Old 06-10-2019, 16:29   #58966 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 5,800
Gionee F205 frp done
hi
by
hamada yousri
gem flash
The Following User Says Thank You to profkefah For This Useful Post:
Old 06-10-2019, 16:31   #58967 (permalink)
Member: 974244
Thanks Meter: 50
Tecno w3 frp removed by cm2mt2.06
Card found : E3B1B8F3 , v0137
Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.06
Load IDBase v46104 Ok!
Update configuration ...
Socket Error # 11001
Host not found.
Update failed! Check settings and/or internet connection!
Operation : Reset Settings/Format FS [ v2.06 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : Mobistel PreLoader USB VCOM Port (COM142)
MODE : PRELOADER PORT
PORT : 142
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000000
BROM : SecMode : PLAIN [+PRL]
BROM : PRELOADER PORT
MODE : 0_base : BASE_v1712 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6580
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
NAND : DEVICE NOT FOUND
NAND : 000000000000000000000000
eMMC : OK
eMMC : 460001154D323237F96600423FA360D4
DAInf: 4 : 2 : 156
DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : Receiving HW info
EMMC: 150100463732324D420066F9D460A33F
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : F722MB
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00080000 [ 512.00 KB ]
USER : 0x1D2000000 [ 7.28 GB ]
SRAM: 0x00020000 [ 128.00 KB ]
DRAM: 0x40000000 [ 1.00 GB ]
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 23EA0219E14D0D8EE14F0AD71E0D081
STATUS : BLANK FLASH
BSTYLE : EMMC FLASH BOOT
DA : USB : HIGH-SPEED
Boot done!
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:23
Reconnect Power/Cable!
PTFN : MTK USB Port (COM151)
MODE : BOOTROM
PORT : 151
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6753 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : LEGACY MTK
BROM : BOOTROM
Old 06-10-2019, 16:34   #58968 (permalink)
Member: 974244
Thanks Meter: 50
Lenove a2010 frp done by cm2mt1.58
Card found : S/N : E3B1B8F3 , v0137
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 142 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 510001154D533237A4050042A5FAEB57
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BMS27
[eMMC] : FLASH_CID : 150100513732534D420005A457EB82A5
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0x9BE78CE1080530563BCBDB6F72489B59
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:13
Old 06-10-2019, 16:38   #58969 (permalink)
Member: 974244
Thanks Meter: 50
Lenovo a3600d frp done by ADB AST
Infinity-Box Android Service Tool [AST] v1.03
Operation : Identify (ADB) [ v1.03 ]
Waiting for device in ADB mode ...
1. Connect device, enable 'DEVELOPER MODE' and 'USB DEBUG', if need!
2. Insert USB cable, accept AUTH on PhoneScreen, if software ask!
Connect Ok!
Error : Fail to init secure handshake!
Check cable, connection, drivers and AUTH dialog on device screen!
Operation : Reset FRP (ADB) [ v1.03 ]
Connect Ok!
Connect Ok!
Device : A3800_Pro
Model : A3800 Pro
FRP reset passed! Make FACTORY RESET from menu!
Done!
Elapsed: 00:00:26
Old 06-10-2019, 16:42   #58970 (permalink)
Member: 974244
Thanks Meter: 50
Malata code removed by cm2mt1.58
Operation : Read Pattern/DP Lock [ v1.58 ]
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
eMMC Flash : 7001005631303030385000698862A2A9
[eMMC] : FLASH_VEN : 0x70 , OEM : 0100
[eMMC] : FLASH_INF : [KINGSTON] , 80001
[eMMC] : FLASH_CID : 7001005631303030385000698862A2A9
[eMMC] : FLASH_LEN : 0x00000001C3000000
[eMMC] : FLASH_UCP : 7216 MiB [eMMC 8 GiB]
DEV RID : 0x9BE78CE1CB821E32CB4ED1969CE43BD1
SOC VERIFY : C1
Boot Ok!
Reading data ...
[Info] : PatternLock Not Set!
[Info] : DP Lock not set!
Done!
Elapsed: 00:00:12
Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.58 ]
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
LSSDB Ok!
LSSWL Ok!
LSSSH Ok!
Security Settings : Clear Ok!
[Info] : That feature NOT RESET "PRIVACY PASSWORD LOCK"! Use separate button!
[Info] : That feature NOT RESET "FRP/GoogleLOCK"! Use separate "FRP" reset!
