Old 01-30-2011, 16:09   #5941 (permalink)
TopLink Gsm's Avatar
Member: 333439
Sonork: 100.1589101
Originally Posted by Imran_Fazal View Post
ot-255 Successfull
COM4 [VCP0] selected
module v3.73
Device: Alcatel-255X, 255A
Checking data, wait...
Action: rebuild security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:7B84:A00C
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98000300000001:2BEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
otp offset: 00FE0000
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [protected] type (05), 1 record(s)
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.FB A967DC.[JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN_3F0BCDC2].rpl
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: FBA967DC
rom info ver: 05
sw version: JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A_W08_36_SP 1_V34.BIN
project-id: MAUI.08A.W08.36.SP1.V34, C2CD0B3F
code offset: 00000000
ffs offset/size [01]: 00C00000/00400000
TCL-ID identification
version: 968
provider: 255A-2CRGDO3
customization: CP96NT31
customization: XP96NT31
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 00C00000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
sim-lock status: enabled
product id: JRD_COMMUNICATION_U82X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
security area (sec info, cust) calculation...
identification header detected
customization name adjusted
Write: security area (sec info, cust)
security area (sec info, cust) calculation done
security area (sec info, hash) calculation...
..................security area (sec info, hash) detecting size...
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 35176204252648
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-255X,255A_JRD23_08A_PCB01_GPRS_MT6223_S00.MAUI_08A _W08_36_SP1_V34__system_log_FBA967DC_3F0BCDC2_2011 0130-165037.B0X.bin
Finished, time used: 2 min 48 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Thx infinity team .........really good support
PHOne unlock Done but no give service..................
The Following User Says Thank You to TopLink Gsm For This Useful Post:
Old 01-31-2011, 06:34   #5942 (permalink)
Temporary banned !!
Member: 354975
Sonork: Love For All
Angry w375 unlock done with infinty
COM5 [VCP0] selected
Action: unlock
Device: W375
Connect...
Press and HOLD Power button...
rom version: 0411
Connecting...
initial boot phase complete
Release Power button !
Connect Done
Boot...
Boot Done
Set Baud...
921600
Set Baud Done
Check Flash-1...
SW version: 0.0.72
HW version: MOTOROLA_H80S
LP ver: 0072_001
Flex ver: FLEX_D7_001
cpu id: 08B6
imei eeprom: 3558380171420509
required SW version: 0.0.72
sp-locked: 23430.
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _35583801714205_20110130-233009.34E.bin
unlock step-1 Ok
unlock step-2 Ok
unlock step-3 Ok
unlock step-4 Ok
unlock step-5 Ok
finished Ok
Finished, time used: 30 sec
The Following 3 Users Say Thank You to niceraees For This Useful Post:
Old 01-31-2011, 08:39   #5943 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1586890
Vodafone-225 repaired
COM10 [VCP0] selected
module v1.60
Device: ZTE-225
Action: reset
Boot ...
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 00EC:22A0
Connecting Done
Check hardware ...
sw version: -IN-P108A2V1.0.0B06 Sep 24 2007 VDF-P108A2B07-IN05 g3dBV2.0 04.1
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225_eeprom-static_20110131-121727.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225_eeprom-security_20110131-121728.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-225_eeprom-complete_20110131-121734.B1E.bin
backup critical area Done
Check memory ...
Check memory Done
Write ...
reset...
done
Write Done
Finished, time used: 26 sec
The Following User Says Thank You to akashub For This Useful Post:
Old 01-31-2011, 09:45   #5944 (permalink)
joni_rajpura's Avatar
Member: 508072
module v3.24
Action: reset settings ("format ffs")
Model: Autodetect 6205-6239 NOR
19200 autodetect
CPU: MT6223
high speed boot On
chip: 0011:41E1:000C
status: FF
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6223,E05
Date: 2000.00.00
Version: 1.0
Version: MT506_V2.12
Version: MTK25_08A_HW
detecting structure #2...
