Old 07-10-2019, 06:08   #59641 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 924
Huawei chm u01 hang on logo done by cm2
Card found : S/N : 73CA70CC , v0137
Scatter Load Ok , BaseBand : MT6582 , Project : mbk82_wet_kk , Storage : EMMC
Files found : 11 , Set to Flash : 10
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand : Huawei
Device Model : CHM-U01
Device CPU : MT6582
Device IntName : CHM-U01
Device Version : 4.4.2
Device Compile : 8/27/2015 3:31:46 AM
Device Project : ALPS.KK1.MP1.V2.11
Device ExtInfo : CHM-U01
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4838473264040503A2EA88A15B
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d2G8
[eMMC] : FLASH_CID : 90014A4838473264040503A2EA88A15B
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0x0386520DD949DCE729134AB0DAA7E23B
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : mbk82_wet_kk , Storage : EMMC
Setting : Flash Pre-Erase : Off ( Write Flash Only )
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Skip checking by User request!
BL : BatteryLevel : 3964 mV
BL : BatteryLevel Ok
SecCfg Passed , 1799
BMT remark not need. Will skip
Preloader Download skipped by user request!
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:03:26
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Data Verify Done, time used : 00:00:58
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:04:33
Reconnect Power/Cable!
Old 07-10-2019, 08:28   #59642 (permalink)
nagesss's Avatar
Member: 2306223
Sonork: 1660968:1234
Thanks Meter: 75
oppo A1601 reAd pattern.without dataloss
Load sccater.file
press volume buttons
insert usb
Wait for phone...
Phone found! [ 43 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
SecCfgVal : 0x01000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
DAgent configured successfully
Connection agent : BROM
DRAM configured from ScatFW!
Link with DAgent established
[eMMC] : FLASH_INF : [SAMSUNG] , BMB1X
[eMMC] : FLASH_CID : 150100525831424D420715EBC4E8931D
[eMMC] : FLASH_LEN : 0x0000000747C00000
[eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB]
DEV RID : 0xFD483C444E1F076B7BA2832CDABC3D8B
INT RAM : 0x00000000
EXT RAM : 0x80000000 [2 GiB]
[NAND] : FLASH : NOT INSTALLED
[UFSM] : FLASH : NOT INSTALLED
[HSUSB] : MODE : FULL-SPEED
Boot Ok!
USBDL : Init HSUSB Ok
Reading data ...
Get Locks ...
PatternLock Sequnce : 75869
Done!
Elapsed: 00:00:40
Finish at : [7/10/2019 / 12:01:51 PM]
The Following User Says Thank You to nagesss For This Useful Post:
Old 07-10-2019, 08:55   #59643 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 912
*******Worlds first itel a33 password and frpremove done
Operation : Format FS / Reset Settings [ v2.00r2 ]
Mode : Default [ Reset Settings + FRP ]
1. Power off device, wait 10-15 seconds
2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- )
3. Insert cable in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS
Sending Init Boot ...
Boot sent!
Kick FDL ...
BootVersion : Spreadtrum Boot Block version 1.1
Protocol setup ...
Port speed : 921600
Sending Flash Boot ...
Boot sent!
Kick FLASH FDL ...
FDL : Control transfered!
Boot Done!
Wipe Ok : UserData
Wipe Ok : Cache
Wipe Ok : FRP
Done!
Elapsed: 00:00:52
The Following User Says Thank You to kothamamun For This Useful Post:
Old 07-10-2019, 09:07   #59644 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 14,737
Smile Qmobile M350 Pro F.R.p Reset Done
Operation : Reset Settings/Format FS [ v2.06 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM (Android) (COM40)
MODE : PRELOADER PORT
PORT : 40
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
TYPE : LEGACY MTK
BROM : SecLevel : 0x00000000
BROM : SecMode : PLAIN [+PRL]
BROM : PRELOADER PORT
MODE : 0_base : BASE_v1712 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6580
AGENT : MTK_DOWNLOAD_AGENT
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
NAND : DEVICE NOT FOUND
NAND : 000000000000000000000000
eMMC : OK
eMMC : 460001154D323237E95900421333B3CC
DAInf: 4 : 2 : 156
DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : Receiving HW info
EMMC: 150100463732324D420059E9CCB33313
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : F722MB
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00080000 [ 512.00 KB ]
USER : 0x1D2000000 [ 7.28 GB ]
SRAM: 0x00020000 [ 128.00 KB ]
DRAM: 0x40000000 [ 1.00 GB ]
CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : 9EAF8FD3418F8945F10FCD22BBE56579
STATUS : BLANK FLASH
BSTYLE : EMMC FLASH BOOT
DA : USB : HIGH-SPEED
Boot done!