[Info] : If phone stuck on "Logo" :
1. Wait 2-3 minutes. Power Off phone by long press "Power" button
2. Power On phone again
3. Or wait up to 3-7 minutes, until phone start by itself
4. Also recommended reboot phone twice before start use it
Done!
Elapsed: 00:00:19
Old 06-10-2019, 16:49   #58971 (permalink)
Member: 974244
Thanks Meter: 50
Homtom HT16pro format done by cm2mt1.58
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 422201F46E69776900001020B32BAD08
[WARNING] : MEMORY_eMMC_VALIDATE_FAILED
[eMMC] : FLASH_VEN : 0xF4 , OEM : 0122
[eMMC] : FLASH_INF : [NOT_IN_BASE] , niwi
[eMMC] : FLASH_CID : F40122426977696E2010000008ADC3B3
[eMMC] : FLASH_LEN : 0x000000039A000000
[eMMC] : FLASH_UCP : 14752 MiB [eMMC 16 GiB]
DEV RID : 0x9BE78CE1AD06219A9845F0ACC0300CC6
EXT RAM : 0x80000000 [2 GiB]
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:55
Old 06-10-2019, 16:58   #58972 (permalink)
Member: 974244
Thanks Meter: 50
VantiumJunior webm868lbdw operations done by cm2mt1.58
Wait for phone...
Phone found! [ 148 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x87
eMMC Flash : 8801034E436172642010F04D94568197
[eMMC] : FLASH_VEN : 0x88 , OEM : 0103
[eMMC] : FLASH_INF : [FORESEE] , draC
[eMMC] : FLASH_CID : 8801034E436172642010F04D94568197
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000
[eMMC] : FLASH_LEN : 0x000000039D000000
[eMMC] : FLASH_UCP : 14800 MiB [eMMC 16 GiB]
DEV RID : 0x9BE78CE151185E7EC591E2FFD8BD0F22
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Done!
Elapsed: 00:00:31
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 238 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0x2003
EMICFG_NOT_FOUND
TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT!
Boot Error!
Operation Failed
Elapsed: 00:00:36
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
ErroCode : 0x2004
EMICFG_UNKNOWN_ERROR
Boot Error!
Operation Failed
Elapsed: 00:00:18
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
a
Brand : VantiumJunior
ProdName : webm868lbdw
ProdModel : Vantium
Device : webm868lbdw
AndroidVer: 4.4.2
MTKxCPU : MT6582
MTKxPRJ : ALPS.KK1.MP1.V2.10
SECURITY :
IMEI_SW [1] : 868762011574767
BTMAC Addr : 2C373D049BF3
WiFi MAC : 2C3731051B11
Done!
Elapsed: 00:00:10
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Error read initial info! Make "Identify" first!
Operation Failed
Elapsed: 00:00:09
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:08
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:08
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:24
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:22
Old 06-11-2019, 05:15   #58973 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Oppo copy v8 hang on logo done by cm2
Card found : 73CA70CC , v0137
Update Ok!
Operation : Identify [ v2.06 ]
PTFN : MediaTek PreLoader USB VCOM (Android) (COM11)
PORT : 11
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
DA : AGENT started!
eMMC : OK
eMMC : 204A0190594E49589FA116488F30834E
DAInf: 4 : 2 : 156
DA : DRAM ready!
EMMC: 90014A2058494E594816A19F4E83308F
EMMC: VEN : HYNIX | OEM : 4A01 | DEV : XINYH
EMMC:
BOOT1 : 0x00200000 [ 2.00 MB ]
BOOT2 : 0x00200000 [ 2.00 MB ]
RPMB : 0x00200000 [ 2.00 MB ]
USER : 0xE7000000 [ 3.61 GB ]
DRAM: 0x20000000 [ 512.00 MB ]
RNID : 9BCD3A67C89DBF2F2479A09BACB5BB9D
Boot done!
Patch Level : LMY47I
Display ID : LMY47I test-keys
Ver. CodeName : REL
Ver. Release : 5.1
Sec. Patch : 2016-06-01
Build Time : 1538115580
Product Model : V8
Product Brand : X-BO
Product Name : V8
Product Device : V8
Product Manfct : alps
Board Platform : mt6580
Product Info : V8
USERDATA : PLAIN ( NOT encrypted )
Done!
Elapsed: 00:00:19
PORT : 11
BROM : Init BROM
BROM init passed!
