Old 06-10-2019, 08:12   #58741 (permalink)
rafi_5217705's Avatar
Member: 627475
Sonork: 100.1594828
Thanks Meter: 1,073
Talking Q Mobile LT360 8.1.0 Reset FRP Done
SC9850xx
Mode : Reset FRP
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Sedning Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sedning Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : Control transfered!
Boot Done!
Wipe Ok : FRP
Reconnect Power/Cable!
Done!
Elapsed: 00:00:37
Old 06-10-2019, 08:58   #58742 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,075
Qmobile S1 MT6582 Hanging Probelam Fix Only Formate With King Infinity CM2
Card found : S/N : A19EC787 , v0137
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 258 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A483847316505075CA198437299
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A483847316505075CA198437299
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0xD9C8F395A5225A4ADBB364AB192C826A
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:54
Old 06-10-2019, 12:14   #58743 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 582
Vgotel i251 format done
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 69 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 6C6ADAF70B788CF9CE791D1D2912CD78
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0113 , [Winbond] SF_W25Q32JV
[0] : FLASH_DIE : 00EF 0070 0016 0000
[0] : FLASH_LEN : 0x00300000
SDS_INFO : 0x002FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Backup done
Executing FFS FORMAT now...
FAT_RANGE : 0x002A7000-0x002FDFFF , LEN : 0x00057000
DA_RET : DA_IN_PROGRESS
DA_RET : FORMAT_DONE
Done!
Elapsed: 00:00:12
Old 06-10-2019, 13:57   #58744 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 812
Maxx grand g1 reset password done by cm2
Card found : S/N : 73CA70CC , v0137
Operation : Reset UserCode [ v1.58 ]
Wait for phone...
Phone found! [ 6 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_SN : E33C156F8D3922CD4DCA4D0D0C991F79
Setting...
BROM stage done
SOC_VERIFY : 0xC1
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
Backup done
Read ExtData
Sorting ExtData
Sort Ok, Rebuild Ok
Restore ExtData
All done
UserCode request removed
UserCode set to default ( 0000 or 1122 )
Done!
Elapsed: 00:00:10
Old 06-10-2019, 14:04   #58745 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 812
Calme c232 reset password done by cm2
Card found : 73CA70CC , v0137
Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ]
SPRD mode : SC6531 : REV : 0000 : NOR : [ 8MB-16MB]
Operation : Format FileSystem [ v1.04 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Infinity SCR 653x NOR v1.3(c)2019
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ]
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_1E7 C0206387C_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:22
Old 06-10-2019, 14:10   #58746 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 812
Qmobile x2 hang on logo done by cm2
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6571
BB_CPU_NME : [MediaTek] MT6571_S00
BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x8B
NAND Flash : 009800BC009000660076001600080000
eMMC Flash : NOT INSTALLED
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1
[NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008
[NAND] : FLASH_LEN : 0x20000000
[NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1
DEV RID : 0x0B9C44DE19C591CE296A6DFF16B806A4
EXT RAM : 0x10000000 [256 MiB]
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : QMobile
ProdName : s3510ap
ProdModel : QMobile X2
Device : s3510ap
AndroidVer: 4.4.2
MTKxCPU : MT6571
MTKxPRJ : ALPS.KK1.MP7.V1
Done!
Elapsed: 00:00:15
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6571
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:15
Old 06-10-2019, 14:24   #58747 (permalink)
Member: 733449
Sonork: 100.334100
Thanks Meter: 172
Symphony V128 Flash Done
Operation : Identify [ v2.00r1 ]
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Device info :
Patch Level : O21019
Display ID : V128_HW1_V9
Ver. CodeName : REL
Ver. Release : 8.1.0
Sec. Patch : 2019-03-05
Build Time : 1552471244
Product Model : V128
Product Brand : SYMPHONY
Product Name : V128
Product Device : V128
Product Manfct : SYMPHONY
Product Info : V128
Product Board : sp7731e_1h10
Board Platform : sp7731e
UserData : STATE : DAMAGED
Done!
Elapsed: 00:02:25
Open : V128_HW1_V8_190123.pac
VER : BP_R1.0.0
LEN : 0x5AE4B1DF
CPU : sp7731e_1h10
VER : V128_HW1_V8_190123
Reading package ...
Read package finished!
Display ID : V128_HW1_V8
Ver. CodeName : REL
Sec. Patch : 2019-01-05
Build Time : 1548226727
Product Name : V128
Product Info : V128
Operation : Flash Firmware [ v2.00r1 ]
Setting : Update NVRAM : False
Setting : Update PMT : True
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
PMTMng : Load PMT
PMTMng : 0x1F
PMTMng : Update PMT Ok!
