM check : Passed!
Done!
Elapsed: 00:00:36
Operation : Repair BaseBand [ v2.06 ]
SECBackup : Enabled
MODE : BOOTROM
PORT : 5
BROM : Init BROM
BROM init passed!
BROM : BOOTROM
BROM : SLA
BROM : SLA Passed!
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
EMI : DEV : MT6763
EMI : CNT : 000F
EMMC:
Boot done!
Backup sensetive data [ 10 ]
Backup path : Backup\MT6763__DCF424B4D79D093D0ABE7FD6B2E11951\
[0] Read : PRELOADER
Backup done!
Process Block #0
Process Block #1
Process Block #2
Process Block #5
Done!
Elapsed: 00:00:34
nb. if problem same, you must change original modem file using modem file in another firmware, scatter file must be same partition, after that u can try baseband repair again. 100% work. thx
regards: tatan ghitsa cell
Old 05-17-2019, 05:31   #58626 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Vivo y71 reset frp done by cm2
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 425 [MSM8917]
ID_BLOCK_S : 1A334845
ID_BLOCK_L : EE2912F17CE3306E2A026E8C6857EBB8
ID_BLOCK_L : EC512BDED6DC1BAC15A2A6E7404479C3
Running FireHose on BBID : MSM8917 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ]
Storage : MFR : 0x90 , VENDOR : HYNIX , NAME : HAG4a2
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:18
Old 05-17-2019, 05:34   #58627 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Qmobile x25 hang on logo done by cm2
Scatter Load Ok , BaseBand : MT6572 , Project : s4011 , Storage : EMMC
Ready to Flash!
======= Flash
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 90014A4834473164040504A2AD9D32A7
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164040504A2AD9D32A7
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0x0CF2E6DECEDC3CC71E6AF8387618B315
EXT RAM : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : s4011 , Storage : EMMC
BL : BatteryLevel : 3562 mV
BL : [WARNING] : BatteryLevel LOW!!!
Erase : 0x0000000002900000-0x00000000E5E00000
Flash Pre-Erase Done, time used : 00:00:07
Use : preloader_s4011.bin
PartCount : 0012
Repartition Done!
Use FLN Mode
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:49
Processing : Verify
Verify Passed : MBR
Data Verify Done, time used : 00:00:40
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:52
Old 05-17-2019, 05:37   #58628 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Qmobile sp 3000 reset password done by cm2
Operation : Reset UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 6 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : EE7F0A5F11E9D21B317E6AA6C128A619
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV
[0] : FLASH_DIE : 00EF 0070 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Backup done
Read ExtData
Sorting ExtData
Sort Ok, Rebuild Ok
Restore ExtData
All done
UserCode request removed
UserCode set to default ( 0000 or 1122 )
Done!
Elapsed: 00:00:12
Old 05-17-2019, 05:40   #58629 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Qmobile star power hang on logo done by cm2
SCRD mode : AUTO
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
IMEI[1] :
IMEI[2] :
Done!
Elapsed: 00:00:31
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_1D6 CB68FBE5A_NVM.nv
Format FFS Done!
Done!
Elapsed: 00:00:21
Old 05-17-2019, 05:41   #58630 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Qmobile i7i hang on logo done by cm2
Card found: S/N : 73CA70CC , v0137
Chinese Miracle II [SPD module] v 1.27
Set mode to : SP [SC773x] eMMC [Android 5.x]
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 33 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v3 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Done!
Elapsed: 00:00:21
Old 05-17-2019, 05:45   #58631 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Tecno f3 reset frp done by cm2
Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.06
Load IDBase v46104 Ok!
Update configuration ...
Update Ok!
Operation : Reset Settings/Format FS [ v2.06 ]
PTFN : MediaTek PreLoader USB VCOM (Android) (COM15)
MODE : PRELOADER PORT
PORT : 15
PRELOADER : ACK confirm FAIL!
BROM : Init BROM
BROM init passed!
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000000
BROM : SecMode : PLAIN [+PRL]
BROM : PRELOADER PORT
MODE : TECNO : LB6 | Manual : Enabled
AGENT : DA_SWSEC.bin
AGENT : Found MT6580
BROM : DA sent
DA : AGENT started!
NAND : DEVICE NOT FOUND
NAND : 000000000000000000000000
eMMC : OK
eMMC : 460001154D32584E08E80642A5A4BCD0
DAInf: 4 : 2 : 156
DA : DRAM ready!
EMMC: 150100464E58324D4206E808D0BCA4A5
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FNX2MB
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00080000 [ 512.00 KB ]
USER : 0x1D2000000 [ 7.28 GB ]
SRAM: 0x00020000 [ 128.00 KB ]
DRAM: 0x40000000 [ 1.00 GB ]
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 7217028E1E7CA9EBAC484CB613355275
STATUS : BLANK FLASH
BSTYLE : EMMC FLASH BOOT
Boot done!
Format Ok : USERDATA
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:26
Old 05-17-2019, 07:30   #58632 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Qmobile X36 SPD77XX FRP Reset Done With King Infinity CM2
Card found: S/N : A19EC787 , v0137
Set mode to : SP [SC773x] eMMC [Android 6.x]
3. Insert cable
Phone found! [ 8 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:23
Old 05-17-2019, 14:24   #58633 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 15,420
Smile VgoTel Venture V8 Format Done
PTFN : MediaTek PreLoader USB VCOM (Android) (COM12)
PORT : 12
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
MODE : 0_base : BASE_v1712 | Manual : Disabled
AGENT : MTK_AllInOne_DA.bin
BROM : DA sent
DA : AGENT started!
eMMC : OK
eMMC : 450001704543414822160141B1839698
DAInf: 4 : 2 : 156
DA : DRAM ready!