1 2 3 5 7 8 9warning: wrong packet cs
11 13 done
80 byte(s) read
imei: 91008020004847
connection Ok
building list...
done
items to clear: 149
items cleared: 149 of 149
items remains: 0
Finished, time used: 28 sec
The Following User Says Thank You to joni_rajpura For This Useful Post:
Old 01-31-2011, 11:25   #5945 (permalink)
Member: 508072
module v3.24
Device: Autodetect 6205-6239 NOR
Action: "repair imei"
imei write channel: imei #1 (default imei inside firmware)
new imei: 353812003848752
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:AF32788
status: FF
high speed boot Off
Boot Done
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
otp offset: 00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
921600
Set baud Done
interesting cpu type found
device parameters detection in progress...
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
rom info structure: [protected] type (04), 1 record(s)
TCL-ID is absent
startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.5ECF2C91.[E553_K10F8_E553_GPRS_MT6226_S01.00_0.BIN_2949EA11].rpl
device-id: 5ECF2C91
rom info ver: 04
sw version: E553_K10F8_E553_GPRS_MT6226_S01.00_0.BIN
project-id: E553_K10F8.00.0, 11EA4929
ffs offset/size [01]: 00800000/001FF000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00800000
checking area [00000000]: 00080000-00FFFFFF...
ffs/eeprom found near: 00E00000
Detected ffs/eeprom address is non-standard: 00E00000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
autodetected ffs/eeprom address confirmed by user: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
detecting startup code area #2...
startup code area #2 is absent
detecting ffs/eeprom structure pass 2...
ffs/eeprom: detect std location pass #1...
ffs/eeprom: detect ext location pass #1...
ffs/eeprom: detect standard offset pass #1...
ffs/eeprom record offset detected
ffs/eeprom: detect standard data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok element #2
imei default found: 13579024681122
====> Write ...
Write: imei
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\E 553_K10F8_E553_GPRS_MT6226_S01.00_0__system_log_5E CF2C91_2949EA11_20110131-165258.B0X.bin
Finished, time used: 2 min 22 sec
Old 01-31-2011, 13:31   #5946 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
ZTE x761 unlock done................
Model: ZTE-X761
19200 autodetect
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:4903:0003
status: FF
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: X761_Z2_SF_BFFA106
Version: ZTEMT25_07A_HW_C
44 byte(s) read
imei: 35787302292533
connection Ok
157 byte(s) read
reading data...
building new data...
writing data...
145 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 12 sec
The Following User Says Thank You to zeerik For This Useful Post:
Old 01-31-2011, 14:40   #5947 (permalink)
Member: 633231
COM53 [VCP0] selected
module v1.78
Device: ZTE-A35
Action: "sp-unlock"
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
Check hardware Done
sw version: ARO-P108A7 Z B01-EnEs-DOM02 g3dBV2.0 ES-DOM-CLARO-P108A7 Z V1.0.
file saved: C:\Archivos de programa\InfinityBox\Pana01\ZTE-A35_eeprom-static_20110130-223921.B1E.bin
loading data...
data loaded
file saved: C:\Archivos de programa\InfinityBox\Pana01\ZTE-A35_eeprom-security_20110130-223922.B1E.bin
file saved: C:\Archivos de programa\InfinityBox\Pana01\ZTE-A35_eeprom-complete_20110130-223929.B1E.bin
reading additional data...
file saved: C:\Archivos de programa\InfinityBox\Pana01\ZTE-A35_lock-area_20110130-223948.B1E.bin
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 1 min 9 sec
The Following User Says Thank You to thewolverine For This Useful Post:
Old 01-31-2011, 16:09   #5948 (permalink)
Member: 633231
module v3.73
Action: "sp-unlock"
unlock method: smart fast
Model: ZTE-A261
19200 autodetect
CPU: MT6225
chip: 0001:4A03:0005
status: FF
Date: 2006.06.14
Version: 1.0
Version: ES-DM-CLARO-P103B9LFV1.0.1B02
44 byte(s) read
imei: 35803402049778
connection Ok
157 byte(s) read
reading data...
writing data...