CODE : prodnv.img
ERASE : UBOOT
UBOOT : u-boot-spl-16k-sign.bin
CODE : vbmeta-sign.img
CODE : SC9600_pike2_pubcp_modem.dat
CODE : pike2_pubcp_deltanv.bin
CODE : PIKE2_DM_DSP.bin
CODE : pike2_cm4.bin
CODE : gnssmodem.bin
CODE : gnssbdmodem.bin
CODE : PM_pike2_cm4.bin
CODE : boot.img
CODE : recovery.img
FSIMG : system.img
FSIMG : userdata.img
CODE : FWVGA_logo_256_td.bmp
CODE : fastboot_FWVGA_logo_256_td.bmp
FSIMG : cache.img
FSIMG : vendor.img
ERASE : W_RUNTIMENV1
ERASE : MISC
CODE : tos-sign.bin
CODE : sml-sign.bin
UBOOT : u-boot-sign.bin
FSIMG : persist.img
Flashing finished!
Done!
Elapsed: 00:06:51
The Following 3 Users Say Thank You to somratjisan For This Useful Post:
Old 06-10-2019, 14:25   #58748 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 812
Vgotel venture 11 hang on logo done by cm2
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
eMMC Flash : 150100513832334D42006CB0E476B3FB
[eMMC] : FLASH_INF : [SAMSUNG] , BM328
[eMMC] : FLASH_CID : 150100513832334D42006CB0E476B3FB
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0x0B9C44DE8C8BC541E51AC32EAA0302B9
EXT RAM : 0x80000000 [2 GiB]
SOC VERIFY : C1
Boot Ok!
Brand : VGOTEL
ProdName : VENTURE_11
ProdModel : VENTURE 11
Device : VENTURE_11
AndroidVer: 6.0
MTKxCPU : MT6580
MTKxPRJ : alps-mp-m0.mp1-V2.34_vsun6580.we.m_P2
SECURITY :
IMEI_SW [1] : 358241080147729
IMEI_SW [2] : 358241080147737
BTMAC Addr : 240D6525CEFC
WiFi MAC : 240D6525E2E8
MODEM :
BaseBand : MT6580_S00_MOLY_WR8_W1449_MD_WG_MP_V57_P2_1_wg_n
EXTRA :
LCD : Not info available
LCD Res : 1280x720
TOUCH [0] : GT5668
CAM [0] : s5k4h5yc_mipi_raw
CAM [1] : s5k5e2ya_mipi_raw
CAM [2] : gc2365_mipi_raw
CAM [3] : s5k5e2ya_sub_mipi_raw
MODEM : vsun6580_v5013_2_18band
LOCALE : en_US en_IN en_GB hi_IN in_ID cs_CZ de_DE es_ES es_US fr_CA hr_HR it_IT sw_TZ hu_HU pl_PL pt_PT ro_RO sk_SK sl_SI sr_RS tr_TR el_GR bg_BG ru_RU ka_GE ur_PK ar_EG fa_IR bn_BD my_MM th_TH vi_VN
Done!
Elapsed: 00:00:08
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:47
Old 06-10-2019, 15:25   #58749 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 582
Gfive diamond flash done
BINARY : FLASH_DUMP.bin
FLSIZE : 0x00400000
Load Ok!
Operation : Write Flash [ v1.04 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootVersion : Infinity SCR 6531EFM v1.1 (c)2019
Port speed : 921600
Boot Done!
BIN : Format UserData
BIN : Format UserData Ok!
Done!
Elapsed: 00:01:21
Old 06-10-2019, 16:07   #58750 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 812
Qmobile energy x2 reset frp done by cm2
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A4841473265050720CAF13CB371
[eMMC] : FLASH_INF : [HYNIX] , e2GA
[eMMC] : FLASH_CID : 90014A4841473265050720CAF13CB371
[eMMC] : FLASH_LEN : 0x00000003AB800000
[eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB]
DEV RID : 0x0B9C44DEE77CB6339F8D738A60930AC8
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:52
Old 06-10-2019, 16:29   #58751 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 2,187
Gionee F205 frp done
hi
by
hamada yousri
gem flash
The Following User Says Thank You to profkefah For This Useful Post:
Old 06-10-2019, 16:31   #58752 (permalink)
Member: 974244
Thanks Meter: 25
Tecno w3 frp removed by cm2mt2.06
Card found : E3B1B8F3 , v0137
Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.06
Load IDBase v46104 Ok!