TYPE : LEGACY MTK
BROM : DA sent
DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 156
DA : DRAM ready!
EMMC:
Boot done!
Format Ok : USERDATA
Format Ok : CACHE
Done!
Elapsed: 00:00:27
Old 06-11-2019, 05:20   #58974 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Vgo tel i800 reset password done by cm2
Card found : S/N : 73CA70CC , v0137
Operation : Reset UserCode [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 6 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CA02
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 44513420D2A5F2B2B251775D5DC806E6
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0112 , [MXIC] MX25L3291FWJI_09
[0] : FLASH_DIE : 00C2 0020 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS_INFO : 0x003FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Backup done
Read ExtData
Sorting ExtData
Sort Ok, Rebuild Ok
Restore ExtData
All done
UserCode request removed
UserCode set to default ( 0000 or 1122 )
Done!
Elapsed: 00:00:11
Old 06-11-2019, 06:04   #58975 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Infinity K MT6735 FRP Reset Done With King Infinity CM2
Card found : S/N : A19EC787 , v0137
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 460001154D323145B3F30742D3C4134F
[eMMC] : FLASH_INF : [SAMSUNG] , BM21E
[eMMC] : FLASH_CID : 150100464531324D4207F3B34F1314D3
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB]
DEV RID : 0xD9C8F395B4327B71391355891A24AC0A
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:47
Old 06-11-2019, 06:14   #58976 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Lenovo Tab A3300-HV MT6582 Logo Hang Fix Done Formate With King Infinity CM2
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
eMMC Flash : 90014A4838473264040502A2EA7FA1BF
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d2G8
[eMMC] : FLASH_CID : 90014A4838473264040502A2EA7FA1BF
DEV RID : 0xD9C8F3951D92FBF04D024BC358AD1025
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:59
Old 06-11-2019, 08:11   #58977 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 1,773
Amani a10 hang on logo done by cm2
Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ]
SPRD mode : SC6531 : REV : 0000 : NOR : [ 8MB-16MB]
Operation : Identify [ v1.04 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Infinity SCR 653x NOR v1.3(c)2019
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ]
IMEI[1] :
IMEI[2] :
Done!
Elapsed: 00:00:17
Operation : Format FileSystem [ v1.04 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_167 66FFCC1DE_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:20
Operation : Read Flash [ v1.04 ]
1. Power off device
Wait for device ...
Device Connected!
BootVersion : SPRD3
Port speed : 921600
Boot Done!
Read Ok, 4194304 bytes
Saved to : G:\Mix Flash Files\18705205C5EF_SPRD_SPI_WINBOND_W25Q_4MiB.bin
Done!
Elapsed: 00:00:44
Old 06-11-2019, 08:29   #58978 (permalink)
Member: 2233266
Thanks Meter: 252
PTFN : MediaTek PreLoader USB VCOM (Android) (COM4)
PORT : 4
BROM : Init BROM
BROM init passed!
CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : MODERN RAPHAEL
BROM : SecLevel : 0x00000001
BROM : SecMode : SBC
MODE : Wiko : SEC_6739 | Manual : Enabled
AGENT : DA_PL.bin
AGENT : Found MT6739
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : PRELOADER
DA : EXT_RAM initialized!
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
SRAM: 0x00040000 [ 256.00 KB ]
EMMC: 88010345504231303049A7E96303A439
EMMC: VEN : FORESEE | OEM : 301 | DEV : EPB100
EMMC:
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x1CE100000 [ 7.22 GB ]
CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 410ADD1AD99034A024E31BE6BAB7E3C0
Boot done!
Format Ok : CACHE
Done!
Elapsed: 00:00:23
Old 06-11-2019, 11:44   #58979 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 680
Vgotel ocean6 frp reset done
Set mode to : SP [SC773x] eMMC [Android 6.x]
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 75 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:24
Old 06-11-2019, 12:27   #58980 (permalink)
Member: 1586105
Thanks Meter: 17
Itel a16 frp done by cm2 spd2 version
Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.00r2
Operation : Format FS / Reset Settings [ v2.00r2 ]
Mode : Reset FRP
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS
Sending Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : Control transfered!
Boot Done!
Wipe Ok : FRP
https://www.youtube.com/watch?v=TrFW...ture=*********
The Following User Says Thank You to mr_gopal For This Useful Post:
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
Page generated in 0.92717 seconds with 10 queries