145 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 13 sec
Old 01-31-2011, 17:25   #5949 (permalink)
KYEJUSA's Avatar
Member: 394869
Sonork: TAKE NO CHANCES
MOTOROLA-WX181 UNLOCKED SUCCESSFULY
module v3.73
Device: Motorola-WX181
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
chip: 0011:7F7B:A00C
status: 01
Boot Done
flash: 2088BAFFFFFFFF:2088BA00000000
flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb
otp offset: 003F0000
Initialize Done
====> Set baud ...
115200
Set baud Done
rom info structure: [standard] type (05)
TCL-ID is present
TCL-ID detection...
rom info ver: 05
sw version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN
project-id: MAUI.08A.W08.36.SP1.V28.F1, 00000000
ffs offset/size [01]: 003A0000/00058000
version: 564
provider: M181X-CARGAP5
customization: CM56DD10
customization: XM56DD10
TCL-ID is present
ffs/eeprom address assigned: 003A0000
product id: JRD_COMMUNICATION_U91X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
max address is too big, should be recalculated: 0827D124->0826B790
done
original imei: 0000378153C447
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Motorola-WX181_JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_ W08_36_SP1_V28_F1__system_log__00000000_20110131-081620.B0X.bin
Finished, time used: 2 min 8 sec
The Following User Says Thank You to KYEJUSA For This Useful Post:
Old 01-31-2011, 20:45   #5950 (permalink)
Member: 633231
module v3.73
Device: Alcatel-708X, 708A
Do you want to make ffs/eeprom backup before format ?
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
chip: 0001F03:A004
status: 01
Boot Done
flash: 01227E22302200:09EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb
Initialize Done
====> Set baud ...
115200
Set baud Done
usb bootloader (chip) is present: 00020000
rom info structure: [protected] type (07), 1 record(s)
TCL-ID is present
startup code area #1 backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.C4 E9953C.[JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN_A0891A20].rpl
TCL-ID detection...
device-id: C4E9953C
rom info ver: 07
sw version: JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_ SP1_V32.BIN
project-id: MAUI.08A.W08.40.SP1.V32, 201A89A0
code offset: 00020000
ffs offset/size [01]: 01800000/00800000
version: 16Z
provider: 708A-2CRGDO3
customization: CN16NQ30
customization: XN16NQ30
TCL-ID is present
ffs/eeprom address assigned: 01800000
product id: JRDHUIZHOU_MT6225_OTMINI_SERIES
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#3...
search sec info#3 finished
area1 is valid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
original imei: 01224100039715
====> Write ...
Write Done
ffs formatting...
Finalization Done
file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcat el-708X,708A_JRDSZ25_08A_PCB01_GPRS_MT6225_S00.MAUI_0 8A_W08_40_SP1_V32__system_log_C4E9953C_A0891A20_20 110131-044524.B0X.bin
Finished, time used: 2 min 36 sec
Old 02-01-2011, 04:11   #5951 (permalink)
Registered User
Member: 1330543
Arrow jazz unlock ok
COM8 [VCP0] selected
module v1.78
Device: Huawei-T161L
Action: "sp-unlock"
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
Check hardware Done
sw version: 0 R_T161L_01 A_T161L_09 25 5 H5 5
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20110131-124652.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20110131-124653.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20110131-124659.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_lock-area_20110131-124719.B1E.bin
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
The Following User Says Thank You to shahzad2010 For This Useful Post:
Old 02-01-2011, 05:29   #5952 (permalink)
cel_phon's Avatar
Member: 950201
Sonork: 100.1608088
module v1.39
Device: LG-KP135
Action: reset
Boot ...
Connecting, wait...
flash: 01227E22212200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Boot Done
Set baud ...
921600
Set baud Done
Check flash ...
current eeprom imei: 353955020366322
file saved: C:\Program Files\InfinityBox\LGA\eeprom_353955020366322_LG-KP135_20110131-212031.B1E.bin
version: -IDoHGKP135ATV10a
reading -IDoHGKP135ATV10a_eeprom-ffs_353955020366322...
file saved: C:\Program Files\InfinityBox\LGA\-IDoHGKP135ATV10a_eeprom-ffs_353955020366322_LG-KP135_20110131-212140.B1E.bin
Check flash Done
Check space ...