EMMC: 700100454841434541011622989683B1
EMMC: VEN : KINGSTON | OEM : 01 | DEV : EHACEA
EMMC:
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x3A5000000 [ 14.58 GB ]
DRAM: 0x80000000 [ 2.00 GB ]
RNID : 7648670B801A111E33D4311B912C321
Boot done!
Format Ok : CACHE
Done!
Elapsed: 00:00:34
Old 05-17-2019, 15:01   #58634 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Qmobile 350 pro reset frp done by cm2
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 150100513832334D42002229D892B381
[eMMC] : FLASH_INF : [SAMSUNG] , BM328
[eMMC] : FLASH_CID : 150100513832334D42002229D892B381
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0xB9E2EB7705F589B5DD9917681B98A934
EXT RAM : 0x80000000 [2 GiB]
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:10
Old 05-17-2019, 15:39   #58635 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
Smile MOTO E3 POWER XT1706 AND:6.0 MT6735M READ NVRAM BAG BRUSH HANG ON LOGO Done
SUCCESSFULLY READ NVRAM BAG BRUSH HANG ON LOGO (MOTO E3 POWER XT1706 AND:6.0 MT6735M)USB
PTFN : MediaTek PreLoader USB VCOM (Android) (COM3)
PORT : 3
BROM : Init BROM
BROM init passed!
CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000001
MODE : Moto : XT17[54][55][56][58] | Manual : Disabled
AGENT : Found MT6735
BROM : DA sent
DA : AGENT started!
eMMC : OK
eMMC : 13014E51324A3936521002FA55234825
DAInf: 4 : 2 : 147
DA : DRAM ready!
EMMC: 13014E51324A3936521002FA5523A325
EMMC: VEN : MICRON | OEM : 4E01 | DEV : Q2J96R
EMMC:
USER : 0x3AB400000 [ 14.68 GB ]
CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 54F7CE348C899CD3CED2A85E296455DE
Boot done!
Patch Level : MRA58K
Display ID : XT1706_S135_161108_ROW
Ver. CodeName : REL
Ver. Release : 6.0
Sec. Patch : 2016-10-05
Build Time : 1478601726
Product Model : XT1706
Product Brand : motorola
Product Name : taido_row
Product Device : taido_row
Product Manfct : motorola
Board Platform : mt6735m
Product Info : taido_row
USERDATA : PLAIN ( NOT encrypted )
IMEI[0] : 358XXXXXXXX310
IMEI[1] : 358XXXXXXXX328
Backup path : Backup\MT6735__54F7CE348C899CD3CED2A85E296455DE\
[3] Read : NVRAM
[21] Read : NVDATA
[2] Read : PROINFO
[6] Read : LK
[4] Read : PROTECT1
[5] Read : PROTECT2
[18] Read : PERSIST
Backup done!
Done!
Elapsed: 00:00:27
Operation : Read Security [ v2.06 ]
PORT : 3
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 147
DA : DRAM ready!
EMMC:
Boot done!
SEC Data :
NVM saved as : MT6735__eMMC__3582XXXXXX310.mt_sec
NVM saved to : C:\InfinityBox\CM2MT2\Backup\
Done!
Elapsed: 00:00:20
Operation : Write Flash [ v2.06 ]
Repartition : Enabled
Flash Verify : Disabled
Reg.Pre-Erase : Disabled
Verify HW/SW : Enabled
SData Backup : Disabled
Safe UserData : Disabled
Files :12
[FL] : Set : lk.bin
[FL] : Set : boot.img
[FL] : Set : recovery.img
[FL] : Set : logo.bin
[FL] : Set : secro.img
[FL] : Set : trustzone.bin
[FL] : Set : efuse.img
[FL] : Set : preload.img
[FL] : Set : system.img
[FL] : Set : cache.img
[FL] : Set : userdata.img
[FL] : Total size : 0x5DA10CC0 [ 1.46 GB ]
PORT : 3
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 147
DA : DRAM ready!
EMMC:
Boot done!
[FL] : HW verification passed!
SEC_DL : True (CUST)
SEC_DL : SECURE USB DL ENABLED
SEC_ID : 0x35464646304237304435444533464335
[FL] : RePartition
[FL] : RePartition Ok!
SecInit : LK
SecInit : BOOT
SecInit : RECOVERY
SecInit : LOGO
SecInit : SECRO
SecInit : TEE1
SecInit : TEE2
SecInit : EFUSE
SecInit : PRELOAD
SecInit : SYSTEM
SecInit : CACHE
SecInit : USERDATA
[FL] : Flashing now ...
Write : LK
Write : BOOT
Write : RECOVERY
Write : LOGO
Write : SECRO
Write : TEE1
Write : TEE2
Write : EFUSE
Write : PRELOAD
Write : SYSTEM
Write : CACHE
Write : USERDATA
SEC_DL : WRITE INFO : OK
[FL] : RePartition
[FL] : Flashing finished!
Done!
Elapsed: 00:02:35
THANKS INFINITY-BOX TEAM
The Following 2 Users Say Thank You to gracy_elec For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.58822 seconds with 10 queries