Update configuration ...
Socket Error # 11001
Host not found.
Update failed! Check settings and/or internet connection!
Operation : Reset Settings/Format FS [ v2.06 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : Mobistel PreLoader USB VCOM Port (COM142)
MODE : PRELOADER PORT
PORT : 142
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000000
BROM : SecMode : PLAIN [+PRL]
BROM : PRELOADER PORT
MODE : 0_base : BASE_v1712 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6580
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
NAND : DEVICE NOT FOUND
NAND : 000000000000000000000000
eMMC : OK
eMMC : 460001154D323237F96600423FA360D4
DAInf: 4 : 2 : 156
DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : Receiving HW info
EMMC: 150100463732324D420066F9D460A33F
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : F722MB
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00080000 [ 512.00 KB ]
USER : 0x1D2000000 [ 7.28 GB ]
SRAM: 0x00020000 [ 128.00 KB ]
DRAM: 0x40000000 [ 1.00 GB ]
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 23EA0219E14D0D8EE14F0AD71E0D081
STATUS : BLANK FLASH
BSTYLE : EMMC FLASH BOOT
DA : USB : HIGH-SPEED
Boot done!
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:23
PTFN : MTK USB Port (COM151)
MODE : BOOTROM
PORT : 151
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6753 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : LEGACY MTK
BROM : BOOTROM
Old 06-10-2019, 16:34   #58753 (permalink)
Member: 974244
Thanks Meter: 25
Lenove a2010 frp done by cm2mt1.58
Card found : S/N : E3B1B8F3 , v0137
Wait for phone...
Phone found! [ 142 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x93
eMMC Flash : 510001154D533237A4050042A5FAEB57
[eMMC] : FLASH_INF : [SAMSUNG] , BMS27
[eMMC] : FLASH_CID : 150100513732534D420005A457EB82A5
DEV RID : 0x9BE78CE1080530563BCBDB6F72489B59
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Done!
Elapsed: 00:00:13
Old 06-10-2019, 16:38   #58754 (permalink)
Member: 974244
Thanks Meter: 25
Lenovo a3600d frp done by ADB AST
Infinity-Box Android Service Tool [AST] v1.03
Operation : Identify (ADB) [ v1.03 ]
Waiting for device in ADB mode ...
1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need!
2. Insert USB cable, accept AUTH on PhoneScreen, if software ask!
Connect Ok!
Error : Fail to init secure handshake!
Check cable, connection, drivers and AUTH dialog on device screen!
Operation : Reset FRP (ADB) [ v1.03 ]
Connect Ok!
Connect Ok!
Device : A3800_Pro
Model : A3800 Pro
FRP reset passed! Make FACTORY RESET from menu!
Done!
Elapsed: 00:00:26
Old 06-10-2019, 16:42   #58755 (permalink)
Member: 974244
Thanks Meter: 25
Malata code removed by cm2mt1.58
Operation : Read Pattern/DP Lock [ v1.58 ]
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 7001005631303030385000698862A2A9
[eMMC] : FLASH_VEN : 0x70 , OEM : 0100
[eMMC] : FLASH_INF : [KINGSTON] , 80001
[eMMC] : FLASH_CID : 7001005631303030385000698862A2A9
[eMMC] : FLASH_LEN : 0x00000001C3000000
[eMMC] : FLASH_UCP : 7216 MiB [eMMC 8 GiB]
DEV RID : 0x9BE78CE1CB821E32CB4ED1969CE43BD1
SOC VERIFY : C1
Boot Ok!
Reading data ...
[Info] : PatternLock Not Set!
[Info] : DP Lock not set!
Done!
Elapsed: 00:00:12
Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.58 ]
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
LSSDB Ok!
LSSWL Ok!
LSSSH Ok!
Security Settings : Clear Ok!
[Info] : That feature NOT RESET "PRIVACY PASSWORD LOCK"! Use separate button!
[Info] : That feature NOT RESET "FRP/GoogleLOCK"! Use separate "FRP" reset!
[Info] : If phone stuck on "Logo" :
1. Wait 2-3 minutes. Power Off phone by long press "Power" button
2. Power On phone again
3. Or wait up to 3-7 minutes, until phone start by itself
4. Also recommended reboot phone twice before start use it
Done!
Elapsed: 00:00:19
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 16:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Page generated in 0.56010 seconds with 9 queries