Check space Done
Erase ...
Erase Done
Write ...
Write Done
Finished, time used: 114 sec
The Following User Says Thank You to cel_phon For This Useful Post:
Old 02-01-2011, 07:30   #5953 (permalink)
Member: 1329373
Mtk 6253 repair ok with infinty
com3 [vcp0] selected
module v3.25
device: Autodetect 6253 nor
checking data, wait...
Action: Reset settings ("format ffs") nand
interface: Brom_dll_v3.1016.00
connect...
Phone should be switched off !
Press and hold power button now !
Connecting...
Booting...
Release power button now !
Bootcode current/expected: 3.2/3.2
cpu: 6253:8a02:8a00
status: Ff
bbchip bl ver: Fe
nor flash id[0093]: 0089:890300000000 [intel] pf38f30xxm0x1xx
chip size: 16mb
otp status/size: S_da_nor_otp_exist/00000108
nand flash chip: Not installed
internal ram size: 00020000
external ram: S_da_ram_error
done
set baudrate (115200)...
Done
ram test...
Testing...
Ram test passed
===> detect existing firmware structure...
Detect ffs...
Ffs offset/size: 00000000/00000000
detect sec ro...
Detect custom parameters...
Detect project-id...
Project-id: Maui.09a.w09.52.mp.v3.f1
detect nor info...
Number of areas/bytes to read: 1:00040000
reading (hw_storage_nor)...
Warning: Ffs can not be detected
tcl-id detection...
Tcl-id detection done
startup code area #1 detection...
Startup code area #1 detection done
===> done
format (hw_storage_nor)...
Disconnect...
Done
finished, time used: 1 min 20 sec
remove/install battery now !
The Following User Says Thank You to AL-KARAM MOBILE For This Useful Post:
Old 02-01-2011, 08:29   #5954 (permalink)
r-jcomm's Avatar
Member: 601913
Sonork: 100.1597350
SAGEM my200x UNLOCK DONE BY INFINITY BOX
COM30 [VCP1] selected
module v1.78
Device: Sagem-my220x
Action: "sp-unlock"
unlock method-1
Boot ...
e-gold: 820010
loading...
middle part...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-static_20110201-130545.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-security_20110201-130547.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-complete_20110201-130551.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_lock-area_20110201-130617.B1E.bin
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 1 min 22 sec
The Following 2 Users Say Thank You to r-jcomm For This Useful Post:
Old 02-01-2011, 08:50   #5955 (permalink)
harkishan singh's Avatar
Member: 283204
Sonork: 100.1577140
format ok
COM7 [Serial2] selected
module v3.24
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
chip: 0011:7539:000C
status: FF
Boot Done
flash: 2088C4FFFF0013:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
Initialize Done
====> Set baud ...
115200
Set baud Done
it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
rom info structure: [standard] type (07)
TCL-ID is absent
rom info ver: 07
sw version: D386_PCB01_GPRS_MT6223_S00.SW_V00_03_YIDALONG.BIN
project-id: D386.SW.V00.03.YIDALONG, 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
ffs/eeprom chip: 00
reading: D386_PCB01_GPRS_MT6223_S00.SW_V00_03_YIDALONG__ffs ...
warning: wrong cs at 0x00F13000, retry...
read error recovered
warning: wrong cs at 0x00F63C00, retry...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\D386_PCB01_GPRS_M T6223_S00.SW_V00_03_YIDALONG__ffs_20120201-141835.B0E.bin
====> Write ...
Write Done
ffs formatting...
Finalization Done
Finished, time used: 4 min 52 sec
Br:
Harkishan
The Following User Says Thank You to harkishan singh For This Useful Post:
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 08-29-2010 20:17
Page generated in 0.56998 seconds with 12 queries