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:37
Old 07-10-2019, 09:12   #59645 (permalink)
Member: 2721982
I'm looking for Nokia 105,106,3310 3G and 230 imei repair and laguage edit software / doungle or box
Old 07-10-2019, 09:15   #59646 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 924
Oppo f3 reset frp done by cm2
Card found : 73CA70CC , v0137
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16
Operation : Reset Settings [ v1.16 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 652 [MSM8952]
ID_BLOCK_S : 1475B83E
ID_BLOCK_L : BC65F42FDB1B3E170EA8237B412BF3F9
ID_BLOCK_L : 506CFA5E774216CF1DDF86C19D5DEE8E
Use CM2 Internal Loader
Loader Sent! Initializing ...
Running FireHose on BBID : MSM8976 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ]
ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200
Boot Ok!
Format USER ...
Format CACHE ...
Format Ok!
Remove FRP
Reset Ok!
Done!
Elapsed: 00:00:19
Old 07-10-2019, 09:17   #59647 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,127
Haier Iron MT6580 FRP Reset Done With King Infinity CM2
Card found : S/N : A19EC787 , v0137
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 45 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
eMMC Flash : 150100523331314D4200BB25CC1C2299
[eMMC] : FLASH_INF : [SAMSUNG] , BM113
[eMMC] : FLASH_CID : 150100523331314D4200BB25CC1C2299
[eMMC] : FLASH_LEN : 0x00000003AB400000
[eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB]
DEV RID : 0xD9C8F395079FBC61B84AA4B12B3A5F84
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:39
Old 07-10-2019, 09:18   #59648 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 924
Nokia 3330 reset password done by cm2
Infinity-Box Chinese Miracle II : SC/RDA Module [SCR] v1.04
SCRD mode : AUTO
SPRD mode : SC6530 : REV : 0000 : NOR : [ 4MB-8MB ]
Operation : Identify [ v1.04 ]
----- > Powered On :
1. Power On device
2. Connect USB cable
3. When device show StorageMode : Press '0' button for a 5 second!
----- > Powered Off :
1. Insert USB cable
2. Wait when device show Charge icon
Wait for device ...
Device Connected!
BOOT_PWR0 : 0x00600000
BOOT_INIT : 0x81C0024C
BOOT_MODE : DOWNLOAD
BOOT_INTV : "X06_VJ_330_ZX_3330_20170810_D_V01"
Setting BOOTROM mode
BOOT_MODE : BOOTROM
Boot_CPU : 0x08090007 : [SPREADTRUM] : SC6533G
MEMD for flsh_spi32m Branch: none
Boot_CS0 : 0x00000000 : SPI : [SPIDEF] : 25Q32 : 0x00400000 [ 4MiB ]
Performing MemoryInit
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot IV : 0xFBA2A250
Boot done!
Identify : Code Integrity Check pass!
Device Info Details :
[0] : X06_HY_240x320_AOLIXIN_3330_ZXGY4
[1] : 6533
[2] : SC6533G_FP
[3] : SC6533G
[4] : pasw_SC6533
[5] : flsh_spi32m
[6] : SV3029E/SV3029F/SV3029G/SV3029H/GC9301/gc9304/GC9305/gc9306/ili93418b/st7789r8bit
[7] : sp0820/BF3703/bf3901/gc6133
[8] : SCbt_6533
[9] : SCfm_6533G
[10] : release
[11] : 2017-08-10_21:23:33
[12] : X06_VJ_330_ZX_3330_20170810_D_V01
inf_usb-dll:err [_usb_read_async] timeout error
Done!
Elapsed: 00:02:52
Operation : Reset Settings [ v1.04 ]
1. Power On device
1. Insert USB cable
Wait for device ...
Device Connected!
BOOT_MODE : BOOTROM
Selecting RL
Sending RL
Config : MemoryInit
Config : Loader
BOOT_MODE : RLOADER
Boot done!
Preparing PMT
Verifying PMT
Erasing 1474560 bytes
FileSystem format done!
Done!
Elapsed: 00:00:57
Old 07-10-2019, 11:01   #59649 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,127
Oppo A37F QLM Patrren Read Done With King Infinity CM2
Card found : A19EC787 , v0137
Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.14
Operation : Read PatternLock [ v1.14 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 410 [MSM8916]
ID_BLOCK_S : 237DC7D2
ID_BLOCK_I : 007050E1
ID_BLOCK_L : D7114BB32288B5B06FC40C11DEA52D1D
ID_BLOCK_L : 542F91383DA4169F32FDD60F05E886C5
Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1
MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ]
ExtInfo : 0x00004000/00004000/00001000/00001000/00000200
Boot Ok!
Read Ok! Trying decrypt ...
PatternLock sequence : 85236
Done!
Elapsed: 00:00:25
Old 07-10-2019, 11:03   #59650 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,127
Lenovo A2010a MT6735 FRP Reset Done With King Infinity CM2
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x93
eMMC Flash : 510001154D533237C2D800429F37DCF4
[eMMC] : FLASH_INF : [SAMSUNG] , BMS27
[eMMC] : FLASH_CID : 150100513732534D4200D8C2F4DC729F
DEV RID : 0xD9C8F395EC4CFDE0ABA56EAF59F22919
SOC VERIFY : C1
Boot Ok!
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:32
Old 07-10-2019, 11:56   #59651 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,127
Haier G30 MT6572 Dead Set Recover Fix With Flashing By King Infinity CM2
Scatter Load Ok , BaseBand : MT6572 , Project : m11_haier_b1b8_dual , Storage : EMMC
Ready to Flash!
======= Flash
Wait for phone...
Phone found! [ 45 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x88
eMMC Flash : 45010053454D3034473A03C8D7B53297
[eMMC] : FLASH_VEN : 0x45 , OEM : 0100
[eMMC] : FLASH_INF : [SANDISK] , G40ME
[eMMC] : FLASH_CID : 45010053454D3034473A03C8D7B53297
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000EC000000
[eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB]
DEV RID : 0xD9C8F3959BE8CAA0F57BEB9D985F3524
EXT RAM : 0x20000000 [512 MiB]
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : m11_haier_b1b8_dual , Storage : EMMC
BL : BatteryLevel : 3801 mV
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x00000000E0E00000
Flash Pre-Erase Done, time used : 00:00:06
PartCount : 0012
Repartition Done!
Use FLN Mode
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:26
Processing : Verify
Verify Passed : MBR
Data Verify Done, time used : 00:00:43
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:03:31
Old 07-10-2019, 15:40   #59652 (permalink)
Member: 2897012
Sonork: MTK81
Thanks Meter: 153
X4 CRISTAL FRP Remove done
Operation : Identify [ v2.00r2 ]
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Device info :
Patch Level : O21019
Display ID : KIOWA_X4_CRISTAL_180608
Ver. CodeName : REL
Ver. Release : 8.1.0
Sec. Patch : 2018-04-05
Build Time : 1528422142
Product Model : X4_CRISTAL
Product Brand : KIOWA
Product Name : X4_CRISTAL
Product Device : X4_CRISTAL
Product Manfct : revoview
Product Info : X4_CRISTAL
Product Board : sp7731e_1h10
Board Platform : sp7731e
SecInfo :
IMEI[1] : 357440011XXXXXX
IMEI[2] : 357440011XXXXXX
IMEI[3] : 867400020XXXXXX
WIFIMAC : FFFFFFFFFFFF
BT_MAC : FFFFFFFFFFFF
UserData : STATE : DAMAGED
Done!
Elapsed: 00:01:33
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Wipe Ok : UserData
Wipe Ok : Cache
Wipe Ok : FRP
The Following 2 Users Say Thank You to Manikanika81 For This Useful Post:
Old 07-10-2019, 16:18   #59653 (permalink)
A.G.Shahid's Avatar
Member: 2644066
Thanks Meter: 924
Vgotel i220 hang on logo done by cm2
SCRD mode : AUTO
SPRD mode : SC6531 : REV : E001 : NOR : [ 4MB-8MB ]
Operation : Format FileSystem [ v1.04 ]
1. Power off device
2. Press and hold BootKey or use BootCable
3. Insert cable and battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD3
BootSource : InternalLibrary
BootVersion : Infinity SCR 6531EFM v1.1 (c)2019
Port speed : 921600
FDL Flash : Control transfered!
Boot Done!
CS0_MEM : SPI : [WINBOND] : W25Q32 : 0x00400000 [ 4MiB ]
Make backup of sensetive data
Backup saved to : C:\InfinityBox\CM2SCR\Backup\00400000_FMT_BACK_129 4E4B1BF13_NVM.nv
Executing FormatFFS ...
Format FFS Done!
Done!
Elapsed: 00:00:21
Old 07-10-2019, 17:38   #59654 (permalink)
Member: 580077
Sonork: 100.1591941
Thanks Meter: 154
logicom b bot 550 frp ok
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
 -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
 ====  Wait for phone...
Phone found! [ 102 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC9830 eMMC Generic Loader v2 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name  : BBOT550
Model Brand : Logicom
Model Device: BBOT550
AndrVersion : 6.0
BaseBand CPU: SP9832A_3H10_VOLTE
CompileDate : 14/12/2016 11:16:20
Project Ver : Logicom B BOT 550 V1.1
Model Ext   : B BOT 550
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:20
Finish at : [10/07/2019 / 16:28:37]
Start  at : [10/07/2019 / 16:28:45]
Operation : Format File System / Reset Settings [ v1.27 ]
Settings : SmartFormat is On
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:27
Old 07-11-2019, 07:01   #59655 (permalink)
alpona_su's Avatar
Member: 1217358
Sonork: 100.1605541
Thanks Meter: 148
Maximus Max D1 9832E frp reset done.
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot : INF : 0_SC9832E_BASE : SC9832E_eMMC_1GB_RS
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
UserData : STATE : ENCRYPTION
Done!
Elapsed: 00:00:33
Wait for device ...
Device Connected!
BootVersion : SPRD3
Boot sent!
Kick FDL ...
Protocol setup ...
Port speed : 921600
Boot sent!
Kick FLASH FDL ...
Boot Done!
Wipe Ok : FRP
Done!
Elapsed: 00:00:33
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-29-2010 21:17
Page generated in 0.78732 seconds with 9 queries
